[GRASS-SVN] r56019 - in grass/trunk: lib/nviz misc/m.nviz.image
svn_grass at osgeo.org
Sun Apr 28 08:04:28 PDT 2013
Author: martinl
Date: 2013-04-28 08:04:28 -0700 (Sun, 28 Apr 2013)
New Revision: 56019
grass/trunk/lib/nviz/render.c
grass/trunk/misc/m.nviz.image/main.c
m.nviz.image: Nviz_create_render_window(): check return code
Modified: grass/trunk/lib/nviz/render.c
--- grass/trunk/lib/nviz/render.c 2013-04-28 14:52:15 UTC (rev 56018)
+++ grass/trunk/lib/nviz/render.c 2013-04-28 15:04:28 UTC (rev 56019)
@@ -88,7 +88,8 @@
\param width window width
\param height window height
- \return 1
+ \return 0 on success
+ \return -1 on error
int Nviz_create_render_window(struct render_window *rwin, void *display,
int width, int height)
@@ -107,11 +108,16 @@
v = glXChooseVisual(rwin->displayId,
DefaultScreen(rwin->displayId), attributeList);
+ if (!v) {
+ G_warning(_("Unable to get visual info"));
+ return -1;
rwin->contextId = glXCreateContext(rwin->displayId, v, NULL, GL_FALSE);
if (!rwin->contextId) {
- G_fatal_error(_("Unable to create rendering context"));
+ G_warning(_("Unable to create rendering context"));
+ return -1;
/* create win pixmap to render to (same depth as RootWindow) */
@@ -122,9 +128,7 @@
/* create an off-screen GLX rendering area */
rwin->windowId = glXCreateGLXPixmap(rwin->displayId, v, rwin->pixmap);
- if (v) {
- XFree(v);
+ XFree(v);
#elif defined(OPENGL_AQUA)
int attributeList[] = { AGL_RGBA, AGL_RED_SIZE, 1,
AGL_GREEN_SIZE, 1, AGL_BLUE_SIZE, 1,
@@ -170,7 +174,7 @@
rwin->contextId = wglCreateContext(rwin->displayId);
/* TODO */
#endif
- return 1;
+ return 0;
Modified: grass/trunk/misc/m.nviz.image/main.c
--- grass/trunk/misc/m.nviz.image/main.c 2013-04-28 14:52:15 UTC (rev 56018)
+++ grass/trunk/misc/m.nviz.image/main.c 2013-04-28 15:04:28 UTC (rev 56019)
@@ -78,7 +78,8 @@
/* define render window */
offscreen = Nviz_new_render_window();
Nviz_init_render_window(offscreen);
- Nviz_create_render_window(offscreen, NULL, width, height); /* offscreen display */
+ if (Nviz_create_render_window(offscreen, NULL, width, height) == -1)
+ G_fatal_error(_("Unable to render data"));
Nviz_make_current_render_window(offscreen);
/* initialize nviz data */
