[GRASS-SVN] r55832 - in grass/trunk: lib/python/temporal temporal/t.topology
svn_grass at osgeo.org
Tue Apr 16 10:37:37 PDT 2013
Author: huhabla
Date: 2013-04-16 10:37:37 -0700 (Tue, 16 Apr 2013)
New Revision: 55832
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/abstract_temporal_dataset.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
grass/trunk/lib/python/temporal/temporal_extent.py
grass/trunk/lib/python/temporal/temporal_relationships.py
grass/trunk/temporal/t.topology/t.topology.py
Fixed temporal relationship computation. Avoid using the reserved python word "connect".
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2013-04-16 10:54:03 UTC (rev 55831)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2013-04-16 17:37:37 UTC (rev 55832)
@@ -191,7 +191,7 @@
"""!Select temporal dataset entry from database and fill
up the internal structure"""
- dbif, connect = init_dbif(dbif)
+ dbif, connected = init_dbif(dbif)
self.base.select(dbif)
if self.is_time_absolute():
@@ -201,7 +201,7 @@
self.spatial_extent.select(dbif)
self.metadata.select(dbif)
- if connect:
+ if connected:
dbif.close()
def is_in_db(self, dbif=None):
@@ -226,7 +226,7 @@
and must be executed by the caller.
# Build the INSERT SQL statement
statement = self.base.get_insert_statement_mogrified(dbif)
@@ -241,11 +241,11 @@
if execute:
dbif.execute_transaction(statement)
- if connect:
+ if connected:
dbif.close()
return ""
- if connect:
+ if connected:
dbif.close()
return statement
@@ -260,7 +260,7 @@
@param ident: The identifier to be updated, useful for renaming
# Build the UPDATE SQL statement
statement = self.base.get_update_statement_mogrified(dbif, ident)
@@ -276,11 +276,11 @@
if execute:
- if connect:
+ if connected:
dbif.close()
return ""
- if connect:
+ if connected:
dbif.close()
return statement
@@ -295,7 +295,7 @@
statement = self.base.get_update_all_statement_mogrified(dbif, ident)
@@ -311,11 +311,11 @@
if execute:
- if connect:
+ if connected:
dbif.close()
return ""
- if connect:
+ if connected:
dbif.close()
return statement
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-04-16 10:54:03 UTC (rev 55831)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-04-16 17:37:37 UTC (rev 55832)
@@ -344,13 +344,13 @@
@param end_time: a datetime object specifying the end time of the map
@param timezone: Thee timezone of the map
self.set_absolute_time(start_time, end_time, timezone)
self.absolute_time.update_all(dbif)
self.base.update(dbif)
- if connect:
+ if connected:
dbif.close()
self.write_timestamp_to_grass()
@@ -418,13 +418,13 @@
@param end_time: A double value
@param dbif: The database interface to be used
if self.set_relative_time(start_time, end_time, unit):
self.relative_time.update_all(dbif)
- if connect:
+ if connected:
dbif.close()
@@ -490,7 +490,7 @@
None in case of a failure
statement = ""
if self.is_in_db(dbif):
@@ -522,7 +522,7 @@
self.reset(None)
- if connect:
+ if connected:
dbif.close()
if execute:
@@ -558,7 +558,7 @@
# % {'type':self.get_type(), 'map':self.get_map_id()}))
statement = ""
# Get all datasets in which this map is registered
rows = self.get_registered_datasets(dbif)
@@ -579,7 +579,7 @@
if execute:
- if connect:
+ if connected:
dbif.close()
if execute:
@@ -594,7 +594,7 @@
rows = None
@@ -608,7 +608,7 @@
core.error(_("Unable to select space time dataset register table "
"<%s>") % (self.get_stds_register()))
- if connect:
+ if connected:
dbif.close()
return rows
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-04-16 10:54:03 UTC (rev 55831)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-04-16 17:37:37 UTC (rev 55832)
@@ -383,7 +383,7 @@
- follows -> allowed
- precedes -> allowed
- - equivalent -> not allowed
+ - equal -> not allowed
- during -> not allowed
- contains -> not allowed
- overlaps -> not allowed
@@ -604,7 +604,7 @@
use_follows = False
use_precedes = False
obj_list = []
sample_maps = stds.get_registered_maps_as_objects_with_gaps(
@@ -656,7 +656,7 @@
obj_list.append(copy.copy(result))
- if connect:
+ if connected:
dbif.close()
return obj_list
@@ -699,7 +699,7 @@
obj_list = []
@@ -839,7 +839,7 @@
start = next
- if connect:
+ if connected:
dbif.close()
@@ -867,7 +867,7 @@
@return ordered object list, in case nothing found None is returned
obj_list = []
@@ -897,7 +897,7 @@
self.get_relative_time_unit())
obj_list.append(copy.copy(map))
- if connect:
+ if connected:
dbif.close()
return obj_list
@@ -921,13 +921,13 @@
In case nothing found None is returned
obj_list = self.get_registered_maps_as_objects(where, order, dbif)
tb = TemporalTopologyBuilder()
tb.build(obj_list)
- if connect:
+ if connected:
dbif.close()
return obj_list
@@ -951,7 +951,7 @@
obj_list = []
@@ -968,7 +968,7 @@
- if connect:
+ if connected:
dbif.close()
return obj_list
@@ -990,7 +990,7 @@
rows = None
@@ -1019,13 +1019,13 @@
dbif.cursor.execute(sql)
rows = dbif.cursor.fetchall()
except:
- if connect:
+ if connected:
dbif.close()
core.error(_("Unable to get map ids from register table <%s>")
% (self.get_map_register()))
raise
- if connect:
+ if connected:
dbif.close()
return rows
@@ -1040,7 +1040,7 @@
# SELECT all needed information from the database
self.select(dbif)
@@ -1078,7 +1078,7 @@
# Execute the accumulated statements
- if connect:
+ if connected:
dbif.close()
def delete(self, dbif=None, execute=True):
@@ -1098,13 +1098,14 @@
# First we need to check if maps are registered in this dataset and
# unregister them
- core.verbose(_("Delete space time %s dataset <%s> from temporal "
- "database") % \
- (self.get_new_map_instance(ident=None).get_type(),
- self.get_id()))
+ # Commented because of performance issue calling g.message thousend times
+ #core.verbose(_("Delete space time %s dataset <%s> from temporal "
+ # "database") % \
+ # (self.get_new_map_instance(ident=None).get_type(),
+ # self.get_id()))
statement = ""
@@ -1132,7 +1133,7 @@
self.reset(None)
- if connect:
+ if connected:
dbif.close()
if execute:
@@ -1148,11 +1149,13 @@
In case the map is already registered this function
will break with a warning and return False.
+ This method raises a ScriptError in case of a fatal error
@param map: The AbstractMapDataset object that should be registered
if map.is_in_db(dbif) == False:
dbif.close()
@@ -1237,8 +1240,6 @@
"<%s> and map <%s> are different") % \
(self.get_id(), map.get_map_id()))
- #print "STDS register table", stds_register_table
if stds_mapset != map_mapset:
dbif.close()
core.fatal(_("Only maps from the same mapset can be registered"))
@@ -1255,12 +1256,11 @@
dbif.cursor.execute(sql, (map_id,))
row = dbif.cursor.fetchone()
except:
- row = None
core.warning(_("Error in strds_register_table request"))
raise
if row is not None and row[0] == map_id:
- if connect == True:
+ if connected == True:
dbif.close()
if map.get_layer() is not None:
@@ -1270,7 +1270,7 @@
else:
core.warning(_("Map <%s> is already registered.")
% (map.get_map_id()))
- return ""
+ return False
# Create tables
sql_path = get_sql_template_path()
@@ -1378,11 +1378,13 @@
# Now execute the insert transaction
- if connect:
+ if connected:
dbif.close()
# increase the counter
self.map_counter += 1
+ return True
def unregister_map(self, map, dbif=None, execute=True):
"""!Unregister a map from the space time dataset.
@@ -1403,7 +1405,7 @@
statement = ""
# First select needed data from the database
map.metadata.select(dbif)
@@ -1443,7 +1445,7 @@
core.warning(_("Map <%s> is not registered in space "
"time dataset <%s>") % (map.get_map_id(),
self.base.get_id()))
dbif.close()
return ""
@@ -1470,7 +1472,7 @@
if execute:
- if connect:
+ if connected:
dbif.close()
# decrease the counter
@@ -1504,7 +1506,7 @@
if not self.get_map_register():
return
map_time = None
@@ -1679,7 +1681,7 @@
self.relative_time.set_granularity(None)
- if connect:
+ if connected:
dbif.close()
Modified: grass/trunk/lib/python/temporal/abstract_temporal_dataset.py
--- grass/trunk/lib/python/temporal/abstract_temporal_dataset.py 2013-04-16 10:54:03 UTC (rev 55831)
+++ grass/trunk/lib/python/temporal/abstract_temporal_dataset.py 2013-04-16 17:37:37 UTC (rev 55832)
@@ -207,7 +207,7 @@
return None
return self._topology["PREV"]
- def append_equivalent(self, map_):
+ def append_equal(self, map_):
"""!Append a map with equivalent temporal extent as this map
@param map_: This object should be of type AbstractMapDataset
@@ -217,7 +217,7 @@
self._topology["EQUAL"] = []
self._topology["EQUAL"].append(map_)
- def get_equivalent(self):
+ def get_equal(self):
"""!Return a list of map objects with equivalent temporal extent as this map
@return A list of map objects or None
@@ -436,8 +436,8 @@
return string
# Set the properties
- equivalent = property(fget=get_equivalent,
- fset=append_equivalent)
+ equal = property(fget=get_equal,
+ fset=append_equal)
follows = property(fget=get_follows,
fset=append_follows)
precedes = property(fget=get_precedes,
@@ -463,7 +463,7 @@
"""!Print information about this class in human readable style"""
_next = self.next()
_prev = self.prev()
- _equal = self.get_equivalent()
+ _equal = self.get_equal()
_follows = self.get_follows()
_precedes = self.get_precedes()
_overlaps = self.get_overlaps()
@@ -482,7 +482,7 @@
if _prev is not None:
print " | Previous: .................. " + str(_prev.get_id())
if _equal is not None:
- print " | Equivalent: ................ " + \
+ print " | Equal:...................... " + \
self._generate_map_list_string(_equal)
if _follows is not None:
print " | Follows: ................... " + \
@@ -520,7 +520,7 @@
_next = self.next()
_prev = self.prev()
@@ -537,7 +537,7 @@
print "prev=" + _prev.get_id()
- print "equivalent=" + self._generate_map_list_string(_equal, False)
+ print "equal=" + self._generate_map_list_string(_equal, False)
print "follows=" + self._generate_map_list_string(_follows, False)
if _precedes is not None:
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2013-04-16 10:54:03 UTC (rev 55831)
+++ grass/trunk/lib/python/temporal/core.py 2013-04-16 17:37:37 UTC (rev 55832)
@@ -448,10 +448,10 @@
@param statement The executable SQL statement or SQL script
- connect = False
+ connected = False
if not self.connected:
self.connect()
- connect = True
+ connected = True
sql_script = ""
sql_script += "BEGIN TRANSACTION;\n"
@@ -465,13 +465,13 @@
self.cursor.execute(statement)
self.connection.commit()
except:
- if connect:
+ if connected:
self.close()
core.error(_("Unable to execute transaction:\n %(sql)s" % \
{"sql":statement}))
raise
- if connect:
+ if connected:
self.close()
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2013-04-16 10:54:03 UTC (rev 55831)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2013-04-16 17:37:37 UTC (rev 55832)
@@ -98,7 +98,7 @@
else:
core.fatal(_("Unkown map type: %s") % (type))
- dbif, connect = init_dbif(None)
+ dbif, connected = init_dbif(None)
if name:
# Read content from temporal database
@@ -326,7 +326,7 @@
ds.select(dbif)
ds.update_from_registered_maps(dbif)
dbif.close()
core.percent(num_maps, num_maps, 1)
@@ -886,10 +886,10 @@
sp = dataset_factory(type, id)
if sp.is_in_db(dbif) and overwrite == False:
- if connect:
+ if connected:
dbif.close()
core.fatal(_("Space time %s dataset <%s> is already in the database. "
"Use the overwrite flag.") %
@@ -910,7 +910,7 @@
title=title, description=descr)
sp.insert(dbif)
- if connect:
+ if connected:
dbif.close()
return sp
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py 2013-04-16 10:54:03 UTC (rev 55831)
+++ grass/trunk/lib/python/temporal/temporal_extent.py 2013-04-16 17:37:37 UTC (rev 55832)
@@ -465,15 +465,15 @@
else:
return False
- def equivalent(self, extent):
- """!Return True if this temporal extent (A) is equivalent to the provided
+ def equal(self, extent):
+ """!Return True if this temporal extent (A) is equal to the provided
temporal extent (B)
@verbatim
A |---------|
B |---------|
@endverbatim
- @param extent: The temporal extent object that is equivalent
+ @param extent: The temporal extent object that is equal
during this extent
Usage:
@@ -482,9 +482,9 @@
>>> A = AbstractTemporalExtent(start_time=5, end_time=6 )
>>> B = AbstractTemporalExtent(start_time=5, end_time=6 )
- >>> A.equivalent(B)
+ >>> A.equal(B)
True
- >>> B.equivalent(A)
+ >>> B.equal(A)
True
@endcode
@@ -578,7 +578,7 @@
The following temporal relationships are supported:
- - equivalent
+ - equal
- during
- contains
- overlaps
@@ -609,8 +609,8 @@
if self.D["start_time"] is None or extent.D["start_time"] is None:
return None
- if self.equivalent(extent):
- return "equivalent"
+ if self.equal(extent):
+ return "equal"
if self.during(extent):
return "during"
if self.contains(extent):
Modified: grass/trunk/lib/python/temporal/temporal_relationships.py
--- grass/trunk/lib/python/temporal/temporal_relationships.py 2013-04-16 10:54:03 UTC (rev 55831)
+++ grass/trunk/lib/python/temporal/temporal_relationships.py 2013-04-16 17:37:37 UTC (rev 55832)
@@ -135,7 +135,7 @@
# relation = maps[j].temporal_relation(maps[i])
# # Build the next reference
-# if relation != "equivalent" and relation != "started":
+# if relation != "equal" and relation != "started":
# maps[i].set_next(maps[j])
# break
@@ -232,10 +232,16 @@
# Get the temporal relationship
relation = mapsB[j].temporal_relation(mapsA[i])
- if relation == "equivalent":
- if mapsB[j].get_id() != mapsA[i].get_id():
- mapsB[j].append_equivalent(mapsA[i])
- mapsA[i].append_equivalent(mapsB[j])
+ if relation == "equal":
+ if mapsB[j] != mapsA[i]:
+ if not mapsB[j].get_equal() or \
+ (mapsB[j].get_equal() and \
+ mapsA[i] not in mapsB[j].get_equal()):
+ mapsB[j].append_equal(mapsA[i])
+ if not mapsA[i].get_equal() or \
+ (mapsA[i].get_equal() and \
+ mapsB[j] not in mapsA[i].get_equal()):
+ mapsA[i].append_equal(mapsB[j])
elif relation == "follows":
if not mapsB[j].get_follows() or \
(mapsB[j].get_follows() and \
Modified: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py 2013-04-16 10:54:03 UTC (rev 55831)
+++ grass/trunk/temporal/t.topology/t.topology.py 2013-04-16 17:37:37 UTC (rev 55832)
@@ -119,9 +119,9 @@
if dict_:
for key in dict_.keys():
- if key == "equivalent":
+ if key == "equal":
# 0123456789012345678901234567890
- print " | Equivalent: ................ %s" % (dict_[key])
+ print " | Equal:...................... %s" % (dict_[key])
if key == "during":
print " | During: .................... %s" % (dict_[key])
if key == "contains":
