[GRASS-SVN] r57558 - grass/trunk/lib/python/pygrass/gis
Fri Aug 30 10:14:22 PDT 2013
Author: zarch
Date: 2013-08-30 10:14:21 -0700 (Fri, 30 Aug 2013)
New Revision: 57558
   grass/trunk/lib/python/pygrass/gis/__init__.py
Fix typo when setting GISDBASE
Modified: grass/trunk/lib/python/pygrass/gis/__init__.py
--- grass/trunk/lib/python/pygrass/gis/__init__.py	2013-08-30 13:52:44 UTC (rev 57557)
+++ grass/trunk/lib/python/pygrass/gis/__init__.py	2013-08-30 17:14:21 UTC (rev 57558)
@@ -50,7 +50,6 @@
 def _check(value, path, type):
-    #import pdb; pdb.set_trace()
     if value and CHECK_IS[type](join(path, value)):
         return value
     elif value is '':
@@ -65,7 +64,7 @@
     if location:
         libgis.G_setenv('LOCATION_NAME', location)
     if gisdbase:
-        libgis.G_setenv('GISDBASEE', gisdbase)
+        libgis.G_setenv('GISDBASE', gisdbase)
 def make_mapset(mapset, location=None, gisdbase=None):
