[GRASS-SVN] r57444 - in grass/trunk/lib/vector: Vlib diglib
svn_grass at osgeo.org
Sun Aug 11 11:08:11 PDT 2013
Author: martinl
Date: 2013-08-11 11:08:11 -0700 (Sun, 11 Aug 2013)
New Revision: 57444
grass/trunk/lib/vector/Vlib/cindex.c
grass/trunk/lib/vector/Vlib/close_nat.c
grass/trunk/lib/vector/Vlib/level_two.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/open_nat.c
grass/trunk/lib/vector/diglib/head.c
vlib: fix open topo/cidx for temporary vector maps
introduce GRASS_VECTOR_TEMPORARY variable
debug messages cosmetics
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c 2013-08-11 09:11:11 UTC (rev 57443)
+++ grass/trunk/lib/vector/Vlib/cindex.c 2013-08-11 18:08:11 UTC (rev 57444)
@@ -485,7 +485,7 @@
int Vect_cidx_open(struct Map_info *Map, int head_only)
int ret;
- char buf[500], file_path[2000];
+ char file_path[GPATH_MAX], *path;
struct gvfile fp;
struct Plus_head *Plus;
@@ -494,16 +494,18 @@
Plus = &(Map->plus);
- sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
- G_file_name(file_path, buf, GV_CIDX_ELEMENT, Map->mapset);
+ path = Vect__get_path(Map);
+ G_file_name(file_path, path, GV_CIDX_ELEMENT, Map->mapset);
- if (access(file_path, F_OK) != 0) /* does not exist */
+ if (access(file_path, F_OK) != 0) { /* does not exist */
+ G_free(path);
return 1;
dig_file_init(&fp);
- fp.file = G_fopen_old(buf, GV_CIDX_ELEMENT, Map->mapset);
+ fp.file = G_fopen_old(path, GV_CIDX_ELEMENT, Map->mapset);
+ G_free(path);
if (fp.file == NULL) { /* category index file is not available */
G_warning(_("Unable to open category index file for vector map <%s>"),
Vect_get_full_name(Map));
Modified: grass/trunk/lib/vector/Vlib/close_nat.c
--- grass/trunk/lib/vector/Vlib/close_nat.c 2013-08-11 09:11:11 UTC (rev 57443)
+++ grass/trunk/lib/vector/Vlib/close_nat.c 2013-08-11 18:08:11 UTC (rev 57444)
@@ -50,9 +50,15 @@
fclose(Map->dig_fp.file);
dig_file_free(&(Map->dig_fp));
- /* delete temporary map */
+ /* delete temporary map ? */
if (Map->temporary) {
- Vect__delete(Map->name, TRUE);
+ if (getenv("GRASS_VECTOR_TEMPORARY") == NULL) {
+ G_debug(1, "V1_close_nat(): temporary map <%s> TO BE DELETED", Map->name);
+ Vect__delete(Map->name, TRUE);
+ else {
+ G_debug(1, "V1_close_nat(): temporary map <%s> IS NOT DELETED", Map->name);
return 0;
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c 2013-08-11 09:11:11 UTC (rev 57443)
+++ grass/trunk/lib/vector/Vlib/level_two.c 2013-08-11 18:08:11 UTC (rev 57444)
@@ -457,6 +457,8 @@
void Vect_set_updated(struct Map_info *Map, int enable)
+ G_debug(1, "Vect_set_updated(): name = '%s' enabled = %d", Map->name, enable);
check_level(Map);
Map->plus.uplist.do_uplist = enable != 0 ? TRUE : FALSE;
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2013-08-11 09:11:11 UTC (rev 57443)
+++ grass/trunk/lib/vector/Vlib/open.c 2013-08-11 18:08:11 UTC (rev 57444)
@@ -171,8 +171,13 @@
const char *fmapset;
G_debug(1, "Vect__open_old(): name = %s, mapset = %s, layer = %s, update = %d, "
- "head_only = %d, is_tmp = %d", name, mapset, layer ? layer : "", update, head_only,
+ "head_only = %d, is_tmp = %d", name, mapset, layer ? layer : "NULL", update, head_only,
is_tmp);
+ if (!is_tmp) {
+ is_tmp = getenv("GRASS_VECTOR_TEMPORARY") ? TRUE : FALSE;
+ G_debug(1, "Vect__open_old(): is_tmp = %d (check GRASS_VECTOR_TEMPORARY)", is_tmp);
/* zero Map_info structure */
G_zero(Map, sizeof(struct Map_info));
@@ -845,7 +850,12 @@
int Vect_open_new(struct Map_info *Map, const char *name, int with_z)
- return open_new(Map, name, with_z, FALSE);
+ int is_tmp;
+ G_debug(1, "Vect_open_new(): is_tmp = %d", is_tmp);
+ return open_new(Map, name, with_z, is_tmp);
@@ -878,7 +888,8 @@
else {
sprintf(tmp_name, "%s", name);
+ G_debug(1, "Vect_open_tmp_new(): name = '%s' with_z = %d", name, with_z);
return open_new(Map, tmp_name, with_z, TRUE); /* temporary map */
@@ -1017,24 +1028,27 @@
int Vect_open_topo(struct Map_info *Map, int head_only)
int err, ret;
- char buf[GPATH_MAX], file_path[GPATH_MAX];
struct gvfile fp;
struct Coor_info CInfo;
- G_debug(1, "Vect_open_topo(): name = %s mapset= %s", Map->name,
+ G_debug(1, "Vect_open_topo(): name = %s mapset = %s", Map->name,
Map->mapset);
- G_file_name(file_path, buf, GV_TOPO_ELEMENT, Map->mapset);
+ G_file_name(file_path, path, GV_TOPO_ELEMENT, Map->mapset);
+ G_free(path);
return 1;
dig_file_init(&fp);
- fp.file = G_fopen_old(buf, GV_TOPO_ELEMENT, Map->mapset);
+ fp.file = G_fopen_old(path, GV_TOPO_ELEMENT, Map->mapset);
+ G_free(path);
if (fp.file == NULL) { /* topo file is not available */
G_debug(1, "Cannot open topo file for vector '%s@%s'.",
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c 2013-08-11 09:11:11 UTC (rev 57443)
+++ grass/trunk/lib/vector/Vlib/open_nat.c 2013-08-11 18:08:11 UTC (rev 57444)
@@ -38,32 +38,36 @@
int V1_open_old_nat(struct Map_info *Map, int update)
- char buf[1000];
+ char *path;
G_debug(1, "V1_open_old_nat(): name = %s mapset = %s", Map->name,
Map->mapset);
dig_file_init(&(Map->dig_fp));
if (update)
- Map->dig_fp.file = G_fopen_modify(buf, GV_COOR_ELEMENT);
+ Map->dig_fp.file = G_fopen_modify(path, GV_COOR_ELEMENT);
else
Map->dig_fp.file =
- G_fopen_old(buf, GV_COOR_ELEMENT, Map->mapset);
+ G_fopen_old(path, GV_COOR_ELEMENT, Map->mapset);
+ G_free(path);
if (Map->dig_fp.file == NULL) {
G_warning(_("Unable to open coor file for vector map <%s>"),
return -1;
- /* needed to determine file size, Map->head.size will be updated by dig__read_head(Map) */
+ /* needed to determine file size, Map->head.size will be updated
+ by dig__read_head(Map) */
Vect_coor_info(Map, &CInfo);
Map->head.size = CInfo.size;
- if (!(dig__read_head(Map)))
- return (-1);
+ if (!(dig__read_head(Map))) {
+ G_debug(1, "dig__read_head(): failed");
+ return -1;
/* compare coor size stored in head with real size */
/* check should catch if LFS is required but not available */
Modified: grass/trunk/lib/vector/diglib/head.c
--- grass/trunk/lib/vector/diglib/head.c 2013-08-11 09:11:11 UTC (rev 57443)
+++ grass/trunk/lib/vector/diglib/head.c 2013-08-11 18:08:11 UTC (rev 57444)
@@ -85,6 +85,7 @@
unsigned char buf[10];
struct Port_info port;
+ G_debug(2, "dig__read_head(): name = '%s'", Map->name);
dig_fseek(&(Map->dig_fp), 0L, 0);
/* bytes 1 - 5 */
@@ -96,8 +97,7 @@
Map->head.coor_version.back_minor = buf[3];
Map->head.port.byte_order = buf[4];
- G_debug(2,
- "Coor header: file version %d.%d , supported from GRASS version %d.%d",
+ G_debug(2, "Coor header: file version %d.%d , supported from GRASS version %d.%d",
Map->head.coor_version.major, Map->head.coor_version.minor,
Map->head.coor_version.back_major, Map->head.coor_version.back_minor);
