[GRASS-SVN] r57464 - in grass/trunk/temporal: t.info t.remove
svn_grass at osgeo.org
Sat Aug 17 15:20:27 PDT 2013
Author: huhabla
Date: 2013-08-17 15:20:27 -0700 (Sat, 17 Aug 2013)
New Revision: 57464
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.remove/t.remove.py
Added tgis metadata output to t.info. Improved map removal speed in t.remove.
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2013-08-17 22:18:14 UTC (rev 57463)
+++ grass/trunk/temporal/t.info/t.info.py 2013-08-17 22:20:27 UTC (rev 57464)
@@ -68,9 +68,12 @@
# Make sure the temporal database exists
tgis.init()
- dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif, connected = tgis.init_dbif(None)
+ rows = tgis.get_tgis_metadata(dbif)
if system and not shellstyle:
# 0123456789012345678901234567890
print " +------------------- Temporal DBMI backend information ----------------------+"
@@ -79,14 +82,20 @@
tgis.get_temporal_dbmi_init_string())
print " | SQL template path:.......... " + str(
tgis.get_sql_template_path())
+ if rows:
+ for row in rows:
+ print " | %s .......... %s"%(row[0], row[1])
print " +----------------------------------------------------------------------------+"
return
elif system:
- print "dbmi_python_interface=" + str(dbif.dbmi.__name__)
- print "dbmi_init_string=" + str(tgis.get_temporal_dbmi_init_string())
- print "sql_template_path=" + str(tgis.get_sql_template_path())
+ print "dbmi_python_interface=\'" + str(dbif.dbmi.__name__) + "\'"
+ print "dbmi_init_string=\'" + str(tgis.get_temporal_dbmi_init_string()) + "\'"
+ print "sql_template_path=\'" + str(tgis.get_sql_template_path()) + "\'"
+ if rows:
+ for row in rows:
+ print "%s=\'%s\'"%(row[0], row[1])
return
if not system and not name:
grass.fatal(_("Please specify %s=") % ("name"))
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2013-08-17 22:18:14 UTC (rev 57463)
+++ grass/trunk/temporal/t.remove/t.remove.py 2013-08-17 22:20:27 UTC (rev 57464)
@@ -55,6 +55,7 @@
#%end
import grass.script as grass
import grass.temporal as tgis
+import grass.pygrass.modules as pyg
@@ -128,19 +129,24 @@
maps = sp.get_registered_maps_as_objects(dbif=dbif)
map_statement = ""
count = 1
+ name_list = []
for map in maps:
map.select(dbif)
- grass.run_command("g.remove", rast=map.get_name(), quiet=True)
+ name_list.append(map.get_name())
map_statement += map.delete(dbif=dbif, execute=False)
count += 1
# Delete every 100 maps
if count%100 == 0:
dbif.execute_transaction(map_statement)
+ pyg.Module("g.remove", rast=name_list, quiet=True)
map_statement = ""
+ name_list = []
if map_statement:
+ if name_list:
statement += sp.delete(dbif=dbif, execute=False)
