[GRASS-SVN] r57515 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Tue Aug 27 05:02:00 PDT 2013
Author: huhabla
Date: 2013-08-27 05:01:59 -0700 (Tue, 27 Aug 2013)
New Revision: 57515
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/open.py
grass/trunk/lib/python/temporal/register.py
Added check map/stds dataset functions
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-08-27 11:00:24 UTC (rev 57514)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-08-27 12:01:59 UTC (rev 57515)
@@ -166,7 +166,8 @@
return self.base.get_map_id()
- def build_id(self, name, mapset, layer=None):
+ @staticmethod
+ def build_id(name, mapset, layer=None):
"""!Convenient method to build the unique identifier
Existing layer and mapset definitions in the name
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2013-08-27 11:00:24 UTC (rev 57514)
+++ grass/trunk/lib/python/temporal/extract.py 2013-08-27 12:01:59 UTC (rev 57515)
@@ -58,11 +58,9 @@
dbif.connect()
sp = open_old_space_time_dataset(input, type, dbif)
- dummy = sp.get_new_map_instance(None)
# Check the new stds
- new_sp = open_new_space_time_dataset(output, type, sp.get_temporal_type(),
- "None", "None", "mean", dbif,
- core.overwrite(), dry=True)
+ new_sp = check_new_space_time_dataset(output, type, dbif,
+ core.overwrite())
if type == "vector":
rows = sp.get_registered_maps(
"id,name,mapset,layer", where, "start_time", dbif)
@@ -97,9 +95,9 @@
expr = expr.replace(sp.base.get_name(), row["id"])
# We need to build the id
- map_id = dummy.build_id(map_name, mapset)
+ map_id = AbstractMapDataset.build_id(map_name, mapset)
else:
- map_id = dummy.build_id(map_name, mapset, row["layer"])
+ map_id = AbstractMapDataset.build_id(map_name, mapset, row["layer"])
new_map = sp.get_new_map_instance(map_id)
@@ -171,7 +169,7 @@
title, description,
semantic_type, dbif,
- core.overwrite(), dry=False)
+ core.overwrite())
# collect empty maps to remove them
empty_maps = []
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2013-08-27 11:00:24 UTC (rev 57514)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2013-08-27 12:01:59 UTC (rev 57515)
@@ -96,10 +96,8 @@
input_list.append(copy.copy(sp))
- first_input.get_temporal_type(),
- "New", "New dataset", "mean", dbif,
- core.overwrite(), True)
+ core.overwrite())
# Sample all inputs by the first input and create a sample matrix
if spatial:
@@ -285,7 +283,7 @@
temporal_type, title, description,
- core.overwrite(), False)
+ core.overwrite())
count = 0
Modified: grass/trunk/lib/python/temporal/open.py
--- grass/trunk/lib/python/temporal/open.py 2013-08-27 11:00:24 UTC (rev 57514)
+++ grass/trunk/lib/python/temporal/open.py 2013-08-27 12:01:59 UTC (rev 57515)
@@ -76,26 +76,17 @@
-def open_new_space_time_dataset(name, type, temporaltype, title, descr, semantic,
- dbif=None, overwrite=False, dry=False):
- """!Create a new space time dataset of a specific type
+def check_new_space_time_dataset(name, type, dbif=None, overwrite=False):
+ """!Check if a new space time dataset of a specific type can be created
- This function is sensitive to the settings in grass.core.overwrite to
- overwrite existing space time datasets.
@param name The name of the new space time dataset
@param type The type of the new space time dataset (strd, str3ds, stvds,
raster, vector, raster3d)
- @param temporaltype The temporal type (relative or absolute)
- @param title The title
- @param descr The dataset description
- @param semantic Semantical information
@param dbif The temporal database interface to be used
@param overwrite Flag to allow overwriting
- @param dry Do not create the space time dataset in the temporal database,
- make a dry run with including all checks
- @return The new created space time dataset
+ @return A space time dataset object that must be filled with
+ content before insertion in the temporal database
This function will raise a ScriptError in case of an error.
@@ -120,26 +111,53 @@
elif type == "stvds" or type == "vect" or type == "vector":
sp = dataset_factory("stvds", id)
else:
- core.fatal(_("Unkown type: %s") % (type))
+ core.error(_("Unkown type: %s") % (type))
+ return None
dbif, connected = init_dbif(dbif)
if sp.is_in_db(dbif) and overwrite is False:
- if connected:
- dbif.close()
core.fatal(_("Space time %(sp)s dataset <%(name)s> is already in the"
" database. Use the overwrite flag.") % {
'sp': sp.get_new_map_instance(None).get_type(),
'name': name})
- return None
+ if connected:
+ dbif.close()
- if sp.is_in_db(dbif) and overwrite is True:
+ return sp
+def open_new_space_time_dataset(name, type, temporaltype, title, descr, semantic,
+ dbif=None, overwrite=False):
+ """!Create a new space time dataset of a specific type
+ @param name The name of the new space time dataset
+ @param type The type of the new space time dataset (strd, str3ds, stvds,
+ raster, vector, raster3d)
+ @param temporaltype The temporal type (relative or absolute)
+ @param title The title
+ @param descr The dataset description
+ @param semantic Semantical information
+ @param dbif The temporal database interface to be used
+ @param overwrite Flag to allow overwriting
+ @param dry Do not create the space time dataset in the temporal database,
+ make a dry run with including all checks
+ @return The new created space time dataset
+ This function will raise a ScriptError in case of an error.
+ dbif, connected = init_dbif(dbif)
+ sp = check_new_space_time_dataset(name, type, dbif, overwrite)
+ if sp.is_in_db(dbif):
core.warning(_("Overwrite space time %(sp)s dataset <%(name)s> and "
"unregister all maps.") % {
'name': name})
- if not dry:
- sp.delete(dbif)
+ id = sp.get_id()
+ sp.delete(dbif)
sp = sp.get_new_instance(id)
core.verbose(_("Create new space time %s dataset.") %
@@ -147,10 +165,94 @@
sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
title=title, description=descr)
- if not dry:
- sp.insert(dbif)
+ sp.insert(dbif)
if connected:
dbif.close()
return sp
+def check_new_map_dataset(name, layer=None, mapset=None,
+ type="raster", overwrite=False, dbif=None):
+ """!Check if a new map dataset of a specific type can be created in
+ the temporal database
+ @param name The name of the new map dataset
+ @param layer The layer of the new map dataset
+ @param mapset The current mapset the new map dataset is created in,
+ this argument is optional, if not provided g.gisenv
+ will be called to reveive the current mapset
+ @param type The type of the new map dataset (raster, vector, raster3d)
+ @return A map dataset object
+ if not mapset:
+ mapset = core.gisenv()["MAPSET"]
+ map_id = AbstractMapDataset.build_id(name, mapset, layer)
+ new_map = dataset_factory(type, map_id)
+ # Check if new map is in the temporal database
+ if new_map.is_in_db(dbif):
+ if not overwrite:
+ if connected:
+ dbif.close()
+ core.fatal(_("Map <%s> is already in temporal database,"
+ " use overwrite flag to overwrite") % (map_id))
+ if connected:
+ dbif.close()
+ return new_map
+def open_new_map_dataset(name, layer=None, mapset=None, type="raster",
+ temporal_extent=None, overwrite=False,
+ dbif=None):
+ """!Create a new map dataset object of a specific type that can be
+ registered in the temporal database
+ if not mapset:
+ new_map = check_new_map_dataset(name, layer, mapset, "raster",
+ overwrite, dbif)
+ # Remove the existing temporal database entry
+ map_id = new_map.get_id()
+ new_map.delete(dbif)
+ new_map = new_map.get_new_instance(map_id)
+ if temporal_extent:
+ new_map.set_temporal_extent(temporal_extent)
+ if connected:
+ dbif.close()
+ return new_map
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py 2013-08-27 11:00:24 UTC (rev 57514)
+++ grass/trunk/lib/python/temporal/register.py 2013-08-27 12:01:59 UTC (rev 57515)
@@ -98,9 +98,6 @@
'name': name})
- # We need a dummy map object to build the map ids
- dummy = dataset_factory(type, None)
maplist = []
# Map names as comma separated string
@@ -113,7 +110,7 @@
# Build the map list again with the ids
for count in range(len(maplist)):
row = {}
- mapid = dummy.build_id(maplist[count], mapset, None)
+ mapid = AbstractMapDataset.build_id(maplist[count], mapset, None)
row["id"] = mapid
maplist[count] = row
@@ -151,7 +148,7 @@
if start_time_in_file and not end_time_in_file:
row["start"] = line_list[1].strip()
- row["id"] = dummy.build_id(mapname, mapset)
+ row["id"] = AbstractMapDataset.build_id(mapname, mapset)
maplist.append(row)
