[GRASS-SVN] r57489 - grass/trunk/lib/python/pygrass/gis
svn_grass at osgeo.org
Fri Aug 23 04:36:25 PDT 2013
Author: zarch
Date: 2013-08-23 04:36:25 -0700 (Fri, 23 Aug 2013)
New Revision: 57489
grass/trunk/lib/python/pygrass/gis/__init__.py
Add visible mappsets
Modified: grass/trunk/lib/python/pygrass/gis/__init__.py
--- grass/trunk/lib/python/pygrass/gis/__init__.py 2013-08-23 11:35:27 UTC (rev 57488)
+++ grass/trunk/lib/python/pygrass/gis/__init__.py 2013-08-23 11:36:25 UTC (rev 57489)
@@ -322,3 +322,51 @@
def path(self):
return join(self.gisdbase, self.location, self.name)
+class VisibleMapset(object):
+ def __init__(self, mapset, location='', gisdbase=''):
+ self.mapset = mapset
+ self.location = Location(location, gisdbase)
+ self._list = []
+ self.spath = join(self.location.path(), self.mapset, 'SEARCH_PATH')
+ def __repr__(self):
+ return repr(self.read())
+ def __iter__(self):
+ for mapset in self.read():
+ yield mapset
+ def read(self):
+ with open(self.spath, "a+") as f:
+ lines = f.readlines()
+ #lines.remove('')
+ if lines:
+ return [l.strip() for l in lines]
+ lns = ['PERMANENT', ]
+ self.write(lns)
+ return lns
+ def write(self, mapsets):
+ ms = self.location.mapsets()
+ f.write('%s' % '\n'.join([m for m in mapsets if m in ms]))
+ def add(self, mapset):
+ if mapset in self.location:
+ f.write('\n%s' % mapset)
+ else:
+ raise TypeError('Mapset not found')
+ def remove(self, mapset):
+ mapsets = self.read()
+ mapsets.remove(mapset)
+ self.write(mapsets)
+ def extend(self, mapsets):
+ final = self.read()
+ final.extend([m for m in mapsets if m in ms and m not in final])
+ self.write(final)
