[GRASS-SVN] r57400 - in grass/trunk/gui/wxpython: lmgr mapdisp nviz vdigit
svn_grass at osgeo.org
Sun Aug 4 10:51:16 PDT 2013
Author: wenzeslaus
Date: 2013-08-04 10:51:16 -0700 (Sun, 04 Aug 2013)
New Revision: 57400
grass/trunk/gui/wxpython/lmgr/layertree.py
grass/trunk/gui/wxpython/mapdisp/statusbar.py
grass/trunk/gui/wxpython/nviz/mapwindow.py
grass/trunk/gui/wxpython/vdigit/toolbars.py
wxGUI: removing dead code related to vdigit button in lmgr (not needed, might be useful but this was not working for multiple map displays), fixing query in nviz (frame required), fixing statusbar error displaying
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2013-08-04 17:02:58 UTC (rev 57399)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2013-08-04 17:51:16 UTC (rev 57400)
@@ -719,9 +719,8 @@
maplayer = self.GetLayerInfo(self.layer_selected, key = 'maplayer')
self.mapdisplay.toolbars['vdigit'].OnExit()
- if self.lmgr:
- self.lmgr.toolbars['tools'].Enable('vdigit', enable = True)
+ # here was dead code to enable vdigit button in toolbar
self._setGradient()
self.RefreshLine(self.layer_selected)
Modified: grass/trunk/gui/wxpython/mapdisp/statusbar.py
--- grass/trunk/gui/wxpython/mapdisp/statusbar.py 2013-08-04 17:02:58 UTC (rev 57399)
+++ grass/trunk/gui/wxpython/mapdisp/statusbar.py 2013-08-04 17:51:16 UTC (rev 57400)
@@ -886,7 +886,7 @@
value = self._basicValue
self.SetValue(value)
except SbException, e:
- self.SetValue(e)
+ self.SetValue(e.message)
# TODO: remove these excepts, they just hide errors, solve problems differently
except TypeError, e:
self.SetValue("")
@@ -955,7 +955,7 @@
regionReprojected = self.ReprojectRegionFromMap(region, projection, precision, format)
self.SetValue(regionReprojected)
- self.SetValue(e)
SbTextItem.Show(self)
def _getRegion(self):
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py 2013-08-04 17:02:58 UTC (rev 57399)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py 2013-08-04 17:51:16 UTC (rev 57400)
@@ -71,12 +71,14 @@
class GLWindow(MapWindow, glcanvas.GLCanvas):
"""!OpenGL canvas for Map Display Window"""
- def __init__(self, parent, giface, id = wx.ID_ANY, frame = None,
- Map = None, tree = None, lmgr = None):
- self.parent = parent # MapFrame
+ def __init__(self, parent, giface, frame, Map, tree, lmgr, id=wx.ID_ANY):
+ """All parameters except for id are mandatory. The todo is to remove
+ them completely."""
+ self.parent = parent
self.tree = tree
self.lmgr = lmgr
+ self.frame = frame
# for wxGTK we need to set WX_GL_DEPTH_SIZE to draw vectors correctly
# but we don't know the right value
# in wxpython 2.9, there is IsDisplaySupported
Modified: grass/trunk/gui/wxpython/vdigit/toolbars.py
--- grass/trunk/gui/wxpython/vdigit/toolbars.py 2013-08-04 17:02:58 UTC (rev 57399)
+++ grass/trunk/gui/wxpython/vdigit/toolbars.py 2013-08-04 17:51:16 UTC (rev 57400)
@@ -798,10 +798,9 @@
if 'map' in self.parent.toolbars:
self.parent.toolbars['map'].combo.SetValue (_('Digitize'))
- if self.digitClass != IClassVDigit:
- lmgr = self.parent.GetLayerManager()
- if lmgr:
- lmgr.toolbars['tools'].Enable('vdigit', enable = False)
+ # with if to ignore iclass
+ # some signal (DigitizerStarted) can be emitted here
Debug.msg (4, "VDigitToolbar.StartEditing(): layer=%s" % mapLayer.GetName())
@@ -854,7 +853,8 @@
# TODO: replace by giface
if lmgr:
- lmgr.toolbars['tools'].Enable('vdigit', enable = True)
+ # some signal (DigitizerEnded) can be emitted here
lmgr._giface.GetProgress().SetValue(0)
lmgr.GetLogWindow().WriteCmdLog(_("Editing of vector map <%s> successfully finished") % \
self.mapLayer.GetName())
