[GRASS-SVN] r56003 - grass/trunk
svn_grass at osgeo.org
Thu Apr 25 23:44:22 PDT 2013
Author: hamish
Date: 2013-04-25 23:44:22 -0700 (Thu, 25 Apr 2013)
New Revision: 56003
grass/trunk/configure
grass/trunk/configure.in
OpenCL on Mac uses '-framework OpenCL' instead of libOpenCL.so, try to make that work (#1446)
Modified: grass/trunk/configure
--- grass/trunk/configure 2013-04-26 03:19:07 UTC (rev 56002)
+++ grass/trunk/configure 2013-04-26 06:44:22 UTC (rev 56003)
@@ -2320,6 +2320,7 @@
fi
+#LOC_ARG_WITH_FRAMEWORK(opencl, OpenCL)
# Put this early on so CPPFLAGS and LDFLAGS have any additional dirs
@@ -2330,7 +2331,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2334: checking for additional include dirs" >&5
+echo "configure:2335: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2353,7 +2354,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2357: checking for additional library dirs" >&5
+echo "configure:2358: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2387,7 +2388,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2391: checking for a BSD compatible install" >&5
+echo "configure:2392: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2440,7 +2441,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:2444: checking for $ac_word" >&5
+echo "configure:2445: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2471,13 +2472,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2475: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2476: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 2481 "configure"
+#line 2482 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2488,7 +2489,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2493: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2513,7 +2514,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2517: checking for $ac_word" >&5
+echo "configure:2518: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2553,7 +2554,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2557: checking for $ac_word" >&5
+echo "configure:2558: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2584,7 +2585,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2588: checking for $ac_word" >&5
+echo "configure:2589: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2622,7 +2623,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2626: checking for $ac_word" >&5
+echo "configure:2627: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2651,7 +2652,7 @@
-echo "configure:2655: checking for $ac_word" >&5
+echo "configure:2656: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2682,7 +2683,7 @@
-echo "configure:2686: checking for $ac_word" >&5
+echo "configure:2687: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2711,7 +2712,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2715: checking for $ac_word" >&5
+echo "configure:2716: checking for $ac_word" >&5
case "$PERL" in
@@ -2742,7 +2743,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2746: checking how to run the C preprocessor" >&5
+echo "configure:2747: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2755,13 +2756,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2759 "configure"
+#line 2760 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2765: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2766: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2772,13 +2773,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2776 "configure"
+#line 2777 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2782: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2783: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2789,13 +2790,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2793 "configure"
+#line 2794 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2799: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2800: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2819,10 +2820,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2823: checking for ANSI C header files" >&5
+echo "configure:2824: checking for ANSI C header files" >&5
-#line 2826 "configure"
+#line 2827 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2830,7 +2831,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2834: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2835: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2847,7 +2848,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2851 "configure"
+#line 2852 "configure"
#include <string.h>
EOF
@@ -2865,7 +2866,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2869 "configure"
+#line 2870 "configure"
#include <stdlib.h>
EOF
@@ -2886,7 +2887,7 @@
else
-#line 2890 "configure"
+#line 2891 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2897,7 +2898,7 @@
exit (0); }
EOF
-if { (eval echo configure:2901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2924,15 +2925,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2928: checking for $ac_hdr" >&5
+echo "configure:2929: checking for $ac_hdr" >&5
-#line 2931 "configure"
+#line 2932 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2936: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2961,15 +2962,15 @@
do
-echo "configure:2965: checking for $ac_hdr" >&5
+echo "configure:2966: checking for $ac_hdr" >&5
-#line 2968 "configure"
+#line 2969 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2973: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2974: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2998,15 +2999,15 @@
do
-echo "configure:3002: checking for $ac_hdr" >&5
+echo "configure:3003: checking for $ac_hdr" >&5
-#line 3005 "configure"
+#line 3006 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3010: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3011: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3035,15 +3036,15 @@
do
-echo "configure:3039: checking for $ac_hdr" >&5
+echo "configure:3040: checking for $ac_hdr" >&5
-#line 3042 "configure"
+#line 3043 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3072,15 +3073,15 @@
do
-echo "configure:3076: checking for $ac_hdr" >&5
+echo "configure:3077: checking for $ac_hdr" >&5
-#line 3079 "configure"
+#line 3080 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3084: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3085: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3106,10 +3107,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3110: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3111: checking whether time.h and sys/time.h may both be included" >&5
-#line 3113 "configure"
+#line 3114 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3118,7 +3119,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3122: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3123: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3138,10 +3139,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3142: checking for off_t" >&5
+echo "configure:3143: checking for off_t" >&5
-#line 3145 "configure"
+#line 3146 "configure"
#if STDC_HEADERS
@@ -3168,10 +3169,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3172: checking for uid_t in sys/types.h" >&5
+echo "configure:3173: checking for uid_t in sys/types.h" >&5
-#line 3175 "configure"
+#line 3176 "configure"
EOF
@@ -3199,10 +3200,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3203: checking return type of signal handlers" >&5
+echo "configure:3204: checking return type of signal handlers" >&5
-#line 3206 "configure"
+#line 3207 "configure"
#include <signal.h>
@@ -3219,7 +3220,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3223: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3224: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3237,10 +3238,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3241: checking for Cygwin environment" >&5
+echo "configure:3242: checking for Cygwin environment" >&5
-#line 3244 "configure"
+#line 3245 "configure"
int main() {
@@ -3251,7 +3252,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3255: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3256: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3269,10 +3270,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3273: checking for $ac_func" >&5
+echo "configure:3274: checking for $ac_func" >&5
-#line 3276 "configure"
+#line 3277 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3295,7 +3296,7 @@
; return 0; }
EOF
-if { (eval echo configure:3299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3321,10 +3322,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3325: checking for $ac_func" >&5
+echo "configure:3326: checking for $ac_func" >&5
-#line 3328 "configure"
+#line 3329 "configure"
@@ -3347,7 +3348,7 @@
; return 0; }
EOF
-if { (eval echo configure:3351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3373,10 +3374,10 @@
for ac_func in drand48
do
-echo "configure:3377: checking for $ac_func" >&5
+echo "configure:3378: checking for $ac_func" >&5
-#line 3380 "configure"
+#line 3381 "configure"
@@ -3399,7 +3400,7 @@
; return 0; }
EOF
-if { (eval echo configure:3403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3425,10 +3426,10 @@
for ac_func in putenv setenv
do
-echo "configure:3429: checking for $ac_func" >&5
+echo "configure:3430: checking for $ac_func" >&5
-#line 3432 "configure"
+#line 3433 "configure"
@@ -3451,7 +3452,7 @@
; return 0; }
EOF
-if { (eval echo configure:3455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3477,10 +3478,10 @@
for ac_func in nanosleep
do
-echo "configure:3481: checking for $ac_func" >&5
+echo "configure:3482: checking for $ac_func" >&5
-#line 3484 "configure"
+#line 3485 "configure"
@@ -3503,7 +3504,7 @@
; return 0; }
EOF
-if { (eval echo configure:3507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3528,13 +3529,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3532: checking whether setpgrp takes no argument" >&5
+echo "configure:3533: checking whether setpgrp takes no argument" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3538 "configure"
+#line 3539 "configure"
#ifdef HAVE_UNISTD_H
@@ -3554,7 +3555,7 @@
EOF
-if { (eval echo configure:3558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3582,16 +3583,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3586: checking for long long int" >&5
+echo "configure:3587: checking for long long int" >&5
-#line 3588 "configure"
+#line 3589 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3595: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3596: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -3611,7 +3612,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3615: checking for W11" >&5
+echo "configure:3616: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3639,7 +3640,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3643: checking for X" >&5
+echo "configure:3644: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3699,12 +3700,12 @@
# First, try using that file with no special directory specified.
-#line 3703 "configure"
+#line 3704 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3708: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3709: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3773,14 +3774,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3777 "configure"
+#line 3778 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3885,17 +3886,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3889: checking whether -R must be followed by a space" >&5
+echo "configure:3890: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3892 "configure"
+#line 3893 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3911,14 +3912,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3915 "configure"
+#line 3916 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3950,13 +3951,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3954: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3955: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3960 "configure"
+#line 3961 "configure"
@@ -3967,7 +3968,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3988,13 +3989,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3992: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3993: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3998 "configure"
+#line 3999 "configure"
@@ -4005,7 +4006,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4033,10 +4034,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4037: checking for gethostbyname" >&5
+echo "configure:4038: checking for gethostbyname" >&5
-#line 4040 "configure"
+#line 4041 "configure"
which can conflict with char gethostbyname(); below. */
@@ -4059,7 +4060,7 @@
; return 0; }
EOF
-if { (eval echo configure:4063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4079,13 +4080,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4083: checking for gethostbyname in -lnsl" >&5
+echo "configure:4084: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4089 "configure"
+#line 4090 "configure"
@@ -4096,7 +4097,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4125,10 +4126,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4129: checking for connect" >&5
+echo "configure:4130: checking for connect" >&5
-#line 4132 "configure"
+#line 4133 "configure"
which can conflict with char connect(); below. */
@@ -4151,7 +4152,7 @@
; return 0; }
EOF
-if { (eval echo configure:4155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4171,13 +4172,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4175: checking for connect in -lsocket" >&5
+echo "configure:4176: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4181 "configure"
+#line 4182 "configure"
@@ -4188,7 +4189,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4211,10 +4212,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4215: checking for remove" >&5
+echo "configure:4216: checking for remove" >&5
-#line 4218 "configure"
+#line 4219 "configure"
which can conflict with char remove(); below. */
@@ -4237,7 +4238,7 @@
; return 0; }
EOF
-if { (eval echo configure:4241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4257,13 +4258,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4261: checking for remove in -lposix" >&5
+echo "configure:4262: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4267 "configure"
+#line 4268 "configure"
@@ -4274,7 +4275,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4297,10 +4298,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4301: checking for shmat" >&5
+echo "configure:4302: checking for shmat" >&5
-#line 4304 "configure"
+#line 4305 "configure"
which can conflict with char shmat(); below. */
@@ -4323,7 +4324,7 @@
; return 0; }
EOF
-if { (eval echo configure:4327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4343,13 +4344,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4347: checking for shmat in -lipc" >&5
+echo "configure:4348: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4353 "configure"
+#line 4354 "configure"
@@ -4360,7 +4361,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4392,13 +4393,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4396: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4397: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4402 "configure"
+#line 4403 "configure"
@@ -4409,7 +4410,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4449,12 +4450,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4453: checking for library containing cuserid" >&5
+echo "configure:4454: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4458 "configure"
+#line 4459 "configure"
@@ -4465,7 +4466,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4476,7 +4477,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4480 "configure"
+#line 4481 "configure"
@@ -4487,7 +4488,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4513,10 +4514,10 @@
for ac_func in asprintf
do
-echo "configure:4517: checking for $ac_func" >&5
+echo "configure:4518: checking for $ac_func" >&5
-#line 4520 "configure"
+#line 4521 "configure"
@@ -4539,7 +4540,7 @@
; return 0; }
EOF
-if { (eval echo configure:4543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4566,10 +4567,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4570: checking for atan" >&5
+echo "configure:4571: checking for atan" >&5
-#line 4573 "configure"
+#line 4574 "configure"
which can conflict with char atan(); below. */
@@ -4592,7 +4593,7 @@
; return 0; }
EOF
-if { (eval echo configure:4596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4610,13 +4611,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4614: checking for atan in -lm" >&5
+echo "configure:4615: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4620 "configure"
+#line 4621 "configure"
@@ -4627,7 +4628,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4654,10 +4655,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4658: checking for dlsym" >&5
+echo "configure:4659: checking for dlsym" >&5
-#line 4661 "configure"
+#line 4662 "configure"
which can conflict with char dlsym(); below. */
@@ -4680,7 +4681,7 @@
; return 0; }
EOF
-if { (eval echo configure:4684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4698,13 +4699,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4702: checking for dlsym in -ldl" >&5
+echo "configure:4703: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4708 "configure"
+#line 4709 "configure"
@@ -4715,7 +4716,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4742,10 +4743,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4746: checking for iconv" >&5
+echo "configure:4747: checking for iconv" >&5
-#line 4749 "configure"
+#line 4750 "configure"
which can conflict with char iconv(); below. */
@@ -4768,7 +4769,7 @@
; return 0; }
EOF
-if { (eval echo configure:4772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4786,13 +4787,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4790: checking for iconv in -liconv" >&5
+echo "configure:4791: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4796 "configure"
+#line 4797 "configure"
@@ -4803,7 +4804,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4822,13 +4823,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4826: checking for iconv in -lgiconv" >&5
+echo "configure:4827: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4832 "configure"
+#line 4833 "configure"
@@ -4839,7 +4840,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4858,10 +4859,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4862: checking for libiconv" >&5
+echo "configure:4863: checking for libiconv" >&5
-#line 4865 "configure"
+#line 4866 "configure"
which can conflict with char libiconv(); below. */
@@ -4884,7 +4885,7 @@
; return 0; }
EOF
-if { (eval echo configure:4888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -4902,13 +4903,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4906: checking for libiconv in -liconv" >&5
+echo "configure:4907: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4912 "configure"
+#line 4913 "configure"
@@ -4919,7 +4920,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4938,13 +4939,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4942: checking for libiconv in -lgiconv" >&5
+echo "configure:4943: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4948 "configure"
+#line 4949 "configure"
@@ -4955,7 +4956,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4992,10 +4993,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4996: checking for socket" >&5
+echo "configure:4997: checking for socket" >&5
-#line 4999 "configure"
+#line 5000 "configure"
which can conflict with char socket(); below. */
@@ -5018,7 +5019,7 @@
; return 0; }
EOF
-if { (eval echo configure:5022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5036,13 +5037,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5040: checking for socket in -lsocket" >&5
+echo "configure:5041: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5046 "configure"
+#line 5047 "configure"
@@ -5053,7 +5054,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5101,7 +5102,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5105: checking for location of zlib includes" >&5
+echo "configure:5106: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5127,15 +5128,15 @@
do
-echo "configure:5131: checking for $ac_hdr" >&5
+echo "configure:5132: checking for $ac_hdr" >&5
-#line 5134 "configure"
+#line 5135 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5139: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5140: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5169,7 +5170,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5173: checking for location of zlib library" >&5
+echo "configure:5174: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5194,13 +5195,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5198: checking for deflate in -lz" >&5
+echo "configure:5199: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5204 "configure"
+#line 5205 "configure"
@@ -5211,7 +5212,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5259,7 +5260,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5263: checking for location of External PROJ.4 includes" >&5
+echo "configure:5264: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5285,15 +5286,15 @@
do
-echo "configure:5289: checking for $ac_hdr" >&5
+echo "configure:5290: checking for $ac_hdr" >&5
-#line 5292 "configure"
+#line 5293 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5298: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5330,7 +5331,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5334: checking External PROJ.4 version" >&5
+echo "configure:5335: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5338,7 +5339,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 5342 "configure"
+#line 5343 "configure"
#include <stdio.h>
@@ -5350,7 +5351,7 @@
EOF
-if { (eval echo configure:5354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5375,7 +5376,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5379: checking for location of External PROJ.4 library" >&5
+echo "configure:5380: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5400,13 +5401,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5404: checking for pj_get_def in -lproj" >&5
+echo "configure:5405: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5410 "configure"
+#line 5411 "configure"
@@ -5417,7 +5418,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5451,7 +5452,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5455: checking for location of External PROJ.4 data files" >&5
+echo "configure:5456: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5475,14 +5476,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5479: checking for epsg" >&5
+echo "configure:5480: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5486: checking for $PROJSHARE/epsg" >&5
+echo "configure:5487: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -5514,7 +5515,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5518: checking for $ac_word" >&5
+echo "configure:5519: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5554,7 +5555,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5558: checking whether to use regex" >&5
+echo "configure:5559: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5574,7 +5575,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5578: checking for location of regex includes" >&5
+echo "configure:5579: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5600,15 +5601,15 @@
do
-echo "configure:5604: checking for $ac_hdr" >&5
+echo "configure:5605: checking for $ac_hdr" >&5
-#line 5607 "configure"
+#line 5608 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5612: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5613: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5642,7 +5643,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5646: checking for location of regex library" >&5
+echo "configure:5647: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5667,10 +5668,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5671: checking for regcomp" >&5
+echo "configure:5672: checking for regcomp" >&5
-#line 5674 "configure"
+#line 5675 "configure"
which can conflict with char regcomp(); below. */
@@ -5693,7 +5694,7 @@
; return 0; }
EOF
-if { (eval echo configure:5697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5720,13 +5721,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5724: checking for regcomp in -lregex" >&5
+echo "configure:5725: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5730 "configure"
+#line 5731 "configure"
@@ -5737,7 +5738,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5787,7 +5788,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5791: checking whether to use Readline" >&5
+echo "configure:5792: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5808,7 +5809,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5812: checking for location of Readline includes" >&5
+echo "configure:5813: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5834,15 +5835,15 @@
do
-echo "configure:5838: checking for $ac_hdr" >&5
+echo "configure:5839: checking for $ac_hdr" >&5
-#line 5841 "configure"
+#line 5842 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5846: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5847: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5878,15 +5879,15 @@
do
-echo "configure:5882: checking for $ac_hdr" >&5
+echo "configure:5883: checking for $ac_hdr" >&5
-#line 5885 "configure"
+#line 5886 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5890: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5920,7 +5921,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5924: checking for location of Readline library" >&5
+echo "configure:5925: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5945,13 +5946,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5949: checking for readline in -lreadline" >&5
+echo "configure:5950: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 5955 "configure"
+#line 5956 "configure"
@@ -5962,7 +5963,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:5966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5997,13 +5998,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6001: checking for add_history in -lhistory" >&5
+echo "configure:6002: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6007 "configure"
+#line 6008 "configure"
@@ -6014,7 +6015,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6056,7 +6057,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6060: checking whether to use GDAL" >&5
+echo "configure:6061: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6074,7 +6075,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6078: checking for $ac_word" >&5
+echo "configure:6079: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6129,14 +6130,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6133 "configure"
+#line 6134 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6145,14 +6146,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6149 "configure"
+#line 6150 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6184,7 +6185,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6188: checking whether to use libLAS" >&5
+echo "configure:6189: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6201,7 +6202,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6205: checking for $ac_word" >&5
+echo "configure:6206: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6249,14 +6250,14 @@
LIBS="$LIBS $LIBLAS_LIBS"
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6253 "configure"
+#line 6254 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6264,14 +6265,14 @@
rm -rf conftest*
-#line 6268 "configure"
+#line 6269 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6303,7 +6304,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6307: checking whether to use NetCDF" >&5
+echo "configure:6308: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6320,7 +6321,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6324: checking for $ac_word" >&5
+echo "configure:6325: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6367,14 +6368,14 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6371 "configure"
+#line 6372 "configure"
#include <netcdf.h>
int main() {
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6382,14 +6383,14 @@
rm -rf conftest*
-#line 6386 "configure"
+#line 6387 "configure"
#include <netcdf.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6420,7 +6421,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6424: checking whether to use GEOS" >&5
+echo "configure:6425: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6438,7 +6439,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6442: checking for $ac_word" >&5
+echo "configure:6443: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6486,15 +6487,15 @@
do
-echo "configure:6490: checking for $ac_hdr" >&5
+echo "configure:6491: checking for $ac_hdr" >&5
-#line 6493 "configure"
+#line 6494 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6498: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6499: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6533,13 +6534,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6537: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6538: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6543 "configure"
+#line 6544 "configure"
@@ -6550,7 +6551,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6594,7 +6595,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6598: checking whether to use TIFF" >&5
+echo "configure:6599: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6614,7 +6615,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6618: checking for location of TIFF includes" >&5
+echo "configure:6619: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6640,15 +6641,15 @@
do
-echo "configure:6644: checking for $ac_hdr" >&5
+echo "configure:6645: checking for $ac_hdr" >&5
-#line 6647 "configure"
+#line 6648 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6653: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6682,7 +6683,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6686: checking for location of TIFF library" >&5
+echo "configure:6687: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6713,13 +6714,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6717: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6718: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6723 "configure"
+#line 6724 "configure"
@@ -6730,7 +6731,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6749,13 +6750,13 @@
-echo "configure:6753: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6754: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6759 "configure"
+#line 6760 "configure"
@@ -6766,7 +6767,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6785,13 +6786,13 @@
-echo "configure:6789: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6790: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6795 "configure"
+#line 6796 "configure"
@@ -6802,7 +6803,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6821,13 +6822,13 @@
-echo "configure:6825: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6826: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6831 "configure"
+#line 6832 "configure"
@@ -6838,7 +6839,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6857,13 +6858,13 @@
-echo "configure:6861: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6862: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 6867 "configure"
+#line 6868 "configure"
@@ -6874,7 +6875,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6893,13 +6894,13 @@
-echo "configure:6897: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6898: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6903 "configure"
+#line 6904 "configure"
@@ -6910,7 +6911,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6929,13 +6930,13 @@
-echo "configure:6933: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6934: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6939 "configure"
+#line 6940 "configure"
@@ -6946,7 +6947,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6965,13 +6966,13 @@
-echo "configure:6969: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6970: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6975 "configure"
+#line 6976 "configure"
@@ -6982,7 +6983,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7080,7 +7081,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7084: checking whether to use PNG" >&5
+echo "configure:7085: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7099,7 +7100,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7103: checking for location of PNG includes" >&5
+echo "configure:7104: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7125,15 +7126,15 @@
do
-echo "configure:7129: checking for $ac_hdr" >&5
+echo "configure:7130: checking for $ac_hdr" >&5
-#line 7132 "configure"
+#line 7133 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7137: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7138: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7167,7 +7168,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7171: checking for location of PNG library" >&5
+echo "configure:7172: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7192,13 +7193,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7196: checking for png_read_image in -lpng" >&5
+echo "configure:7197: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7202 "configure"
+#line 7203 "configure"
@@ -7209,7 +7210,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7251,7 +7252,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7255: checking whether to use PostgreSQL" >&5
+echo "configure:7256: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7278,7 +7279,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7282: checking for location of PostgreSQL includes" >&5
+echo "configure:7283: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7304,15 +7305,15 @@
do
-echo "configure:7308: checking for $ac_hdr" >&5
+echo "configure:7309: checking for $ac_hdr" >&5
-#line 7311 "configure"
+#line 7312 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7317: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7350,7 +7351,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7354: checking for location of PostgreSQL library" >&5
+echo "configure:7355: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7379,13 +7380,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7383: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7384: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7389 "configure"
+#line 7390 "configure"
@@ -7396,7 +7397,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7415,13 +7416,13 @@
-echo "configure:7419: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7420: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7425 "configure"
+#line 7426 "configure"
@@ -7432,7 +7433,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7451,13 +7452,13 @@
-echo "configure:7455: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7456: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7461 "configure"
+#line 7462 "configure"
@@ -7468,7 +7469,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7487,13 +7488,13 @@
-echo "configure:7491: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7492: checking for PQsetdbLogin in -lpq" >&5
ac_save_LIBS="$LIBS"
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7497 "configure"
+#line 7498 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7504,7 +7505,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7561,13 +7562,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7565: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7566: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7571 "configure"
+#line 7572 "configure"
@@ -7578,7 +7579,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7600,13 +7601,13 @@
-echo "configure:7604: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7605: checking for PQcmdTuples in -lpq" >&5
-#line 7610 "configure"
+#line 7611 "configure"
@@ -7617,7 +7618,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7660,7 +7661,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7664: checking whether to use MySQL" >&5
+echo "configure:7665: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7680,7 +7681,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7684: checking for location of MySQL includes" >&5
+echo "configure:7685: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7706,15 +7707,15 @@
do
-echo "configure:7710: checking for $ac_hdr" >&5
+echo "configure:7711: checking for $ac_hdr" >&5
-#line 7713 "configure"
+#line 7714 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7718: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7751,7 +7752,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7755: checking for location of MySQL library" >&5
+echo "configure:7756: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7782,13 +7783,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7786: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7787: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7792 "configure"
+#line 7793 "configure"
@@ -7799,7 +7800,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7818,13 +7819,13 @@
-echo "configure:7822: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7823: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7828 "configure"
+#line 7829 "configure"
@@ -7835,7 +7836,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7854,13 +7855,13 @@
-echo "configure:7858: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7859: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7864 "configure"
+#line 7865 "configure"
@@ -7871,7 +7872,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7890,13 +7891,13 @@
-echo "configure:7894: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7895: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7900 "configure"
+#line 7901 "configure"
@@ -7907,7 +7908,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7926,13 +7927,13 @@
-echo "configure:7930: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7931: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7936 "configure"
+#line 7937 "configure"
@@ -7943,7 +7944,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7962,13 +7963,13 @@
-echo "configure:7966: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7967: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7972 "configure"
+#line 7973 "configure"
@@ -7979,7 +7980,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7998,13 +7999,13 @@
-echo "configure:8002: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8003: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8008 "configure"
+#line 8009 "configure"
@@ -8015,7 +8016,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8034,13 +8035,13 @@
-echo "configure:8038: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8039: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8044 "configure"
+#line 8045 "configure"
@@ -8051,7 +8052,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8141,7 +8142,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8145: checking for $ac_word" >&5
+echo "configure:8146: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8190,10 +8191,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8194: checking for mysql_server_init" >&5
+echo "configure:8195: checking for mysql_server_init" >&5
-#line 8197 "configure"
+#line 8198 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8219,7 +8220,7 @@
; return 0; }
EOF
-if { (eval echo configure:8223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8271,7 +8272,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8275: checking whether to use SQLite" >&5
+echo "configure:8276: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8291,7 +8292,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8295: checking for location of SQLite includes" >&5
+echo "configure:8296: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8317,15 +8318,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8321: checking for $ac_hdr" >&5
+echo "configure:8322: checking for $ac_hdr" >&5
-#line 8324 "configure"
+#line 8325 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8329: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8368,7 +8369,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8372: checking for location of SQLite library" >&5
+echo "configure:8373: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8397,13 +8398,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8401: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8402: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8407 "configure"
+#line 8408 "configure"
@@ -8414,7 +8415,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8433,13 +8434,13 @@
-echo "configure:8437: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8438: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8443 "configure"
+#line 8444 "configure"
@@ -8450,7 +8451,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8469,13 +8470,13 @@
-echo "configure:8473: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8474: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8479 "configure"
+#line 8480 "configure"
@@ -8486,7 +8487,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8505,13 +8506,13 @@
-echo "configure:8509: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8510: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8515 "configure"
+#line 8516 "configure"
@@ -8522,7 +8523,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8591,7 +8592,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8595: checking whether to use FFMPEG" >&5
+echo "configure:8596: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8611,7 +8612,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8615: checking for location of FFMPEG includes" >&5
+echo "configure:8616: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8637,15 +8638,15 @@
do
-echo "configure:8641: checking for $ac_hdr" >&5
+echo "configure:8642: checking for $ac_hdr" >&5
-#line 8644 "configure"
+#line 8645 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8650: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8681,15 +8682,15 @@
do
-echo "configure:8685: checking for $ac_hdr" >&5
+echo "configure:8686: checking for $ac_hdr" >&5
-#line 8688 "configure"
+#line 8689 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8693: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8725,15 +8726,15 @@
do
-echo "configure:8729: checking for $ac_hdr" >&5
+echo "configure:8730: checking for $ac_hdr" >&5
-#line 8732 "configure"
+#line 8733 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8737: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8738: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8776,7 +8777,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8780: checking for location of FFMPEG library" >&5
+echo "configure:8781: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8803,13 +8804,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8807: checking for av_free in -lavutil" >&5
+echo "configure:8808: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8813 "configure"
+#line 8814 "configure"
@@ -8820,7 +8821,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8839,13 +8840,13 @@
-echo "configure:8843: checking for av_free in -lavutil" >&5
+echo "configure:8844: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8849 "configure"
+#line 8850 "configure"
@@ -8856,7 +8857,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8901,13 +8902,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8905: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8906: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 8911 "configure"
+#line 8912 "configure"
@@ -8918,7 +8919,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8937,13 +8938,13 @@
-echo "configure:8941: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8942: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8947 "configure"
+#line 8948 "configure"
@@ -8954,7 +8955,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8999,13 +9000,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:9003: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9004: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 9009 "configure"
+#line 9010 "configure"
@@ -9016,7 +9017,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:9020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9035,13 +9036,13 @@
-echo "configure:9039: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9040: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9045 "configure"
+#line 9046 "configure"
@@ -9052,7 +9053,7 @@
; return 0; }
EOF
-if { (eval echo configure:9056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9111,7 +9112,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9115: checking whether to use OpenGL" >&5
+echo "configure:9116: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9145,7 +9146,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9149: checking for location of OpenGL includes" >&5
+echo "configure:9150: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9171,15 +9172,15 @@
do
-echo "configure:9175: checking for $ac_hdr" >&5
+echo "configure:9176: checking for $ac_hdr" >&5
-#line 9178 "configure"
+#line 9179 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9183: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9184: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9213,7 +9214,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9217: checking for location of OpenGL library" >&5
+echo "configure:9218: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9242,13 +9243,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9246: checking for glBegin in -lGL" >&5
+echo "configure:9247: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9252 "configure"
+#line 9253 "configure"
@@ -9259,7 +9260,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9278,13 +9279,13 @@
-echo "configure:9282: checking for glBegin in -lGL" >&5
+echo "configure:9283: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9288 "configure"
+#line 9289 "configure"
@@ -9295,7 +9296,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9314,13 +9315,13 @@
-echo "configure:9318: checking for glBegin in -lGL" >&5
+echo "configure:9319: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9324 "configure"
+#line 9325 "configure"
@@ -9331,7 +9332,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9350,13 +9351,13 @@
-echo "configure:9354: checking for glBegin in -lGL" >&5
+echo "configure:9355: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9360 "configure"
+#line 9361 "configure"
@@ -9367,7 +9368,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9429,13 +9430,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9433: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9434: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9439 "configure"
+#line 9440 "configure"
@@ -9446,7 +9447,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9450: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9465,13 +9466,13 @@
-echo "configure:9469: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9470: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9475 "configure"
+#line 9476 "configure"
@@ -9482,7 +9483,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9529,10 +9530,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9533: checking for glXCreatePbuffer" >&5
+echo "configure:9534: checking for glXCreatePbuffer" >&5
-#line 9536 "configure"
+#line 9537 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -9555,7 +9556,7 @@
; return 0; }
EOF
-if { (eval echo configure:9559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9592,10 +9593,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9596: checking for glXCreateGLXPixmap" >&5
+echo "configure:9597: checking for glXCreateGLXPixmap" >&5
-#line 9599 "configure"
+#line 9600 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9618,7 +9619,7 @@
; return 0; }
EOF
-if { (eval echo configure:9622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9661,7 +9662,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9665: checking for location of OpenGL framework" >&5
+echo "configure:9666: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9685,15 +9686,15 @@
do
-echo "configure:9689: checking for $ac_hdr" >&5
+echo "configure:9690: checking for $ac_hdr" >&5
-#line 9692 "configure"
+#line 9693 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9698: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9729,10 +9730,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9733: checking for glBegin" >&5
+echo "configure:9734: checking for glBegin" >&5
-#line 9736 "configure"
+#line 9737 "configure"
which can conflict with char glBegin(); below. */
@@ -9755,7 +9756,7 @@
; return 0; }
EOF
-if { (eval echo configure:9759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9792,10 +9793,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9796: checking for gluBeginCurve" >&5
+echo "configure:9797: checking for gluBeginCurve" >&5
-#line 9799 "configure"
+#line 9800 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9818,7 +9819,7 @@
; return 0; }
EOF
-if { (eval echo configure:9822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9866,7 +9867,7 @@
-echo "configure:9870: checking for location of OpenGL includes" >&5
+echo "configure:9871: checking for location of OpenGL includes" >&5
@@ -9892,15 +9893,15 @@
do
-echo "configure:9896: checking for $ac_hdr" >&5
+echo "configure:9897: checking for $ac_hdr" >&5
-#line 9899 "configure"
+#line 9900 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9904: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9905: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9934,7 +9935,7 @@
-echo "configure:9938: checking for location of OpenGL library" >&5
+echo "configure:9939: checking for location of OpenGL library" >&5
@@ -9959,18 +9960,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9963: checking for OpenGL library" >&5
+echo "configure:9964: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9967 "configure"
+#line 9968 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9994,18 +9995,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9998: checking for GLU library" >&5
+echo "configure:9999: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 10002 "configure"
+#line 10003 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:10009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10054,7 +10055,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10058: checking whether to use ODBC" >&5
+echo "configure:10059: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -10073,7 +10074,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10077: checking for location of ODBC includes" >&5
+echo "configure:10078: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10099,15 +10100,15 @@
do
-echo "configure:10103: checking for $ac_hdr" >&5
+echo "configure:10104: checking for $ac_hdr" >&5
-#line 10106 "configure"
+#line 10107 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10111: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10112: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10141,7 +10142,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10145: checking for location of ODBC library" >&5
+echo "configure:10146: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10166,13 +10167,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10170: checking for SQLConnect in -lodbc" >&5
+echo "configure:10171: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10176 "configure"
+#line 10177 "configure"
@@ -10183,7 +10184,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10208,13 +10209,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10212: checking for SQLConnect in -liodbc" >&5
+echo "configure:10213: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10218 "configure"
+#line 10219 "configure"
@@ -10225,7 +10226,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10250,11 +10251,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10254: checking for ODBC library" >&5
+echo "configure:10255: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10258 "configure"
+#line 10259 "configure"
#include <windows.h>
#include <sql.h>
@@ -10262,7 +10263,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10311,7 +10312,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10315: checking whether to use FFTW" >&5
+echo "configure:10316: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10330,7 +10331,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10334: checking for location of FFTW includes" >&5
+echo "configure:10335: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10356,15 +10357,15 @@
do
-echo "configure:10360: checking for $ac_hdr" >&5
+echo "configure:10361: checking for $ac_hdr" >&5
-#line 10363 "configure"
+#line 10364 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10368: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10392,15 +10393,15 @@
do
-echo "configure:10396: checking for $ac_hdr" >&5
+echo "configure:10397: checking for $ac_hdr" >&5
-#line 10399 "configure"
+#line 10400 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10405: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10428,15 +10429,15 @@
do
-echo "configure:10432: checking for $ac_hdr" >&5
+echo "configure:10433: checking for $ac_hdr" >&5
-#line 10435 "configure"
+#line 10436 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10440: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10441: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10482,7 +10483,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10486: checking for location of FFTW library" >&5
+echo "configure:10487: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10507,13 +10508,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10511: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10512: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10517 "configure"
+#line 10518 "configure"
@@ -10524,7 +10525,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10549,13 +10550,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10553: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10554: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10559 "configure"
+#line 10560 "configure"
@@ -10566,7 +10567,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10591,13 +10592,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10595: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10596: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10601 "configure"
+#line 10602 "configure"
@@ -10608,7 +10609,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10665,7 +10666,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10669: checking whether to use BLAS" >&5
+echo "configure:10670: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10686,7 +10687,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10690: checking for location of BLAS includes" >&5
+echo "configure:10691: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10706,7 +10707,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10710: checking for location of BLAS library" >&5
+echo "configure:10711: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10732,15 +10733,15 @@
do
-echo "configure:10736: checking for $ac_hdr" >&5
+echo "configure:10737: checking for $ac_hdr" >&5
-#line 10739 "configure"
+#line 10740 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10744: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10745: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10775,13 +10776,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10779: checking for dnrm2_ in -lblas" >&5
+echo "configure:10780: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10785 "configure"
+#line 10786 "configure"
@@ -10792,7 +10793,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10811,13 +10812,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10815: checking for dnrm2_ in -lblas" >&5
+echo "configure:10816: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10821 "configure"
+#line 10822 "configure"
@@ -10828,7 +10829,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10833: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10872,13 +10873,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10876: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10877: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10882 "configure"
+#line 10883 "configure"
@@ -10889,7 +10890,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10904,13 +10905,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10908: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10909: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10914 "configure"
+#line 10915 "configure"
@@ -10921,7 +10922,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10936,13 +10937,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10940: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10941: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10946 "configure"
+#line 10947 "configure"
@@ -10953,7 +10954,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10999,16 +11000,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11003: checking for sgemm in $vlib_flags" >&5
+echo "configure:11004: checking for sgemm in $vlib_flags" >&5
-#line 11005 "configure"
+#line 11006 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:11012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -11026,13 +11027,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11030: checking for sgemm_ in -lblas" >&5
+echo "configure:11031: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 11036 "configure"
+#line 11037 "configure"
@@ -11043,7 +11044,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11058,13 +11059,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11062: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11063: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 11068 "configure"
+#line 11069 "configure"
@@ -11075,7 +11076,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:11079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11090,13 +11091,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11094: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11095: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 11100 "configure"
+#line 11101 "configure"
@@ -11107,7 +11108,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11141,13 +11142,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11145: checking for acosp in -lsunmath" >&5
+echo "configure:11146: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 11151 "configure"
+#line 11152 "configure"
@@ -11158,7 +11159,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:11162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11173,13 +11174,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11177: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11178: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11183 "configure"
+#line 11184 "configure"
@@ -11190,7 +11191,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11220,13 +11221,13 @@
# Generic BLAS library
-echo "configure:11224: checking for sgemm_ in -lblas" >&5
+echo "configure:11225: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11230 "configure"
+#line 11231 "configure"
@@ -11237,7 +11238,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11276,7 +11277,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11280: checking whether to use LAPACK" >&5
+echo "configure:11281: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11301,7 +11302,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11305: checking for location of LAPACK includes" >&5
+echo "configure:11306: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11321,7 +11322,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11325: checking for location of LAPACK library" >&5
+echo "configure:11326: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11347,15 +11348,15 @@
do
-echo "configure:11351: checking for $ac_hdr" >&5
+echo "configure:11352: checking for $ac_hdr" >&5
-#line 11354 "configure"
+#line 11355 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11359: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11360: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11387,10 +11388,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11391: checking for dsegv_" >&5
+echo "configure:11392: checking for dsegv_" >&5
-#line 11394 "configure"
+#line 11395 "configure"
which can conflict with char dsegv_(); below. */
@@ -11413,7 +11414,7 @@
; return 0; }
EOF
-if { (eval echo configure:11417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11440,13 +11441,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11444: checking for desgv_ in -llapack" >&5
+echo "configure:11445: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 11450 "configure"
+#line 11451 "configure"
@@ -11457,7 +11458,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11489,13 +11490,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11493: checking for dgesv_ in -llapack" >&5
+echo "configure:11494: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11499 "configure"
+#line 11500 "configure"
@@ -11506,7 +11507,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11525,13 +11526,13 @@
-echo "configure:11529: checking for dgesv_ in -llapack" >&5
+echo "configure:11530: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11535 "configure"
+#line 11536 "configure"
@@ -11542,7 +11543,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11598,7 +11599,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11602: checking whether to use Cairo" >&5
+echo "configure:11603: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11630,7 +11631,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11634: checking for location of cairo includes" >&5
+echo "configure:11635: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11656,15 +11657,15 @@
do
-echo "configure:11660: checking for $ac_hdr" >&5
+echo "configure:11661: checking for $ac_hdr" >&5
-#line 11663 "configure"
+#line 11664 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11700,7 +11701,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11704: checking for location of cairo library" >&5
+echo "configure:11705: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11720,7 +11721,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11724: checking for cairo linking flags" >&5
+echo "configure:11725: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11736,10 +11737,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11740: checking for cairo_create" >&5
+echo "configure:11741: checking for cairo_create" >&5
-#line 11743 "configure"
+#line 11744 "configure"
which can conflict with char cairo_create(); below. */
@@ -11762,7 +11763,7 @@
; return 0; }
EOF
-if { (eval echo configure:11766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11796,10 +11797,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11800: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11801: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11803 "configure"
+#line 11804 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11822,7 +11823,7 @@
; return 0; }
EOF
-if { (eval echo configure:11826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11855,10 +11856,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11859: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11860: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11862 "configure"
+#line 11863 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11881,7 +11882,7 @@
; return 0; }
EOF
-if { (eval echo configure:11885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11923,7 +11924,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11927: checking whether to use FreeType" >&5
+echo "configure:11928: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11942,7 +11943,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11946: checking for location of FreeType includes" >&5
+echo "configure:11947: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11968,15 +11969,15 @@
do
-echo "configure:11972: checking for $ac_hdr" >&5
+echo "configure:11973: checking for $ac_hdr" >&5
-#line 11975 "configure"
+#line 11976 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11980: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11981: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12010,7 +12011,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12014: checking for location of FreeType library" >&5
+echo "configure:12015: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12035,13 +12036,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12039: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12040: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 12045 "configure"
+#line 12046 "configure"
@@ -12052,7 +12053,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12093,7 +12094,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12097: checking whether to use NLS" >&5
+echo "configure:12098: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -12113,10 +12114,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12117: checking for gettext" >&5
+echo "configure:12118: checking for gettext" >&5
-#line 12120 "configure"
+#line 12121 "configure"
which can conflict with char gettext(); below. */
@@ -12139,7 +12140,7 @@
; return 0; }
EOF
-if { (eval echo configure:12143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -12157,13 +12158,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12161: checking for gettext in -lintl" >&5
+echo "configure:12162: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12167 "configure"
+#line 12168 "configure"
@@ -12174,7 +12175,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12209,7 +12210,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12213: checking whether to use C++" >&5
+echo "configure:12214: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12225,7 +12226,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:12229: checking for $ac_word" >&5
+echo "configure:12230: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12254,7 +12255,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12258: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12259: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12265,12 +12266,12 @@
cat > conftest.$ac_ext << EOF
-#line 12269 "configure"
+#line 12270 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12296,19 +12297,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12300: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12301: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12305: checking whether we are using GNU C++" >&5
+echo "configure:12306: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12312: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12313: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12326,7 +12327,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12330: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12331: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12367,7 +12368,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12371: checking whether to use openDWG" >&5
+echo "configure:12372: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12387,7 +12388,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12391: checking for location of openDGW includes" >&5
+echo "configure:12392: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12413,15 +12414,15 @@
do
-echo "configure:12417: checking for $ac_hdr" >&5
+echo "configure:12418: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 12420 "configure"
+#line 12421 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12425: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12455,7 +12456,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12459: checking for location of openDWG library" >&5
+echo "configure:12460: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12496,7 +12497,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12500: checking whether to use POSIX threads" >&5
+echo "configure:12501: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12516,7 +12517,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12520: checking for location of POSIX threads includes" >&5
+echo "configure:12521: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12542,15 +12543,15 @@
do
-echo "configure:12546: checking for $ac_hdr" >&5
+echo "configure:12547: checking for $ac_hdr" >&5
-#line 12549 "configure"
+#line 12550 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12554: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12555: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12584,7 +12585,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12588: checking for location of POSIX threads library" >&5
+echo "configure:12589: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12609,10 +12610,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12613: checking for pthread_create" >&5
+echo "configure:12614: checking for pthread_create" >&5
-#line 12616 "configure"
+#line 12617 "configure"
which can conflict with char pthread_create(); below. */
@@ -12635,7 +12636,7 @@
; return 0; }
EOF
-if { (eval echo configure:12639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12662,13 +12663,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12666: checking for pthread_create in -lpthread" >&5
+echo "configure:12667: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 12672 "configure"
+#line 12673 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12679,7 +12680,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12729,7 +12730,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12733: checking whether to use OpenMP" >&5
+echo "configure:12734: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12750,7 +12751,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12754: checking for location of OpenMP includes" >&5
+echo "configure:12755: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12776,15 +12777,15 @@
do
-echo "configure:12780: checking for $ac_hdr" >&5
+echo "configure:12781: checking for $ac_hdr" >&5
-#line 12783 "configure"
+#line 12784 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12788: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12789: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12822,7 +12823,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12826: checking for location of OpenMP library" >&5
+echo "configure:12827: checking for location of OpenMP library" >&5
case "$with_openmp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12847,10 +12848,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12851: checking for GOMP_parallel_start" >&5
+echo "configure:12852: checking for GOMP_parallel_start" >&5
-#line 12854 "configure"
+#line 12855 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12873,7 +12874,7 @@
; return 0; }
EOF
-if { (eval echo configure:12877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12900,13 +12901,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12904: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12905: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12910 "configure"
+#line 12911 "configure"
@@ -12917,7 +12918,7 @@
; return 0; }
EOF
-if { (eval echo configure:12921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12990,7 +12991,7 @@
echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12994: checking whether to use OpenCL" >&5
+echo "configure:12995: checking whether to use OpenCL" >&5
echo "$ac_t"""$with_opencl"" 1>&6
case "$with_opencl" in
"no") USE_OPENCL= ;;
@@ -13010,7 +13011,7 @@
echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13014: checking for location of OpenCL includes" >&5
+echo "configure:13015: checking for location of OpenCL includes" >&5
case "$with_opencl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13037,15 +13038,15 @@
do
-echo "configure:13041: checking for $ac_hdr" >&5
+echo "configure:13042: checking for $ac_hdr" >&5
-#line 13044 "configure"
+#line 13045 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13049: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13074,7 +13075,75 @@
CPPFLAGS=$ac_save_cppflags
+ # With OpenCL library directory
+ ### FIXME: ###
+ #LOC_CHECK_FRAMEWORK_PATH(opencl,OpenCL,OPENCLPATH)
+ # last term in following would become ',$OPENCLPATH)' if above is uncommented
+ac_save_libs="$LIBS"
+ac_save_ldflags="$LDFLAGS"
+LIBS="-framework OpenCL $LIBS"
+LDFLAGS=" $LDFLAGS"
+echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
+echo "configure:13090: checking for clGetPlatformInfo" >&5
+cat > conftest.$ac_ext <<EOF
+#line 13093 "configure"
+#include "confdefs.h"
+/* System header to define __stub macros and hopefully few prototypes,
+ which can conflict with char clGetPlatformInfo(); below. */
+#include <assert.h>
+/* Override any gcc2 internal prototype to avoid an error. */
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char clGetPlatformInfo();
+int main() {
+/* The GNU C library defines this for functions which it implements
+ to always fail with ENOSYS. Some functions are actually named
+ something starting with __ and the normal name is an alias. */
+#if defined (__stub_clGetPlatformInfo) || defined (__stub___clGetPlatformInfo)
+choke me
+#else
+clGetPlatformInfo();
+#endif
+; return 0; }
+EOF
+if { (eval echo configure:13116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+ eval "ac_cv_func_clGetPlatformInfo=yes"
else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_func_clGetPlatformInfo=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_func_'clGetPlatformInfo`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+ OCLLIB="$OCLLIB -framework OpenCL"
+else
+ echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate OpenCL library." 1>&2; exit 1; }
+fi
+LIBS=${ac_save_libs}
+LDFLAGS=${ac_save_ldflags}
+else
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$OCLINCPATH $CPPFLAGS"
@@ -13082,15 +13151,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13086: checking for $ac_hdr" >&5
+echo "configure:13155: checking for $ac_hdr" >&5
-#line 13089 "configure"
+#line 13158 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13163: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13119,13 +13188,11 @@
-fi
-# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13129: checking for location of OpenCL library" >&5
+echo "configure:13196: checking for location of OpenCL library" >&5
case "$with_opencl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13143,20 +13210,19 @@
done
fi
LDFLAGS="$OCLLIBPATH $LDFLAGS"
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13154: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13220: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
LIBS="-lOpenCL $LIBS"
-#line 13160 "configure"
+#line 13226 "configure"
@@ -13167,7 +13233,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:13171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13196,10 +13262,11 @@
-# expanded symbol check: yes? no?
-#LOC_CHECK_FUNC(clGetPlatformInfo,OpenCL functions,OCLLIB,,,,,[
-#LOC_CHECK_LIBS(OpenCL,clGetPlatformInfo,OpenCL,$OCLLIBPATH,OCLLIB,,,)
+ # expanded symbol check: yes? no?
+ #LOC_CHECK_FUNC(clGetPlatformInfo,OpenCL functions,OCLLIB,,,,,[
+ #LOC_CHECK_LIBS(OpenCL,clGetPlatformInfo,OpenCL,$OCLLIBPATH,OCLLIB,,,)
+fi
fi # $USE_OPENCL
@@ -13220,7 +13287,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13224: checking for special C compiler options needed for large files" >&5
+echo "configure:13291: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13228,7 +13295,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13232 "configure"
+#line 13299 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13244,7 +13311,7 @@
; return 0; }
EOF
-if { (eval echo configure:13248: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13315: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13253,7 +13320,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13257 "configure"
+#line 13324 "configure"
@@ -13269,7 +13336,7 @@
; return 0; }
EOF
-if { (eval echo configure:13273: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13340: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13289,11 +13356,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13293: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13360: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13297 "configure"
+#line 13364 "configure"
@@ -13309,14 +13376,14 @@
; return 0; }
EOF
-if { (eval echo configure:13313: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13380: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13320 "configure"
+#line 13387 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13334,7 +13401,7 @@
; return 0; }
EOF
-if { (eval echo configure:13338: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13405: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13353,11 +13420,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13357: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13424: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13361 "configure"
+#line 13428 "configure"
@@ -13373,14 +13440,14 @@
; return 0; }
EOF
-if { (eval echo configure:13377: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13444: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13384 "configure"
+#line 13451 "configure"
#define _LARGE_FILES 1
@@ -13398,7 +13465,7 @@
; return 0; }
EOF
-if { (eval echo configure:13402: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13469: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13417,25 +13484,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13421: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13488: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13425 "configure"
+#line 13492 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13432: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13499: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13439 "configure"
+#line 13506 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13444,7 +13511,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13448: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13515: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13465,25 +13532,25 @@
fi
-echo "configure:13469: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13536: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13473 "configure"
+#line 13540 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13480: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13547: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13487 "configure"
+#line 13554 "configure"
#include <stdio.h>
@@ -13492,7 +13559,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13496: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13563: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13515,18 +13582,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13519: checking for fseeko" >&5
+echo "configure:13586: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13523 "configure"
+#line 13590 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13543,10 +13610,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13547: checking if system supports Large Files at all" >&5
+echo "configure:13614: checking if system supports Large Files at all" >&5
-#line 13550 "configure"
+#line 13617 "configure"
#include <stdio.h>
@@ -13578,7 +13645,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13582: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13649: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13607,7 +13674,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13611: checking whether to use wxWidgets" >&5
+echo "configure:13678: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13628,7 +13695,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13632: checking for $ac_word" >&5
+echo "configure:13699: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13676,7 +13743,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13680: checking wxWidgets version" >&5
+echo "configure:13747: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13699,15 +13766,15 @@
do
-echo "configure:13703: checking for $ac_hdr" >&5
+echo "configure:13770: checking for $ac_hdr" >&5
-#line 13706 "configure"
+#line 13773 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13711: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13778: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2013-04-26 03:19:07 UTC (rev 56002)
+++ grass/trunk/configure.in 2013-04-26 06:44:22 UTC (rev 56003)
@@ -369,6 +369,7 @@
LOC_ARG_WITH_INC(opencl, OpenCL)
LOC_ARG_WITH_LIB(opencl, OpenCL)
+#LOC_ARG_WITH_FRAMEWORK(opencl, OpenCL)
# Put this early on so CPPFLAGS and LDFLAGS have any additional dirs
@@ -1768,20 +1769,24 @@
if test -n "$MACOSX_APP" ; then
LOC_CHECK_INCLUDES(OpenCL/opencl.h,OpenCL,$OCLINCPATH)
+ ### FIXME: ###
+ LOC_CHECK_FUNC(clGetPlatformInfo,OpenCL library,OCLLIB,-framework OpenCL,)
else
LOC_CHECK_INCLUDES(CL/cl.h,OpenCL,$OCLINCPATH)
+ LOC_CHECK_LIB_PATH(opencl,OpenCL,OCLLIBPATH)
+ LOC_CHECK_LIBS(OpenCL,clGetPlatformInfo,OpenCL,$OCLLIBPATH,OCLLIB,,,)
fi
-LOC_CHECK_LIB_PATH(opencl,OpenCL,OCLLIBPATH)
-LOC_CHECK_LIBS(OpenCL,clGetPlatformInfo,OpenCL,$OCLLIBPATH,OCLLIB,,,)
fi # $USE_OPENCL
AC_SUBST(OCLINCPATH)
