[GRASS-SVN] r55833 - grass/branches/develbranch_6/mswindows
Tue Apr 16 17:27:54 PDT 2013
Author: hamish
Date: 2013-04-16 17:27:54 -0700 (Tue, 16 Apr 2013)
New Revision: 55833
   grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl
adjust wording of the MSVCR download option to make it more urgent, and explain what it is
Modified: grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl	2013-04-16 17:37:37 UTC (rev 55832)
+++ grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl	2013-04-17 00:27:54 UTC (rev 55833)
@@ -959,15 +959,24 @@
 	StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME.$\r$\n"
 	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_These system libraries from Microsoft are needed for programs"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ built with Microsoft's Visual C++ compiler, such as Python and"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ GDAL which ship with GRASS, since MS does not include them by"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ default. You might already have them installed by other software,"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ if so you don't need to install them again, but if not GRASS will"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ fail to start and you will see errors like 'Missing MSVCR71.DLL"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ or MSVCP100.DLL'.$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
 	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
 	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
 	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
 	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$TEMP\$CUSTOM_UNTAR_FOLDER.$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue and install runtimes or Cancel to skip the download and complete the GRASS"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue and install the runtimes, or Cancel"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ to skip the download and complete the GRASS"
 	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME.$\r$\n"
 	MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
 	download:
@@ -1008,7 +1017,7 @@
 FunctionEnd
-Section /O "MS Visual C++ Redistributable Package" SecMSRuntime
+Section /O "Important Microsoft Runtime DLLs" SecMSRuntime
 	;Set the size (in KB)  of the archive file
 	StrCpy $ARCHIVE_SIZE_KB 12521
@@ -1018,7 +1027,7 @@
 	StrCpy $HTTP_PATH "http://download.osgeo.org/osgeo4w/release/msvcrt/"
 	StrCpy $ARCHIVE_NAME "msvcrt-1.0.1-7.tar.bz2"
-	StrCpy $EXTENDED_ARCHIVE_NAME "MS Visual C++ Redistributable Package"
+	StrCpy $EXTENDED_ARCHIVE_NAME "Microsoft Visual C++ Redistributable Packages"
 	StrCpy $ORIGINAL_UNTAR_FOLDER "install_msruntime"
 	Call DownloadInstallMSRuntime
@@ -1060,9 +1069,9 @@
 ;Installer Section Descriptions
 !insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
 	!insertmacro MUI_DESCRIPTION_TEXT ${SecGRASS} "Install GRASS ${VERSION_NUMBER}"
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecMSRuntime} "Some software included in the installer (e.g. GDAL, Python) may need Microsoft's Visual C++ redistributable system libraries.$\r$\nDownload and install the Redistributable Package"
 	!insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina (Wake County) sample data set"
 	!insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish County) sample data set"
-	!insertmacro MUI_DESCRIPTION_TEXT ${SecMSRuntime} "Some software included in the installer (e.g. GDAL, Python) may need Microsoft's Visual C++ redistributable system libraries.$\r$\nDownload and install the Redistributable Package"
 !insertmacro MUI_FUNCTION_DESCRIPTION_END
