[GRASS-SVN] r57463 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Sat Aug 17 15:18:15 PDT 2013
Author: huhabla
Date: 2013-08-17 15:18:14 -0700 (Sat, 17 Aug 2013)
New Revision: 57463
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/register.py
Code refracturing. Added metadata table to allow tgis database version check.
Sqlite database build speedup.
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-08-17 22:15:59 UTC (rev 57462)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-08-17 22:18:14 UTC (rev 57463)
@@ -1087,8 +1087,9 @@
rows = self.get_registered_maps("id,start_time,end_time",
where, order, dbif)
has_bt_columns = False
- core.warning(_("Old temporal database format. The top and "\
- "bottom column is missing in the views, using"\
+ core.warning(_("Old temporal database format detected. "
+ "The top and "
+ "bottom column is missing in the views, using"
"a work around."))
except:
raise
@@ -1105,9 +1106,10 @@
if has_bt_columns:
map.set_spatial_extent_from_values(west=row["west"],
east=row["east"],
- south=row["south"], top=row["top"],
- north=row["north"],
- bottom=row["bottom"])
+ south=row["south"],
+ top=row["top"],
+ north=row["north"],
+ bottom=row["bottom"])
# The slow work around
else:
map.spatial_extent.select(dbif)
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2013-08-17 22:15:59 UTC (rev 57462)
+++ grass/trunk/lib/python/temporal/core.py 2013-08-17 22:18:14 UTC (rev 57463)
@@ -35,9 +35,8 @@
@author Soeren Gebbert
import os
-import copy
-import sys
import grass.script.core as core
+from datetime import datetime
# Import all supported database backends
# Ignore import errors since they are checked later
try:
@@ -54,10 +53,17 @@
# Global variable that defines the backend
# of the temporal GIS
# It can either be "sqlite" or "pg"
-tgis_backed = None
+tgis_backend = None
# The version of the temporal framework
-tgis_version="1.0"
+# this value must be an integer larger than 0
+# Increase this value in case of backward incompatible changes in the TGIS API
+tgis_version=1
+# The version of the temporal database since framework and database version can differ
+# temporal database SQL layout
+tgis_db_version=1
@@ -68,14 +74,38 @@
global tgis_version
return tgis_version
+def get_tgis_metadata(dbif=None):
+ """!Return the tgis metadata table as a list of rows (dicts)
+ or None if not present
+ @param dbif The database interface to be used
+ @return The selected rows with key/value comumns or None
+ dbif, connected = init_dbif(dbif)
+ # Select metadata if the table is present
+ try:
+ statement = "SELECT * FROM tgis_metadata;\n"
+ dbif.cursor.execute(statement)
+ rows = dbif.cursor.fetchall()
+ except:
+ rows = None
+ if connected:
+ dbif.close()
+ return rows
def get_temporal_dbmi_init_string():
kv = core.parse_command("t.connect", flags="pg")
grassenv = core.gisenv()
- global tgis_backed
- if tgis_backed == "sqlite":
+ global tgis_backend
+ if tgis_backend == "sqlite":
if "database" in kv:
string = kv["database"]
string = string.replace("$GISDBASE", grassenv["GISDBASE"])
@@ -86,7 +116,7 @@
core.fatal(_("Unable to initialize the temporal GIS DBMI "
"interface. Use t.connect to specify the driver "
"and the database string"))
- elif tgis_backed == "pg":
+ elif tgis_backend == "pg":
return string
@@ -146,16 +176,14 @@
can be started
# We need to set the correct database backend from the environment variables
- global has_command_column
core.run_command("t.connect", flags="c")
if "driver" in kv:
if kv["driver"] == "sqlite":
- tgis_backed = kv["driver"]
+ tgis_backend = kv["driver"]
try:
import sqlite3
except ImportError:
@@ -163,7 +191,7 @@
raise
dbmi = sqlite3
elif kv["driver"] == "pg":
try:
import psycopg2
except ImportError:
@@ -178,183 +206,206 @@
# Set the default sqlite3 connection in case nothing was defined
core.run_command("t.connect", flags="d")
+ db_exists = False
database = get_temporal_dbmi_init_string()
+ dbif = SQLDatabaseInterfaceConnection()
- db_exists = False
# Check if the database already exists
# Check path of the sqlite database
if os.path.exists(database):
- # Connect to database
- connection = dbmi.connect(database)
- cursor = connection.cursor()
+ dbif.connect()
# Check for raster_base table
- cursor.execute("SELECT name FROM sqlite_master WHERE type='table' AND name='raster_base';")
- name = cursor.fetchone()[0]
- if name == "raster_base":
+ dbif.cursor.execute("SELECT name FROM sqlite_master WHERE type='table' AND name='raster_base';")
+ name = dbif.cursor.fetchone()
+ if name and name[0] == "raster_base":
db_exists = True
+ dbif.close()
- # Try to add the command column to the space time dataset metadata tables
- try:
- cursor.execute('ALTER TABLE strds_metadata ADD COLUMN command VARCHAR;')
- except:
- pass
- try:
- cursor.execute('ALTER TABLE str3ds_metadata ADD COLUMN command VARCHAR;')
- except:
- pass
- try:
- cursor.execute('ALTER TABLE stvds_metadata ADD COLUMN command VARCHAR;')
- except:
- pass
- connection.commit()
- cursor.close()
+ dbif.connect()
- cursor.execute("SELECT EXISTS(SELECT * FROM information_schema.tables "
- "WHERE table_name=%s)", ('raster_base',))
- db_exists = cursor.fetchone()[0]
+ dbif.cursor.execute("SELECT EXISTS(SELECT * FROM information_schema.tables "
+ "WHERE table_name=%s)", ('raster_base',))
+ if dbif.cursor.fetchone()[0]:
+ db_exists = True
- if db_exists:
+ if db_exists:
+ # Check if we have to add the command column
+ add_command_col = True
+ rows = get_tgis_metadata(dbif)
+ if rows:
+ for row in rows:
+ if row["key"] == "tgis_db_version":
+ version = int(row["value"])
+ if version >= 1:
+ add_command_col = False
+ if add_command_col:
+ # this is due backward compatibility with old databases
try:
+ dbif.cursor.execute('ALTER TABLE strds_metadata ADD COLUMN command VARCHAR;')
except:
pass
try:
+ dbif.cursor.execute('ALTER TABLE str3ds_metadata ADD COLUMN command VARCHAR;')
except:
pass
try:
+ dbif.cursor.execute('ALTER TABLE stvds_metadata ADD COLUMN command VARCHAR;')
except:
pass
- cursor.close()
if db_exists == True:
+ dbif.close()
return
- core.message(_("Create temporal database: %s" % (database)))
+ create_temporal_database(dbif, database)
+def create_temporal_database(dbif, database):
+ """!This function will create the temporal database
+ It will create all tables and triggers that are needed to run
+ the temporal GIS
+ global tgis_version
+ global tgis_db_version
+ template_path = get_sql_template_path()
# Read all SQL scripts and templates
map_tables_template_sql = open(os.path.join(
- get_sql_template_path(), "map_tables_template.sql"), 'r').read()
+ template_path, "map_tables_template.sql"), 'r').read()
raster_metadata_sql = open(os.path.join(
get_sql_template_path(), "raster_metadata_table.sql"), 'r').read()
- raster3d_metadata_sql = open(os.path.join(get_sql_template_path(
- ), "raster3d_metadata_table.sql"), 'r').read()
- vector_metadata_sql = open(os.path.join(
- get_sql_template_path(), "vector_metadata_table.sql"), 'r').read()
- raster_views_sql = open(os.path.join(
- get_sql_template_path(), "raster_views.sql"), 'r').read()
- raster3d_views_sql = open(os.path.join(get_sql_template_path(
- ), "raster3d_views.sql"), 'r').read()
- vector_views_sql = open(os.path.join(
- get_sql_template_path(), "vector_views.sql"), 'r').read()
+ raster3d_metadata_sql = open(os.path.join(template_path,
+ "raster3d_metadata_table.sql"),
+ 'r').read()
+ vector_metadata_sql = open(os.path.join(template_path,
+ "vector_metadata_table.sql"),
+ 'r').read()
+ raster_views_sql = open(os.path.join(template_path, "raster_views.sql"),
+ 'r').read()
+ raster3d_views_sql = open(os.path.join(template_path,
+ "raster3d_views.sql"), 'r').read()
+ vector_views_sql = open(os.path.join(template_path, "vector_views.sql"),
+ 'r').read()
- stds_tables_template_sql = open(os.path.join(
- get_sql_template_path(), "stds_tables_template.sql"), 'r').read()
- strds_metadata_sql = open(os.path.join(
- get_sql_template_path(), "strds_metadata_table.sql"), 'r').read()
- str3ds_metadata_sql = open(os.path.join(
- get_sql_template_path(), "str3ds_metadata_table.sql"), 'r').read()
- stvds_metadata_sql = open(os.path.join(
- get_sql_template_path(), "stvds_metadata_table.sql"), 'r').read()
- strds_views_sql = open(os.path.join(
- get_sql_template_path(), "strds_views.sql"), 'r').read()
- str3ds_views_sql = open(os.path.join(
- get_sql_template_path(), "str3ds_views.sql"), 'r').read()
- stvds_views_sql = open(os.path.join(
- get_sql_template_path(), "stvds_views.sql"), 'r').read()
+ stds_tables_template_sql = open(os.path.join(template_path,
+ "stds_tables_template.sql"),
+ 'r').read()
+ strds_metadata_sql = open(os.path.join(template_path,
+ "strds_metadata_table.sql"),
+ 'r').read()
+ str3ds_metadata_sql = open(os.path.join(template_path,
+ "str3ds_metadata_table.sql"),
+ 'r').read()
+ stvds_metadata_sql = open(os.path.join(template_path,
+ "stvds_metadata_table.sql"),
+ 'r').read()
+ strds_views_sql = open(os.path.join(template_path, "strds_views.sql"),
+ 'r').read()
+ str3ds_views_sql = open(os.path.join(template_path, "str3ds_views.sql"),
+ 'r').read()
+ stvds_views_sql = open(os.path.join(template_path, "stvds_views.sql"),
+ 'r').read()
- # Create the raster, raster3d and vector tables
+ # Create the raster, raster3d and vector tables SQL statements
raster_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "raster")
vector_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "vector")
raster3d_tables_sql = map_tables_template_sql.replace(
"GRASS_MAP", "raster3d")
# Create the space-time raster, raster3d and vector dataset tables
+ # SQL statements
strds_tables_sql = stds_tables_template_sql.replace("STDS", "strds")
stvds_tables_sql = stds_tables_template_sql.replace("STDS", "stvds")
str3ds_tables_sql = stds_tables_template_sql.replace("STDS", "str3ds")
+ core.message(_("Create temporal database: %s" % (database)))
# We need to create the sqlite3 database path if it does not exists
tgis_dir = os.path.dirname(database)
if not os.path.exists(tgis_dir):
os.makedirs(tgis_dir)
+ # Sqlite needs some trigger to emulate the foreign keys
+ sqlite3_delete_trigger_sql = open(os.path.join(template_path,
+ "sqlite3_delete_trigger.sql"),
+ 'r').read()
+ # Connect now to the database
+ if not dbif.connected:
+ dbif.connect()
- sqlite3_delete_trigger_sql = open(os.path.join(get_sql_template_path(
- ), "sqlite3_delete_trigger.sql"), 'r').read()
+ # Execute the SQL statements for sqlite
+ # Create the global tables for the native grass datatypes
+ dbif.execute_transaction(raster_tables_sql)
+ dbif.execute_transaction(raster_metadata_sql)
+ dbif.execute_transaction(raster_views_sql)
+ dbif.execute_transaction(vector_tables_sql)
+ dbif.execute_transaction(vector_metadata_sql)
+ dbif.execute_transaction(vector_views_sql)
+ dbif.execute_transaction(raster3d_tables_sql)
+ dbif.execute_transaction(raster3d_metadata_sql)
+ dbif.execute_transaction(raster3d_views_sql)
+ # Create the tables for the new space-time datatypes
+ dbif.execute_transaction(strds_tables_sql)
+ dbif.execute_transaction(strds_metadata_sql)
+ dbif.execute_transaction(strds_views_sql)
+ dbif.execute_transaction(stvds_tables_sql)
+ dbif.execute_transaction(stvds_metadata_sql)
+ dbif.execute_transaction(stvds_views_sql)
+ dbif.execute_transaction(str3ds_tables_sql)
+ dbif.execute_transaction(str3ds_metadata_sql)
+ dbif.execute_transaction(str3ds_views_sql)
- # Execute the SQL statements for sqlite
- # Create the global tables for the native grass datatypes
- cursor.executescript(raster_tables_sql)
- cursor.executescript(raster_metadata_sql)
- cursor.executescript(raster_views_sql)
- cursor.executescript(vector_tables_sql)
- cursor.executescript(vector_metadata_sql)
- cursor.executescript(vector_views_sql)
- cursor.executescript(raster3d_tables_sql)
- cursor.executescript(raster3d_metadata_sql)
- cursor.executescript(raster3d_views_sql)
- # Create the tables for the new space-time datatypes
- cursor.executescript(strds_tables_sql)
- cursor.executescript(strds_metadata_sql)
- cursor.executescript(strds_views_sql)
- cursor.executescript(stvds_tables_sql)
- cursor.executescript(stvds_metadata_sql)
- cursor.executescript(stvds_views_sql)
- cursor.executescript(str3ds_tables_sql)
- cursor.executescript(str3ds_metadata_sql)
- cursor.executescript(str3ds_views_sql)
- cursor.executescript(sqlite3_delete_trigger_sql)
- # Execute the SQL statements for postgresql
- cursor.execute(raster_tables_sql)
- cursor.execute(raster_metadata_sql)
- cursor.execute(raster_views_sql)
- cursor.execute(vector_tables_sql)
- cursor.execute(vector_metadata_sql)
- cursor.execute(vector_views_sql)
- cursor.execute(raster3d_tables_sql)
- cursor.execute(raster3d_metadata_sql)
- cursor.execute(raster3d_views_sql)
- cursor.execute(strds_tables_sql)
- cursor.execute(strds_metadata_sql)
- cursor.execute(strds_views_sql)
- cursor.execute(stvds_tables_sql)
- cursor.execute(stvds_metadata_sql)
- cursor.execute(stvds_views_sql)
- cursor.execute(str3ds_tables_sql)
- cursor.execute(str3ds_metadata_sql)
- cursor.execute(str3ds_views_sql)
+ dbif.execute_transaction(sqlite3_delete_trigger_sql)
- cursor.close()
+ # Create the tgis metadata table to store the database
+ # initial configuration
+ # The metadata table content
+ metadata = {}
+ metadata["tgis_version"] = tgis_version
+ metadata["tgis_db_version"] = tgis_db_version
+ metadata["has_command_column"] = True
+ metadata["creation_time"] = datetime.today()
+ _create_tgis_metadata_table(metadata, dbif)
+ dbif.close()
+def _create_tgis_metadata_table(content, dbif=None):
+ """!Create the temporal gis metadata table which stores all metadata
+ information about the temporal database.
+ @param content The dictionary that stores the key:value metadata
+ that should be stored in the metadata table
+ statement = "CREATE TABLE tgis_metadata (key VARCHAR NOT NULL, value VARCHAR);\n";
+ dbif.execute_transaction(statement)
+ for key in content.keys():
+ statement = "INSERT INTO tgis_metadata (key, value) VALUES " + \
+ "(\'%s\' , \'%s\');\n"%(str(key), str(content[key]))
+ if connected:
+ dbif.close()
class SQLDatabaseInterfaceConnection():
"""!This class represents the database interface connection
@@ -366,7 +417,7 @@
def __init__(self):
self.connected = False
global tgis_backend
self.dbmi = sqlite3
else:
self.dbmi = psycopg2
@@ -387,10 +438,10 @@
Supported backends are sqlite3 and postgresql
- init = get_temporal_dbmi_init_string()
+ self.database = get_temporal_dbmi_init_string()
#print "Connect to", self.database
if self.dbmi.__name__ == "sqlite3":
- self.connection = self.dbmi.connect(init,
+ self.connection = self.dbmi.connect(self.database,
detect_types = self.dbmi.PARSE_DECLTYPES | self.dbmi.PARSE_COLNAMES)
self.connection.row_factory = self.dbmi.Row
self.connection.isolation_level = None
@@ -398,7 +449,7 @@
self.cursor.execute("PRAGMA synchronous = OFF")
self.cursor.execute("PRAGMA journal_mode = MEMORY")
elif self.dbmi.__name__ == "psycopg2":
- self.connection = self.dbmi.connect(init)
+ self.connection = self.dbmi.connect(self.database)
#self.connection.set_isolation_level(dbmi.extensions.ISOLATION_LEVEL_AUTOCOMMIT)
self.cursor = self.connection.cursor(
cursor_factory = self.dbmi.extras.DictCursor)
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py 2013-08-17 22:15:59 UTC (rev 57462)
+++ grass/trunk/lib/python/temporal/register.py 2013-08-17 22:18:14 UTC (rev 57463)
@@ -296,8 +296,6 @@
if dbif.dbmi.__name__ == "sqlite3":
if count % 100 == 0:
if statement is not None and statement != "":
- core.message(_("Registering maps in the temporal database")
statement = ""
