[GRASS-SVN] r57490 - grass/trunk/lib/python/pygrass/modules/interface
Fri Aug 23 04:39:55 PDT 2013
Author: zarch
Date: 2013-08-23 04:39:55 -0700 (Fri, 23 Aug 2013)
New Revision: 57490
   grass/trunk/lib/python/pygrass/modules/interface/parameter.py
Manage string parameter
Modified: grass/trunk/lib/python/pygrass/modules/interface/parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/parameter.py	2013-08-23 11:36:25 UTC (rev 57489)
+++ grass/trunk/lib/python/pygrass/modules/interface/parameter.py	2013-08-23 11:39:55 UTC (rev 57490)
@@ -106,6 +106,15 @@
                                      (self.name, self.values))
             else:
                 self._value = value
+        elif self.type is str and isinstance(value, unicode):
+            if hasattr(self, 'values'):
+                if value in self.values:
+                    self._value = value
+                else:
+                    raise ValueError('The Parameter <%s>, must be one of: %r' %
+                                     (self.name, self.values))
+            else:
         else:
             str_err = 'The Parameter <%s>, require: %s, get: %s instead'
             raise TypeError(str_err % (self.name, self.typedesc, type(value)))
