[GRASS-SVN] r57394 - in grass/trunk/gui/wxpython: core gcp gui_core mapdisp
svn_grass at osgeo.org
Sun Aug 4 06:05:27 PDT 2013
Author: wenzeslaus
Date: 2013-08-04 06:05:26 -0700 (Sun, 04 Aug 2013)
New Revision: 57394
grass/trunk/gui/wxpython/core/units.py
grass/trunk/gui/wxpython/core/utils.py
grass/trunk/gui/wxpython/gcp/mapdisplay.py
grass/trunk/gui/wxpython/gui_core/mapwindow.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
wxGUI: moving code from BufferedWindow and map display to utils, adding doctests, removing unused functions
Modified: grass/trunk/gui/wxpython/core/units.py
--- grass/trunk/gui/wxpython/core/units.py 2013-08-04 12:29:21 UTC (rev 57393)
+++ grass/trunk/gui/wxpython/core/units.py 2013-08-04 13:05:26 UTC (rev 57394)
@@ -22,6 +22,15 @@
@author Martin Landa <landa.martin gmail.com>
+import math
+if __name__ == '__main__':
+ import os
+ import sys
+ gui_wx_path = os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython')
+ if gui_wx_path not in sys.path:
+ sys.path.append(gui_wx_path)
from core.utils import _
class BaseUnits:
@@ -117,3 +126,96 @@
f = 1.0e-4
return f * value
+def formatDist(distance, mapunits):
+ """!Formats length numbers and units in a nice way.
+ Formats length numbers and units as a function of length.
+ @code
+ >>> formatDist(20.56915, 'metres')
+ (20.57, 'm')
+ >>> formatDist(6983.4591, 'metres')
+ (6.983, 'km')
+ >>> formatDist(0.59, 'feet')
+ (0.59, 'ft')
+ >>> formatDist(8562, 'feet')
+ (1.622, 'miles')
+ >>> formatDist(0.48963, 'degrees')
+ (29.38, 'min')
+ >>> formatDist(20.2546, 'degrees')
+ (20.25, 'deg')
+ >>> formatDist(82.146, 'unknown')
+ (82.15, 'meters')
+ @endcode
+ Accepted map units are 'meters', 'metres', 'feet', 'degree'. Any
+ other units will be considered as meters (output 'meters').
+ @param distance map units
+ @param mapunits map units
+ From code by Hamish Bowman Grass Development Team 2006.
+ if mapunits == 'metres':
+ mapunits = 'meters'
+ outunits = mapunits
+ distance = float(distance)
+ divisor = 1.0
+ # figure out which units to use
+ if mapunits == 'meters':
+ if distance > 2500.0:
+ outunits = 'km'
+ divisor = 1000.0
+ else:
+ outunits = 'm'
+ elif mapunits == 'feet':
+ # nano-bug: we match any "feet", but US Survey feet is really
+ # 5279.9894 per statute mile, or 10.6' per 1000 miles. As >1000
+ # miles the tick markers are rounded to the nearest 10th of a
+ # mile (528'), the difference in foot flavours is ignored.
+ if distance > 5280.0:
+ outunits = 'miles'
+ divisor = 5280.0
+ else:
+ outunits = 'ft'
+ elif 'degree' in mapunits:
+ # was: 'degree' in mapunits and not haveCtypes (for unknown reason)
+ if distance < 1:
+ outunits = 'min'
+ divisor = (1/60.0)
+ else:
+ outunits = 'deg'
+ else:
+ outunits = 'meters'
+ # format numbers in a nice way
+ if (distance / divisor) >= 2500.0:
+ outdistance = round(distance / divisor)
+ elif (distance / divisor) >= 1000.0:
+ outdistance = round(distance / divisor, 1)
+ elif (distance / divisor) > 0.0:
+ int(math.ceil(3 - math.log10(distance / divisor))))
+ else:
+ outdistance = float(distance / divisor)
+ return (outdistance, outunits)
+def doc_test():
+ """Tests the module using doctest
+ @return a number of failed tests
+ import doctest
+ from core.utils import do_doctest_gettext_workaround
+ do_doctest_gettext_workaround()
+ return doctest.testmod().failed
+ sys.exit(doc_test())
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2013-08-04 12:29:21 UTC (rev 57393)
+++ grass/trunk/gui/wxpython/core/utils.py 2013-08-04 13:05:26 UTC (rev 57394)
@@ -21,6 +21,11 @@
import re
import inspect
from core.globalvar import ETCDIR
if os.path.join(ETCDIR, "python") not in sys.path:
sys.path.append(os.path.join(ETCDIR, "python"))
@@ -1062,3 +1067,75 @@
os._exit(0)
else:
mainfn()
+def isInRegion(regionA, regionB):
+ """!Tests if 'regionA' is inside of 'regionB'.
+ For example, region A is a display region and region B is some reference
+ region, e.g., a computational region.
+ @code
+ >>> displayRegion = {'n': 223900, 's': 217190, 'w': 630780, 'e': 640690}
+ >>> compRegion = {'n': 228500, 's': 215000, 'w': 630000, 'e': 645000}
+ >>> isInRegion(displayRegion, compRegion)
+ True
+ >>> displayRegion = {'n':226020, 's': 212610, 'w': 626510, 'e': 646330}
+ False
+ @endcode
+ @param regionA input region A as dictionary
+ @param regionB input region B as dictionary
+ @return True if region A is inside of region B
+ @return False othewise
+ if regionA['s'] >= regionB['s'] and \
+ regionA['n'] <= regionB['n'] and \
+ regionA['w'] >= regionB['w'] and \
+ regionA['e'] <= regionB['e']:
+ return True
+ return False
+def do_doctest_gettext_workaround():
+ """Setups environment for doing a doctest with gettext usage.
+ When using gettext with dynamically defined underscore function
+ (`_("For translation")`), doctest does not work properly. One option is to
+ use `import as` instead of dynamically defined underscore function but this
+ would require change all modules which are used by tested module. This
+ should be considered for the future. The second option is to define dummy
+ underscore function and one other function which creates the right
+ environment to satisfy all. This is done by this function.
+ def new_displayhook(string):
+ """A replacement for default `sys.displayhook`"""
+ if string is not None:
+ sys.stdout.write("%r\n" % (string,))
+ def new_translator(string):
+ """A fake gettext underscore function."""
+ return string
+ sys.displayhook = new_displayhook
+ import __builtin__
+ __builtin__._ = new_translator
+def doc_test():
+ import doctest
Modified: grass/trunk/gui/wxpython/gcp/mapdisplay.py
--- grass/trunk/gui/wxpython/gcp/mapdisplay.py 2013-08-04 12:29:21 UTC (rev 57393)
+++ grass/trunk/gui/wxpython/gcp/mapdisplay.py 2013-08-04 13:05:26 UTC (rev 57394)
@@ -431,25 +431,6 @@
win.EraseMap()
- def OnZoomRegion(self, event):
- Zoom to region
- self.Map.getRegion()
- self.Map.getResolution()
- self.UpdateMap()
- # event.Skip()
- def OnAlignRegion(self, event):
- Align region
- if not self.Map.alignRegion:
- self.Map.alignRegion = True
- else:
- self.Map.alignRegion = False
- # event.Skip()
def SaveToFile(self, event):
"""!Save map to image
@@ -516,54 +497,7 @@
# will be called before PopupMenu returns.
self.PopupMenu(printmenu)
printmenu.Destroy()
- def FormatDist(self, dist):
- """!Format length numbers and units in a nice way,
- as a function of length. From code by Hamish Bowman
- Grass Development Team 2006"""
- mapunits = self.Map.projinfo['units']
- if mapunits == 'metres': mapunits = 'meters'
- outunits = mapunits
- dist = float(dist)
- divisor = 1.0
- # figure out which units to use
- if mapunits == 'meters':
- if dist > 2500.0:
- outunits = 'km'
- divisor = 1000.0
- else: outunits = 'm'
- elif mapunits == 'feet':
- # nano-bug: we match any "feet", but US Survey feet is really
- # 5279.9894 per statute mile, or 10.6' per 1000 miles. As >1000
- # miles the tick markers are rounded to the nearest 10th of a
- # mile (528'), the difference in foot flavours is ignored.
- if dist > 5280.0:
- outunits = 'miles'
- divisor = 5280.0
- else:
- outunits = 'ft'
- elif 'degree' in mapunits:
- if dist < 1:
- outunits = 'min'
- divisor = (1/60.0)
- else:
- outunits = 'deg'
- # format numbers in a nice way
- if (dist/divisor) >= 2500.0:
- outdist = round(dist/divisor)
- elif (dist/divisor) >= 1000.0:
- outdist = round(dist/divisor,1)
- elif (dist/divisor) > 0.0:
- outdist = round(dist/divisor,int(math.ceil(3-math.log10(dist/divisor))))
- else:
- outdist = float(dist/divisor)
- return (outdist, outunits)
def OnZoomToRaster(self, event):
Set display extents to match selected raster map (ignore NULLs)
Modified: grass/trunk/gui/wxpython/gui_core/mapwindow.py
--- grass/trunk/gui/wxpython/gui_core/mapwindow.py 2013-08-04 12:29:21 UTC (rev 57393)
+++ grass/trunk/gui/wxpython/gui_core/mapwindow.py 2013-08-04 13:05:26 UTC (rev 57394)
@@ -107,7 +107,12 @@
self.parent = parent
self.Map = Map
self._giface = giface
+ # Emitted when someone registers as mouse event handler
+ self.mouseHandlerRegistered = Signal('BufferedWindow.mouseHandlerRegistered')
+ # Emitted when mouse event handler is unregistered
+ self.mouseHandlerUnregistered = Signal('BufferedWindow.mouseHandlerUnregistered')
# mouse attributes -- position on the screen, begin and end of
# dragging, and type of drawing
self.mouse = {
@@ -205,7 +210,9 @@
self.mapwin.UnregisterMouseEventHandler(wx.EVT_LEFT_DOWN, self.OnMouseAction)
event.Skip()
@endcode
+ Emits mouseHandlerRegistered signal before handler is registered.
@param event one of mouse events
@param handler function to handle event
@param cursor cursor which temporary overrides current cursor
@@ -213,6 +220,7 @@
@return True if successful
@return False if event cannot be bind
+ self.mouseHandlerRegistered.emit()
# inserts handler into list
for containerEv, handlers in self.handlersContainer.iteritems():
if event == containerEv:
@@ -254,6 +262,8 @@
Before handler is unregistered it is called with string value
"unregistered" of event parameter.
+ Emits mouseHandlerUnregistered signal after handler is unregistered.
@param handler handler to unbind
@param event event from which handler will be unbinded
@@ -283,7 +293,8 @@
# restore overridden cursor
if self._overriddenCursor:
self.SetCursor(self._overriddenCursor)
+ self.mouseHandlerUnregistered.emit()
return True
def Pixel2Cell(self, xyCoords):
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-04 12:29:21 UTC (rev 57393)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-04 13:05:26 UTC (rev 57394)
@@ -37,6 +37,7 @@
sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
from core import globalvar
+import core.units as units
from core.render import Map
from vdigit.toolbars import VDigitToolbar
from mapdisp.toolbars import MapToolbar, NvizIcons
@@ -559,26 +560,7 @@
# change the cursor
self.MapWindow.SetCursor(self.cursors["hand"])
self.MapWindow.SetFocus()
- # TODO: can be replaced/merged by ZoomToWind
- """!Zoom to region
- self.UpdateMap()
- # event.Skip()
- # TODO: delete this here and in gcp
- """!Align region
- else:
- # event.Skip()
@@ -933,11 +915,12 @@
dist, (north, east) = self.MapWindow.Distance(beginpt, endpt)
dist = round(dist, 3)
- d, dunits = self.FormatDist(dist)
+ d, dunits = units.formatDist(dist, self.Map.projinfo['units'])
self.totaldist += dist
- td, tdunits = self.FormatDist(self.totaldist)
+ td, tdunits = units.formatDist(self.totaldist,
+ self.Map.projinfo['units'])
strdist = str(d)
strtotdist = str(td)
@@ -981,58 +964,6 @@
# the desired raster) is selected to be profiled
win.OnSelectRaster(None)
- # TODO: move somewhere where can be reused (utils?), remove from gcp
- mapunits = 'meters'
- divisor = 1.0
- if dist > 2500.0:
- outunits = 'km'
- divisor = 1000.0
- if dist > 5280.0:
- divisor = 5280.0
- else:
- outunits = 'ft'
- elif 'degree' in mapunits and \
- not haveCtypes:
- if dist < 1:
- outunits = 'min'
- else:
- outunits = 'deg'
- else:
- outunits = 'meters'
- else:
def OnHistogramPyPlot(self, event):
"""!Init PyPlot histogram display canvas and tools
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-08-04 12:29:21 UTC (rev 57393)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-08-04 13:05:26 UTC (rev 57394)
@@ -8,7 +8,7 @@
- mapwindow::GraphicsSet
- mapwindow::GraphicsSetItem
-(C) 2006-2012 by the GRASS Development Team
+(C) 2006-2013 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -16,8 +16,9 @@
@author Michael Barton
@author Jachym Cepicky
- at author Vaclav Petras <wenzeslaus gmail.com> (handlers support)
@author Stepan Turek <stepan.turek seznam.cz> (handlers support, GraphicsSet)
+ at author Anna Petrasova <kratochanna gmail.com> (refactoring)
+ at author Vaclav Petras <wenzeslaus gmail.com> (refactoring)
import os
@@ -38,6 +39,7 @@
from core.settings import UserSettings
from gui_core.mapwindow import MapWindow
from core.utils import GetGEventAttribsForHandler, _
+import core.utils as utils
try:
import grass.lib.gis as gislib
@@ -100,11 +102,6 @@
# Emitted when the zoom history stack is not empty
self.zoomHistoryAvailable = Signal('BufferedWindow.zoomHistoryAvailable')
- # Emitted when someone registers as mouse event handler
- self.mouseHandlerRegistered = Signal('BufferedWindow.mouseHandlerRegistered')
- # Emitted when mouse event handler is unregistered
- self.mouseHandlerUnregistered = Signal('BufferedWindow.mouseHandlerUnregistered')
# Emitted when map enters the window
self.mouseEntered = Signal('BufferedWindow.mouseEntered')
# Emitted when left mouse button is released and mouse use is 'pointer'
@@ -766,7 +763,7 @@
compReg = self.Map.GetRegion()
dispReg = self.Map.GetCurrentRegion()
reg = None
- if self.IsInRegion(dispReg, compReg):
+ if utils.isInRegion(dispReg, compReg):
self.polypen = wx.Pen(colour = wx.Colour(0, 0, 255, 128), width = 3, style = wx.SOLID)
reg = dispReg
else:
@@ -783,25 +780,6 @@
# draw region extent
self.DrawLines(pdc=self.pdcDec, polycoords=regionCoords)
- # TODO: move to utils
- def IsInRegion(self, region, refRegion):
- Test if 'region' is inside of 'refRegion'
- @param region input region
- @param refRegion reference region (e.g. computational region)
- @return True if region is inside of refRegion
- @return False
- if region['s'] >= refRegion['s'] and \
- region['n'] <= refRegion['n'] and \
- region['w'] >= refRegion['w'] and \
- region['e'] <= refRegion['e']:
- return True
- return False
def EraseMap(self):
"""!Erase map canvas
@@ -1817,22 +1795,6 @@
"""!Get render.Map() instance"""
return self.Map
- def RegisterMouseEventHandler(self, event, handler, cursor = None):
- """Registeres mouse event handler.
- Emits mouseHandlerRegistered signal before handler is registered.
- self.mouseHandlerRegistered.emit()
- MapWindow.RegisterMouseEventHandler(self, event, handler, cursor)
- def UnregisterMouseEventHandler(self, event, handler):
- """Unregisteres mouse event handler.
- Emits mouseHandlerUnregistered signal after handler is unregistered.
- MapWindow.UnregisterMouseEventHandler(self, event, handler)
- self.mouseHandlerUnregistered.emit()
def RegisterGraphicsToDraw(self, graphicsType, setStatusFunc = None, drawFunc = None):
"""! This method registers graphics to draw.
