[GRASS-SVN] r57445 - grass/trunk/lib/init
svn_grass at osgeo.org
Sun Aug 11 11:27:36 PDT 2013
Author: martinl
Date: 2013-08-11 11:27:36 -0700 (Sun, 11 Aug 2013)
New Revision: 57445
grass/trunk/lib/init/variables.html
document GRASS_VECTOR_TEMPORARY variable
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2013-08-11 18:08:11 UTC (rev 57444)
+++ grass/trunk/lib/init/variables.html 2013-08-11 18:27:36 UTC (rev 57445)
@@ -259,6 +259,19 @@
by <em><a href="v.external.out.html">v.external.out</a></em> is
ignored. The format is always native.</dd>
+ <dt>GRASS_VECTOR_TEMPORARY</dt>
+ <dd>[vectorlib]<br> If the environment variable
+ GRASS_VECTOR_TEMPORARY exists, vector library will operate with
+ temporary vector maps. New vector maps will be created
+ in <tt>$MAPSET/.tmp/$HOSTNAME/vector</tt>, existing vector maps
+ will be read also from this directory. Note that temporary vector
+ maps are not visible to the user
+ via <em><a href="g.list.html">g.list</a></em>. They are used
+ internally by the GRASS modules and deleted automatically when the
+ map is closed or GRASS session quited. Note that this variable is
+ dedicated for internal use only.
+ </dd>
<dt>GRASS_WXBUNDLED</dt>
<dd>[wxGUI]<br>
set to tell wxGUI that a bundled wxPython will be used.<br>
