[GRASS-SVN] r57534 - in grass/trunk/lib/python/pygrass/modules: . interface
svn_grass at osgeo.org
Wed Aug 28 14:13:41 PDT 2013
Author: huhabla
Date: 2013-08-28 14:13:41 -0700 (Wed, 28 Aug 2013)
New Revision: 57534
grass/trunk/lib/python/pygrass/modules/__init__.py
grass/trunk/lib/python/pygrass/modules/interface/__init__.py
grass/trunk/lib/python/pygrass/modules/interface/module.py
New process queue class to easily run grass.pygrass.modules.Module processes in parallel.
Modified: grass/trunk/lib/python/pygrass/modules/__init__.py
--- grass/trunk/lib/python/pygrass/modules/__init__.py 2013-08-28 19:39:20 UTC (rev 57533)
+++ grass/trunk/lib/python/pygrass/modules/__init__.py 2013-08-28 21:13:41 UTC (rev 57534)
@@ -6,7 +6,7 @@
import interface
-from interface import Module
+from interface import Module, ParallelModuleQueue
import grid
from grid.grid import GridModule
Modified: grass/trunk/lib/python/pygrass/modules/interface/__init__.py
--- grass/trunk/lib/python/pygrass/modules/interface/__init__.py 2013-08-28 19:39:20 UTC (rev 57533)
+++ grass/trunk/lib/python/pygrass/modules/interface/__init__.py 2013-08-28 21:13:41 UTC (rev 57534)
@@ -10,4 +10,4 @@
import typedict
import read
-from module import Module
+from module import Module, ParallelModuleQueue
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py 2013-08-28 19:39:20 UTC (rev 57533)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py 2013-08-28 21:13:41 UTC (rev 57534)
@@ -60,7 +60,121 @@
from typedict import TypeDict
from read import GETFROMTAG, DOC
+class ParallelModuleQueue(object):
+ """!This class is designed to run an arbitrary number of pygrass Module
+ processes in parallel.
+ Objects of type grass.pygrass.modules.Module can be put into the
+ queue using put() method. When the queue is full with the maximum
+ number of parallel processes it will wait for all processes to finish,
+ sets the stdout and stderr of the Module object and removes it
+ from the queue when its finished.
+ This class will raise a GrassError in case a Module process exits
+ with a return code other than 0.
+ Usage:
+ @code
+ >>> import copy
+ >>> import grass.pygrass.modules as pymod
+ >>> mapcalc_list = []
+ >>> mapcalc = pymod.Module("r.mapcalc",
+ ... overwrite=True,
+ ... run_=False,
+ ... finish_=False)
+ >>> queue = pymod.ParallelModuleQueue(max_num_procs=3)
+ >>> for i in xrange(5):
+ ... new_mapcalc = copy.deepcopy(mapcalc)
+ ... mapcalc_list.append(new_mapcalc)
+ ... new_mapcalc(expression="test_pygrass_%i = %i"%(i, i))
+ ... queue.put(new_mapcalc)
+ >>> queue.wait()
+ >>> for mapcalc in mapcalc_list:
+ ... print(mapcalc.popen.returncode)
+ 0
+ 0
+ 0
+ 0
+ 0
+ @endcode
+ def __init__(self, max_num_procs=1):
+ """!Constructor
+ @param max_num_procs The maximum number of Module processes that
+ can be run in parallel
+ self._num_procs = int(max_num_procs)
+ self._list = int(max_num_procs) * [None]
+ self._proc_count = 0
+ def put(self, module):
+ """!Put the next Module object in the queue
+ To run the Module objects in parallel the run_ and finish_ options
+ of the Module must be set to False.
+ @param module A preconfigured Module object with run_ and finish_
+ set to False
+ self._list[self._proc_count] = module
+ self._list[self._proc_count].run()
+ self._proc_count += 1
+ if self._proc_count == self._num_procs:
+ self.wait()
+ def get(self, num):
+ """!Get a Module object from the queue
+ @param num The number of the object in queue
+ @return The Module object or None if num is not in the queue
+ if num < self._num_procs:
+ return self._list[num]
+ return None
+ def get_num_run_procs(self):
+ """!Get the number of Module processes that are in the queue running
+ or finished
+ @return The maximum number fo Module processes running/finished in
+ the queue
+ return len(self._list)
+ def get_max_num_procs(self):
+ """!Return the maximum number of parallel Module processes
+ return self._num_procs
+ def set_max_num_procs(self, max_num_procs):
+ """!Set the maximum number of Module processes that should run
+ in parallel
+ self.wait()
+ def wait(self):
+ """!Wait for all Module processes that are in the list to finish
+ and set the modules stdout and stderr output options
+ for proc in self._list:
+ if proc:
+ stdout, stderr = proc.popen.communicate(input=proc.stdin)
+ proc.outputs['stdout'].value = stdout if stdout else ''
+ proc.outputs['stderr'].value = stderr if stderr else ''
+ if proc.popen.returncode != 0:
+ GrassError(("Error running module %s")%(proc.name))
+ self._list = self._num_procs * [None]
class Module(object):
@@ -308,7 +422,7 @@
return dic
def make_cmd(self):
- """!Create the commdn string that can be exceuted in a shell
+ """!Create the command string that can be executed in a shell
@return The command string
