[GRASS-SVN] r57572 - grass/branches/releasebranch_6_4/scripts/v.colors
svn_grass at osgeo.org
Sat Aug 31 23:33:55 PDT 2013
Author: hamish
Date: 2013-08-31 23:33:55 -0700 (Sat, 31 Aug 2013)
New Revision: 57572
grass/branches/releasebranch_6_4/scripts/v.colors/v.colors
add v.colors placeholder raster map naming option (#1693, merge r55191 from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/v.colors/v.colors
--- grass/branches/releasebranch_6_4/scripts/v.colors/v.colors 2013-09-01 06:30:53 UTC (rev 57571)
+++ grass/branches/releasebranch_6_4/scripts/v.colors/v.colors 2013-09-01 06:33:55 UTC (rev 57572)
@@ -83,6 +83,15 @@
#% gisprompt: old_file,file,input
#% guisection: Colors
#%End
+#%Option
+#% key: placeholder
+#% type: string
+#% required: no
+#% label: Dummy raster map name containing color rules for use with d.legend
+#% description: Use with the -s flag (using this option implies -s)
+#% gisprompt: new,cell,raster
+#% guisection: Colors
+#%End
#%Flag
#% key: s
#% description: Save placeholder raster map for use with d.legend
@@ -313,16 +322,24 @@
fi
-if [ $GIS_FLAG_S -eq 1 ] ; then
- g.rename rast="tmp_colr_$$","vcolors_$$" --quiet
- g.message "Raster map containing color rules saved to <vcolors_$$>"
+if [ -n "$GIS_OPT_PLACEHOLDER" ] || [ $GIS_FLAG_S -eq 1 ] ; then
+ if [ -n "$GIS_OPT_PLACEHOLDER" ] ; then
+ DUMMY_NAME="$GIS_OPT_PLACEHOLDER"
+ else
+ DUMMY_NAME="vcolors_$$"
+ fi
+ g.rename rast="tmp_colr_$$","$DUMMY_NAME" --quiet
+ g.message "Raster map containing color rules saved to <$DUMMY_NAME>"
# TODO save full v.colors command line history
- r.support map="vcolors_$$" history="" \
+ r.support map="$DUMMY_NAME" history="" \
source1="vector map=$GIS_OPT_MAP" \
source2="column=$GIS_OPT_COLUMN" \
title="Dummy raster to use as thematic vector legend" \
description="generated by v.colors using r.mapcalc"
- r.support map="vcolors_$$" \
+ r.support map="$DUMMY_NAME" \
history="RGB saved into <$GIS_OPT_RGB_COLUMN> using <$GIS_OPT_COLOR$GIS_OPT_RASTER$GIS_OPT_RULES>"
else
g.remove rast="tmp_colr_$$" --quiet
