[GRASS-SVN] r55927 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Sat Apr 20 02:40:13 PDT 2013
Author: zarch
Date: 2013-04-20 02:40:13 -0700 (Sat, 20 Apr 2013)
New Revision: 55927
grass/trunk/lib/python/pygrass/vector/abstract.py
grass/trunk/lib/python/pygrass/vector/find.py
Add Finder classes from point, bbox, polygon
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2013-04-20 09:38:56 UTC (rev 55926)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2013-04-20 09:40:13 UTC (rev 55927)
@@ -12,7 +12,7 @@
from grass.pygrass import functions
from grass.pygrass.errors import GrassError, OpenError, must_be_open
from table import DBlinks, Link
-from find import Finder
+from find import PointFinder, BboxFinder, PolygonFinder
def is_open(c_mapinfo):
@@ -362,7 +362,12 @@
self.table = self.dblinks.by_layer(layer).table()
self.n_lines = self.table.n_rows()
self.writable = self.mapset == functions.getenv("MAPSET")
- self.find = Finder(self.c_mapinfo, self.table, self.writable)
+ self.find = {'by_point': PointFinder(self.c_mapinfo, self.table,
+ self.writable),
+ 'by_box': BboxFinder(self.c_mapinfo, self.table,
+ self.writable),
+ 'by_polygon': PolygonFinder(self.c_mapinfo, self.table,
+ self.writable), }
def close(self):
"""Method to close the Vector"""
@@ -380,7 +385,7 @@
"""Remove vector map"""
if self.is_open():
self.close()
- functions.remove(self.name,'vect')
+ functions.remove(self.name, 'vect')
def build(self):
"""Close the vector map and build vector Topology"""
Modified: grass/trunk/lib/python/pygrass/vector/find.py
--- grass/trunk/lib/python/pygrass/vector/find.py 2013-04-20 09:38:56 UTC (rev 55926)
+++ grass/trunk/lib/python/pygrass/vector/find.py 2013-04-20 09:40:13 UTC (rev 55927)
@@ -8,11 +8,30 @@
from grass.pygrass.errors import must_be_open
-from basic import Ilist
-from geometry import read_line, Isle, Area
+from basic import Ilist, BoxList
+from geometry import read_line, Isle, Area, Point
-class Finder(object):
+class AbstractFinder(object):
+ def __init__(self, c_mapinfo, table=None, writable=False):
+ """Find geometry feature around a point.
+ self.c_mapinfo = c_mapinfo
+ self.table = table
+ self.writable = writable
+ self.vtype = {'point': libvect.GV_POINT, # 1
+ 'line': libvect.GV_LINE, # 2
+ 'boundary': libvect.GV_BOUNDARY, # 3
+ 'centroid': libvect.GV_CENTROID, # 4
+ 'all': -1}
+ def is_open(self):
+ """Check if the vector map is open or not"""
+ import abstract
+ return abstract.is_open(self.c_mapinfo)
+class PointFinder(AbstractFinder):
"""Find the geomtry features of a vector map that are close to a point. ::
>>> from grass.pygrass.vector import VectorTopo
@@ -49,14 +68,7 @@
- self.c_mapinfo = c_mapinfo
- self.table = table
- self.writable = writable
- self.vtype = {'point': libvect.GV_POINT, # 1
- 'line': libvect.GV_LINE, # 2
- 'boundary': libvect.GV_BOUNDARY, # 3
- 'centroid': libvect.GV_CENTROID, # 4
- 'all': -1} # -1
+ super(PointFinder, self).__init__(c_mapinfo, table, writable)
# TODO: add the Node class and enable this method
# def node(self, point, maxdist):
@@ -81,12 +93,12 @@
@must_be_open
- def geos(self, point, maxdist, type='all', exclude=[]):
+ def geos(self, point, maxdist, type='all', exclude=None):
"""Find the nearest line. Vect_find_line_list
Valid type are all the keys in find.vtype dictionary
- excl = Ilist(exclude)
+ excl = Ilist(exclude) if exclude else Ilist([])
found = Ilist()
if libvect.Vect_find_line_list(self.c_mapinfo,
point.x, point.y,
@@ -115,7 +127,72 @@
return Isle(v_id=isle_id, c_mapinfo=self.c_mapinfo,
table=self.table, writable=self.writable)
- def is_open(self):
- """Check if the vector map is open or not"""
- import abstract
- return abstract.is_open(self.c_mapinfo)
+class BboxFinder(AbstractFinder):
+ super(BboxFinder, self).__init__(c_mapinfo, table, writable)
+ @must_be_open
+ def geos(self, bbox, type='all', bbox_list=False):
+ """Find the geometry features contained in the bbox.
+ Vect_select_lines_by_box
+ Valid type are all the keys in find.vtype dictionary
+ found = BoxList()
+ if libvect.Vect_select_lines_by_box(self.c_mapinfo, bbox.c_bbox,
+ self.vtype[type], found.c_boxlist):
+ if bbox_list:
+ return found
+ else:
+ return (read_line(f_id, self.c_mapinfo, self.table,
+ self.writable) for f_id in found.ids)
+ @must_be_open
+ def nodes(self, bbox):
+ """Find the nearest area. Vect_find_area"""
+ found = Ilist()
+ if libvect.Vect_select_nodes_by_box(self.c_mapinfo, bbox.c_bbox,
+ found.c_ilist):
+ for n_id in found:
+ yield Point(v_id=n_id, c_mapinfo=self.c_mapinfo,
+ table=self.table, writable=self.writable)
+ @must_be_open
+ def areas(self, bbox, bbox_list=False):
+ found = BoxList()
+ if libvect.Vect_select_areas_by_box(self.c_mapinfo, bbox.c_bbox,
+ found.c_boxlist):
+ if bbox_list:
+ return found
+ else:
+ return (Area(v_id=a_id, c_mapinfo=self.c_mapinfo,
+ for a_id in found.ids)
+ return []
+ @must_be_open
+ def islands(self, bbox, bbox_list=False):
+ """Find the nearest island. Vect_find_island"""
+ found = BoxList()
+ if libvect.Vect_select_isles_by_box(self.c_mapinfo, bbox.c_bbox,
+ found.c_boxlist):
+ if bbox_list:
+ return found
+ else:
+ return (Isle(v_id=i_id, c_mapinfo=self.c_mapinfo,
+ for i_id in found.ids)
+ return []
+class PolygonFinder(AbstractFinder):
+ super(PolygonFinder, self).__init__(c_mapinfo, table, writable)
+ def lines(self, polygon, isles=None):
+ pass
+ def areas(self, polygon, isles=None):
+ pass
