[GRASS-SVN] r55928 - in grass/trunk: lib/python/temporal temporal temporal/t.info temporal/t.shift temporal/t.snap temporal/t.topology
Sat Apr 20 06:08:01 PDT 2013
Author: huhabla
Date: 2013-04-20 06:08:00 -0700 (Sat, 20 Apr 2013)
New Revision: 55928
Added:
   grass/trunk/temporal/t.shift/
   grass/trunk/temporal/t.shift/Makefile
   grass/trunk/temporal/t.shift/t.shift.html
   grass/trunk/temporal/t.shift/t.shift.py
   grass/trunk/temporal/t.shift/test.t.shift.absolue.sh
   grass/trunk/temporal/t.shift/test.t.shift.relative.sh
   grass/trunk/temporal/t.snap/
   grass/trunk/temporal/t.snap/Makefile
   grass/trunk/temporal/t.snap/t.snap.html
   grass/trunk/temporal/t.snap/t.snap.py
   grass/trunk/temporal/t.snap/test.t.snap.absolute.sh
   grass/trunk/temporal/t.snap/test.t.snap.relative.sh
   grass/trunk/lib/python/temporal/abstract_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/create.py
   grass/trunk/lib/python/temporal/datetime_math.py
   grass/trunk/lib/python/temporal/gui_support.py
   grass/trunk/lib/python/temporal/list.py
   grass/trunk/lib/python/temporal/pythontemporallib.dox
   grass/trunk/lib/python/temporal/register.py
   grass/trunk/lib/python/temporal/sampling.py
   grass/trunk/lib/python/temporal/stds_export.py
   grass/trunk/lib/python/temporal/stds_import.py
   grass/trunk/lib/python/temporal/temporal_extent.py
   grass/trunk/lib/python/temporal/univar_statistics.py
   grass/trunk/temporal/Makefile
   grass/trunk/temporal/t.info/t.info.py
   grass/trunk/temporal/t.topology/t.topology.py
Fixed missing imports. Added two new modules for temporally shifting and snapping. Improved doxygen docs.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -401,17 +401,31 @@
         else:
             return None
-    def temporal_relation(self, map):
+    def temporal_relation(self, dataset):
         """!Return the temporal relation of self and the provided dataset
             @return The temporal relation as string
-        if self.is_time_absolute() and map.is_time_absolute():
-            return self.absolute_time.temporal_relation(map.absolute_time)
-        if self.is_time_relative() and map.is_time_relative():
-            return self.relative_time.temporal_relation(map.relative_time)
+        if self.is_time_absolute() and dataset.is_time_absolute():
+            return self.absolute_time.temporal_relation(dataset.absolute_time)
+        if self.is_time_relative() and dataset.is_time_relative():
+            return self.relative_time.temporal_relation(dataset.relative_time)
         return None
+    def temporal_intersection(self, dataset):
+        """!Intersect self with the provided datasetand
+           return a new temporal extent with the new start and end time
+           @param dataset The abstract dataset to temporal intersect with
+           @return The new temporal extent with start and end time,
+                   or None in case of no intersection
+            return self.absolute_time.intersect(dataset.absolute_time)
+            return self.relative_time.intersect(dataset.relative_time)
+        return None
 class AbstractDatasetComparisonKeyStartTime(object):
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -19,7 +19,6 @@
 class AbstractSpaceTimeDataset(AbstractDataset):
     """!Abstract space time dataset class
@@ -1079,7 +1078,142 @@
             dbif.close()
         return rows
+    def shift(self, gran, dbif=None):
+        """!Temporally shift each registered map with the provided granularity
+           @param gran The granularity to be used for shifting
+           @param dbif The database interface to be used
+           @return True something to shift, False nothing to shift or wrong granularity
+        if not check_granularity_string(gran, self.get_temporal_type()):
+            self.error(_("Wrong granularity format: %s"%(gran)))
+            return False
+        dbif, connected = init_dbif(dbif)
+        maps = self.get_registered_maps_as_objects(dbif=dbif)
+        if maps is None:
+            return False
+        date_list = []
+        # We need to make a dry run to avoid a break
+        # in the middle of the update process when the increment
+        # results in wrong number of days in a month
+        for map in maps:
+            start, end = map.get_valid_time()
+            if self.is_time_absolute():
+                start = increment_datetime_by_string(start, gran)
+                if end is not None:
+                    end = increment_datetime_by_string(end, gran)
+            elif self.is_time_relative():
+                start = start + int(gran)
+                    end = end + int(gran)
+            date_list.append((start, end))
+        self. _update_map_timestamps(maps, date_list, dbif)
+        if connected:
+            dbif.close()
+        return True
+    def snap(self, dbif=None):
+        """!For each registered map snap the end time to the start time of its
+           temporal nearest neighbor in the future
+           Maps with equal time stamps are not snapped
+        if maps is None:
+            return
+        date_list = []
+        for i in range(len(maps) - 1):
+            start, end = maps[i].get_valid_time()
+            start_next, end = maps[i + 1].get_valid_time()
+            # Maps with equal time stamps can not be snapped
+            if start != start_next:
+                date_list.append((start, start_next))
+            else:
+                # Keep the original time stamps
+        # Last map
+        start, end = maps[-1].get_valid_time()
+        # We increment the start time with the dataset
+        # granularity if the end time is None
+        if end is None:
+                end =  increment_datetime_by_string(start, self.get_granularity())
+                end = start + self.get_granularity()
+        if connected:
+            dbif.close()
+    def _update_map_timestamps(self, maps, date_list, dbif):
+        """!Update the timestamps of maps with the start and end time
+           stored in the date_list.
+           The number of dates in the list must be equal to the number
+           of maps.
+           @param maps A list of map objects
+           @param date_list A list with date tuples (start_time, end_time)
+        datatsets_to_modify = {}
+        # Now update the maps
+        count = 0
+        for map in maps:
+            start = date_list[count][0]
+            end   = date_list[count][1]
+            map.select(dbif)
+            count += 1
+                map.update_absolute_time(start_time=start, end_time=end, dbif=dbif)
+                map.update_relative_time(start_time=start, end_time=end,
+                                         unit=self.get_relative_time_unit(), dbif=dbif)
+            # Save the datasets that must be updated
+            datasets = map.get_registered_datasets(dbif)
+            if datasets:
+                for dataset in datasets:
+                    datatsets_to_modify[dataset["id"]] = dataset["id"]
+        self.update_from_registered_maps(dbif)
+        # Update affected datasets
+        if datatsets_to_modify:
+            for dataset in datatsets_to_modify:
+                if dataset != self.get_id():
+                    ds = self.get_new_instance(ident=dataset)
+                    ds.select(dbif)
+                    ds.update_from_registered_maps(dbif)
     def rename(self, ident, dbif=None):
         """!Rename the space time dataset
Modified: grass/trunk/lib/python/temporal/create.py
--- grass/trunk/lib/python/temporal/create.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/create.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -23,6 +23,7 @@
 from space_time_datasets import *
+from factory import *
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/datetime_math.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -186,7 +186,12 @@
         if residual_months == 0:
             residual_months = 1
-        dt1 = dt1.replace(year=year + years_to_add, month=residual_months)
+        try:
+            dt1 = dt1.replace(year=year + years_to_add, month=residual_months)
+        except:
+            core.fatal(_("Unable to increment the datetime %s. "\
+                         "Please check that the yearly or monthly increment does not result in wrong number of days."%(mydate)))
         tdelta_months = dt1 - mydate
     if years > 0:
Modified: grass/trunk/lib/python/temporal/gui_support.py
--- grass/trunk/lib/python/temporal/gui_support.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/gui_support.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -14,6 +14,7 @@
Modified: grass/trunk/lib/python/temporal/list.py
--- grass/trunk/lib/python/temporal/list.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/list.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -23,6 +23,7 @@
Modified: grass/trunk/lib/python/temporal/pythontemporallib.dox
--- grass/trunk/lib/python/temporal/pythontemporallib.dox	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/pythontemporallib.dox	2013-04-20 13:08:00 UTC (rev 55928)
@@ -204,6 +204,37 @@
 \endcode
+\subsevtion PythonTGISExamplesShifting Temporal shifting
+\code
+import grass.script as grass
+import grass.temporal as tgis
+id="test at PERMANENT"
+type="strds"
+# Make sure the temporal database exists
+tgis.init()
+dbif = tgis.SQLDatabaseInterfaceConnection()
+dbif.connect()
+stds = tgis.dataset_factory(type, id)
+if stds.is_in_db(dbif) == False:
+    dbif.close()
+    grass.fatal(_("Space time dataset <%s> not found in temporal database") % (id))
+stds.select(dbif=dbif)
+stds.snap(dbif=dbif)
+stds.update_command_string(dbif=dbif)
+dbif.close()
+\endcode
 \section PythonTGISAuthors Authors
 Soeren Gebbert
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/register.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -23,6 +23,7 @@
Modified: grass/trunk/lib/python/temporal/sampling.py
--- grass/trunk/lib/python/temporal/sampling.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/sampling.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -23,6 +23,7 @@
Modified: grass/trunk/lib/python/temporal/stds_export.py
--- grass/trunk/lib/python/temporal/stds_export.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/stds_export.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -32,8 +32,10 @@
 import os
 import tarfile
 import tempfile
-from space_time_datasets_tools import *
+from space_time_datasets import *
 proj_file_name = "proj.txt"
 init_file_name = "init.txt"
 metadata_file_name = "metadata.txt"
Modified: grass/trunk/lib/python/temporal/stds_import.py
--- grass/trunk/lib/python/temporal/stds_import.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/stds_import.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -39,9 +39,13 @@
 import tempfile
 import time
 import filecmp
-import space_time_datasets_tools
+import core
+from register import *
+import factory
 list_file_name = "list.txt"
@@ -249,7 +253,7 @@
     try:
-        space_time_datasets_tools.init()
+        factory.init()
         fs = "|"
         maplist = []
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/temporal_extent.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -83,6 +83,119 @@
         self.set_start_time(start_time)
         self.set_end_time(end_time)
+    def intersect(self, extent):
+        """!Intersect this temporal extent with the provided temporal extent and
+           @param extent The temporal extent to intersect with
+           Usage:
+           @code
+           >>> A = AbstractTemporalExtent(start_time=5, end_time=6 )
+           >>> inter = A.intersect(A)
+           >>> inter.print_info()
+            | Start time:................. 5
+            | End time:................... 6
+           >>> B = AbstractTemporalExtent(start_time=5, end_time=7 )
+           >>> inter = A.intersect(B)
+           >>> inter = B.intersect(A)
+           >>> A = AbstractTemporalExtent(start_time=3, end_time=6 )
+           >>> A = AbstractTemporalExtent(start_time=3, end_time=8 )
+           >>> B = AbstractTemporalExtent(start_time=5, end_time=6 )
+           >>> A = AbstractTemporalExtent(start_time=5, end_time=8 )
+           >>> B = AbstractTemporalExtent(start_time=3, end_time=6 )
+           >>> A = AbstractTemporalExtent(start_time=5, end_time=None )
+            | End time:................... None
+           >>> B = AbstractTemporalExtent(start_time=3, end_time=4 )
+           >>> print inter
+           None
+           >>> B = AbstractTemporalExtent(start_time=3, end_time=None )
+           >>> print inter
+           None
+           @endcode
+        relation = self.temporal_relation(extent)
+        if relation == "after" or relation == "before":
+            return None
+        if self.D["end_time"] is None:
+            return AbstractTemporalExtent(start_time=self.D["start_time"])
+        if extent.D["end_time"] is None:
+            return AbstractTemporalExtent(start_time=extent.D["start_time"])
+        start = None
+        end = None
+        if self.D["start_time"] > extent.D["start_time"]:
+            start = self.D["start_time"]
+        else:
+            start = extent.D["start_time"]
+        if self.D["end_time"] > extent.D["end_time"]:
+            end = extent.D["end_time"]
+        else:
+            end = self.D["end_time"]
+        return AbstractTemporalExtent(start_time=start, end_time=end)
     def starts(self, extent):
         """!Return True if this temporal extent (A) starts at the start of the
            provided temporal extent (B) and finishes within it
@@ -91,7 +204,7 @@
            B  |---------|
            @endverbatim
-           @param extent: The temporal extent object with which this extent starts
+           @param extent The temporal extent object with which this extent starts
            Usage:
@@ -123,7 +236,7 @@
            B  |-----|
            @endverbatim
-           @param extent: The temporal extent object with which this extent started
+           @param extent The temporal extent object with which this extent started
            Usage:
@@ -155,7 +268,7 @@
            B  |---------|
            @endverbatim
-           @param extent: The temporal extent object with which this extent finishes
+           @param extent The temporal extent object with which this extent finishes
            Usage:
@@ -187,7 +300,7 @@
            B      |-----|
            @endverbatim
            Usage:
@@ -219,7 +332,7 @@
            B  |---------|
            @endverbatim
-           @param extent: The temporal extent object that is located before this extent
+           @param extent The temporal extent object that is located before this extent
            Usage:
@@ -253,7 +366,7 @@
            B             |---------|
            @endverbatim
-           @param extent: The temporal extent object that is located after this extent
+           @param extent The temporal extent object that is located after this extent
            Usage:
@@ -289,7 +402,7 @@
            B            |---------|
            @endverbatim
-           @param extent: The temporal extent object that is a meeting neighbor
+           @param extent The temporal extent object that is a meeting neighbor
                           of this extent
            Usage:
@@ -328,7 +441,7 @@
            B  |---------|
            @endverbatim
-           @param extent: The temporal extent object that is the predecessor
+           @param extent The temporal extent object that is the predecessor
                           of this extent
            Usage:
@@ -360,7 +473,7 @@
            B            |---------|
            @endverbatim
-           @param extent: The temporal extent object that is the successor
+           @param extent The temporal extent object that is the successor
                           of this extent
            Usage:
@@ -392,7 +505,7 @@
            B  |---------|
            @endverbatim
-           @param extent: The temporal extent object that contains this extent
+           @param extent The temporal extent object that contains this extent
            Usage:
@@ -433,7 +546,7 @@
            B   |-------|
            @endverbatim
                           during this extent
            Usage:
@@ -475,7 +588,7 @@
            B  |---------|
            @endverbatim
-           @param extent: The temporal extent object that is equal
+           @param extent The temporal extent object that is equal
                           during this extent
            Usage:
@@ -513,7 +626,7 @@
            A  |---------|
            B    |---------|
            @endverbatim
-           @param extent: The temporal extent object that is overlaps
+           @param extent The temporal extent object that is overlaps
                           this extent
            Usage:
@@ -547,7 +660,7 @@
            B  |---------|
            @endverbatim
-           @param extent: The temporal extent object that is overlapped
+           @param extent The temporal extent object that is overlapped
                           this extent
            Usage:
@@ -594,7 +707,7 @@
                - follows
                - precedes
            @return The name of the temporal relation or None if no relation found
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/lib/python/temporal/univar_statistics.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -23,7 +23,8 @@
 @author Soeren Gebbert
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/temporal/Makefile	2013-04-20 13:08:00 UTC (rev 55928)
@@ -29,6 +29,8 @@
 	t.rast3d.mapcalc \
 	t.rast3d.univar \
 	t.rename \
+	t.snap \
+	t.shift \
 	t.vect.list \
 	t.vect.db.select \
 	t.vect.export \
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/temporal/t.info/t.info.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -64,7 +64,7 @@
     tgis.init()
     if system and not shellstyle:
         #      0123456789012345678901234567890
         print " +------------------- Temporal DBMI backend information ----------------------+"
@@ -80,7 +80,7 @@
         print "dbmi_init_string=" + str(tgis.get_temporal_dbmi_init_string())
         print "sql_template_path=" + str(tgis.get_sql_template_path())
         return
     if not system and not name:
         grass.fatal(_("Please specify %s=") % ("name"))
Added: grass/trunk/temporal/t.shift/Makefile
--- grass/trunk/temporal/t.shift/Makefile	                        (rev 0)
+++ grass/trunk/temporal/t.shift/Makefile	2013-04-20 13:08:00 UTC (rev 55928)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.shift
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.shift/t.shift.html
--- grass/trunk/temporal/t.shift/t.shift.html	                        (rev 0)
+++ grass/trunk/temporal/t.shift/t.shift.html	2013-04-20 13:08:00 UTC (rev 55928)
@@ -0,0 +1,188 @@
+<h2>DESCRIPTION</h2>
+<em>t.shift</em> is designed to temporally shift all registered maps in a space time dataset
+with a user defined granularity. Raster, 3D raster and vector space time datasets are supported.
+<p>
+The format of the absolute time granularity is "number unit". Number is an integer, unit is the temporal
+unit that can be one of year(s), month(s), week(s), day(s), hour(s), minute(s) or second(s).
+<p>
+The granularity in case of relative time is an integer. The temporal unit is the unit of the space time dataset
+and can not be modified.
+<h2>Note</h2>
+Be careful when shifting space time datasets with absolute time.
+The temporal granularity may change if you shift a space time dataset with a unit that is
+different from the space time dataset granularity. Be aware that the shifting with months and years
+may result in incorrect days per month. Shifting the date 20012-03-31 with a granularity
+of one month will result in 2012-04-31 which is incorrect. In this case an error will raise
+and the shifting will not performed for the whole dataset.
+<p>
+You can use the extraction module to shift only a subset of maps from a space time dataset.
+Be aware that the shifting of maps affect all space time datasets in which they are registered.
+<h2>EXAMPLE</h2>
+We create 6 raster maps and register them in a space time raster dataset using an increment of one day.
+Then we shift the time intervals with a granularity of 12 hours.
+<div class="code"><pre>
+r.mapcalc expr="prec_1 = rand(0, 550)"
+r.mapcalc expr="prec_2 = rand(0, 450)"
+r.mapcalc expr="prec_3 = rand(0, 320)"
+r.mapcalc expr="prec_4 = rand(0, 510)"
+r.mapcalc expr="prec_5 = rand(0, 300)"
+r.mapcalc expr="prec_6 = rand(0, 650)"
+t.create type=strds temporaltype=absolute \
+         output=precipitation_daily \
+         title="Daily precipitation" \
+         description="Test dataset with daily precipitation"
+t.register -i type=rast input=precipitation_daily \
+           maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 \
+           start=2012-01-01 increment="1 day"
+t.info type=strds input=precipitation_daily
+ +-------------------- Space Time Raster Dataset -----------------------------+
+ +-------------------- Basic information -------------------------------------+
+ | Id: ........................ precipitation_daily at soeren
+ | Name: ...................... precipitation_daily
+ | Mapset: .................... soeren
+ | Creator: ................... soeren
+ | Creation time: ............. 2013-04-20 14:41:55.392394
+ | Temporal type: ............. absolute
+ | Semantic type:.............. mean
+ +-------------------- Absolute time -----------------------------------------+
+ | Start time:................. 2012-01-01 00:00:00
+ | End time:................... 2012-01-07 00:00:00
+ | Granularity:................ 1 day
+ | Temporal type of maps:...... interval
+ +-------------------- Spatial extent ----------------------------------------+
+ | North:...................... 80.0
+ | South:...................... 0.0
+ | East:.. .................... 120.0
+ | West:....................... 0.0
+ | Top:........................ 0.0
+ | Bottom:..................... 0.0
+ +-------------------- Metadata information ----------------------------------+
+ | Number of registered maps:.. 6
+ | Title:
+ | Daily precipitation
+ | Description:
+ | Test dataset with daily precipitation
+ | Commands of creation:
+ | - 2013-04-20 14:41:55 -
+ | t.create type="strds" temporaltype="absolute"
+ |     output="precipitation_daily" title="Daily precipitation"
+ |     description="Test dataset with daily precipitation"
+ | t.register -i type="rast"
+ |     input="precipitation_daily"
+ |     maps="prec_1,prec_2,prec_3,prec_4,prec_5,prec_6" start="2012-01-01"
+ |     increment="1 day"
+ | North-South resolution min:. 10.0
+ | North-South resolution max:. 10.0
+ | East-west resolution min:... 10.0
+ | East-west resolution max:... 10.0
+ | Minimum value min:.......... 0.0
+ | Minimum value max:.......... 0.0
+ | Maximum value min:.......... 296.0
+ | Maximum value max:.......... 648.0
+ | Raster register table:...... precipitation_daily_soeren_raster_register
+t.rast.list input=precipitation_daily
+prec_1  soeren  2012-01-01 00:00:00 2012-01-02 00:00:00
+prec_2  soeren  2012-01-02 00:00:00 2012-01-03 00:00:00
+prec_3  soeren  2012-01-03 00:00:00 2012-01-04 00:00:00
+prec_4  soeren  2012-01-04 00:00:00 2012-01-05 00:00:00
+prec_5  soeren  2012-01-05 00:00:00 2012-01-06 00:00:00
+prec_6  soeren  2012-01-06 00:00:00 2012-01-07 00:00:00
+t.shift type=strds input=precipitation_daily granularity="12 hours"
+ | Start time:................. 2012-01-01 12:00:00
+ | End time:................... 2012-01-07 12:00:00
+ | Granularity:................ 24 hours
+ | Title:
+ | Description:
+ | - 2013-04-20 14:42:21 -
+ | t.shift type="strds" input="precipitation_daily"
+ |     granularity="12 hours"
+prec_1  soeren  2012-01-01 12:00:00 2012-01-02 12:00:00
+prec_2  soeren  2012-01-02 12:00:00 2012-01-03 12:00:00
+prec_3  soeren  2012-01-03 12:00:00 2012-01-04 12:00:00
+prec_4  soeren  2012-01-04 12:00:00 2012-01-05 12:00:00
+prec_5  soeren  2012-01-05 12:00:00 2012-01-06 12:00:00
+prec_6  soeren  2012-01-06 12:00:00 2012-01-07 12:00:00
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="t.create.html">t.create</a>,
+<a href="t.register.html">t.register</a>,
+<a href="t.snap.html">t.snap</a>
+</em>
+<h2>AUTHOR</h2>
+Sören Gebbert
+<p><i>Last changed: $Date: 2013-01-22 14:44:08 +0100 (Di, 22. Jan 2013) $</i>
Added: grass/trunk/temporal/t.shift/t.shift.py
--- grass/trunk/temporal/t.shift/t.shift.py	                        (rev 0)
+++ grass/trunk/temporal/t.shift/t.shift.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -0,0 +1,89 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:	t.shift
+# AUTHOR(S):	Soeren Gebbert
+# PURPOSE:	Temporally shift the maps of a space time dataset.
+# COPYRIGHT:	(C) 2013 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (version 2). Read the file COPYING that comes with GRASS
+#		for details.
+#%module
+#% description: Temporally shift the maps of a space time dataset.
+#% keywords: temporal
+#% keywords: shift
+#%end
+#%option G_OPT_STDS_INPUT
+#% description: Name of an existing space time dataset
+#%end
+#%option
+#% key: type
+#% type: string
+#% description: Type of the dataset, default is strds (space time raster dataset)
+#% required: no
+#% guidependency: input
+#% guisection: Required
+#% options: strds, str3ds, stvds
+#% answer: strds
+#%end
+#%option
+#% key: granularity
+#% type: string
+#% description: Shift granularity, format absolute time "x years, x months, x weeks, x days, x hours, x minutes, x seconds" or an integer value for relative time
+#% required: yes
+#% multiple: no
+#%end
+def main():
+    name = options["input"]
+    type = options["type"]
+    gran = options["granularity"]
+    # Make sure the temporal database exists
+    tgis.init()
+    dbif = tgis.SQLDatabaseInterfaceConnection()
+    dbif.connect()
+    if name.find("@") >= 0:
+        id = name
+    else:
+        mapset = grass.gisenv()["MAPSET"]
+        id = name + "@" + mapset
+    stds = tgis.dataset_factory(type, id)
+    if stds.is_in_db(dbif) == False:
+        dbif.close()
+    stds.select(dbif)
+    check = stds.shift(gran=gran, dbif=dbif)
+    if check == False:
+        dbif.close()
+        grass.fatal(_("Unable to temporally shift the space time %s dataset <%s>") % \
+                     (stds.get_new_map_instance(None).get_type(), id))
+    stds.update_command_string(dbif=dbif)
+    dbif.close()
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/temporal/t.shift/t.shift.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.shift/test.t.shift.absolue.sh
--- grass/trunk/temporal/t.shift/test.t.shift.absolue.sh	                        (rev 0)
+++ grass/trunk/temporal/t.shift/test.t.shift.absolue.sh	2013-04-20 13:08:00 UTC (rev 55928)
@@ -0,0 +1,45 @@
+#!/bin/sh
+# Space time raster dataset temporal shifting
+# We need to set a specific region in the
+# @preprocess step of this test.
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+# Generate data
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --o type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
+t.register -i --o type=rast input=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 \
+    start="2001-01-01 12:00:00" increment="14 days"
+t.rast.list input=precip_abs
+# The first @test
+t.shift --o input=precip_abs granularity="3 years"
+t.info type=strds input=precip_abs
+t.shift --o input=precip_abs granularity="12 months"
+t.shift --o input=precip_abs granularity="2 days"
+t.shift --o input=precip_abs granularity="3 hours"
+t.shift --o input=precip_abs granularity="30 minutes"
+t.shift --o input=precip_abs granularity="5 seconds"
+# This should give an error because of the monthly increment
+# that will result in wrong number of days in the next month
+t.shift --o input=precip_abs granularity="1 month"
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_abs
Property changes on: grass/trunk/temporal/t.shift/test.t.shift.absolue.sh
Added: grass/trunk/temporal/t.shift/test.t.shift.relative.sh
--- grass/trunk/temporal/t.shift/test.t.shift.relative.sh	                        (rev 0)
+++ grass/trunk/temporal/t.shift/test.t.shift.relative.sh	2013-04-20 13:08:00 UTC (rev 55928)
@@ -0,0 +1,31 @@
+#!/bin/sh
+# Space time raster dataset temporal shifting with relative time
+# Generate data
+t.create --o type=strds temporaltype=relative output=precip_rel title="A test" descr="A test"
+t.register -i --o type=rast unit=days input=precip_rel maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 \
+    start=0 increment=1
+t.info type=strds input=precip_rel
+t.rast.list input=precip_rel
+# The first @test
+t.shift --o input=precip_rel granularity=3
+t.shift --o input=precip_rel granularity=10000
+t.remove type=strds input=precip_rel
Property changes on: grass/trunk/temporal/t.shift/test.t.shift.relative.sh
Added: grass/trunk/temporal/t.snap/Makefile
--- grass/trunk/temporal/t.snap/Makefile	                        (rev 0)
+++ grass/trunk/temporal/t.snap/Makefile	2013-04-20 13:08:00 UTC (rev 55928)
@@ -0,0 +1,7 @@
+PGM = t.snap
Added: grass/trunk/temporal/t.snap/t.snap.html
--- grass/trunk/temporal/t.snap/t.snap.html	                        (rev 0)
+++ grass/trunk/temporal/t.snap/t.snap.html	2013-04-20 13:08:00 UTC (rev 55928)
@@ -0,0 +1,176 @@
+<em>t.snap</em> is designed to convert time instances of maps into time intervals or to
+create valid temporal topologies for space time datasets. Raster, 3D raster and vector space time datasets are supported
+with absolute and relative time.
+<p>
+This module "snaps" the end time of each registered map of a space time dataset to the start time
+of the map that is the temporal nearest neighbour in the future. Maps with equal time stamps
+are not modified and must be removed or modified to create a valid temporal topology.
+In case the last map in the space time dataset is a time instance, the granularity of the space time
+dataset will be used to create the time interval.
+<h2>EXAMPLE</h2>
+We create 6 raster maps and register them using absolute time
+in a space time raster dataset using an increment of one month.
+Then we snap the created time instances resulting in time intervals.
+t.register type=rast input=precipitation_daily \
+ | Creation time: ............. 2013-04-20 14:39:07.136253
+ | End time:................... 2012-01-06 00:00:00
+ | Temporal type of maps:...... point
+ | Title:
+ | Description:
+ | - 2013-04-20 14:39:07 -
+ | t.register type="rast" input="precipitation_daily"
+prec_1  soeren  2012-01-01 00:00:00 None
+prec_2  soeren  2012-01-02 00:00:00 None
+prec_3  soeren  2012-01-03 00:00:00 None
+prec_4  soeren  2012-01-04 00:00:00 None
+prec_5  soeren  2012-01-05 00:00:00 None
+prec_6  soeren  2012-01-06 00:00:00 None
+t.snap type=strds input=precipitation_daily
+ | Title:
+ | Description:
+ | - 2013-04-20 14:39:54 -
+ | t.snap type="strds" input="precipitation_daily"
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="t.shift.html">t.shift</a>,
+</em>
+<h2>AUTHOR</h2>
+Sören Gebbert
Added: grass/trunk/temporal/t.snap/t.snap.py
--- grass/trunk/temporal/t.snap/t.snap.py	                        (rev 0)
+++ grass/trunk/temporal/t.snap/t.snap.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -0,0 +1,75 @@
+# MODULE:   t.snap
+# PURPOSE:  Temporally snap the maps of a space time dataset.
+#       for details.
+#%module
+#% description: Temporally snap the maps of a space time dataset.
+#% keywords: snap
+#%end
+#%end
+#%option
+#% key: type
+#% type: string
+#% required: no
+#% answer: strds
+#%end
+def main():
+    tgis.init()
+    dbif.connect()
+        id = name
+    else:
+        dbif.close()
+    stds.select(dbif)
+    stds.snap(dbif=dbif)
+    dbif.close()
+    main()
Property changes on: grass/trunk/temporal/t.snap/t.snap.py
Added: grass/trunk/temporal/t.snap/test.t.snap.absolute.sh
--- grass/trunk/temporal/t.snap/test.t.snap.absolute.sh	                        (rev 0)
+++ grass/trunk/temporal/t.snap/test.t.snap.absolute.sh	2013-04-20 13:08:00 UTC (rev 55928)
@@ -0,0 +1,52 @@
+#!/bin/sh
+# Space time raster dataset temporal snapping with absolute time
+# Generate data
+n1=`g.tempfile pid=1 -d`
+cat > "${n1}" << EOF
+prec_1|2001-01-01|2001-07-01
+prec_2|2001-02-01|2001-04-01
+prec_3|2001-03-01|2001-04-01
+prec_4|2001-04-01|2001-06-01
+prec_5|2001-05-01|2001-06-01
+prec_6|2001-06-01|2001-07-01
+EOF
+t.register --o type=rast input=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 \
+# The first @test
+t.snap --o input=precip_abs
+# The second @test
+# Creating a valid topology
+t.register --o type=rast input=precip_abs file=${n1}
+t.topology input=precip_abs
Property changes on: grass/trunk/temporal/t.snap/test.t.snap.absolute.sh
Added: grass/trunk/temporal/t.snap/test.t.snap.relative.sh
--- grass/trunk/temporal/t.snap/test.t.snap.relative.sh	                        (rev 0)
+++ grass/trunk/temporal/t.snap/test.t.snap.relative.sh	2013-04-20 13:08:00 UTC (rev 55928)
@@ -0,0 +1,29 @@
+#!/bin/sh
+# Space time raster dataset temporal snapping with relative time
+# Generate data
+t.register --o type=rast input=precip_rel unit="days" \
+    start=0 increment=14
+# The first @test
+t.snap --o input=precip_rel
Property changes on: grass/trunk/temporal/t.snap/test.t.snap.relative.sh
Modified: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py	2013-04-20 09:40:13 UTC (rev 55927)
+++ grass/trunk/temporal/t.topology/t.topology.py	2013-04-20 13:08:00 UTC (rev 55928)
@@ -5,7 +5,7 @@
 # MODULE:	t.topology
-# PURPOSE:	List and modify temporal topology of a space time dataset
+# PURPOSE:	List temporal topology of a space time dataset
 # COPYRIGHT:	(C) 2011 by the GRASS Development Team
@@ -15,7 +15,7 @@
 #%module
-#% description: Lists and modifies temporal topology of a space time dataset.
+#% description: Lists temporal topology of a space time dataset.
 #% keywords: topology
 #%end
@@ -33,7 +33,7 @@
 #%flag
 #% key: m
-#% description: Print temporal relation matrix and exit
+#% description: Print temporal relationships and exit
 #%end
