[GRASS-SVN] r55962 - grass/trunk
svn_grass at osgeo.org
Tue Apr 23 19:45:33 PDT 2013
Author: hamish
Date: 2013-04-23 19:45:33 -0700 (Tue, 23 Apr 2013)
New Revision: 55962
grass/trunk/configure
grass/trunk/configure.in
more fixes related to #1943
Modified: grass/trunk/configure
--- grass/trunk/configure 2013-04-24 02:34:57 UTC (rev 55961)
+++ grass/trunk/configure 2013-04-24 02:45:33 UTC (rev 55962)
@@ -12823,15 +12823,15 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
echo "configure:12826: checking for location of OpenMP library" >&5
-case "$with_gomp_libs" in
+case "$with_openmp_libs" in
y | ye | yes | n | no)
- { echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
+ { echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
esac
-echo "$ac_t""$with_gomp_libs" 1>&6
+echo "$ac_t""$with_openmp_libs" 1>&6
-if test -n "$with_gomp_libs"; then
- for dir in $with_gomp_libs; do
+if test -n "$with_openmp_libs"; then
+ for dir in $with_openmp_libs; do
if test -d "$dir"; then
OMPLIBPATH="$OMPLIBPATH -L$dir"
else
@@ -13143,8 +13143,8 @@
done
fi
-# FIXME: -L${OCLLIBPATH} is not being added to the gcc conftest.c command. why not? (trac #1943?)
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$OCLLIBPATH $LDFLAGS"
@@ -13196,7 +13196,6 @@
LDFLAGS=${ac_save_ldflags}
# expanded symbol check: yes? no?
#LOC_CHECK_FUNC(clGetPlatformInfo,OpenCL functions,OCLLIB,,,,,[
#LOC_CHECK_LIBS(OpenCL,clGetPlatformInfo,OpenCL,$OCLLIBPATH,OCLLIB,,,)
@@ -13221,7 +13220,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13225: checking for special C compiler options needed for large files" >&5
+echo "configure:13224: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13229,7 +13228,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
cat > conftest.$ac_ext <<EOF
-#line 13233 "configure"
+#line 13232 "configure"
#include "confdefs.h"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13245,7 +13244,7 @@
; return 0; }
EOF
-if { (eval echo configure:13249: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13248: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -13254,7 +13253,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13258 "configure"
+#line 13257 "configure"
@@ -13270,7 +13269,7 @@
; return 0; }
EOF
-if { (eval echo configure:13274: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13273: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13290,11 +13289,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13294: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13293: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13298 "configure"
+#line 13297 "configure"
@@ -13310,14 +13309,14 @@
; return 0; }
EOF
-if { (eval echo configure:13314: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13313: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 13321 "configure"
+#line 13320 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13335,7 +13334,7 @@
; return 0; }
EOF
-if { (eval echo configure:13339: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13338: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13354,11 +13353,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13358: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13357: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13362 "configure"
+#line 13361 "configure"
@@ -13374,14 +13373,14 @@
; return 0; }
EOF
-if { (eval echo configure:13378: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13377: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13385 "configure"
+#line 13384 "configure"
#define _LARGE_FILES 1
@@ -13399,7 +13398,7 @@
; return 0; }
EOF
-if { (eval echo configure:13403: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13402: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13418,25 +13417,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13422: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13421: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13426 "configure"
+#line 13425 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13433: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13432: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13440 "configure"
+#line 13439 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13445,7 +13444,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13449: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13448: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13466,25 +13465,25 @@
fi
-echo "configure:13470: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13469: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13474 "configure"
+#line 13473 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13481: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13480: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13488 "configure"
+#line 13487 "configure"
#include <stdio.h>
@@ -13493,7 +13492,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13497: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13496: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13516,18 +13515,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13520: checking for fseeko" >&5
+echo "configure:13519: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13524 "configure"
+#line 13523 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13544,10 +13543,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13548: checking if system supports Large Files at all" >&5
+echo "configure:13547: checking if system supports Large Files at all" >&5
-#line 13551 "configure"
+#line 13550 "configure"
#include <stdio.h>
@@ -13579,7 +13578,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13583: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13582: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13608,7 +13607,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13612: checking whether to use wxWidgets" >&5
+echo "configure:13611: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13629,7 +13628,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13633: checking for $ac_word" >&5
+echo "configure:13632: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13677,7 +13676,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13681: checking wxWidgets version" >&5
+echo "configure:13680: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13700,15 +13699,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13704: checking for $ac_hdr" >&5
+echo "configure:13703: checking for $ac_hdr" >&5
-#line 13707 "configure"
+#line 13706 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13712: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13711: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2013-04-24 02:34:57 UTC (rev 55961)
+++ grass/trunk/configure.in 2013-04-24 02:45:33 UTC (rev 55962)
@@ -1714,7 +1714,7 @@
# AIX xlc: -lxlsmp
# SGI IRIX 6.5 MIPSpro C/C++: -lmp
-LOC_CHECK_LIB_PATH(gomp,OpenMP,OMPLIBPATH)
+LOC_CHECK_LIB_PATH(openmp,OpenMP,OMPLIBPATH)
LOC_CHECK_FUNC(GOMP_parallel_start,OpenMP functions,OMPLIB,,,,,[
LOC_CHECK_LIBS(gomp,GOMP_parallel_start,OpenMP,$OMPLIBPATH,OMPLIB,,,)
@@ -1775,9 +1775,8 @@
# With OpenCL library directory
LOC_CHECK_LIB_PATH(opencl,OpenCL,OCLLIBPATH)
-LOC_CHECK_LIBS(OpenCL,clGetPlatformInfo,OpenCL,$OCLLIBPATH,OCLLIB,,,)
+LOC_CHECK_LIBS(OpenCL,clGetPlatformInfo,OpenCL,$OCLLIBPATH,OCLLIB,,,)
