[GRASS-SVN] r57347 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Thu Aug 1 09:45:11 PDT 2013
Author: martinl
Date: 2013-08-01 09:45:11 -0700 (Thu, 01 Aug 2013)
New Revision: 57347
grass/trunk/lib/vector/diglib/update.c
vlib: enable check for duplications in dig_line_add_updated()
assuming that uplist is not large (list is reseted for every operation)
Modified: grass/trunk/lib/vector/diglib/update.c
--- grass/trunk/lib/vector/diglib/update.c 2013-08-01 16:42:21 UTC (rev 57346)
+++ grass/trunk/lib/vector/diglib/update.c 2013-08-01 16:45:11 UTC (rev 57347)
@@ -36,14 +36,18 @@
void dig_line_add_updated(struct Plus_head *Plus, int line)
+ int i;
G_debug(3, "dig_line_add_updated(): line = %d", line);
- /* Check if already in list
- for (i = 0; i < Plus->uplist.n_uplines; i++)
- if (Plus->uplist.uplines[i] == line)
+ /* Check if already in list */
+ for (i = 0; i < Plus->uplist.n_uplines; i++) {
+ if (Plus->uplist.uplines[i] == line) {
+ G_debug(3, "\tskipped");
return;
/* Alloc space if needed */
if (Plus->uplist.n_uplines == Plus->uplist.alloc_uplines) {
Plus->uplist.alloc_uplines += 1000;
@@ -82,9 +86,12 @@
G_debug(3, "dig_node_add_updated(): node = %d", node);
- for (i = 0; i < Plus->uplist.n_upnodes; i++)
- if (Plus->uplist.upnodes[i] == node)
+ for (i = 0; i < Plus->uplist.n_upnodes; i++) {
+ if (abs(Plus->uplist.upnodes[i]) == abs(node)) {
return;
if (Plus->uplist.n_upnodes == Plus->uplist.alloc_upnodes) {
