[GRASS-SVN] r55945 - grass/trunk/lib/python/pygrass/vector
    svn_grass at osgeo.org
    Mon Apr 22 08:48:44 PDT 2013
Author: zarch
Date: 2013-04-22 08:48:44 -0700 (Mon, 22 Apr 2013)
New Revision: 55945
   grass/trunk/lib/python/pygrass/vector/__init__.py
Fix if set_cats is True reset the previous cat values and set the new one.
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py	2013-04-22 15:31:32 UTC (rev 55944)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py	2013-04-22 15:48:44 UTC (rev 55945)
@@ -15,7 +15,7 @@
 from geometry import GEOOBJ as _GEOOBJ
 from geometry import read_line, read_next_line
 from abstract import Info
-from basic import Bbox
+from basic import Bbox, Cats
 _NUMOF = {"areas": libvect.Vect_get_num_areas,
@@ -183,7 +183,9 @@
             cur.close()
         if set_cats:
-            libvect.Vect_cat_set(geo_obj.c_cats, self.layer, self.n_lines)
+            cats = Cats(geo_obj.c_cats)
+            cats.reset()
+            cats.set(self.n_lines, self.layer)
         result = libvect.Vect_write_line(self.c_mapinfo, geo_obj.gtype,
                                          geo_obj.c_points, geo_obj.c_cats)
         if result == -1:
