[GRASS-SVN] r57369 - grass/trunk/mswindows
svn_grass at osgeo.org
Fri Aug 2 09:38:24 PDT 2013
Author: martinl
Date: 2013-08-02 09:38:24 -0700 (Fri, 02 Aug 2013)
New Revision: 57369
grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
grass/trunk/mswindows/Makefile
wingrass: remove unused OSGEO4W_DIR_POSTFIX
Modified: grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
--- grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2013-08-02 13:40:31 UTC (rev 57368)
+++ grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2013-08-02 16:38:24 UTC (rev 57369)
@@ -10,11 +10,11 @@
;Define the source path of the demolocation files
-!define DEMOLOCATION_PATH "c:\OSGeo4W at OSGEO4W_DIR_POSTFIX@\usr\src\grass_trunk\demolocation"
+!define DEMOLOCATION_PATH "c:\OSGeo4W\usr\src\grass_trunk\demolocation"
;Define the source of the patched msys.bat
-!define MSYS_BATCH "C:\OSGeo4W at OSGEO4W_DIR_POSTFIX@\usr\src\grass_trunk\mswindows\osgeo4w\msys.bat"
+!define MSYS_BATCH "C:\OSGeo4W\usr\src\grass_trunk\mswindows\osgeo4w\msys.bat"
;Select if you are building a "Development Version" (Devel) or a "Release Version" (Release) of the GRASS Installer
@@ -887,13 +887,13 @@
;replace gisbase
Push "$INSTDIR\etc\grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py" ; file to modify
- Push 'gisbase = "/c/OSGeo4W at OSGEO4W_DIR_POSTFIX@/apps/grass/grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@"' ; string that a line must begin with *WS Sensitive*
+ Push 'gisbase = "/c/OSGeo4W/apps/grass/grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@"' ; string that a line must begin with *WS Sensitive*
Push 'gisbase = "$INSTDIR"' ; string to replace whole line with
Call ReplaceLineStr
;replace config_projshare
- Push 'config_projshare = "/c/OSGeo4W at OSGEO4W_DIR_POSTFIX@/share/proj"' ; string that a line must begin with *WS Sensitive*
+ Push 'config_projshare = "/c/OSGeo4W/share/proj"' ; string that a line must begin with *WS Sensitive*
Push 'config_projshare = "$INSTDIR\share\proj"' ; string to replace whole line with
Call ReplaceLineStr
Modified: grass/trunk/mswindows/Makefile
--- grass/trunk/mswindows/Makefile 2013-08-02 13:40:31 UTC (rev 57368)
+++ grass/trunk/mswindows/Makefile 2013-08-02 16:38:24 UTC (rev 57369)
@@ -4,10 +4,6 @@
EXTRA_CLEAN_FILES = GRASS-Packager.bat GRASS-Installer.nsi
-# OSGeo4W directory postfix, separate OSGeo4W installations are used
-# for building GRASS 6.x and 7.x
-OSGEO4W_DIR_POSTFIX = '_g7'
ifneq ($(MINGW),)
default: GRASS-Packager.bat GRASS-Installer.nsi
else
@@ -19,7 +15,6 @@
-e 's#@GRASS_VERSION_MAJOR@#$(GRASS_VERSION_MAJOR)#' \
-e 's#@GRASS_VERSION_MINOR@#$(GRASS_VERSION_MINOR)#' \
-e 's#@GRASS_VERSION_RELEASE@#$(GRASS_VERSION_RELEASE)#' \
- -e 's#@OSGEO4W_DIR_POSTFIX@#$(OSGEO4W_DIR_POSTFIX)#' \
GRASS-Installer.nsi: GRASS-Installer.nsi.tmpl
@@ -28,5 +23,4 @@
