[GRASS-SVN] r56018 - in grass/trunk: lib/vector/Vlib vector/v.in.ascii
svn_grass at osgeo.org
Sun Apr 28 07:52:15 PDT 2013
Author: martinl
Date: 2013-04-28 07:52:15 -0700 (Sun, 28 Apr 2013)
New Revision: 56018
grass/trunk/lib/vector/Vlib/ascii.c
grass/trunk/vector/v.in.ascii/main.c
v.in.ascii: fatal error when import fails
Vect_read_ascii(): return -1 and print warning instead of fatal error
skip 3D features when map is 2D
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2013-04-28 14:28:15 UTC (rev 56017)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2013-04-28 14:52:15 UTC (rev 56018)
@@ -47,7 +47,7 @@
double *zarray;
double *x, *y, *z;
int i, n_points, n_coors, n_cats, n_lines;
- int type;
+ int type, with_z, skip_feat, nskipped_3d;
int alloc_points;
struct line_pnts *Points;
struct line_cats *Cats;
@@ -63,11 +63,13 @@
yarray = (double *)G_calloc(alloc_points, sizeof(double));
zarray = (double *)G_calloc(alloc_points, sizeof(double));
- n_lines = 0;
+ n_lines = nskipped_3d = 0;
+ with_z = Vect_is_3d(Map);
while (G_getl2(buff, BUFFSIZE - 1, ascii) != 0) {
n_cats = 0;
+ skip_feat = FALSE;
if (buff[0] == '\0') {
G_debug(3, "a2b: skipping blank line");
continue;
@@ -79,8 +81,9 @@
G_debug(2, "a2b: skipping commented line");
continue;
- G_fatal_error(_("Error reading ASCII file: (bad type) [%s]"),
- buff);
+ G_warning(_("Error reading ASCII file: (bad type) [%s]"),
+ buff);
+ return -1;
if (ctype == '#') {
G_debug(2, "a2b: Skipping commented line");
@@ -116,12 +119,19 @@
case 'p':
type = 0; /* dead -> ignore */
break;
- default:
- G_fatal_error(_("Error reading ASCII file: (unknown type) [%s]"),
- buff);
+ default: {
+ G_warning(_("Error reading ASCII file: (unknown type) [%s]"),
+ buff);
+ return -1;
G_debug(5, "feature type = %d", type);
+ if ((type & (GV_FACE | GV_KERNEL)) && !with_z) {
+ skip_feat = TRUE;
+ nskipped_3d++;
n_points = 0;
x = xarray;
y = yarray;
@@ -129,9 +139,10 @@
/* Collect the points */
for (i = 0; i < n_coors; i++) {
- if (G_getl2(buff, BUFFSIZE - 1, ascii) == 0)
- G_fatal_error(_("End of ASCII file reached before end of coordinates"));
+ if (G_getl2(buff, BUFFSIZE - 1, ascii) == 0) {
+ G_warning(_("End of ASCII file reached before end of coordinates"));
+ return -1;
G_debug(3, "a2b: skipping blank line while reading vertices");
i--;
@@ -141,15 +152,20 @@
*z = 0;
if (sscanf(buff, "%lf%lf%lf", x, y, z) < 2) {
if (sscanf(buff, " %s %s %lf", east_str, north_str, z) < 2) {
- G_fatal_error(_("Error reading ASCII file: (bad point) [%s]"),
- buff);
+ G_warning(_("Error reading ASCII file: (bad point) [%s]"),
+ buff);
+ return -1;
} else {
- if( ! G_scan_easting(east_str, x, G_projection()) )
- G_fatal_error(_("Unparsable longitude value: [%s]"),
- east_str);
- if( ! G_scan_northing(north_str, y, G_projection()) )
- G_fatal_error(_("Unparsable latitude value: [%s]"),
- north_str);
+ if (!G_scan_easting(east_str, x, G_projection())) {
+ G_warning(_("Unparsable longitude value: [%s]"),
+ east_str);
+ return -1;
+ if (!G_scan_northing(north_str, y, G_projection())) {
+ G_warning(_("Unparsable latitude value: [%s]"),
+ north_str);
+ return -1;
@@ -179,10 +195,12 @@
/* Collect the cats */
+ Vect_reset_cats(Cats);
for (i = 0; i < n_cats; i++) {
- G_fatal_error(_("End of ASCII file reached before end of categories"));
+ G_warning(_("End of ASCII file reached before end of categories"));
+ return -1;
G_debug(3,
"a2b: skipping blank line while reading category info");
@@ -190,28 +208,36 @@
continue;
- if (sscanf(buff, "%u%u", &catn, &cat) != 2)
- G_fatal_error(_("Error reading categories: [%s]"), buff);
+ if (sscanf(buff, "%u%u", &catn, &cat) != 2) {
+ G_warning(_("Error reading categories: [%s]"), buff);
+ return -1;
Vect_cat_set(Cats, catn, cat);
+ if (skip_feat)
+ continue;
/* Allocation is handled for line_pnts */
if (0 >
- Vect_copy_xyz_to_pnts(Points, xarray, yarray, zarray, n_points))
- G_fatal_error(_("Out of memory"));
+ Vect_copy_xyz_to_pnts(Points, xarray, yarray, zarray, n_points)) {
+ G_warning(_("Unable to copy points"));
+ return -1;
if (type > 0) {
if (-1 == Vect_write_line(Map, type, Points, Cats)) {
- G_warning(_("Unable to write new feature"));
return -1;
n_lines++;
- Vect_reset_cats(Cats);
+ if (nskipped_3d > 0)
+ G_warning(_("Vector map <%s> is 2D. %d 3D features (faces or kernels) skipped."),
+ Vect_get_name(Map), nskipped_3d);
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
@@ -240,8 +266,10 @@
if (strncmp(buff, "VERTI:", 6) == 0)
return (0);
- if (!(ptr = strchr(buff, ':')))
- G_fatal_error(_("Unexpected data in vector head:\n[%s]"), buff);
+ if (!(ptr = strchr(buff, ':'))) {
+ G_warning(_("Unexpected data in vector header:\n[%s]"), buff);
+ return -1;
ptr++; /* Search for the start of text */
while (*ptr == ' ')
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c 2013-04-28 14:28:15 UTC (rev 56017)
+++ grass/trunk/vector/v.in.ascii/main.c 2013-04-28 14:52:15 UTC (rev 56018)
@@ -543,9 +543,11 @@
else { /* FORMAT_ALL (standard mode) */
if (!noheader_flag->answer)
- Vect_read_ascii_head(ascii, &Map);
+ if (Vect_read_ascii_head(ascii, &Map) == -1)
+ G_fatal_error(_("Import failed"));
- Vect_read_ascii(ascii, &Map);
+ if (Vect_read_ascii(ascii, &Map) == -1)
if (ascii != stdin)
