[GRASS-SVN] r57559 - grass/trunk/lib/python/pygrass/modules/grid
svn_grass at osgeo.org
Fri Aug 30 15:18:01 PDT 2013
Author: zarch
Date: 2013-08-30 15:18:01 -0700 (Fri, 30 Aug 2013)
New Revision: 57559
grass/trunk/lib/python/pygrass/modules/grid/grid.py
Small fixes when create a new directory
Modified: grass/trunk/lib/python/pygrass/modules/grid/grid.py
--- grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-08-30 17:14:21 UTC (rev 57558)
+++ grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-08-30 22:18:01 UTC (rev 57559)
@@ -53,8 +53,8 @@
per_new = os.path.join(path, 'PERMANENT')
map_old = mapset.path()
map_new = os.path.join(path, mapset.name)
- if not os.path.isdir(path):
- os.makedirs(path)
+ if not os.path.isdir(per_new):
+ os.makedirs(per_new)
if not os.path.isdir(map_new):
os.mkdir(map_new)
for f in (fi for fi in os.listdir(per_old) if fi.isupper()):
@@ -100,6 +100,7 @@
dst.current()
rupck(input=file_dst, output=rast, overwrite=True)
os.remove(file_dst)
+ return gisrc_src, gisrc_dst
def get_cmd(cmdd):
@@ -201,10 +202,15 @@
self.start_col = start_col
self.out_prefix = out_prefix
self.n_mset = None
+ self.gisrc_src = self.gisrc_dst = None
if move:
self.n_mset = copy_mapset(self.mset, move)
- copy_raster(select(self.module.inputs, 'raster'),
- self.mset, self.n_mset, region=self.region)
+ rasters = select(self.module.inputs, 'raster')
+ self.gisrc_src, self.gisrc_dst = copy_raster(rasters,
+ self.mset,
+ self.n_mset,
+ region=self.region)
self.bboxes = split_region_tiles(region=region,
width=width, height=height,
overlap=overlap)
