[GRASS-SVN] r57516 - in grass/trunk/temporal: t.rast.neighbors t.sample t.vect.observe.strds
Tue Aug 27 05:02:49 PDT 2013
Author: huhabla
Date: 2013-08-27 05:02:47 -0700 (Tue, 27 Aug 2013)
New Revision: 57516
   grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
   grass/trunk/temporal/t.sample/t.sample.py
   grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
Use new check and open functions
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2013-08-27 12:01:59 UTC (rev 57515)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2013-08-27 12:02:47 UTC (rev 57516)
@@ -5,7 +5,8 @@
 # MODULE:       t.rast.neighbors
 # AUTHOR(S):    Soeren Gebbert
-# PURPOSE:      Performs a neighborhood analysis for each map in a space time raster dataset.
+# PURPOSE:      Performs a neighborhood analysis for each map in a space time
+#               raster dataset.
 # COPYRIGHT:    (C) 2013 by the GRASS Development Team
 #               This program is free software under the GNU General Public
@@ -71,7 +72,6 @@
 def main():
     # Get the options
@@ -90,126 +90,101 @@
     dbif = tgis.SQLDatabaseInterfaceConnection()
     dbif.connect()
+    overwrite = grass.overwrite()
     mapset = grass.gisenv()["MAPSET"]
     sp = tgis.open_old_space_time_dataset(input, "strds", dbif)
-    dummy = sp.get_new_map_instance(None)
+    maps = sp.get_registered_maps_as_objects(where=where, dbif=dbif)
-    temporal_type, semantic_type, title, description = sp.get_initial_values()
-    new_sp = tgis.open_new_space_time_dataset(output, "strds", sp.get_temporal_type(),
-                                              title, description, semantic_type,
-                                              dbif, grass.overwrite(), dry=True)
-    rows = sp.get_registered_maps("id,start_time", where, "start_time", dbif)
-    if not rows:
+    if not maps:
         dbif.close()
-        grass.fatal(_("Space time raster dataset <%s> is empty") % out_id)
+        grass.fatal(_("Space time raster dataset <%s> is empty") % sp.get_id())
+    new_sp = tgis.check_new_space_time_dataset(input, "strds", dbif=dbif,
+                                               overwrite=overwrite)
     count = 0
-    proc_count = 0
     proc_list = []
-    num_rows = len(rows)
-    new_maps = {}
+    num_maps = len(maps)
+    new_maps = []
-    for row in rows:
+    for map in maps:
         count += 1
         if count%10 == 0:
-            grass.percent(count, num_rows, 1)
+            grass.percent(count, num_maps, 1)
         map_name = "%s_%i" % (base, count)
-        map_id = dummy.build_id(map_name, mapset)
+        new_map = tgis.open_new_map_dataset(map_name, None, mapset,
+                                       type="raster",
+                                       temporal_extent=map.get_temporal_extent(),
+                                       overwrite=overwrite, dbif=dbif)
-        new_map = sp.get_new_map_instance(map_id)
-        # Check if new map is in the temporal database
-        if new_map.is_in_db(dbif):
-            if grass.overwrite():
-                # Remove the existing temporal database entry
-                new_map.delete(dbif)
-            else:
-                grass.error(_("Map <%s> is already in temporal database,"
-                             " use overwrite flag to overwrite") %
-                            (new_map.get_map_id()))
-                continue
         proc_list.append(Process(target=run_neighbors,
-                                     args=(row["id"],map_name,method,size)))
+                                     args=(map.get_id(),map_name,
+                                           method,size, overwrite)))
+        proc_list[-1].start()
-        proc_list[proc_count].start()
-        proc_count += 1
         # Join processes if the maximum number of processes are
         # reached or the end of the loop is reached
-        if proc_count == nprocs or proc_count == num_rows:
-            proc_count = 0
-            exitcodes = 0
+        if len(proc_list) == nprocs:
             for proc in proc_list:
                 proc.join()
-                exitcodes += proc.exitcode
+                if proc.exitcode != 0:
+                    dbif.close()
+                    grass.fatal(_("Error while neighborhood computation"))
-            if exitcodes != 0:
-                dbif.close()
-                grass.fatal(_("Error while computation"))
             # Empty process list
             proc_list = []
-        # Store the new maps
-        new_maps[row["id"]] = new_map
+        # Initlialize and load the content of the map
+        new_maps.append(new_map)
-    grass.percent(0, num_rows, 1)
+    for proc in proc_list:
+        proc.join()
+            dbif.close()
+            grass.fatal(_("Error while computation"))
+    grass.percent(1, 1, 1)
+    # Open the new space time raster dataset
+    temporal_type, semantic_type, title, description = sp.get_initial_values()
                                               title, description,
                                               semantic_type,
-                                              dry=False)
+                                              dbif, overwrite)
     # collect empty maps to remove them
+    num_maps = len(new_maps)
     empty_maps = []
     # Register the maps in the database
     count = 0
-    for row in rows:
+    for map in new_maps:
         count += 1
         if count%10 == 0:
-        # Register the new maps
-        if row["id"] in new_maps:
-            new_map = new_maps[row["id"]]
-            # Read the raster map data
-            new_map.load()
-            # In case of a empty map continue, do not register empty maps
-            if new_map.metadata.get_min() is None and \
-                new_map.metadata.get_max() is None:
-                if not register_null:
-                    empty_maps.append(new_map)
-                    continue
+        # In case of a empty map continue, do not register empty maps
+        map.load()
+        if map.metadata.get_min() is None and \
+            map.metadata.get_max() is None:
+            if not register_null:
+                empty_maps.append(map)
+                continue
-            old_map = sp.get_new_map_instance(row["id"])
-            old_map.select(dbif)
+        # Insert map in temporal database
+        map.insert(dbif)
+        new_sp.register_map(map, dbif)
-            # Set the time stamp
-            if old_map.is_time_absolute():
-                start, end, tz = old_map.get_absolute_time()
-                new_map.set_absolute_time(start, end, tz)
-            else:
-                start, end, unit = old_map.get_relative_time()
-                new_map.set_relative_time(start, end, unit)
-            # Insert map in temporal database
-            new_map.insert(dbif)
-            new_sp.register_map(new_map, dbif)
     # Update the spatio-temporal extent and the metadata table entries
     new_sp.update_from_registered_maps(dbif)
-    grass.percent(num_rows, num_rows, 1)
     # Remove empty maps
     if len(empty_maps) > 0:
@@ -224,15 +199,18 @@
         grass.run_command("g.remove", rast=names, quiet=True)
     dbif.close()
-def run_neighbors(input, output, method, size):
+def run_neighbors(input, output, method, size, overwrite):
     """Helper function to run r.neighbors in parallel"""
     return grass.run_command("r.neighbors", input=input, output=output,
-                            method=method, size=size, overwrite=grass.overwrite(),
+                            method=method, size=size,
                             quiet=True)
 if __name__ == "__main__":
     options, flags = grass.parser()
Modified: grass/trunk/temporal/t.sample/t.sample.py
--- grass/trunk/temporal/t.sample/t.sample.py	2013-08-27 12:01:59 UTC (rev 57515)
+++ grass/trunk/temporal/t.sample/t.sample.py	2013-08-27 12:02:47 UTC (rev 57516)
@@ -79,12 +79,13 @@
     method = options["method"]
     header = flags["c"]
     spatial = flags["s"]
     # Make sure the temporal database exists
     tgis.init()
     tgis.sample_stds_by_stds_topology(intype, samtype, inputs, sampler,
-                                      header, separator, method, spatial, True)
+                                      header, separator, method, spatial,
+                                      True)
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py	2013-08-27 12:01:59 UTC (rev 57515)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py	2013-08-27 12:02:47 UTC (rev 57516)
@@ -72,6 +72,8 @@
     if where == "" or where == " " or where == "\n":
         where = None
     tgis.init()
     # We need a database interface
@@ -88,12 +90,8 @@
                                 " with vector map <%s>") % (strds_sp.get_id(),
                                                             input)
-    out_sp = tgis.open_new_space_time_dataset(output, "stvds",
-                                              strds_sp.get_temporal_type(),
-                                              strds_sp.get_semantic_type(),
-                                              dbif,
-                                              grass.overwrite(), dry=True)
+    out_sp = tgis.check_new_space_time_dataset(output, "stvds", dbif,
+                                               overwrite)
     # Select the raster maps
     rows = strds_sp.get_registered_maps(
@@ -134,7 +132,7 @@
     # We create a new vector map using the categories of the original map
     ret = grass.run_command("v.category", input=input, layer=layers,
                             output=vectmap, option="transfer",
-                            overwrite=grass.overwrite())
     if ret != 0:
         grass.fatal(_("Unable to create new layers for vector map <%s>")
                     % (vectmap))
@@ -144,8 +142,7 @@
                                               title, description,
-                                              dry=False)
+                                              dbif, overwrite)
     dummy = out_sp.get_new_map_instance(None)
@@ -175,7 +172,7 @@
             ret = grass.run_command("v.db.addcolumn", map=vectmap,
                                     layer=count,
                                     column="%s %s" % (col_name, coltype),
             if ret != 0:
                 dbif.close()
                 grass.fatal(_("Unable to add column %s to vector map <%s> "
@@ -185,7 +182,7 @@
             grass.message("Add table to layer %i" % (count))
             ret = grass.run_command("v.db.addtable", map=vectmap, layer=count,
                                     columns="%s %s" % (col_name, coltype),
             if ret != 0:
                 dbif.close()
                 grass.fatal(_("Unable to add table to vector map "
