[GRASS-SVN] r57368 - grass/branches/releasebranch_6_4/mswindows
svn_grass at osgeo.org
Fri Aug 2 06:40:31 PDT 2013
Author: martinl
Date: 2013-08-02 06:40:31 -0700 (Fri, 02 Aug 2013)
New Revision: 57368
grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl
grass/branches/releasebranch_6_4/mswindows/env.bat
wingrass: restore PROJ_LIB variable (fix r57344)
Modified: grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl 2013-08-02 13:39:34 UTC (rev 57367)
+++ grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl 2013-08-02 13:40:31 UTC (rev 57368)
@@ -806,6 +806,10 @@
FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\share\proj"$\r$\n'
FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
FileWrite $0 '$\r$\n'
+ FileWrite $0 '# Set the PROJ_LIB variable$\r$\n'
+ FileWrite $0 'PROJ_LIB="$INSTALL_DIR\share\proj"$\r$\n'
+ FileWrite $0 'export PROJ_LIB $\r$\n'
+ FileWrite $0 '$\r$\n'
FileWrite $0 '# Set the GDAL_DATA variable$\r$\n'
FileWrite $0 'GDAL_DATA="$INSTALL_DIR\share\gdal"$\r$\n'
FileWrite $0 'export GDAL_DATA$\r$\n'
Modified: grass/branches/releasebranch_6_4/mswindows/env.bat
--- grass/branches/releasebranch_6_4/mswindows/env.bat 2013-08-02 13:39:34 UTC (rev 57367)
+++ grass/branches/releasebranch_6_4/mswindows/env.bat 2013-08-02 13:40:31 UTC (rev 57368)
@@ -10,6 +10,8 @@
set PYTHONHOME=%GISBASE%\Python27
set GRASS_PROJSHARE=%GISBASE%\share\proj
+set PROJ_LIB=%GISBASE%\share\proj
set GDAL_DATA=%GISBASE%\share\gdal
set GEOTIFF_CSV=%GISBASE%\share\epsg_csv
