[GRASS-SVN] r57535 - grass/trunk/temporal/t.rast.neighbors
Wed Aug 28 14:53:19 PDT 2013
Author: huhabla
Date: 2013-08-28 14:53:19 -0700 (Wed, 28 Aug 2013)
New Revision: 57535
   grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
   grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh
New module structure.
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2013-08-28 21:13:41 UTC (rev 57534)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2013-08-28 21:53:19 UTC (rev 57535)
@@ -66,10 +66,12 @@
 #% description: Register Null maps
 #%end
-from multiprocessing import Process
+import copy
 import grass.script as grass
 import grass.temporal as tgis
+import grass.pygrass.modules as pymod
 def main():
@@ -99,67 +101,48 @@
     if not maps:
         dbif.close()
-        grass.fatal(_("Space time raster dataset <%s> is empty") % sp.get_id())
+        grass.warning(_("Space time raster dataset <%s> is empty") % sp.get_id())
+        return
     new_sp = tgis.check_new_space_time_dataset(input, "strds", dbif=dbif,
                                                overwrite=overwrite)
+    # Configure the r.neighbor module
+    neighbor_module = pymod.Module("r.neighbors", input="dummy",
+                                   output="dummy", run_=False,
+                                   finish_=False, size=int(size),
+                                   method=method, overwrite=overwrite,
+                                   quiet=True)
+    # The module queue for parallel execution
+    process_queue = pymod.ParallelModuleQueue(int(nprocs))
     count = 0
-    proc_list = []
     num_maps = len(maps)
     new_maps = []
+    # run r.neighbors all selected maps
     for map in maps:
         count += 1
-        if count%10 == 0:
-            grass.percent(count, num_maps, 1)
         map_name = "%s_%i" % (base, count)
         new_map = tgis.open_new_map_dataset(map_name, None, mapset,
-                                       type="raster",
-                                       temporal_extent=map.get_temporal_extent(),
-                                       overwrite=overwrite, dbif=dbif)
-        proc_list.append(Process(target=run_neighbors,
-                                     args=(map.get_id(),map_name,
-                                           method,size, overwrite)))
-        proc_list[-1].start()
-        # Join processes if the maximum number of processes are
-        # reached or the end of the loop is reached
-        if len(proc_list) == nprocs:
-            for proc in proc_list:
-                proc.join()
-                if proc.exitcode != 0:
-                    dbif.close()
-                    grass.fatal(_("Error while neighborhood computation"))
-            # Empty process list
-            proc_list = []
-        # Initlialize and load the content of the map
+                                            type="raster",
+                                            temporal_extent=map.get_temporal_extent(),
+                                            overwrite=overwrite, dbif=dbif)
         new_maps.append(new_map)
-        proc.join()
-            dbif.close()
-            grass.fatal(_("Error while computation"))
+        mod = copy.deepcopy(neighbor_module)
+        mod(input=map.get_id(), output=new_map.get_id())
+        print(mod.get_bash())
+        process_queue.put(mod)
-    grass.percent(1, 1, 1)
+    # Wait for unfinished processes
+    process_queue.wait()
     # Open the new space time raster dataset
-    temporal_type, semantic_type, title, description = sp.get_initial_values()
-    new_sp = tgis.open_new_space_time_dataset(output, "strds",
-                                              sp.get_temporal_type(),
-                                              title, description,
-                                              semantic_type,
-                                              dbif, overwrite)
-    # collect empty maps to remove them
+    ttype, stype, title, descr = sp.get_initial_values()
+    new_sp = tgis.open_new_space_time_dataset(output, "strds", ttype, title,
+                                              descr, stype, dbif, overwrite)
     num_maps = len(new_maps)
+    # collect empty maps to remove them
     empty_maps = []
     # Register the maps in the database
@@ -170,7 +153,7 @@
         if count%10 == 0:
-        # In case of a empty map continue, do not register empty maps
+        # Do not register empty maps
         map.load()
         if map.metadata.get_min() is None and \
             map.metadata.get_max() is None:
@@ -192,10 +175,10 @@
         count = 0
         for map in empty_maps:
             if count == 0:
+                count += 1
                 names += "%s" % (map.get_name())
             else:
                 names += ",%s" % (map.get_name())
-            count += 1
         grass.run_command("g.remove", rast=names, quiet=True)
@@ -203,15 +186,6 @@
-def run_neighbors(input, output, method, size, overwrite):
-    """Helper function to run r.neighbors in parallel"""
-    return grass.run_command("r.neighbors", input=input, output=output,
-                            method=method, size=size,
-                            quiet=True)
 if __name__ == "__main__":
     options, flags = grass.parser()
     main()
Modified: grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh
--- grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh	2013-08-28 21:13:41 UTC (rev 57534)
+++ grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh	2013-08-28 21:53:19 UTC (rev 57535)
@@ -9,7 +9,7 @@
 r.mapcalc --o expr="prec_2 = rand(0, 450)"
 r.mapcalc --o expr="prec_3 = rand(0, 320)"
 r.mapcalc --o expr="prec_4 = rand(0, 510)"
-r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_5 = null()"
 r.mapcalc --o expr="prec_6 = rand(0, 650)"
 t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
@@ -21,17 +21,16 @@
     size=3 method=average nprocs=1
 t.info type=strds input=precip_abs2
 t.rast.neighbors --o input=precip_abs1 output=precip_abs2 base=prec_avg \
-    size=5 method=average nprocs=2
+    size=5 method=average nprocs=2 -n
     size=7 method=average nprocs=3
-    size=7 method=max nprocs=3
+    size=7 method=max nprocs=3 -n
     size=7 method=min nprocs=3
-t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove type=strds input=precip_abs1,precip_abs2
+t.remove -rf type=strds input=precip_abs1,precip_abs2
