[GRASS-SVN] r55913 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Fri Apr 19 01:52:02 PDT 2013
Author: mmetz
Date: 2013-04-19 01:52:02 -0700 (Fri, 19 Apr 2013)
New Revision: 55913
grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: suggest a minimum snapping threshold if topological errors are encountered
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2013-04-19 08:51:24 UTC (rev 55912)
+++ grass/trunk/vector/v.in.ogr/main.c 2013-04-19 08:52:02 UTC (rev 55913)
@@ -109,6 +109,8 @@
int overwrite;
double area_size;
int use_tmp_vect;
+ int ncentr, n_overlaps;
+ struct bound_box box;
xmin = ymin = xmax = ymax = 0.0;
loc_proj_info = loc_proj_units = NULL;
@@ -815,6 +817,8 @@
Vect_hist_command(&Map);
+ ncentr = n_overlaps = n_polygons = 0;
/* Points and lines are written immediately with categories. Boundaries of polygons are
* written to the vector then cleaned and centroids are calculated for all areas in cleaan vector.
* Then second pass through finds all centroids in each polygon feature and adds its category
@@ -1102,11 +1106,10 @@
if (use_tmp_vect && !flag.no_clean->answer &&
Vect_get_num_primitives(Out, GV_BOUNDARY) > 0) {
- int ret, centr, ncentr, otype, n_overlaps, n_nocat;
+ int ret, centr, otype, n_nocat;
CENTR *Centr;
struct spatial_index si;
double x, y, total_area, overlap_area, nocat_area;
- struct bound_box box;
struct line_pnts *Points;
int nmodif;
@@ -1341,6 +1344,46 @@
Vect_build(&Map);
if (0 && flag.no_clean->answer)
Vect_topo_check(&Map, NULL);
+ if (n_polygons) {
+ ncentr = Vect_get_num_primitives(&Map, GV_CENTROID);
+ /* this test is not perfect:
+ * small gaps (areas without centroid) are not detected
+ * because they may be true gaps */
+ if (ncentr != n_polygons || n_overlaps) {
+ double new_snap;
+ Vect_get_map_box(&Map, &box);
+ if (abs(box.E) > abs(box.W))
+ xmax = abs(box.E);
+ else
+ xmax = abs(box.W);
+ if (abs(box.N) > abs(box.S))
+ xmax = abs(box.N);
+ else
+ xmax = abs(box.S);
+ if (xmax < ymax)
+ xmax = ymax;
+ new_snap = log2(xmax) - 52;
+ new_snap = pow(2, new_snap);
+ new_snap = log10(new_snap);
+ if (new_snap < 0)
+ new_snap = (int)new_snap;
+ else
+ new_snap = (int)new_snap + 1;
+ new_snap = pow(10, new_snap);
+ if (snap < new_snap) {
+ G_important_message("%s", separator);
+ G_warning(_("Errors were encountered during the import"));
+ G_important_message(_("Try to import again, snapping with at least %g: 'snap=%g'"), new_snap, new_snap);
Vect_close(&Map);
