[GRASS-SVN] r56004 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Apr 26 02:36:01 PDT 2013
Author: martinl
Date: 2013-04-26 02:36:01 -0700 (Fri, 26 Apr 2013)
New Revision: 56004
grass/trunk/lib/vector/Vlib/open.c
vlib: Vect__open_old(): call G_fatal_error() when vector map is not found
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2013-04-26 06:44:22 UTC (rev 56003)
+++ grass/trunk/lib/vector/Vlib/open.c 2013-04-26 09:36:01 UTC (rev 56004)
@@ -224,11 +224,11 @@
fmapset = G_find_vector2(Map->name, Map->mapset);
if (fmapset == NULL) {
if (mapset && strcmp(mapset, G_mapset()) == 0)
- G_warning(_("Vector map <%s> not found in current mapset"),
- Vect_get_name(Map));
+ G_fatal_error(_("Vector map <%s> not found in current mapset"),
+ Vect_get_name(Map));
else
- G_warning(_("Vector map <%s> not found"),
- Vect_get_full_name(Map));
+ G_fatal_error(_("Vector map <%s> not found"),
+ Vect_get_full_name(Map));
return -1;
Map->mapset = G_store(fmapset);
