[GRASS-SVN] r57348 - grass/trunk/gui/wxpython/gui_core
Thu Aug 1 11:47:15 PDT 2013
Author: annakrat
Date: 2013-08-01 11:47:14 -0700 (Thu, 01 Aug 2013)
New Revision: 57348
   grass/trunk/gui/wxpython/gui_core/dialogs.py
   grass/trunk/gui/wxpython/gui_core/gselect.py
wxGUI: further fixes for import dialog
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py	2013-08-01 16:45:11 UTC (rev 57347)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py	2013-08-01 18:47:14 UTC (rev 57348)
@@ -1591,7 +1591,6 @@
         self.btn_run = wx.Button(parent = self.panel, id = wx.ID_OK, label = _("&Import"))
         self.btn_run.SetToolTipString(_("Import selected layers"))
         self.btn_run.SetDefault()
-        self.btn_run.Enable(False)
         self.btn_run.Bind(wx.EVT_BUTTON, self.OnRun)
     def doLayout(self):
@@ -1741,6 +1740,7 @@
         self.dsnInput = GdalSelect(parent = self, panel = self.panel,
                                    ogr = ogr, link = link)
+        self.dsnInput.reloadDataRequired.connect(lambda data: self.list.LoadData(data))
         if link:
             self.add.SetLabel(_("Add linked layers into layer tree"))
@@ -1872,7 +1872,6 @@
         self.btnOk = wx.Button(parent = self.panel, id = wx.ID_OK)
         self.btnOk.SetToolTipString(_("Set external format and close dialog"))
         self.btnOk.SetDefault()
-        self.btnOk.Enable(False)
                                    ogr = ogr,
@@ -1922,6 +1921,9 @@
             dsn = self.dsnInput.GetDsn()
             frmt = self.dsnInput.GetFormat()
             options = self.dsnInput.GetOptions()
+            if not dsn:
+                GMessage(_("No data source selected."), parent=self)
+                return
             RunCommand('v.external.out',
                        parent = self,
@@ -1956,6 +1958,9 @@
     def OnRun(self, event):
         """!Import/Link data (each layes as separate vector map)"""
         data = self.list.GetLayers()
+        if not data:
+            GMessage(_("No layers selected."), parent=self)
+            return
         # hide dialog
         self.Hide()
@@ -1979,7 +1984,7 @@
             # run in Layer Manager
             self._giface.RunCmd(cmd, switchPage = True, onDone = self.AddLayers)
-        self.OnCancel()
+        self.Close()
     def OnSetDsn(self, event):
         """!Input DXF file defined, update list of layer widget"""
@@ -1996,7 +2001,6 @@
                          input = path)
         if not ret:
             self.list.LoadData()
             return
         for line in ret.splitlines():
@@ -2006,11 +2010,8 @@
             data.append((layerId, layerName.strip(), grassName.strip()))
-        if len(data) > 0:
-            self.btn_run.Enable(True)
-        else:
 class LayersList(GListCtrl, listmix.TextEditMixin):
     """!List of layers to be imported (dxf, shp...)"""
     def __init__(self, parent, columns, log = None):
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py	2013-08-01 16:45:11 UTC (rev 57347)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py	2013-08-01 18:47:14 UTC (rev 57348)
@@ -63,6 +63,7 @@
 from core.settings import UserSettings
 from core.debug    import Debug
+from grass.pydispatch.signal import Signal
 class Select(wx.combo.ComboCtrl):
     def __init__(self, parent, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
@@ -1185,6 +1186,8 @@
         wx.Panel.__init__(self, parent=panel)
+        self.reloadDataRequired = Signal('GdalSelect.reloadDataRequired')
         if self.ogr:
             settingsFile = os.path.join(GetSettingsPath(), 'wxOGR')
         else:
@@ -1405,8 +1408,9 @@
             self.dbWidgets['format'].SetStringSelection(format)
             self.dbWidgets['options'].SetValue(options)
             name = self._getCurrentDbWidgetName()
-            if name == 'choice' and dsn in self.dbWidgets[name].GetItems():
-                self.dbWidgets[name].SetStringSelection(dsn)
+            if name == 'choice':
+                if dsn in self.dbWidgets[name].GetItems():
+                    self.dbWidgets[name].SetStringSelection(dsn)
             else:
                 self.dbWidgets[name].SetValue(dsn)
@@ -1604,9 +1608,8 @@
             db = self.dbWidgets['format'].GetStringSelection()
             self.SetDatabase(db)
-        if hasattr(self.parent, 'list'):
-            self.parent.list.DeleteAllItems()
-            self._reloadLayers()
+        self.reloadDataRequired.emit(data=None)
+        self._reloadLayers()
     def OnSettingsChanged(self, data):
         """!User changed setting"""
@@ -1744,8 +1747,6 @@
                                 dbNames.append(dbname)
                         self.dbWidgets['choice'].SetItems(db)
                         self.dbWidgets['choice'].SetSelection(0)
-                if self.dest and self.dbWidgets['choice'].GetStringSelection():
-                    self.parent.btnOk.Enable(True)
             else:
                 sizer.Show(self.dbWidgets['text'])
                 sizer.Show(self.dbWidgets['choice'], False)
@@ -1774,10 +1775,7 @@
                              flags = 't',
                              dsn = dsn)
             if not ret:
-                    self.parent.list.LoadData()
-                if hasattr(self, "btn_run"):
                 return
             layerId = 1
@@ -1811,11 +1809,7 @@
 #        wx.PostEvent(self.parent, evt)
         if self.parent.GetName() == 'MultiImportDialog':
-            self.parent.list.LoadData(data)
-            if len(data) > 0:
-                self.parent.btn_run.Enable(True)
-            else:
-                self.parent.btn_run.Enable(False)
+            self.reloadDataRequired.emit(data=data)
     def ExtensionChanged(self, event):
         if not self.dest:
@@ -1833,18 +1827,15 @@
     def GetFormat(self):
         """!Get format as string"""
-        if self._sourceType == 'file':
-            format = self.fileWidgets['browse'].GetValue()
-        elif self._sourceType == 'dir':
-            format = self.dirWidgets['browse'].GetValue()
+        if self._sourceType == 'dir':
+            format = self.dirWidgets['format'].GetStringSelection()
         elif self._sourceType == 'pro':
-            format = self.protocolWidgets['text'].GetValue()
+            format = self.protocolWidgets['format'].GetStringSelection()
         elif self._sourceType in ('db', 'db-pg'):
-            wname = self._getCurrentDbWidgetName()
-            if wname =='choice':
-                format = self.dbWidgets[wname].GetStringSelection()
-            else:
-                format = self.dbWidgets[wname].GetValue()
+            format = self.dbWidgets['format'].GetStringSelection()
+        else:
+            format = ''
         return format.replace(' ', '_')
     def GetFormatExt(self):
