[GRASS-SVN] r57488 - grass/trunk/lib/python/pygrass/gis
svn_grass at osgeo.org
Fri Aug 23 04:35:27 PDT 2013
Author: zarch
Date: 2013-08-23 04:35:27 -0700 (Fri, 23 Aug 2013)
New Revision: 57488
grass/trunk/lib/python/pygrass/gis/__init__.py
Add path methods and manage errors when create a new mapset
Modified: grass/trunk/lib/python/pygrass/gis/__init__.py
--- grass/trunk/lib/python/pygrass/gis/__init__.py 2013-08-23 11:27:51 UTC (rev 57487)
+++ grass/trunk/lib/python/pygrass/gis/__init__.py 2013-08-23 11:35:27 UTC (rev 57488)
@@ -69,8 +69,11 @@
def make_mapset(mapset, location=None, gisdbase=None):
- if libgis.G__make_mapset(gisdbase, location, mapset) != 0:
+ res = libgis.G_make_mapset(gisdbase, location, mapset)
+ if res == -1:
raise GrassError("I cannot create a new mapset.")
+ elif res == -2:
+ raise GrassError("Illegal name.")
class Gisdbase(object):
@@ -208,7 +211,10 @@
return fnmatch.filter(mapsets, pattern)
return mapsets
+ def path(self):
+ return join(self.gisdbase, self.name)
class Mapset(object):
"""Mapset ::
@@ -226,6 +232,7 @@
self.gisdbase = gisdbase
self.location = location
self.name = mapset
+ self.visible = VisibleMapset(self.name, self.location, self.gisdbase)
def _get_gisdb(self):
return self._gisdb
@@ -311,4 +318,7 @@
"""Delete the mapset"""
if self.is_current():
raise GrassError('The mapset is in use.')
- shutil.rmtree(join(self.gisdbase, self.location, self.name))
+ shutil.rmtree(self.path())
+ def path(self):
+ return join(self.gisdbase, self.location, self.name)
