[GRASS-SVN] r55961 - grass/trunk
svn_grass at osgeo.org
Tue Apr 23 19:34:57 PDT 2013
Author: hamish
Date: 2013-04-23 19:34:57 -0700 (Tue, 23 Apr 2013)
New Revision: 55961
grass/trunk/configure
grass/trunk/configure.in
the first arg of LOC_CHECK_LIB_PATH() needs to match the --with-xx-libs= line (#1943)
Modified: grass/trunk/configure
--- grass/trunk/configure 2013-04-23 23:29:57 UTC (rev 55960)
+++ grass/trunk/configure 2013-04-24 02:34:57 UTC (rev 55961)
@@ -13126,15 +13126,15 @@
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
echo "configure:13129: checking for location of OpenCL library" >&5
-case "$with_OpenCL_libs" in
+case "$with_opencl_libs" in
y | ye | yes | n | no)
- { echo "configure: error: *** You must supply a directory to --with-OpenCL-libs." 1>&2; exit 1; }
+ { echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
esac
-echo "$ac_t""$with_OpenCL_libs" 1>&6
+echo "$ac_t""$with_opencl_libs" 1>&6
-if test -n "$with_OpenCL_libs"; then
- for dir in $with_OpenCL_libs; do
+if test -n "$with_opencl_libs"; then
+ for dir in $with_opencl_libs; do
if test -d "$dir"; then
OCLLIBPATH="$OCLLIBPATH -L$dir"
else
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2013-04-23 23:29:57 UTC (rev 55960)
+++ grass/trunk/configure.in 2013-04-24 02:34:57 UTC (rev 55961)
@@ -1774,7 +1774,7 @@
# With OpenCL library directory
-LOC_CHECK_LIB_PATH(OpenCL,OpenCL,OCLLIBPATH)
+LOC_CHECK_LIB_PATH(opencl,OpenCL,OCLLIBPATH)
# FIXME: -L${OCLLIBPATH} is not being added to the gcc conftest.c command. why not? (trac #1943?)
LOC_CHECK_LIBS(OpenCL,clGetPlatformInfo,OpenCL,$OCLLIBPATH,OCLLIB,,,)
