[GRASS-SVN] r57393 - grass/trunk/scripts/g.extension.all
svn_grass at osgeo.org
Sun Aug 4 05:29:21 PDT 2013
Author: martinl
Date: 2013-08-04 05:29:21 -0700 (Sun, 04 Aug 2013)
New Revision: 57393
Added:
grass/trunk/scripts/g.extension.all/g.extension.all.html
grass/trunk/scripts/g.extension.all/g.extension.all.py
Removed:
grass/trunk/scripts/g.extension.all/g.extension.rebuild.all.html
grass/trunk/scripts/g.extension.all/g.extension.rebuild.all.py
grass/trunk/scripts/g.extension.all/Makefile
rename g.extension.rebuild.all to g.extension.all (step 2)
Modified: grass/trunk/scripts/g.extension.all/Makefile
--- grass/trunk/scripts/g.extension.all/Makefile 2013-08-04 12:28:23 UTC (rev 57392)
+++ grass/trunk/scripts/g.extension.all/Makefile 2013-08-04 12:29:21 UTC (rev 57393)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = g.extension.rebuild.all
+PGM = g.extension.all
include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass/trunk/scripts/g.extension.all/g.extension.all.html (from rev 57392, grass/trunk/scripts/g.extension.all/g.extension.rebuild.all.html)
--- grass/trunk/scripts/g.extension.all/g.extension.all.html (rev 0)
+++ grass/trunk/scripts/g.extension.all/g.extension.all.html 2013-08-04 12:29:21 UTC (rev 57393)
@@ -0,0 +1,41 @@
+<h2>DESCRIPTION</h2>
+<em>g.extension.rebuild.all</em> reinstalls and updates all locally
+installed GRASS Addons extensions in local GRASS installation. The
+extensions can be installed
+by <em><a href="g.extension.html">g.extension</a></em>. List of
+locally installed extensions can be printed by <tt>g.extension
+-a</tt>.
+<h2>EXAMPLES</h2>
+Rebuild locally installed extensions which were built against
+different GIS Library (see <tt>g.version -r</tt>)
+<div class="code"><pre>
+g.extension.rebuild.all
+</pre></div>
+Force to rebuild all locally installed extensions
+g.extension.rebuild.all -f
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+ <a href="g.extension.html">g.extension</a>
+</em>
+<p>
+See also <a href="http://grasswiki.osgeo.org/wiki/GRASS_AddOns">GRASS Addons</a> wiki page.
+<h2>AUTHOR</h2>
+<a href="http://geo.fsv.cvut.cz/gwiki/Landa">Martin
+Landa</a>, <a href="http://www.cvut.cz">Czech Technical University in
+Prague</a>, Czech Republic
+<p>
+<i>Last changed: $Date$</i>
Copied: grass/trunk/scripts/g.extension.all/g.extension.all.py (from rev 57392, grass/trunk/scripts/g.extension.all/g.extension.rebuild.all.py)
--- grass/trunk/scripts/g.extension.all/g.extension.all.py (rev 0)
+++ grass/trunk/scripts/g.extension.all/g.extension.all.py 2013-08-04 12:29:21 UTC (rev 57393)
@@ -0,0 +1,92 @@
+#!/usr/bin/env python
+# MODULE: g.extension.rebuild.all
+# AUTHOR(S): Martin Landa <landa.martin gmail.com>
+# PURPOSE: Rebuild locally installed GRASS Addons extensions
+# COPYRIGHT: (C) 2011 by Martin Landa, and the GRASS Development Team
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
+#%module
+#% label: Rebuilds all locally installed GRASS Addons extensions.
+#% description: By default only extensions built against different GIS Library are rebuilt.
+#% keywords: general
+#% keywords: installation
+#% keywords: extensions
+#%end
+#%flag
+#% key: f
+#% description: Force to rebuild all extensions
+#% end
+import os
+import sys
+try:
+ import xml.etree.ElementTree as etree
+except ImportError:
+ import elementtree.ElementTree as etree # Python <= 2.4
+import grass.script as grass
+def get_extensions():
+ addon_base = os.getenv('GRASS_ADDON_BASE')
+ if not addon_base:
+ grass.fatal(_("%s not defined") % "GRASS_ADDON_BASE")
+ fXML = os.path.join(addon_base, 'modules.xml')
+ if not os.path.exists(fXML):
+ return []
+ # read XML file
+ fo = open(fXML, 'r')
+ try:
+ tree = etree.fromstring(fo.read())
+ except StandardError, e:
+ grass.error(_("Unable to parse metadata file: %s") % e)
+ fo.close()
+ return []
+ fo.close()
+ libgis_rev = grass.version()['libgis_revision']
+ ret = list()
+ for tnode in tree.findall('task'):
+ gnode = tnode.find('libgis')
+ if gnode is not None and \
+ gnode.get('revision', '') != libgis_rev:
+ ret.append(tnode.get('name'))
+ return ret
+def main():
+ if flags['f']:
+ extensions = grass.read_command('g.extension',
+ quiet = True, flags = 'a').splitlines()
+ else:
+ extensions = get_extensions()
+ if not extensions:
+ grass.info(_("Nothing to rebuild."))
+ return 0
+ for ext in extensions:
+ grass.message('-' * 60)
+ grass.message(_("Reinstalling extension <%s>...") % ext)
+ grass.run_command('g.extension',
+ extension = ext)
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Deleted: grass/trunk/scripts/g.extension.all/g.extension.rebuild.all.html
--- grass/trunk/scripts/g.extension.all/g.extension.rebuild.all.html 2013-08-04 12:28:23 UTC (rev 57392)
+++ grass/trunk/scripts/g.extension.all/g.extension.rebuild.all.html 2013-08-04 12:29:21 UTC (rev 57393)
@@ -1,41 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>g.extension.rebuild.all</em> reinstalls and updates all locally
-installed GRASS Addons extensions in local GRASS installation. The
-extensions can be installed
-by <em><a href="g.extension.html">g.extension</a></em>. List of
-locally installed extensions can be printed by <tt>g.extension
--a</tt>.
-<h2>EXAMPLES</h2>
-Rebuild locally installed extensions which were built against
-different GIS Library (see <tt>g.version -r</tt>)
-<div class="code"><pre>
-g.extension.rebuild.all
-</pre></div>
-Force to rebuild all locally installed extensions
-g.extension.rebuild.all -f
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
- <a href="g.extension.html">g.extension</a>
-</em>
-<p>
-See also <a href="http://grasswiki.osgeo.org/wiki/GRASS_AddOns">GRASS Addons</a> wiki page.
-<h2>AUTHOR</h2>
-<a href="http://geo.fsv.cvut.cz/gwiki/Landa">Martin
-Landa</a>, <a href="http://www.cvut.cz">Czech Technical University in
-Prague</a>, Czech Republic
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass/trunk/scripts/g.extension.all/g.extension.rebuild.all.py
--- grass/trunk/scripts/g.extension.all/g.extension.rebuild.all.py 2013-08-04 12:28:23 UTC (rev 57392)
+++ grass/trunk/scripts/g.extension.all/g.extension.rebuild.all.py 2013-08-04 12:29:21 UTC (rev 57393)
@@ -1,92 +0,0 @@
-#!/usr/bin/env python
-# MODULE: g.extension.rebuild.all
-# AUTHOR(S): Martin Landa <landa.martin gmail.com>
-# PURPOSE: Rebuild locally installed GRASS Addons extensions
-# COPYRIGHT: (C) 2011 by Martin Landa, and the GRASS Development Team
-# This program is free software under the GNU General
-# Public License (>=v2). Read the file COPYING that
-# comes with GRASS for details.
-#%module
-#% label: Rebuilds all locally installed GRASS Addons extensions.
-#% description: By default only extensions built against different GIS Library are rebuilt.
-#% keywords: general
-#% keywords: installation
-#% keywords: extensions
-#%end
-#%flag
-#% key: f
-#% description: Force to rebuild all extensions
-#% end
-import os
-import sys
-try:
- import xml.etree.ElementTree as etree
-except ImportError:
- import elementtree.ElementTree as etree # Python <= 2.4
-import grass.script as grass
-def get_extensions():
- addon_base = os.getenv('GRASS_ADDON_BASE')
- if not addon_base:
- grass.fatal(_("%s not defined") % "GRASS_ADDON_BASE")
- fXML = os.path.join(addon_base, 'modules.xml')
- if not os.path.exists(fXML):
- return []
- # read XML file
- fo = open(fXML, 'r')
- try:
- tree = etree.fromstring(fo.read())
- except StandardError, e:
- grass.error(_("Unable to parse metadata file: %s") % e)
- fo.close()
- return []
- fo.close()
- libgis_rev = grass.version()['libgis_revision']
- ret = list()
- for tnode in tree.findall('task'):
- gnode = tnode.find('libgis')
- if gnode is not None and \
- gnode.get('revision', '') != libgis_rev:
- ret.append(tnode.get('name'))
- return ret
-def main():
- if flags['f']:
- extensions = grass.read_command('g.extension',
- quiet = True, flags = 'a').splitlines()
- else:
- extensions = get_extensions()
- if not extensions:
- grass.info(_("Nothing to rebuild."))
- return 0
- for ext in extensions:
- grass.message('-' * 60)
- grass.message(_("Reinstalling extension <%s>...") % ext)
- grass.run_command('g.extension',
- extension = ext)
- return 0
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
