[GRASS-SVN] r55953 - grass/trunk/lib/python/pygrass/raster
svn_grass at osgeo.org
Tue Apr 23 03:46:47 PDT 2013
Author: zarch
Date: 2013-04-23 03:46:47 -0700 (Tue, 23 Apr 2013)
New Revision: 55953
grass/trunk/lib/python/pygrass/raster/__init__.py
grass/trunk/lib/python/pygrass/raster/abstract.py
Add the *with statement* to the Raster classes and add an example in the docstring.
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py 2013-04-23 10:45:23 UTC (rev 55952)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py 2013-04-23 10:46:47 UTC (rev 55953)
@@ -34,8 +34,6 @@
from buffer import Buffer
from segment import Segment
from rowio import RowIO
-from category import Category
-from history import History
class RasterRow(RasterAbstractBase):
@@ -101,7 +99,18 @@
('bare ground path', 10, None),
('grass', 11, None)]
+ Open a raster map using the *with statement*: ::
+ >>> with RasterRow('elevation') as elev:
+ ... for row in elev[:3]:
+ ... print row[:4]
+ [ 141.99613953 141.27848816 141.37904358 142.29821777]
+ [ 142.90461731 142.39450073 142.68611145 143.59086609]
+ [ 143.81854248 143.54707336 143.83972168 144.59527588]
+ >>> elev.is_open()
+ False
def __init__(self, name, mapset='', *args, **kargs):
super(RasterRow, self).__init__(name, mapset, *args, **kargs)
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py 2013-04-23 10:45:23 UTC (rev 55952)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py 2013-04-23 10:46:47 UTC (rev 55953)
@@ -4,19 +4,12 @@
@author: pietro
import ctypes
-from numpy import isnan
# import GRASS modules
-from grass.script import fatal, warning, gisenv
-from grass.script import core as grasscore
-#from grass.script import core
-#import grass.lib as grasslib
+from grass.script import fatal, gisenv
import grass.lib.gis as libgis
import grass.lib.raster as libraster
@@ -26,7 +19,7 @@
from grass.pygrass import functions
from grass.pygrass.gis.region import Region
from grass.pygrass.errors import must_be_open
-from grass.pygrass.gis import Mapset
# import raster classes
@@ -194,7 +187,13 @@
if self.exist():
self.info = Info(self.name, self.mapset)
+ def __enter__(self):
+ self.open('r')
+ return self
+ def __exit__(self, exc_type, exc_value, traceback):
+ self.close()
def _get_mtype(self):
"""Private method to get the Raster type"""
return self._mtype
