[GRASS-SVN] r57399 - grass/trunk/gui/wxpython/mapdisp
svn_grass at osgeo.org
Sun Aug 4 10:02:58 PDT 2013
Author: annakrat
Date: 2013-08-04 10:02:58 -0700 (Sun, 04 Aug 2013)
New Revision: 57399
grass/trunk/gui/wxpython/mapdisp/frame.py
wxGUI: fix distance formatting for ll projection (recent change broke it)
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-04 16:47:23 UTC (rev 57398)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-04 17:02:58 UTC (rev 57399)
@@ -1226,12 +1226,14 @@
self._mapWindow = self._giface.GetMapWindow()
self._projInfo = self._mapWindow.Map.projinfo
self._measureGraphics = None
self._totaldist = 0.0 # total measured distance
self._oldMouseUse = None
self._oldCursor = None
+ self._useCtypes = False
def IsMeasuring(self):
"""!Returns True if measuring mode is enabled, otherwise False"""
return bool(self._measureGraphics)
@@ -1329,10 +1331,11 @@
try:
import grass.lib.gis as gislib
gislib.G_begin_distance_calculations()
+ self._useCtypes = True
except ImportError, e:
- self._giface.WriteWarning(_('Geodesic distance is not yet '
- 'supported by this tool.\n'
- 'Reason: %s' % e))
+ self._giface.WriteWarning(_('Geodesic distance calculation '
+ 'is not available.\n'
+ 'Reason: %s' % e))
def MeasureDist(self, beginpt, endpt):
"""!Calculate distance and print to output window.
@@ -1343,11 +1346,14 @@
dist, (north, east) = self._mapWindow.Distance(beginpt, endpt, screen=False)
dist = round(dist, 3)
- d, dunits = units.formatDist(dist, self._projInfo['units'])
+ mapunits = self._projInfo['units']
+ if mapunits == 'degrees' and self._useCtypes:
+ mapunits = 'meters'
+ d, dunits = units.formatDist(dist, mapunits)
self._totaldist += dist
td, tdunits = units.formatDist(self._totaldist,
- self._projInfo['units'])
+ mapunits)
strdist = str(d)
strtotdist = str(td)
