[GRASS-SVN] r57367 - grass/trunk/mswindows
svn_grass at osgeo.org
Fri Aug 2 06:39:36 PDT 2013
Author: martinl
Date: 2013-08-02 06:39:34 -0700 (Fri, 02 Aug 2013)
New Revision: 57367
grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
grass/trunk/mswindows/env.bat
wingrass: restore PROJ_LIB variable (fix r57344)
Modified: grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
--- grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2013-08-02 13:37:19 UTC (rev 57366)
+++ grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2013-08-02 13:39:34 UTC (rev 57367)
@@ -835,6 +835,10 @@
FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\share\proj"$\r$\n'
FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
FileWrite $0 '$\r$\n'
+ FileWrite $0 '# Set the PROJ_LIB variable$\r$\n'
+ FileWrite $0 'PROJ_LIB="$INSTALL_DIR\share\proj"$\r$\n'
+ FileWrite $0 'export PROJ_LIB $\r$\n'
+ FileWrite $0 '$\r$\n'
FileWrite $0 '# Set the GDAL_DATA variable$\r$\n'
FileWrite $0 'GDAL_DATA="$INSTALL_DIR\share\gdal"$\r$\n'
FileWrite $0 'export GDAL_DATA$\r$\n'
Modified: grass/trunk/mswindows/env.bat
--- grass/trunk/mswindows/env.bat 2013-08-02 13:37:19 UTC (rev 57366)
+++ grass/trunk/mswindows/env.bat 2013-08-02 13:39:34 UTC (rev 57367)
@@ -6,6 +6,8 @@
set PYTHONHOME=%GISBASE%\Python27
set GRASS_PROJSHARE=%GISBASE%\proj
+set PROJ_LIB=%GISBASE%\share\proj
set GDAL_DATA=%GISBASE%\share\gdal
set GEOTIFF_CSV=%GISBASE%\share\epsg_csv
