[GRASS-SVN] r55914 - grass/trunk/lib/python/temporal
Fri Apr 19 05:20:23 PDT 2013
Author: huhabla
Date: 2013-04-19 05:20:22 -0700 (Fri, 19 Apr 2013)
New Revision: 55914
Added:
   grass/trunk/lib/python/temporal/create.py
   grass/trunk/lib/python/temporal/factory.py
   grass/trunk/lib/python/temporal/gui_support.py
   grass/trunk/lib/python/temporal/list.py
   grass/trunk/lib/python/temporal/register.py
   grass/trunk/lib/python/temporal/sampling.py
Removed:
   grass/trunk/lib/python/temporal/space_time_datasets_tools.py
   grass/trunk/lib/python/temporal/Makefile
   grass/trunk/lib/python/temporal/__init__.py
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/base.py
   grass/trunk/lib/python/temporal/mapcalc.py
   grass/trunk/lib/python/temporal/pythontemporallib.dox
   grass/trunk/lib/python/temporal/stds_import.py
Better code and file structure. Fixed several doxygen errors and warnings.
More API documentation.
Modified: grass/trunk/lib/python/temporal/Makefile
--- grass/trunk/lib/python/temporal/Makefile	2013-04-19 08:52:02 UTC (rev 55913)
+++ grass/trunk/lib/python/temporal/Makefile	2013-04-19 12:20:22 UTC (rev 55914)
@@ -8,7 +8,7 @@
 GDIR = $(PYDIR)/grass
 DSTDIR = $(GDIR)/temporal
-MODULES = base core abstract_dataset abstract_temporal_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets space_time_datasets_tools metadata spatial_extent temporal_extent datetime_math temporal_granularity temporal_relationships unit_tests aggregation stds_export stds_import extract mapcalc univar_statistics
+MODULES = base core abstract_dataset abstract_temporal_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets create factory gui_support list register sampling metadata spatial_extent temporal_extent datetime_math temporal_granularity temporal_relationships unit_tests aggregation stds_export stds_import extract mapcalc univar_statistics
 PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
 PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Modified: grass/trunk/lib/python/temporal/__init__.py
--- grass/trunk/lib/python/temporal/__init__.py	2013-04-19 08:52:02 UTC (rev 55913)
+++ grass/trunk/lib/python/temporal/__init__.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -8,10 +8,15 @@
 from abstract_map_dataset import *
 from abstract_space_time_dataset import *
 from space_time_datasets import *
-from space_time_datasets_tools import *
 from datetime_math import *
 from temporal_granularity import *
 from temporal_relationships import *
+from create import *
+from factory import *
+from gui_support import *
+from list import *
+from register import *
+from sampling import *
 from aggregation import *
 from extract import *
 from stds_export import *
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2013-04-19 08:52:02 UTC (rev 55913)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -66,7 +66,7 @@
            This table stores all space time datasets in
            which this map is registered.
-           @param ident The name of the register table
+           @param name The name of the register table
         raise ImplementationError(
             "This method must be implemented in the subclasses")
@@ -165,7 +165,7 @@
            in the file system but not to identify
            map information in the temporal database.
-           @return The map id name at mapset
+           @return The map id "name at mapset"
         return self.base.get_map_id()
@@ -176,10 +176,10 @@
             string will be reused
            @param name The name of the map
-           @param The mapset in which the map is located
-           @layer The layer of the vector map, use None in case no layer exists
+           @param mapset The mapset in which the map is located
+           @param layer The layer of the vector map, use None in case no layer exists
-           @return the id of the map as name(:layer)@mapset
+           @return the id of the map as "name(:layer)@mapset"
                   while layer is optional
@@ -383,6 +383,7 @@
            @param start_time a datetime object specifying the start time of the map
            @param end_time a datetime object specifying the end time of the map, None in case or time instance
            @param timezone Thee timezone of the map (not used)
+           @param dbif The database interface to be used
         dbif, connected = init_dbif(dbif)
@@ -463,6 +464,7 @@
            @param start_time An integer value
            @param end_time An integer value, None in case or time instance
+           @param unit The relative time unit
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-04-19 08:52:02 UTC (rev 55913)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -1086,7 +1086,7 @@
            This method renames the space time dataset, the map register table
            and updates the entries in registered maps stds register.
-           @param ident The new identifier name at mapset
+           @param ident The new identifier "name at mapset"
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py	2013-04-19 08:52:02 UTC (rev 55913)
+++ grass/trunk/lib/python/temporal/base.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -68,9 +68,9 @@
             >>> t.serialize(type="UPDATE ALL", table="raster_base")
             ('UPDATE raster_base SET  name = ?  ,creator = ?  ,creation_time = ?  ,modification_time = ?  ,mapset = ?  ,id = ? ;\\n', ('soil', 'soeren', datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2001, 1, 1, 0, 0), 'PERMANENT', 'soil at PERMANENT'))
-            @type must be SELECT. INSERT, UPDATE
-            @table The name of the table to select, insert or update
-            @where The optional where statement
+            @param type must be SELECT. INSERT, UPDATE
+            @param table The name of the table to select, insert or update
+            @param where The optional where statement
             @return a tuple containing the SQL string and the arguments
             \endcode
@@ -571,7 +571,7 @@
                           that should be used to store the values
             @param ident The unique identifier must be a combination of
                           the dataset name, layer name and the mapset
-                          name at mapset or name:1 at mapset
+                          "name at mapset" or "name:layer at mapset"
                           used as as primary key in the temporal database
             @param name The name of the map or dataset
             @param mapset The name of the mapset
@@ -604,7 +604,7 @@
                          of the dataset name, layer name and the mapset
         self.ident = ident
         self.D["id"] = ident
@@ -632,7 +632,7 @@
     def set_mapset(self, mapset):
         """!Set the mapset of the dataset
-           @param mapsets The name of the mapset in which this dataset is stored
+           @param mapset The name of the mapset in which this dataset is stored
         self.D["mapset"] = mapset
@@ -699,7 +699,7 @@
         """!Convenient method to get the unique map identifier
            without layer information
-           @return the name of the vector map as name at mapset
+           @return the name of the vector map as "name at mapset"
                   or None in case the id was not set
         if self.id:
Added: grass/trunk/lib/python/temporal/create.py
--- grass/trunk/lib/python/temporal/create.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/create.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -0,0 +1,84 @@
+"""!@package grass.temporal
+ at brief GRASS Python scripting module (temporal GIS functions)
+Temporal GIS related functions to be used in Python scripts.
+Usage:
+ at code
+import grass.temporal as tgis
+tgis.register_maps_in_space_time_dataset(type, name, maps)
+ at endcode
+(C) 2008-2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+from space_time_datasets import *
+def create_space_time_dataset(name, type, temporaltype, title, descr, semantic,
+                              dbif=None, overwrite=False):
+    """!Create a new space time dataset
+       This function is sensitive to the settings in grass.core.overwrite to
+       overwrute existing space time datasets.
+       @param name The name of the new space time dataset
+       @param type The type (strds, stvds, str3ds) of the new space time dataset
+       @param temporaltype The temporal type (relative or absolute)
+       @param title The title
+       @param descr The dataset description
+       @param semantic Semantical information
+       @param dbif The temporal database interface to be used
+       @param overwrite Flag to allow overwriting
+       @return The new created space time dataset
+       This function will raise a ScriptError in case of an error.
+    #Get the current mapset to create the id of the space time dataset
+    mapset = core.gisenv()["MAPSET"]
+    id = name + "@" + mapset
+    sp = dataset_factory(type, id)
+    dbif, connected = init_dbif(dbif)
+    if sp.is_in_db(dbif) and overwrite == False:
+        if connected:
+            dbif.close()
+        core.fatal(_("Space time %s dataset <%s> is already in the database. "
+                      "Use the overwrite flag.") %
+                    (sp.get_new_map_instance(None).get_type(), name))
+        return None
+    if sp.is_in_db(dbif) and overwrite == True:
+        core.warning(_("Overwrite space time %s dataset <%s> "
+                     "and unregister all maps.") %
+        sp.delete(dbif)
+        sp = sp.get_new_instance(id)
+    core.verbose(_("Create new space time %s dataset.") %
+                  sp.get_new_map_instance(None).get_type())
+    sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
+                          title=title, description=descr)
+    sp.insert(dbif)
+    if connected:
+        dbif.close()
+    return sp
Added: grass/trunk/lib/python/temporal/factory.py
--- grass/trunk/lib/python/temporal/factory.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/factory.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -0,0 +1,54 @@
+Usage:
+ at code
+ at endcode
+for details.
+def dataset_factory(type, id):
+    """!A factory functions to create space time or map datasets
+       @param type the dataset type: rast or raster, rast3d,
+                    vect or vector, strds, str3ds, stvds
+       @param id The id of the dataset ("name at mapset")
+    if type == "strds":
+        sp = SpaceTimeRasterDataset(id)
+    elif type == "str3ds":
+        sp = SpaceTimeRaster3DDataset(id)
+    elif type == "stvds":
+        sp = SpaceTimeVectorDataset(id)
+    elif type == "rast" or type == "raster":
+        sp = RasterDataset(id)
+    elif type == "rast3d":
+        sp = Raster3DDataset(id)
+    elif type == "vect" or type == "vector":
+        sp = VectorDataset(id)
+    else:
+        core.error(_("Unknown dataset type: %s") % type)
+        return None
+    return sp
Added: grass/trunk/lib/python/temporal/gui_support.py
--- grass/trunk/lib/python/temporal/gui_support.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/gui_support.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -0,0 +1,111 @@
+for details.
+def tlist_grouped(type, group_type = False):
+    """!List of temporal elements grouped by mapsets.
+    Returns a dictionary where the keys are mapset
+    names and the values are lists of space time datasets in that
+    mapset. Example:
+    @code
+    >>> tgis.tlist_grouped('strds')['PERMANENT']
+    ['precipitation', 'temperature']
+    @endcode
+    @param type element type (strds, str3ds, stvds)
+    @param group_type TBD
+    @return directory of mapsets/elements
+    result = {}
+    mapset = None
+    if type == 'stds':
+        types = ['strds', 'str3ds', 'stvds']
+    else:
+        types = [type]
+    for type in types:
+        try:
+            tlist_result = tlist(type)
+        except core.ScriptError, e:
+            warning(e)
+            continue
+        for line in tlist_result:
+            try:
+                name, mapset = line.split('@')
+            except ValueError:
+                warning(_("Invalid element '%s'") % line)
+                continue
+            if mapset not in result:
+                if group_type:
+                    result[mapset] = {}
+                else:
+                    result[mapset] = []
+            if group_type:
+                if type in result[mapset]:
+                    result[mapset][type].append(name)
+                else:
+                    result[mapset][type] = [name, ]
+            else:
+                result[mapset].append(name)
+    return result
+def tlist(type):
+    """!Return a list of space time datasets of absolute and relative time
+    @return a list of space time dataset ids
+    id = None
+    dbif = SQLDatabaseInterfaceConnection()
+    dbif.connect()
+    output = []
+    temporal_type = ["absolute", 'relative']
+    for type in temporal_type:
+        # Table name
+        if type == "absolute":
+            table = sp.get_type() + "_view_abs_time"
+        else:
+            table = sp.get_type() + "_view_rel_time"
+        # Create the sql selection statement
+        sql = "SELECT id FROM " + table
+        sql += " ORDER BY id"
+        dbif.cursor.execute(sql)
+        rows = dbif.cursor.fetchall()
+        # Append the ids of the space time datasets
+        for row in rows:
+            for col in row:
+                output.append(str(col))
+    dbif.close()
+    return output
Added: grass/trunk/lib/python/temporal/list.py
--- grass/trunk/lib/python/temporal/list.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/list.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -0,0 +1,195 @@
+Usage:
+ at code
+ at endcode
+for details.
+def list_maps_of_stds(type, input, columns, order, where, separator, method, header, gran=None):
+    """! List the maps of a space time dataset using diffetent methods
+        @param type The type of the maps raster, raster3d or vector
+        @param input Name of a space time raster dataset
+        @param columns A comma separated list of columns to be printed to stdout
+        @param order A comma separated list of columns to order the
+                      space time dataset by category
+        @param where A where statement for selected listing without "WHERE"
+                      e.g: start_time < "2001-01-01" and end_time > "2001-01-01"
+        @param separator The field separator character between the columns
+        @param method String identifier to select a method out of cols,
+                       comma,delta or deltagaps
+            - "cols" Print preselected columns specified by columns
+            - "comma" Print the map ids ("name at mapset") as comma separated string
+            - "delta" Print the map ids ("name at mapset") with start time,
+                       end time, relative length of intervals and the relative
+                       distance to the begin
+            - "deltagaps" Same as "delta" with additional listing of gaps.
+                           Gaps can be simply identified as the id is "None"
+            - "gran" List map using the granularity of the space time dataset,
+                      columns are identical to deltagaps
+        @param header Set True to print column names
+        @param gran The user defined granule to be used if method=gran is set, in case gran=None the
+            granule of the space time dataset is used
+    if input.find("@") >= 0:
+        id = input
+    else:
+        id = input + "@" + mapset
+    dbif, connected = init_dbif(None)
+    if not sp.is_in_db(dbif=dbif):
+        core.fatal(_("Dataset <%s> not found in temporal database") % (id))
+    sp.select(dbif=dbif)
+    if separator is None or separator == "":
+        separator = "\t"
+    # This method expects a list of objects for gap detection
+    if method == "delta" or method == "deltagaps" or method == "gran":
+        if type == "stvds":
+            columns = "id,name,layer,mapset,start_time,end_time"
+        else:
+            columns = "id,name,mapset,start_time,end_time"
+        if method == "deltagaps":
+            maps = sp.get_registered_maps_as_objects_with_gaps(where=where, dbif=dbif)
+        elif method == "delta":
+            maps = sp.get_registered_maps_as_objects(where=where, order="start_time", dbif=dbif)
+        elif method == "gran":
+            if gran is not None and gran != "":
+                maps = sp.get_registered_maps_as_objects_by_granularity(gran=gran, dbif=dbif)
+            else:
+                maps = sp.get_registered_maps_as_objects_by_granularity(dbif=dbif)
+        if header:
+            string = ""
+            string += "%s%s" % ("id", separator)
+            string += "%s%s" % ("name", separator)
+                string += "%s%s" % ("layer", separator)
+            string += "%s%s" % ("mapset", separator)
+            string += "%s%s" % ("start_time", separator)
+            string += "%s%s" % ("end_time", separator)
+            string += "%s%s" % ("interval_length", separator)
+            string += "%s" % ("distance_from_begin")
+            print string
+        if maps and len(maps) > 0:
+            if isinstance(maps[0], list):
+                if len(maps[0]) > 0:
+                    first_time, dummy = maps[0][0].get_valid_time()
+                else:
+                    core.warning(_("Empty map list."))
+                    return
+            else:
+                first_time, dummy = maps[0].get_valid_time()
+            for mymap in maps:
+                if isinstance(mymap, list):
+                    if len(mymap) > 0:
+                        map = mymap[0]
+                    else:
+                        core.fatal(_("Empty entry in map list, this should not happen."))
+                else:
+                    map = mymap
+                start, end = map.get_valid_time()
+                if end:
+                    delta = end - start
+                else:
+                    delta = None
+                delta_first = start - first_time
+                if map.is_time_absolute():
+                    if end:
+                        delta = time_delta_to_relative_time(delta)
+                    delta_first = time_delta_to_relative_time(delta_first)
+                string = ""
+                string += "%s%s" % (map.get_id(), separator)
+                string += "%s%s" % (map.get_name(), separator)
+                    string += "%s%s" % (map.get_layer(), separator)
+                string += "%s%s" % (map.get_mapset(), separator)
+                string += "%s%s" % (start, separator)
+                string += "%s%s" % (end, separator)
+                string += "%s%s" % (delta, separator)
+                string += "%s" % (delta_first)
+                print string
+    else:
+        # In comma separated mode only map ids are needed
+        if method == "comma":
+            columns = "id"
+        rows = sp.get_registered_maps(columns, where, order, dbif)
+        if rows:
+                string = ""
+                count = 0
+                for row in rows:
+                    if count == 0:
+                        string += row["id"]
+                    else:
+                        string += ",%s" % row["id"]
+                    count += 1
+                print string
+            elif method == "cols":
+                # Print the column names if requested
+                if header:
+                    output = ""
+                    count = 0
+                    collist = columns.split(",")
+                    for key in collist:
+                        if count > 0:
+                            output += separator + str(key)
+                        else:
+                            output += str(key)
+                        count += 1
+                    print output
+                for row in rows:
+                    output = ""
+                    count = 0
+                    for col in row:
+                        if count > 0:
+                            output += separator + str(col)
+                        else:
+                            output += str(col)
+                        count += 1
+                    print output
+    if connected:
+        dbif.close()
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py	2013-04-19 08:52:02 UTC (rev 55913)
+++ grass/trunk/lib/python/temporal/mapcalc.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -60,13 +60,13 @@
        - end_second() - The minute of the end time [0 - 59]
-       @param input The name of the input space time raster/raster3d dataset
+       @param inputs The names of the input space time raster/raster3d datasets
        @param output The name of the extracted new space time raster(3d) dataset
        @param type The type of the dataset: "raster" or "raster3d"
-       @param method The method to be used for temporal sampling
        @param expression The r(3).mapcalc expression
        @param base The base name of the new created maps in case a
               mapclac expression is provided
+       @param method The method to be used for temporal sampling
        @param nprocs The number of parallel processes to be used for
               mapcalc processing
        @param register_null Set this number True to register empty maps
Modified: grass/trunk/lib/python/temporal/pythontemporallib.dox
--- grass/trunk/lib/python/temporal/pythontemporallib.dox	2013-04-19 08:52:02 UTC (rev 55913)
+++ grass/trunk/lib/python/temporal/pythontemporallib.dox	2013-04-19 12:20:22 UTC (rev 55914)
@@ -1,13 +1,30 @@
-/*! \page pythontemporallib GRASS Python Temporal Library
+/*! \page pythontemporallib GRASS GIS Temporal Framework
 by GRASS Development Team (http://grass.osgeo.org)
-Python Temporal GIS package
+The GRASS GIS Temporal Framework
-TODO: add more detailed documentation
+\section PythonTGISIntro Introduction
-List of modules:
+The GRASS GIS Temporal Framework implements the temporal GIS functionality of GRASS GIS
+and provides an API to implement spatio-temporal processing modules. The framework
+introduces space time datasets that represent time series of raster, 3D raster or vector maps.
+This framework provides the following functionalities:
+- Assign time stamp to maps and register maps in the temporal database
+- Modification of time stamps
+- Creation, renaming and deletion of space time datasets
+- Registration and un-registration of maps in space time datasets
+- Query of maps that are registered in space time datasets using SQL where statements
+- Analysis of the spatio-temporal topology of space time datasets
+- Sampling of space time datasets
+- Computation of temporal and spatial relationships between registered maps
+- Higher level functions that are shared between modules
+Most of the functions described above are member functions of the maps and space time dataset classes.
+Maps and space time datasets are represented as objects in the temporal framework.
+\section PythonTGISPackages Library
 Core functionality such as the database interface connection to sqlite3
 and postgresql as well as the creation of the temporal database are defined here:
@@ -15,18 +32,17 @@
 In these modules are the temporal database interfaces for raster maps,
 3D raster maps, vector maps and space time datasets defined.
+In addition the temporal and spatial extent modules implement the topological
+relationship computation that is needed for spatio-temporal topology computation:
-Additionally the temporal and spatial extent modules implement the topological
-relationship computation that is needed for spatio-temporal topology computation.
 - python::temporal::base
 - python::temporal::spatial_extent
 - python::temporal::temporal_extent
 - python::temporal::metadata
-Several "abstract" modules are defined that implement the shared functionality
+Several "abstract" classes are defined that implement the shared functionality
 of time stamped maps and space time datasets, such as temporal and spatial
-handling and representation.
+handling and representation:
 - python::temporal::abstract_dataset
 - python::temporal::abstract_temporal_dataset
@@ -42,27 +58,155 @@
 and their conversion as well as topology computation are defined in these modules:
 - python::temporal::datetime_math
+- python::temporal::temporal_granularity
 - python::temporal::temporal_relationships
-- python::temporal::temporal_granularity
 Functionality that is shared between different temporal GRASS modules, such as
-map listing, map registration and unregistration, aggregation, extraction,
-map calculation, statistics as well as import and export of
+map listing, space time dataset creation, map registration and unregistration,
+aggregation, extraction, map calculation, statistics as well as import and export of
 space time datasets are defined here:
-- python::temporal::space_time_datasets_tools
 - python::temporal::aggregation
+- python::temporal::create
 - python::temporal::extract
+- python::temporal::factory
+- python::temporal::list
 - python::temporal::mapcalc
+- python::temporal::register
+- python::temporal::sampling
 - python::temporal::stds_export
 - python::temporal::stds_import
 - python::temporal::univar_statistics
+Two helper functions to support the listing of space time datasets in the automatically generated GUI:
+- python::temporal::gui_support
 Lots of unit tests:
 - python::temporal::unit_tests
-\section pythonTempAuthors Authors
+\section PythonTGISExamples Examples
+\subsection PythonTGISExamplesSimple Simple example
+This simple example shows how to open a space time raster dataset
+to access its registered maps.
+\code
+# Lets import the temporal framework and
+# the script framework
+import grass.script as grass
+# Make sure the temporal database exists
+# and set the temporal GIS environment
+tgis.init()
+# We create the temporal database interface for fast processing
+dbif = tgis.SQLDatabaseInterfaceConnection()
+dbif.connect()
+# The id of a space time raster dataset is build from its name and its mapset
+id = "test at PERMANENT"
+# We create a space time raster dataset object
+strds = tgis.SpaceTimeRasterDataset(id)
+# Check if the space time raster dataset is in the temporal database
+if strds.is_in_db(dbif=dbif) == False:
+    dbif.close()
+    grass.fatal(_("Space time %s dataset <%s> not found") % (
+        strds.get_new_map_instance(None).get_type(), id))
+# Fill the object with the content from the temporal database
+strds.select(dbif=dbif)
+# Print informations about the space time raster dataset to stdout
+strds.print_info()
+# Get all maps that are registered in the strds and print
+# informations about the maps to stdout
+maps = strds.get_registered_maps_as_objects(dbif=dbif)
+# We iterate over the temporal sorted map list
+for map in maps:
+    # We fill the map object with the content
+    # from the temporal database. We use the existing
+    # database connection, otherwise a new connection
+    # will be established for each map object
+    # which slows the processing down
+    map.select(dbif=dbif)
+    map.print_info()
+# Close the database connection
+dbif.close()
+\endcode
+\subsection PythonTGISExamplesSTDSCreation Creation of a space time dataset
+This example shows howto create a space time dataset. The code is generic and works
+for different space time datasets (raster, 3D raster and vector):
+\code
+# The id of the new space time dataset
+id="test at PERMANENT"
+# The title of the new space time dataset
+title="This is a test dataset"
+# The description of the space time dataset
+description="The description"
+# The type of the space time dataset (strds, str3ds or stvds)
+type="strds"
+# The temporal type of the space time dataset (absolute or relative)
+temporal_type="absolute"
+tgis.init()
+# We use the dataset factory to create an new space time dataset instance of a specific type
+stds = tgis.dataset_factory(type, id)
+# We need a dtabase connection to insert the content of the space time dataset
+dbif.connect()
+# First we check if the dataset is already in the database
+if stds.is_in_db(dbif=dbif) and overwrite == False:
+    dbif.close()
+    grass.fatal(_("Space time %s dataset <%s> is already in the database. "
+                (stds.get_new_map_instance(None).get_type(), name))
+# We delete the exiting dataset and create a new one in case we are allowed to overwrite it
+if stds.is_in_db(dbif=dbif) and overwrite == True:
+    grass.warning(_("Overwrite space time %s dataset <%s> "
+    stds.delete(dbif=dbif)
+    stds = stds.get_new_instance(id)
+# We set the initial values. This function also created the command history.
+stds.set_initial_values(temporal_type=temporaltype, semantic_type="mean",
+                        title=title, description=description)
+# Now we can insert the new space time dataset in the database
+stds.insert(dbif=dbif)
+dbif.close()
+\endcode
+\section PythonTGISAuthors Authors
 Soeren Gebbert
+TODO: add more documentation
Added: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/register.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -0,0 +1,419 @@
+Usage:
+ at code
+ at endcode
+for details.
+def register_maps_in_space_time_dataset(
+    type, name, maps=None, file=None, start=None,
+    end=None, unit=None, increment=None, dbif=None,
+        interval=False, fs="|"):
+    """!Use this method to register maps in space time datasets.
+       Additionally a start time string and an increment string can be specified
+       to assign a time interval automatically to the maps.
+       It takes care of the correct update of the space time datasets from all
+       registered maps.
+       @param type The type of the maps rast, rast3d or vect
+       @param name The name of the space time dataset
+       @param maps A comma separated list of map names
+       @param file Input file one map with start and optional end time,
+                    one per line
+       @param start The start date and time of the first raster map
+                    (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd",
+                    format relative is integer 5)
+       @param end The end date and time of the first raster map
+       @param unit The unit of the relative time: years, months, days,
+                    hours, minutes, seconds
+       @param increment Time increment between maps for time stamp creation
+                         (format absolute: NNN seconds, minutes, hours, days,
+                         weeks, months, years; format relative: 1.0)
+       @param interval If True, time intervals are created in case the start
+                        time and an increment is provided
+       @param fs Field separator used in input file
+    start_time_in_file = False
+    end_time_in_file = False
+    if maps and file:
+        core.fatal(_("%s= and %s= are mutually exclusive") % ("maps", "file"))
+    if end and increment:
+            "end", "increment"))
+    if end and not start:
+        core.fatal(_("Please specify %s= and %s=") % ("start_time",
+                                                      "end_time"))
+    if not maps and not file:
+        core.fatal(_("Please specify %s= or %s=") % ("maps", "file"))
+    # We may need the mapset
+    # The name of the space time dataset is optional
+    if name:
+        # Check if the dataset name contains the mapset as well
+        if name.find("@") < 0:
+        else:
+            id = name
+        if type == "rast" or type == "raster":
+            sp = dataset_factory("strds", id)
+            sp = dataset_factory("str3ds", id)
+            sp = dataset_factory("stvds", id)
+        else:
+            core.fatal(_("Unkown map type: %s") % (type))
+    if name:
+        # Read content from temporal database
+        sp.select(dbif)
+        if not sp.is_in_db(dbif):
+            dbif.close()
+            core.fatal(_("Space time %s dataset <%s> no found") %
+        if sp.is_time_relative() and not unit:
+            dbif.close()
+            core.fatal(_("Space time %s dataset <%s> with relative time found, "
+                         "but no relative unit set for %s maps") %
+                        name, sp.get_new_map_instance(None).get_type()))
+    # We need a dummy map object to build the map ids
+    dummy = dataset_factory(type, None)
+    maplist = []
+    # Map names as comma separated string
+    if maps:
+        if maps.find(",") < 0:
+            maplist = [maps, ]
+        else:
+            maplist = maps.split(",")
+        # Build the map list again with the ids
+        for count in range(len(maplist)):
+            row = {}
+            mapid = dummy.build_id(maplist[count], mapset, None)
+            row["id"] = mapid
+            maplist[count] = row
+    # Read the map list from file
+    if file:
+        fd = open(file, "r")
+        line = True
+        while True:
+            line = fd.readline()
+            if not line:
+                break
+            line_list = line.split(fs)
+            # Detect start and end time
+            if len(line_list) == 2:
+                start_time_in_file = True
+            elif len(line_list) == 3:
+                end_time_in_file = True
+            else:
+            mapname = line_list[0].strip()
+            row = {}
+            if start_time_in_file and end_time_in_file:
+                row["start"] = line_list[1].strip()
+                row["end"] = line_list[2].strip()
+            if start_time_in_file and not end_time_in_file:
+            row["id"] = dummy.build_id(mapname, mapset)
+            maplist.append(row)
+    num_maps = len(maplist)
+    map_object_list = []
+    statement = ""
+    # Store the ids of datasets that must be updated
+    datatsets_to_modify = {}
+    core.message(_("Gathering map informations"))
+        if count%50 == 0:
+            core.percent(count, num_maps, 1)
+        # Get a new instance of the map type
+        map = dataset_factory(type, maplist[count]["id"])
+        # Use the time data from file
+        if "start" in maplist[count]:
+            start = maplist[count]["start"]
+        if "end" in maplist[count]:
+            end = maplist[count]["end"]
+        is_in_db = False
+        # Put the map into the database
+        if not map.is_in_db(dbif):
+            is_in_db = False
+            # Break in case no valid time is provided
+            if start == "" or start is None:
+                dbif.close()
+                if map.get_layer():
+                    core.fatal(_("Unable to register %s map <%s> with layer %s. "
+                                 "The map has no valid time and the start time is not set.") %
+                               (map.get_type(), map.get_map_id(), map.get_layer()))
+                else:
+                    core.fatal(_("Unable to register %s map <%s>. The map has no valid"
+                                 " time and the start time is not set.") %
+                               (map.get_type(), map.get_map_id()))
+            if unit:
+                map.set_time_to_relative()
+            else:
+                map.set_time_to_absolute()
+        else:
+            is_in_db = True
+            # Check the overwrite flag
+            if not core.overwrite():
+                    core.warning(_("Map is already registered in temporal database. "
+                                   "Unable to update %s map <%s> with layer %s. "
+                                   "Overwrite flag is not set.") %
+                               (map.get_type(), map.get_map_id(), str(map.get_layer())))
+                else:
+                                   "Unable to update %s map <%s>. "
+                # Simple registration is allowed
+                if name:
+                    map_object_list.append(map)
+                # Jump to next map
+                continue
+            # Select information from temporal database
+            map.select(dbif)
+            # Save the datasets that must be updated
+            datasets = map.get_registered_datasets(dbif)
+            if datasets:
+                for dataset in datasets:
+                    datatsets_to_modify[dataset["id"]] = dataset["id"]
+                if name and map.get_temporal_type() != sp.get_temporal_type():
+                    dbif.close()
+                        core.fatal(_("Unable to update %s map <%s> with layer. "
+                                     "The temporal types are different.") %
+                    else:
+                        core.fatal(_("Unable to update %s map <%s>. "
+        # Load the data from the grass file database
+        map.load()
+        # Set the valid time
+        if start:
+            # In case the time is in the input file we ignore the increment counter
+            if start_time_in_file:
+                count = 1
+            assign_valid_time_to_map(ttype=map.get_temporal_type(),
+                                     map=map, start=start, end=end, unit=unit,
+                                     increment=increment, mult=count,
+                                     interval=interval)
+        if is_in_db:
+            #  Gather the SQL update statement
+            statement += map.update_all(dbif=dbif, execute=False)
+        else:
+            #  Gather the SQL insert statement
+            statement += map.insert(dbif=dbif, execute=False)
+        # Sqlite3 performace better for huge datasets when committing in small chunks
+        if dbif.dbmi.__name__ == "sqlite3":
+            if count % 100 == 0:
+                if statement is not None and statement != "":
+                    core.message(_("Registering maps in the temporal database")
+                    dbif.execute_transaction(statement)
+                    statement = ""
+        # Store the maps in a list to register in a space time dataset
+        if name:
+    core.percent(num_maps, num_maps, 1)
+        core.message(_("Register maps in the temporal database"))
+    # Finally Register the maps in the space time dataset
+    if name and map_object_list:
+        statement = ""
+        count = 0
+        num_maps = len(map_object_list)
+        core.message(_("Register maps in the space time raster dataset"))
+        for map in map_object_list:
+            if count%50 == 0:
+            sp.register_map(map=map, dbif=dbif)
+            count += 1
+    # Update the space time tables
+        core.message(_("Update space time raster dataset"))
+        sp.update_from_registered_maps(dbif)
+        sp.update_command_string(dbif=dbif)
+    # Update affected datasets
+    if datatsets_to_modify:
+        for dataset in datatsets_to_modify:
+                ds = dataset_factory("strds", dataset)
+                ds = dataset_factory("str3ds", dataset)
+                ds = dataset_factory("stvds", dataset)
+            ds.select(dbif)
+            ds.update_from_registered_maps(dbif)
+    if connected == True:
+        dbif.close()
+def assign_valid_time_to_map(ttype, map, start, end, unit, increment=None, mult=1, interval=False):
+    """!Assign the valid time to a map dataset
+       @param ttype The temporal type which should be assigned
+                     and which the time format is of
+       @param map A map dataset object derived from abstract_map_dataset
+                    days, hours, minutes, seconds
+                        weeks, months, years; format relative is integer 1)
+       @param mult A multiplier for the increment
+    if ttype == "absolute":
+        start_time = string_to_datetime(start)
+        if start_time is None:
+            core.fatal(_("Unable to convert string \"%s\"into a "
+                         "datetime object") % (start))
+        end_time = None
+        if end:
+            end_time = string_to_datetime(end)
+            if end_time is None:
+                dbif.close()
+                             "datetime object") % (end))
+        # Add the increment
+        if increment:
+            start_time = increment_datetime_by_string(
+                start_time, increment, mult)
+                core.fatal(_("Error in increment computation"))
+            if interval:
+                end_time = increment_datetime_by_string(
+                    start_time, increment, 1)
+        # Commented because of performance issue calling g.message thousend times
+        #if map.get_layer():
+        #    core.verbose(_("Set absolute valid time for map <%(id)s> with "
+        #                   "layer %(layer)s to %(start)s - %(end)s") %
+        #                 {'id': map.get_map_id(), 'layer': map.get_layer(),
+        #                  'start': str(start_time), 'end': str(end_time)})
+        #else:
+        #    core.verbose(_("Set absolute valid time for map <%s> to %s - %s") %
+        #                 (map.get_map_id(), str(start_time), str(end_time)))
+        map.set_absolute_time(start_time, end_time, None)
+    else:
+        start_time = int(start)
+        end_time = None
+        if end:
+            end_time = int(end)
+        if increment:
+            start_time = start_time + mult * int(increment)
+            if interval:
+                end_time = start_time + int(increment)
+        #    core.verbose(_("Set relative valid time for map <%s> with layer %s "
+        #                   "to %i - %s with unit %s") %
+        #                 (map.get_map_id(), map.get_layer(), start_time,
+        #                  str(end_time), unit))
+        #else:
+        #    core.verbose(_("Set relative valid time for map <%s> to %i - %s "
+        #                   "with unit %s") % (map.get_map_id(), start_time,
+        map.set_relative_time(start_time, end_time, unit)
Added: grass/trunk/lib/python/temporal/sampling.py
--- grass/trunk/lib/python/temporal/sampling.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/sampling.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -0,0 +1,169 @@
+Usage:
+ at code
+ at endcode
+for details.
+def sample_stds_by_stds_topology(intype, sampletype, inputs, sampler, header,
+                                 separator, method, spatial=False,
+                                 print_only=True):
+    """!Sample the input space time datasets with a sample
+       space time dataset, return the created map matrix and optionally
+       print the result to stdout
+        In case multiple maps are located in the current granule,
+        the map names are separated by comma.
+        In case a layer is present, the names map ids are extended
+        in this form: "name:layer at mapset"
+        Attention: Do not use the comma as separator for printing
+        @param intype  Type of the input space time dataset (strds, stvds or str3ds)
+        @param sampletype Type of the sample space time dataset (strds, stvds or str3ds)
+        @param inputs Name or comma separated names of space time datasets
+        @param sampler Name of a space time dataset used for temporal sampling
+                       (start,during,contain,overlap,equal)
+        @param spatial Perform spatial overlapping check
+        @param print_only If set True (default) then the result of the sampling will be
+                    printed to stdout, if set to False the resulting map matrix
+                    will be returned.
+        @return The map matrix or None if nothing found
+    # Make a method list
+    method = method.split(",")
+    # Split the inputs
+    input_list = inputs.split(",")
+    sts = []
+    for input in input_list:
+            id = input
+        else:
+        st = dataset_factory(intype, id)
+        sts.append(st)
+    if sampler.find("@") >= 0:
+        sid = sampler
+    else:
+        sid = sampler + "@" + mapset
+    sst = dataset_factory(sampletype, sid)
+    dbif.connect()
+    for st in sts:
+        if st.is_in_db(dbif) == False:
+            core.fatal(_("Dataset <%s> not found in temporal database") % (st.get_id()))
+        st.select(dbif)
+    if sst.is_in_db(dbif) == False:
+        core.fatal(_("Dataset <%s> not found in temporal database") % (sid))
+    sst.select(dbif)
+    if separator is None or separator == "" or separator.find(",") >= 0:
+        separator = " | "
+    mapmatrizes = []
+    for st in sts:
+        mapmatrix = st.sample_by_dataset(sst, method, spatial, dbif)
+        if mapmatrix and len(mapmatrix) > 0:
+            mapmatrizes.append(mapmatrix)
+    if len(mapmatrizes) > 0:
+        # Simply return the map matrix
+        if not print_only:
+            dbif.close()
+            return mapmatrizes
+        if header:
+            string = ""
+            string += "%s%s" % (sst.get_id(), separator)
+            for st in sts:
+                string += "%s%s" % (st.get_id(), separator)
+            print string
+        first_time, dummy = mapmatrizes[0][0]["granule"].get_valid_time()
+        for i in range(len(mapmatrizes[0])):
+            mapname_list = []
+            for mapmatrix in mapmatrizes:
+                mapnames = ""
+                count = 0
+                entry = mapmatrix[i]
+                for sample in entry["samples"]:
+                    if count == 0:
+                        mapnames += str(sample.get_id())
+                    else:
+                        mapnames += ",%s" % str(sample.get_id())
+                    count += 1
+                mapname_list.append(mapnames)
+            entry = mapmatrizes[0][i]
+            map = entry["granule"]
+            if end:
+            else:
+                delta = None
+                if end:
+            string = ""
+            for mapnames in mapname_list:
+                string += "%s%s" % (mapnames, separator)
+            print string
+    dbif.close()
+    return None
Deleted: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2013-04-19 08:52:02 UTC (rev 55913)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -1,917 +0,0 @@
-"""!@package grass.temporal
- at brief GRASS Python scripting module (temporal GIS functions)
-Temporal GIS related functions to be used in Python scripts.
-Usage:
- at code
-import grass.temporal as tgis
-tgis.register_maps_in_space_time_dataset(type, name, maps)
- at endcode
-(C) 2008-2011 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Soeren Gebbert
-from space_time_datasets import *
-def register_maps_in_space_time_dataset(
-    type, name, maps=None, file=None, start=None,
-    end=None, unit=None, increment=None, dbif=None,
-        interval=False, fs="|"):
-    """!Use this method to register maps in space time datasets.
-       Additionally a start time string and an increment string can be specified
-       to assign a time interval automatically to the maps.
-       It takes care of the correct update of the space time datasets from all
-       registered maps.
-       @param type The type of the maps rast, rast3d or vect
-       @param name The name of the space time dataset
-       @param maps A comma separated list of map names
-       @param file Input file one map with start and optional end time,
-                    one per line
-       @param start The start date and time of the first raster map
-                    (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd",
-                    format relative is integer 5)
-       @param end The end date and time of the first raster map
-       @param unit The unit of the relative time: years, months, days,
-                    hours, minutes, seconds
-       @param increment Time increment between maps for time stamp creation
-                         (format absolute: NNN seconds, minutes, hours, days,
-                         weeks, months, years; format relative: 1.0)
-       @param dbif The database interface to be used
-       @param interval If True, time intervals are created in case the start
-                        time and an increment is provided
-       @param fs Field separator used in input file
-    start_time_in_file = False
-    end_time_in_file = False
-    if maps and file:
-        core.fatal(_("%s= and %s= are mutually exclusive") % ("maps", "file"))
-    if end and increment:
-            "end", "increment"))
-    if end and not start:
-        core.fatal(_("Please specify %s= and %s=") % ("start_time",
-                                                      "end_time"))
-    if not maps and not file:
-        core.fatal(_("Please specify %s= or %s=") % ("maps", "file"))
-    # We may need the mapset
-    mapset = core.gisenv()["MAPSET"]
-    # The name of the space time dataset is optional
-    if name:
-        # Check if the dataset name contains the mapset as well
-        if name.find("@") < 0:
-            id = name + "@" + mapset
-        else:
-            id = name
-        if type == "rast" or type == "raster":
-            sp = dataset_factory("strds", id)
-        elif type == "rast3d":
-            sp = dataset_factory("str3ds", id)
-        elif type == "vect" or type == "vector":
-            sp = dataset_factory("stvds", id)
-        else:
-            core.fatal(_("Unkown map type: %s") % (type))
-    dbif, connected = init_dbif(None)
-    if name:
-        # Read content from temporal database
-        sp.select(dbif)
-        if not sp.is_in_db(dbif):
-            dbif.close()
-            core.fatal(_("Space time %s dataset <%s> no found") %
-                       (sp.get_new_map_instance(None).get_type(), name))
-        if sp.is_time_relative() and not unit:
-            dbif.close()
-            core.fatal(_("Space time %s dataset <%s> with relative time found, "
-                         "but no relative unit set for %s maps") %
-                        name, sp.get_new_map_instance(None).get_type()))
-    # We need a dummy map object to build the map ids
-    dummy = dataset_factory(type, None)
-    maplist = []
-    # Map names as comma separated string
-    if maps:
-        if maps.find(",") < 0:
-            maplist = [maps, ]
-        else:
-            maplist = maps.split(",")
-        # Build the map list again with the ids
-        for count in range(len(maplist)):
-            row = {}
-            mapid = dummy.build_id(maplist[count], mapset, None)
-            row["id"] = mapid
-            maplist[count] = row
-    # Read the map list from file
-    if file:
-        fd = open(file, "r")
-        line = True
-        while True:
-            line = fd.readline()
-            if not line:
-                break
-            line_list = line.split(fs)
-            # Detect start and end time
-            if len(line_list) == 2:
-                start_time_in_file = True
-            elif len(line_list) == 3:
-                end_time_in_file = True
-            else:
-            mapname = line_list[0].strip()
-            row = {}
-            if start_time_in_file and end_time_in_file:
-                row["start"] = line_list[1].strip()
-                row["end"] = line_list[2].strip()
-            if start_time_in_file and not end_time_in_file:
-            row["id"] = dummy.build_id(mapname, mapset)
-            maplist.append(row)
-    num_maps = len(maplist)
-    map_object_list = []
-    statement = ""
-    # Store the ids of datasets that must be updated
-    datatsets_to_modify = {}
-    core.message(_("Gathering map informations"))
-        if count%50 == 0:
-            core.percent(count, num_maps, 1)
-        # Get a new instance of the map type
-        map = dataset_factory(type, maplist[count]["id"])
-        # Use the time data from file
-        if "start" in maplist[count]:
-            start = maplist[count]["start"]
-        if "end" in maplist[count]:
-            end = maplist[count]["end"]
-        is_in_db = False
-        # Put the map into the database
-        if not map.is_in_db(dbif):
-            is_in_db = False
-            # Break in case no valid time is provided
-            if start == "" or start is None:
-                dbif.close()
-                if map.get_layer():
-                    core.fatal(_("Unable to register %s map <%s> with layer %s. "
-                                 "The map has no valid time and the start time is not set.") %
-                               (map.get_type(), map.get_map_id(), map.get_layer()))
-                else:
-                    core.fatal(_("Unable to register %s map <%s>. The map has no valid"
-                                 " time and the start time is not set.") %
-                               (map.get_type(), map.get_map_id()))
-            if unit:
-                map.set_time_to_relative()
-            else:
-                map.set_time_to_absolute()
-        else:
-            is_in_db = True
-            # Check the overwrite flag
-            if not core.overwrite():
-                    core.warning(_("Map is already registered in temporal database. "
-                                   "Unable to update %s map <%s> with layer %s. "
-                                   "Overwrite flag is not set.") %
-                               (map.get_type(), map.get_map_id(), str(map.get_layer())))
-                else:
-                                   "Unable to update %s map <%s>. "
-                # Simple registration is allowed
-                if name:
-                    map_object_list.append(map)
-                # Jump to next map
-                continue
-            # Select information from temporal database
-            map.select(dbif)
-            # Save the datasets that must be updated
-            datasets = map.get_registered_datasets(dbif)
-            if datasets:
-                for dataset in datasets:
-                    datatsets_to_modify[dataset["id"]] = dataset["id"]
-                if name and map.get_temporal_type() != sp.get_temporal_type():
-                    dbif.close()
-                        core.fatal(_("Unable to update %s map <%s> with layer. "
-                                     "The temporal types are different.") %
-                    else:
-                        core.fatal(_("Unable to update %s map <%s>. "
-        # Load the data from the grass file database
-        map.load()
-        # Set the valid time
-        if start:
-            # In case the time is in the input file we ignore the increment counter
-            if start_time_in_file:
-                count = 1
-            assign_valid_time_to_map(ttype=map.get_temporal_type(),
-                                     map=map, start=start, end=end, unit=unit,
-                                     increment=increment, mult=count,
-                                     interval=interval)
-        if is_in_db:
-            #  Gather the SQL update statement
-            statement += map.update_all(dbif=dbif, execute=False)
-        else:
-            #  Gather the SQL insert statement
-            statement += map.insert(dbif=dbif, execute=False)
-        # Sqlite3 performace better for huge datasets when committing in small chunks
-        if dbif.dbmi.__name__ == "sqlite3":
-            if count % 100 == 0:
-                if statement is not None and statement != "":
-                    core.message(_("Registering maps in the temporal database")
-                    dbif.execute_transaction(statement)
-                    statement = ""
-        # Store the maps in a list to register in a space time dataset
-        if name:
-    core.percent(num_maps, num_maps, 1)
-        core.message(_("Register maps in the temporal database"))
-    # Finally Register the maps in the space time dataset
-    if name and map_object_list:
-        statement = ""
-        count = 0
-        num_maps = len(map_object_list)
-        core.message(_("Register maps in the space time raster dataset"))
-        for map in map_object_list:
-            if count%50 == 0:
-            sp.register_map(map=map, dbif=dbif)
-            count += 1
-    # Update the space time tables
-        core.message(_("Update space time raster dataset"))
-        sp.update_from_registered_maps(dbif)
-        sp.update_command_string(dbif=dbif)
-    # Update affected datasets
-    if datatsets_to_modify:
-        for dataset in datatsets_to_modify:
-                ds = dataset_factory("strds", dataset)
-                ds = dataset_factory("str3ds", dataset)
-                ds = dataset_factory("stvds", dataset)
-            ds.select(dbif)
-            ds.update_from_registered_maps(dbif)
-    if connected == True:
-        dbif.close()
-def assign_valid_time_to_map(ttype, map, start, end, unit, increment=None, mult=1, interval=False):
-    """!Assign the valid time to a map dataset
-       @param ttype The temporal type which should be assigned
-                     and which the time format is of
-       @param map A map dataset object derived from abstract_map_dataset
-                    days, hours, minutes, seconds
-                        weeks, months, years; format relative is integer 1)
-       @param multi A multiplier for the increment
-    if ttype == "absolute":
-        start_time = string_to_datetime(start)
-        if start_time is None:
-            core.fatal(_("Unable to convert string \"%s\"into a "
-                         "datetime object") % (start))
-        end_time = None
-        if end:
-            end_time = string_to_datetime(end)
-            if end_time is None:
-                dbif.close()
-                             "datetime object") % (end))
-        # Add the increment
-        if increment:
-            start_time = increment_datetime_by_string(
-                start_time, increment, mult)
-                core.fatal(_("Error in increment computation"))
-            if interval:
-                end_time = increment_datetime_by_string(
-                    start_time, increment, 1)
-        # Commented because of performance issue calling g.message thousend times
-        #if map.get_layer():
-        #    core.verbose(_("Set absolute valid time for map <%(id)s> with "
-        #                   "layer %(layer)s to %(start)s - %(end)s") %
-        #                 {'id': map.get_map_id(), 'layer': map.get_layer(),
-        #                  'start': str(start_time), 'end': str(end_time)})
-        #else:
-        #    core.verbose(_("Set absolute valid time for map <%s> to %s - %s") %
-        #                 (map.get_map_id(), str(start_time), str(end_time)))
-        map.set_absolute_time(start_time, end_time, None)
-    else:
-        start_time = int(start)
-        end_time = None
-        if end:
-            end_time = int(end)
-        if increment:
-            start_time = start_time + mult * int(increment)
-            if interval:
-                end_time = start_time + int(increment)
-        #    core.verbose(_("Set relative valid time for map <%s> with layer %s "
-        #                   "to %i - %s with unit %s") %
-        #                 (map.get_map_id(), map.get_layer(), start_time,
-        #                  str(end_time), unit))
-        #else:
-        #    core.verbose(_("Set relative valid time for map <%s> to %i - %s "
-        #                   "with unit %s") % (map.get_map_id(), start_time,
-        map.set_relative_time(start_time, end_time, unit)
-def dataset_factory(type, id):
-    """!A factory functions to create space time or map datasets
-       @param type the dataset type: rast or raster, rast3d,
-                    vect or vector, strds, str3ds, stvds
-       @param id The id of the dataset ("name at mapset")
-    if type == "strds":
-        sp = SpaceTimeRasterDataset(id)
-    elif type == "str3ds":
-        sp = SpaceTimeRaster3DDataset(id)
-    elif type == "stvds":
-        sp = SpaceTimeVectorDataset(id)
-    elif type == "rast" or type == "raster":
-        sp = RasterDataset(id)
-        sp = Raster3DDataset(id)
-        sp = VectorDataset(id)
-    else:
-        core.error(_("Unknown dataset type: %s") % type)
-        return None
-    return sp
-def list_maps_of_stds(type, input, columns, order, where, separator, method, header, gran=None):
-    """! List the maps of a space time dataset using diffetent methods
-        @param type The type of the maps raster, raster3d or vector
-        @param input Name of a space time raster dataset
-        @param columns A comma separated list of columns to be printed to stdout
-        @param order A comma separated list of columns to order the
-                      space time dataset by category
-        @param where A where statement for selected listing without "WHERE"
-                      e.g: start_time < "2001-01-01" and end_time > "2001-01-01"
-        @param separator The field separator character between the columns
-        @param method String identifier to select a method out of cols,
-                       comma,delta or deltagaps
-            - "cols" Print preselected columns specified by columns
-            - "comma" Print the map ids (name at mapset) as comma separated string
-            - "delta" Print the map ids (name at mapset) with start time,
-                       end time, relative length of intervals and the relative
-                       distance to the begin
-            - "deltagaps" Same as "delta" with additional listing of gaps.
-                           Gaps can be simply identified as the id is "None"
-            - "gran" List map using the granularity of the space time dataset,
-                      columns are identical to deltagaps
-        @param header Set True to print column names
-        @param gran The user defined granule to be used if method=gran is set, in case gran=None the
-            granule of the space time dataset is used
-    if input.find("@") >= 0:
-        id = input
-    else:
-        id = input + "@" + mapset
-    sp = dataset_factory(type, id)
-    if not sp.is_in_db(dbif=dbif):
-        core.fatal(_("Dataset <%s> not found in temporal database") % (id))
-    sp.select(dbif=dbif)
-    if separator is None or separator == "":
-        separator = "\t"
-    # This method expects a list of objects for gap detection
-    if method == "delta" or method == "deltagaps" or method == "gran":
-        if type == "stvds":
-            columns = "id,name,layer,mapset,start_time,end_time"
-        else:
-            columns = "id,name,mapset,start_time,end_time"
-        if method == "deltagaps":
-            maps = sp.get_registered_maps_as_objects_with_gaps(where=where, dbif=dbif)
-        elif method == "delta":
-            maps = sp.get_registered_maps_as_objects(where=where, order="start_time", dbif=dbif)
-        elif method == "gran":
-            if gran is not None and gran != "":
-                maps = sp.get_registered_maps_as_objects_by_granularity(gran=gran, dbif=dbif)
-            else:
-                maps = sp.get_registered_maps_as_objects_by_granularity(dbif=dbif)
-        if header:
-            string = ""
-            string += "%s%s" % ("id", separator)
-            string += "%s%s" % ("name", separator)
-                string += "%s%s" % ("layer", separator)
-            string += "%s%s" % ("mapset", separator)
-            string += "%s%s" % ("start_time", separator)
-            string += "%s%s" % ("end_time", separator)
-            string += "%s%s" % ("interval_length", separator)
-            string += "%s" % ("distance_from_begin")
-            print string
-        if maps and len(maps) > 0:
-            if isinstance(maps[0], list):
-                if len(maps[0]) > 0:
-                    first_time, dummy = maps[0][0].get_valid_time()
-                else:
-                    core.warning(_("Empty map list."))
-                    return
-            else:
-                first_time, dummy = maps[0].get_valid_time()
-            for mymap in maps:
-                if isinstance(mymap, list):
-                    if len(mymap) > 0:
-                        map = mymap[0]
-                    else:
-                        core.fatal(_("Empty entry in map list, this should not happen."))
-                else:
-                    map = mymap
-                start, end = map.get_valid_time()
-                if end:
-                    delta = end - start
-                else:
-                    delta = None
-                delta_first = start - first_time
-                if map.is_time_absolute():
-                    if end:
-                        delta = time_delta_to_relative_time(delta)
-                    delta_first = time_delta_to_relative_time(delta_first)
-                string = ""
-                string += "%s%s" % (map.get_id(), separator)
-                string += "%s%s" % (map.get_name(), separator)
-                    string += "%s%s" % (map.get_layer(), separator)
-                string += "%s%s" % (map.get_mapset(), separator)
-                string += "%s%s" % (start, separator)
-                string += "%s%s" % (end, separator)
-                string += "%s%s" % (delta, separator)
-                string += "%s" % (delta_first)
-                print string
-    else:
-        # In comma separated mode only map ids are needed
-        if method == "comma":
-            columns = "id"
-        rows = sp.get_registered_maps(columns, where, order, dbif)
-        if rows:
-                string = ""
-                count = 0
-                for row in rows:
-                    if count == 0:
-                        string += row["id"]
-                    else:
-                        string += ",%s" % row["id"]
-                    count += 1
-                print string
-            elif method == "cols":
-                # Print the column names if requested
-                if header:
-                    output = ""
-                    count = 0
-                    collist = columns.split(",")
-                    for key in collist:
-                        if count > 0:
-                            output += separator + str(key)
-                        else:
-                            output += str(key)
-                        count += 1
-                    print output
-                for row in rows:
-                    output = ""
-                    count = 0
-                    for col in row:
-                        if count > 0:
-                            output += separator + str(col)
-                        else:
-                            output += str(col)
-                        count += 1
-                    print output
-    if connected:
-        dbif.close()
-def sample_stds_by_stds_topology(intype, sampletype, inputs, sampler, header,
-                                 separator, method, spatial=False,
-                                 print_only=True):
-    """!Sample the input space time datasets with a sample
-       space time dataset, return the created map matrix and optionally
-       print the result to stdout
-        In case multiple maps are located in the current granule,
-        the map names are separated by comma.
-        In case a layer is present, the names map ids are extended
-        in this form: name:layer at mapset
-        Attention: Do not use the comma as separator for printing
-        @param intype  Type of the input space time dataset (strds, stvds or str3ds)
-        @param samtype Type of the sample space time dataset (strds, stvds or str3ds)
-        @param inputs Name or comma separated names of space time datasets
-        @param sampler Name of a space time dataset used for temporal sampling
-                       (start,during,contain,overlap,equal)
-        @param spatial Perform spatial overlapping check
-        @param print_only If set True (default) then the result of the sampling will be
-                    printed to stdout, if set to False the resulting map matrix
-                    will be returned.
-        @return The map matrix or None if nothing found
-    # Make a method list
-    method = method.split(",")
-    # Split the inputs
-    input_list = inputs.split(",")
-    sts = []
-    for input in input_list:
-            id = input
-        else:
-        st = dataset_factory(intype, id)
-        sts.append(st)
-    if sampler.find("@") >= 0:
-        sid = sampler
-    else:
-        sid = sampler + "@" + mapset
-    sst = dataset_factory(sampletype, sid)
-    dbif = SQLDatabaseInterfaceConnection()
-    dbif.connect()
-    for st in sts:
-        if st.is_in_db(dbif) == False:
-            core.fatal(_("Dataset <%s> not found in temporal database") % (st.get_id()))
-        st.select(dbif)
-    if sst.is_in_db(dbif) == False:
-        core.fatal(_("Dataset <%s> not found in temporal database") % (sid))
-    sst.select(dbif)
-    if separator is None or separator == "" or separator.find(",") >= 0:
-        separator = " | "
-    mapmatrizes = []
-    for st in sts:
-        mapmatrix = st.sample_by_dataset(sst, method, spatial, dbif)
-        if mapmatrix and len(mapmatrix) > 0:
-            mapmatrizes.append(mapmatrix)
-    if len(mapmatrizes) > 0:
-        # Simply return the map matrix
-        if not print_only:
-            dbif.close()
-            return mapmatrizes
-        if header:
-            string = ""
-            string += "%s%s" % (sst.get_id(), separator)
-            for st in sts:
-                string += "%s%s" % (st.get_id(), separator)
-            print string
-        first_time, dummy = mapmatrizes[0][0]["granule"].get_valid_time()
-        for i in range(len(mapmatrizes[0])):
-            mapname_list = []
-            for mapmatrix in mapmatrizes:
-                mapnames = ""
-                count = 0
-                entry = mapmatrix[i]
-                for sample in entry["samples"]:
-                    if count == 0:
-                        mapnames += str(sample.get_id())
-                    else:
-                        mapnames += ",%s" % str(sample.get_id())
-                    count += 1
-                mapname_list.append(mapnames)
-            entry = mapmatrizes[0][i]
-            map = entry["granule"]
-            if end:
-            else:
-                delta = None
-                if end:
-            string = ""
-            for mapnames in mapname_list:
-                string += "%s%s" % (mapnames, separator)
-            print string
-    dbif.close()
-    return None
-def tlist_grouped(type, group_type = False):
-    """!List of temporal elements grouped by mapsets.
-    Returns a dictionary where the keys are mapset
-    names and the values are lists of space time datasets in that
-    mapset. Example:
-    @code
-    >>> tgis.tlist_grouped('strds')['PERMANENT']
-    ['precipitation', 'temperature']
-    @endcode
-    @param type element type (strds, str3ds, stvds)
-    @return directory of mapsets/elements
-    result = {}
-    mapset = None
-    if type == 'stds':
-        types = ['strds', 'str3ds', 'stvds']
-    else:
-        types = [type]
-    for type in types:
-        try:
-            tlist_result = tlist(type)
-        except core.ScriptError, e:
-            warning(e)
-            continue
-        for line in tlist_result:
-            try:
-                name, mapset = line.split('@')
-            except ValueError:
-                warning(_("Invalid element '%s'") % line)
-                continue
-            if mapset not in result:
-                if group_type:
-                    result[mapset] = {}
-                else:
-                    result[mapset] = []
-            if group_type:
-                if type in result[mapset]:
-                    result[mapset][type].append(name)
-                else:
-                    result[mapset][type] = [name, ]
-            else:
-                result[mapset].append(name)
-    return result
-def tlist(type):
-    """!Return a list of space time datasets of absolute and relative time
-    @return a list of space time dataset ids
-    id = None
-    dbif.connect()
-    output = []
-    temporal_type = ["absolute", 'relative']
-    for type in temporal_type:
-        # Table name
-        if type == "absolute":
-            table = sp.get_type() + "_view_abs_time"
-        else:
-            table = sp.get_type() + "_view_rel_time"
-        # Create the sql selection statement
-        sql = "SELECT id FROM " + table
-        sql += " ORDER BY id"
-        dbif.cursor.execute(sql)
-        rows = dbif.cursor.fetchall()
-        # Append the ids of the space time datasets
-        for row in rows:
-            for col in row:
-                output.append(str(col))
-    dbif.close()
-    return output
-def create_space_time_dataset(name, type, temporaltype, title, descr, semantic,
-                              dbif=None, overwrite=False):
-    """!Create a new space time dataset
-       This function is sensitive to the settings in grass.core.overwrite to
-       overwrute existing space time datasets.
-       @param name The name of the new space time dataset
-       @param type The type (strds, stvds, str3ds) of the new space time dataset
-       @param temporaltype The temporal type (relative or absolute)
-       @param title The title
-       @param descr The dataset description
-       @param semantic Semantical information
-       @param dbif The temporal database interface to be used
-       @return The new created space time dataset
-       This function will raise a ScriptError in case of an error.
-    #Get the current mapset to create the id of the space time dataset
-    print id
-    print overwrite
-    dbif, connected = init_dbif(dbif)
-    if sp.is_in_db(dbif) and overwrite == False:
-        if connected:
-            dbif.close()
-        core.fatal(_("Space time %s dataset <%s> is already in the database. "
-                      "Use the overwrite flag.") %
-        return None
-    if sp.is_in_db(dbif) and overwrite == True:
-        core.warning(_("Overwrite space time %s dataset <%s> "
-                     "and unregister all maps.") %
-        sp.delete(dbif)
-        sp = sp.get_new_instance(id)
-    core.verbose(_("Create new space time %s dataset.") %
-                  sp.get_new_map_instance(None).get_type())
-    sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
-                          title=title, description=descr)
-    sp.insert(dbif)
-    if connected:
-        dbif.close()
-    return sp
Modified: grass/trunk/lib/python/temporal/stds_import.py
--- grass/trunk/lib/python/temporal/stds_import.py	2013-04-19 08:52:02 UTC (rev 55913)
+++ grass/trunk/lib/python/temporal/stds_import.py	2013-04-19 12:20:22 UTC (rev 55914)
@@ -157,7 +157,7 @@
         @param output The name of the output space time dataset
         @param extrdir The extraction directory
         @param title The title of the new created space time dataset
-        @param description The description of the new created
+        @param descr The description of the new created
                             space time dataset
         @param location The name of the location that should be created,
                         maps are imported into this location
