[GRASS-SVN] r55856 - grass/trunk/lib/init
svn_grass at osgeo.org
Wed Apr 17 09:55:58 PDT 2013
Author: martinl
Date: 2013-04-17 09:55:58 -0700 (Wed, 17 Apr 2013)
New Revision: 55856
grass/trunk/lib/init/grass.py
grass.py: print warning when shell is not recognized.
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2013-04-17 15:48:58 UTC (rev 55855)
+++ grass/trunk/lib/init/grass.py 2013-04-17 16:55:58 UTC (rev 55856)
@@ -787,7 +787,10 @@
grass_env_file = os.path.join(grass_config_dir, 'cshrc')
elif sh in ['bash', 'msh', 'cygwin']:
grass_env_file = os.path.join(grass_config_dir, 'bashrc')
+ else:
+ grass_env_file = os.path.join(grass_config_dir, 'bashrc')
+ warning(_("Unsupported shell <%s>: %s") % (sh, grass_env_file))
# check for SHELL
if not os.getenv('SHELL'):
fatal(_("The SHELL variable is not set"))
