[GRASS-SVN] r55954 - grass/branches/develbranch_6/lib/init
svn_grass at osgeo.org
Tue Apr 23 05:32:07 PDT 2013
Author: hamish
Date: 2013-04-23 05:32:07 -0700 (Tue, 23 Apr 2013)
New Revision: 55954
grass/branches/develbranch_6/lib/init/init.sh
bugfix:"C:\" was making it into the unix vesion of the $PATH, where : is the field sep., causing a bad path name and breakage of the addons
Modified: grass/branches/develbranch_6/lib/init/init.sh
--- grass/branches/develbranch_6/lib/init/init.sh 2013-04-23 10:46:47 UTC (rev 55953)
+++ grass/branches/develbranch_6/lib/init/init.sh 2013-04-23 12:32:07 UTC (rev 55954)
@@ -252,6 +252,12 @@
fi
fi
+# in case of fire, break glass
+dos2unix_path()
+ echo "$1" | sed -e 's|^\([A-Za-z]\):|/\1|' -e 's|\\|/|g'
# Set PATH to GRASS bin, ETC to GRASS etc
ETC="$GISBASE/etc"
@@ -266,12 +272,13 @@
# if it doesn't exist set it to something so that g.extension's default is reasonable
if [ -z "$GRASS_ADDON_PATH" ] ; then
if [ "$MINGW" ] ; then
- GRASS_ADDON_PATH="$APPDATA/GRASS6/addons"
+ APPDATA_UNIX=`dos2unix_path "$APPDATA"`
+ GRASS_ADDON_PATH="$APPDATA_UNIX/GRASS6/addons"
else
GRASS_ADDON_PATH="$HOME/.grass6/addons"
fi
+ export GRASS_ADDON_PATH
fi
-export GRASS_ADDON_PATH
PATH="$GISBASE/bin:$GISBASE/scripts:$GRASS_ADDON_PATH:$PATH"
export PATH
