[GRASS-SVN] r55857 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Wed Apr 17 14:19:53 PDT 2013
Author: huhabla
Date: 2013-04-17 14:19:53 -0700 (Wed, 17 Apr 2013)
New Revision: 55857
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/abstract_temporal_dataset.py
grass/trunk/lib/python/temporal/base.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/datetime_math.py
grass/trunk/lib/python/temporal/metadata.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/spatial_extent.py
grass/trunk/lib/python/temporal/temporal_extent.py
grass/trunk/lib/python/temporal/temporal_granularity.py
grass/trunk/lib/python/temporal/temporal_relationships.py
grass/trunk/lib/python/temporal/unit_tests.py
Fixed granularity computation.
Added and fixed many doc-tests and unit tests.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -455,4 +455,4 @@
if __name__ == "__main__":
import doctest
- doctest.testmod()
\ No newline at end of file
+ doctest.testmod()
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -332,6 +332,8 @@
self.absolute_time.set_start_time(start_time)
self.absolute_time.set_end_time(end_time)
self.absolute_time.set_timezone(timezone)
+ return True
def update_absolute_time(self, start_time, end_time=None,
timezone=None, dbif=None):
@@ -361,9 +363,9 @@
@param start_time: A double value
@param end_time: A double value
@param unit: The unit of the relative time. Supported units:
- years, months, days, hours, minutes, seconds
+ year(s), month(s), day(s), hour(s), minute(s), second(s)
- Return True for success and False otherwise
+ @return True for success and False otherwise
@@ -612,9 +614,3 @@
dbif.close()
return rows
-if __name__ == "__main__":
- import doctest
- doctest.testmod()
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -1683,9 +1683,3 @@
if connected:
dbif.close()
- import doctest
- doctest.testmod()
Modified: grass/trunk/lib/python/temporal/abstract_temporal_dataset.py
--- grass/trunk/lib/python/temporal/abstract_temporal_dataset.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/abstract_temporal_dataset.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -61,10 +61,52 @@
@code
- >>> tmr = AbstractTemporalDataset()
+ >>> import grass.temporal as tgis
+ >>> tgis.init()
+ >>> map = tgis.RasterDataset("a at P")
+ >>> tmr = tgis.AbstractTemporalDataset()
+ >>> tmr.set_next(map)
+ >>> tmr.set_prev(map)
+ >>> tmr.append_equal(map)
+ >>> tmr.append_follows(map)
+ >>> tmr.append_precedes(map)
+ >>> tmr.append_overlapped(map)
+ >>> tmr.append_overlaps(map)
+ >>> tmr.append_during(map)
+ >>> tmr.append_contains(map)
+ >>> tmr.append_starts(map)
+ >>> tmr.append_started(map)
+ >>> tmr.append_finishes(map)
+ >>> tmr.append_finished(map)
>>> tmr.print_topology_info()
+-------------------- Temporal Topology -------------------------------------+
+ | Next: ...................... a at P
+ | Previous: .................. a at P
+ | Equal:...................... a at P
+ | Follows: ................... a at P
+ | Precedes: .................. a at P
+ | Overlaps: .................. a at P
+ | Overlapped: ................ a at P
+ | During: .................... a at P
+ | Contains: .................. a at P
+ | Starts:.. .................. a at P
+ | Started:. .................. a at P
+ | Finishes:................... a at P
+ | Finished:................... a at P
>>> tmr.print_topology_shell_info()
+ next=a at P
+ prev=a at P
+ equal=a at P
+ follows=a at P
+ precedes=a at P
+ overlaps=a at P
+ overlapped=a at P
+ during=a at P
+ contains=a at P
+ starts=a at P
+ started=a at P
+ finishes=a at P
+ finished=a at P
@endcode
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/base.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -14,6 +14,7 @@
@code
+>>> tgis.init()
>>> rbase = tgis.RasterBase(ident="soil at PERMANENT")
>>> vbase = tgis.VectorBase(ident="soil:1 at PERMANENT")
>>> r3base = tgis.Raster3DBase(ident="soil at PERMANENT")
@@ -50,7 +51,7 @@
Usage:
\code
+ >>> init()
>>> t = DictSQLSerializer()
>>> t.D["id"] = "soil at PERMANENT"
>>> t.D["name"] = "soil"
@@ -212,6 +213,7 @@
\code
+ >>> init()
>>> t = SQLDatabaseInterface("raster", "soil at PERMANENT")
>>> t.D["mapset"] = "PERMANENT"
@@ -511,6 +513,7 @@
\code
+ >>> init()
>>> t = DatasetBase("raster", "soil at PERMANENT", creator="soeren", ctime=datetime(2001,1,1), ttype="absolute")
>>> t.id
'soil at PERMANENT'
@@ -849,6 +852,7 @@
\code
+ >>> init()
>>> t = STDSBase("stds", "soil at PERMANENT", semantic_type="average", creator="soeren", ctime=datetime(2001,1,1), ttype="absolute")
>>> t.semantic_type
'average'
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/core.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -375,6 +375,7 @@
@code
+ >>> init()
>>> dbif = SQLDatabaseInterfaceConnection()
>>> dbif.mogrify_sql_statement(["SELECT ctime FROM raster_base WHERE id = ?",
... ["soil at PERMANENT",]])
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/datetime_math.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -611,4 +611,4 @@
import doctest
- doctest.testmod()
+ doctest.testmod()
Modified: grass/trunk/lib/python/temporal/metadata.py
--- grass/trunk/lib/python/temporal/metadata.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/metadata.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -9,6 +9,7 @@
@code
+>>> tgis.init()
>>> meta = tgis.RasterMetadata()
>>> meta = tgis.Raster3DMetadata()
>>> meta = tgis.VectorMetadata()
@@ -37,6 +38,7 @@
@code
+ >>> init()
>>> meta = RasterMetadataBase(table="metadata", ident="soil at PERMANENT",
... datatype="CELL", cols=100, rows=100, number_of_cells=10000, nsres=0.1,
... ewres=0.1, min=0, max=100)
@@ -276,6 +278,7 @@
@code
+ >>> init()
>>> meta = RasterMetadata(ident="soil at PERMANENT",
@@ -375,6 +378,7 @@
@code
+ >>> init()
>>> meta = Raster3DMetadata(ident="soil at PERMANENT",
... datatype="FCELL", cols=100, rows=100, depths=100,
... number_of_cells=1000000, nsres=0.1, ewres=0.1, tbres=0.1,
@@ -518,6 +522,7 @@
@code
+ >>> init()
>>> meta = VectorMetadata(ident="lidar at PERMANENT", is_3d=True,
... number_of_points=1, number_of_lines=2, number_of_boundaries=3,
... number_of_centroids=4, number_of_faces=5, number_of_kernels=6,
@@ -871,6 +876,7 @@
@code
+ >>> init()
>>> meta = STDSMetadataBase(ident="soils at PERMANENT",
... title="Soils", description="Soils 1950 - 2010")
>>> meta.id
@@ -886,6 +892,7 @@
| Soils
| Description:
| Soils 1950 - 2010
+ | Command of creation:
>>> meta.print_shell_info()
number_of_maps=None
@@ -1001,7 +1008,7 @@
Usage:
@code
+ >>> init()
>>> meta = STDSRasterMetadataBase(ident="soils at PERMANENT",
>>> meta.id
@@ -1025,6 +1032,7 @@
| Soils
| Description:
| Soils 1950 - 2010
| North-South resolution min:. None
| North-South resolution max:. None
| East-west resolution min:... None
@@ -1192,6 +1200,7 @@
@code
+ >>> init()
>>> meta = STRDSMetadata(ident="soils at PERMANENT",
>>> meta.id
@@ -1217,6 +1226,7 @@
| Soils
| Description:
| Soils 1950 - 2010
@@ -1293,6 +1303,7 @@
@code
+ >>> init()
>>> meta = STR3DSMetadata(ident="soils at PERMANENT",
>>> meta.id
@@ -1320,6 +1331,7 @@
| Soils
| Description:
| Soils 1950 - 2010
@@ -1428,6 +1440,7 @@
@code
+ >>> init()
>>> meta = STVDSMetadata(ident="lidars at PERMANENT",
... title="LIDARS", description="LIDARS 2008 - 2010")
>>> meta.id
@@ -1456,6 +1469,7 @@
| LIDARS
| Description:
| LIDARS 2008 - 2010
| Vector register table:...... None
| Number of points ........... None
| Number of lines ............ None
@@ -1696,4 +1710,4 @@
import doctest
- doctest.testmod()
+ doctest.testmod()
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -46,6 +46,7 @@
@code
>>> import grass.script as grass
+ >>> init()
>>> grass.use_temp_region()
>>> grass.run_command("g.region", n=80.0, s=0.0, e=120.0, w=0.0,
... t=1.0, b=0.0, res=10.0)
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -9,6 +9,7 @@
@code
+>>> tgis.init()
>>> extent = tgis.RasterSpatialExtent(
... ident="raster at PERMANENT", north=90, south=90, east=180, west=180,
... top=100, bottom=-20)
@@ -50,6 +51,7 @@
@code
+ >>> init()
>>> extent = SpatialExtent(table="raster_spatial_extent",
... ident="soil at PERMANENT", north=90, south=90, east=180, west=180,
@@ -1604,4 +1606,4 @@
import doctest
- doctest.testmod()
+ doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/temporal_extent.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -10,6 +10,7 @@
>>> from datetime import datetime
+>>> tgis.init()
>>> t = tgis.RasterRelativeTime()
>>> t = tgis.RasterAbsoluteTime()
@@ -40,6 +41,7 @@
@code
+ >>> init()
>>> A = AbstractTemporalExtent(table="raster_absolute_time",
... ident="soil at PERMANENT", start_time=datetime(2001, 01, 01),
... end_time=datetime(2005,01,01) )
@@ -770,6 +772,7 @@
@code
+ >>> init()
>>> A = STDSAbsoluteTime(table="strds_absolute_time",
... ident="strds at PERMANENT", start_time=datetime(2001, 01, 01),
... end_time=datetime(2005,01,01), granularity="1 days",
@@ -895,6 +898,7 @@
@code
+ >>> init()
>>> A = RelativeTemporalExtent(table="raster_relative_time",
... ident="soil at PERMANENT", start_time=0, end_time=1, unit="years")
>>> A.id
@@ -1007,6 +1011,7 @@
@code
+ >>> init()
>>> A = STDSRelativeTime(table="strds_relative_time",
... ident="strds at PERMANENT", start_time=0, end_time=1, unit="years",
... granularity=5, map_time="interval")
@@ -1128,4 +1133,4 @@
import doctest
- doctest.testmod()
+ doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -31,6 +31,43 @@
@param granularity The granularity string
@param temporal_type The temporal type of the granularity relative or absolute
@return True if valid, False if invalid
+ @code
+ >>> check_granularity_string("1 year", "absolute")
+ True
+ >>> check_granularity_string("1 month", "absolute")
+ True
+ >>> check_granularity_string("1 day", "absolute")
+ True
+ >>> check_granularity_string("1 minute", "absolute")
+ True
+ >>> check_granularity_string("1 hour", "absolute")
+ True
+ >>> check_granularity_string("1 second", "absolute")
+ True
+ >>> check_granularity_string("5 months", "absolute")
+ True
+ >>> check_granularity_string("5 days", "absolute")
+ True
+ >>> check_granularity_string("5 minutes", "absolute")
+ True
+ >>> check_granularity_string("5 years", "absolute")
+ True
+ >>> check_granularity_string("5 hours", "absolute")
+ True
+ >>> check_granularity_string("2 seconds", "absolute")
+ True
+ >>> check_granularity_string("1 secondo", "absolute")
+ False
+ >>> check_granularity_string("bla second", "absolute")
+ False
+ >>> check_granularity_string(1, "relative")
+ True
+ >>> check_granularity_string("bla", "relative")
+ False
+ @endcode
temporal_type
@@ -69,6 +106,94 @@
@param maps: a ordered by start_time list of map objects
@return An integer
+ @code
+ >>> tgis.init()
+ >>> maps = []
+ >>> for i in range(5):
+ ... map = tgis.RasterDataset("a%i at P"%i)
+ ... check = map.set_relative_time(i,i + 1,"seconds")
+ ... if check:
+ ... maps.append(map)
+ >>> tgis.compute_relative_time_granularity(maps)
+ 1
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((0,3), (3,6), (6,9))
+ >>> for t in timelist:
+ ... map = tgis.RasterDataset("a%i at P"%count)
+ ... check = map.set_relative_time(t[0],t[1],"years")
+ ... if check:
+ ... count += 1
+ 3
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((0,3), (4,6), (8,11))
+ ... if check:
+ ... count += 1
+ 1
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((0,8), (2,6), (5,9))
+ ... check = map.set_relative_time(t[0],t[1],"months")
+ ... if check:
+ ... count += 1
+ 4
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((0,8), (8,12), (12,18))
+ ... check = map.set_relative_time(t[0],t[1],"days")
+ ... if check:
+ ... count += 1
+ 2
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((0,None), (8,None), (12,None), (24,None))
+ ... check = map.set_relative_time(t[0],t[1],"minutes")
+ ... if check:
+ ... count += 1
+ 4
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((0,None), (8,14), (18,None), (24,None))
+ ... check = map.set_relative_time(t[0],t[1],"hours")
+ ... if check:
+ ... count += 1
+ 2
+ @endcode
# The interval time must be scaled to days resolution
@@ -125,6 +250,74 @@
@return The temporal topology as string "integer unit"
+ @code
+ >>> import datetime
+ >>> dt = datetime.datetime
+ >>> tgis.init()
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((dt(2000,01,01),None), (dt(2000,02,01),None))
+ ... check = map.set_absolute_time(t[0],t[1])
+ ... if check:
+ ... count += 1
+ >>> tgis.compute_absolute_time_granularity(maps)
+ '1 month'
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((dt(2000,01,01),None), (dt(2000,01,02),None), (dt(2000,01,03),None))
+ ... if check:
+ ... count += 1
+ '1 day'
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((dt(2000,01,01),None), (dt(2000,01,02),None), (dt(2000,05,04,0,5,30),None))
+ ... if check:
+ ... count += 1
+ '30 seconds'
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((dt(2000,01,01),dt(2000,05,02)), (dt(2000,05,04,2),None))
+ ... if check:
+ ... count += 1
+ '2 hours'
+ >>> maps = []
+ >>> count = 0
+ >>> timelist = ((dt(2000,01,01),dt(2000,02,01)), (dt(2005,05,04,12),dt(2007,05,20,6)))
+ ... if check:
+ ... count += 1
+ '6 hours'
+ @endcode
has_seconds = False
@@ -166,42 +359,47 @@
delta.append(start2 - start1)
datetime_delta.append(compute_datetime_delta(
start1, start2))
# Check what changed
dlist = []
for d in datetime_delta:
if "second" in d and d["second"] > 0:
has_seconds = True
+ #print "has second"
if "minute" in d and d["minute"] > 0:
has_minutes = True
+ #print "has minute"
if "hour" in d and d["hour"] > 0:
has_hours = True
+ #print "has hour"
if "day" in d and d["day"] > 0:
has_days = True
+ #print "has day"
if "month" in d and d["month"] > 0:
has_months = True
+ #print "has month"
if "year" in d and d["year"] > 0:
has_years = True
+ #print "has year"
# Create a list with a single time unit only
if has_seconds:
- if "second" in d:
+ if "second" in d and d["second"] > 0:
dlist.append(d["second"])
- elif "minute" in d:
+ elif "minute" in d and d["minute"] > 0:
dlist.append(d["minute"] * 60)
- elif "hour" in d:
+ elif "hour" in d and d["hour"] > 0:
dlist.append(d["hour"] * 3600)
- elif "day" in d:
+ elif "day" in d and d["day"] > 0:
dlist.append(d["day"] * 24 * 3600)
else:
dlist.append(d["max_days"] * 24 * 3600)
use_seconds = True
elif has_minutes:
- if "minute" in d:
+ if "minute" in d and d["minute"] > 0:
dlist.append(d["minute"])
- elif "hour" in d:
dlist.append(d["hour"] * 60)
elif "day" in d:
dlist.append(d["day"] * 24 * 60)
@@ -210,25 +408,25 @@
use_minutes = True
elif has_hours:
- if "hour" in d:
+ if "hour" in d and d["hour"] > 0:
dlist.append(d["hour"])
- elif "day" in d:
dlist.append(d["day"] * 24)
else:
dlist.append(d["max_days"] * 24)
use_hours = True
elif has_days:
- if "day" in d:
+ if "day" in d and d["day"] > 0:
dlist.append(d["day"])
else:
dlist.append(d["max_days"])
use_days = True
elif has_months:
- if "month" in d:
+ if "month" in d and d["month"] > 0:
dlist.append(d["month"])
- elif "year" in d:
+ elif "year" in d and d["year"] > 0:
dlist.append(d["year"] * 12)
use_months = True
elif has_years:
@@ -309,3 +507,9 @@
Returns: GCD of all numbers
return reduce(gcd, list)
+if __name__ == "__main__":
+ import doctest
+ doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_relationships.py
--- grass/trunk/lib/python/temporal/temporal_relationships.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/temporal_relationships.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -632,4 +632,11 @@
if where == "()":
where = None
- return where
+ return where
+ import doctest
+ doctest.testmod()
Modified: grass/trunk/lib/python/temporal/unit_tests.py
--- grass/trunk/lib/python/temporal/unit_tests.py 2013-04-17 16:55:58 UTC (rev 55856)
+++ grass/trunk/lib/python/temporal/unit_tests.py 2013-04-17 21:19:53 UTC (rev 55857)
@@ -563,112 +563,13 @@
if delta != 0:
core.fatal("Compute datetime delta is wrong %s" % (delta))
-def test_compute_relative_time_granularity():
- # First we test intervals
- print "Test 1"
- maps = []
- fact = 5
- start = 1
- end = start * fact
- for i in range(6):
- map = RasterDataset(None)
- map.set_relative_time(start, end, "years")
- maps.append(map)
- start = end
- fact = fact - 1
- gran = round(compute_relative_time_granularity(maps))
- if fact - gran != 0:
- core.fatal("Wrong granularity reference %i != gran %i" % (fact, gran))
- print "Test 2"
- maps = []
- fact = 3
- start = 1.0 / 86400
- for i in range(10):
- maps.append(map)
- start = end
- fact = fact - 1
- gran = round(compute_relative_time_granularity(maps) * 86400)
- print "Test 3 with gaps"
- maps = []
- fact = 3
- start = 1
- end = start + fact
- shift = i * 2 * fact
- start = shift
- maps.append(map)
- # Second we test intervals and points mixed
- print "Test 4 intervals and points"
- maps = []
- fact = 5
- start = 1
- count = 0
- if count % 2 == 0:
- else:
- map.set_relative_time(start, None)
- maps.append(map)
- start = end
- count += 1
- fact = fact - 1
- # Second we test points only
- print "Test 5 points only"
- maps = []
- fact = 3
- point = (i + 1) * fact * start
- map.set_relative_time(point, None, years)
- maps.append(map)
def test_compute_absolute_time_granularity():
print "Test 1"
maps = []
a = datetime(2001, 1, 1)
- increment = "1 years"
+ increment = "1 year"
for i in range(10):
start = increment_datetime_by_string(a, increment, i)
end = increment_datetime_by_string(a, increment, i + 1)
@@ -700,7 +601,7 @@
print "Test 3"
maps = []
a = datetime(2001, 5, 1)
- increment = "1 months"
+ increment = "1 month"
for i in range(20):
@@ -732,7 +633,7 @@
print "Test 3"
maps = []
- increment = "1 days"
+ increment = "1 day"
for i in range(6):
@@ -764,7 +665,7 @@
print "Test 5"
maps = []
a = datetime(2001, 3, 1)
- increment = "1 months, 4 days"
+ increment = "1 month, 4 days"
for i in range(20):
@@ -772,7 +673,7 @@
map.set_absolute_time(start, end)
maps.append(map)
gran = compute_absolute_time_granularity(maps)
if increment != gran:
core.fatal("Wrong granularity reference %s != gran %s" % (
@@ -885,6 +786,8 @@
for i in range(24):
+ print start
+ print end
maps.append(map)
@@ -1489,13 +1392,13 @@
_map.set_absolute_time(datetime(2001, 05, 01), datetime(2001, 06, 01))
map_listA.append(copy.copy(_map))
- tb = temporal_topology_builder()
+ tb = TemporalTopologyBuilder()
tb.build(map_listA)
count = 0
for _map in tb:
print "[%s]" % (_map.get_name())
- _map.print_temporal_topology_info()
+ _map.print_topology_info()
if _map.get_id() != map_listA[count].get_id():
core.fatal("Error building temporal topology <%s> != <%s>" %
(_map.get_id(), map_listA[count].get_id()))
@@ -1519,36 +1422,36 @@
_map.set_absolute_time(datetime(2001, 05, 01), datetime(2001, 05, 14))
map_listB.append(copy.copy(_map))
tb.build(map_listB)
# Probing some relations
- if map_listB[0].get_temporal_overlapped()[0] != map_listB[1]:
+ if map_listB[0].get_overlapped()[0] != map_listB[1]:
core.fatal("Error building temporal topology")
- if map_listB[0].get_temporal_overlapped()[1] != map_listB[2]:
+ if map_listB[0].get_overlapped()[1] != map_listB[2]:
- if map_listB[2].get_temporal_contains()[0] != map_listB[3]:
+ if map_listB[2].get_contains()[0] != map_listB[3]:
- if map_listB[3].get_temporal_during()[0] != map_listB[2]:
+ if map_listB[3].get_during()[0] != map_listB[2]:
count = 0
for _map in tb:
print "[%s]" % (_map.get_map_id
- _map.print_temporal_topology_shell_info()
+ _map.print_topology_shell_info()
if _map.get_id() != map_listB[count].get_id():
(_map.get_id(), map_listB[count].get_id()))
count += 1
- tb.build2(map_listA, map_listB)
+ tb.build(map_listA, map_listB)
count = 0
for _map in tb:
print "[%s]" % (_map.get_map_id())
@@ -1557,21 +1460,21 @@
count = 0
for _map in map_listB:
- if map_listA[3].get_temporal_follows()[0] != map_listB[1]:
+ if map_listA[3].get_follows()[0] != map_listB[1]:
- if map_listA[3].get_temporal_precedes()[0] != map_listB[4]:
+ if map_listA[3].get_precedes()[0] != map_listB[4]:
- if map_listA[3].get_temporal_overlaps()[0] != map_listB[2]:
+ if map_listA[3].get_overlaps()[0] != map_listB[2]:
- if map_listA[3].get_temporal_contains()[0] != map_listB[3]:
+ if map_listA[3].get_contains()[0] != map_listB[3]:
- if map_listA[2].get_temporal_during()[0] != map_listB[1]:
+ if map_listA[2].get_during()[0] != map_listB[1]:
- if map_listA[2].get_temporal_during()[1] != map_listB[2]:
+ if map_listA[2].get_during()[1] != map_listB[2]:
@@ -1751,10 +1654,10 @@
+ init()
test_increment_datetime_by_string()
test_adjust_datetime_to_granularity()
test_spatial_extent_intersection()
- test_compute_relative_time_granularity()
test_compute_datetime_delta()
