[GRASS-SVN] r57573 - in grass/branches/releasebranch_6_4/scripts: v.convert.all v.db.addtable v.db.reconnect.all v.db.renamecol v.db.update
svn_grass at osgeo.org
Sat Aug 31 23:46:04 PDT 2013
Author: hamish
Date: 2013-08-31 23:46:04 -0700 (Sat, 31 Aug 2013)
New Revision: 57573
grass/branches/releasebranch_6_4/scripts/v.convert.all/v.convert.all
grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable
grass/branches/releasebranch_6_4/scripts/v.db.reconnect.all/v.db.reconnect.all
grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol
grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update
better handle spaces in GISDBASE (#1683), rm some unused vars (merge r55220,r55194,r55222,r55196,r55203 from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/v.convert.all/v.convert.all
--- grass/branches/releasebranch_6_4/scripts/v.convert.all/v.convert.all 2013-09-01 06:33:55 UTC (rev 57572)
+++ grass/branches/releasebranch_6_4/scripts/v.convert.all/v.convert.all 2013-09-01 06:46:04 UTC (rev 57573)
@@ -34,10 +34,9 @@
fi
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION="$GISDBASE/$LOCATION_NAME/$MAPSET"
+MAPSET=`g.gisenv get=MAPSET`
CONVERTEDMAPS=0
for i in `g.mlist type=oldvect`
do
Modified: grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable
--- grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable 2013-09-01 06:33:55 UTC (rev 57572)
+++ grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable 2013-09-01 06:46:04 UTC (rev 57573)
@@ -52,7 +52,7 @@
if [ -z "$GISBASE" ] ; then
echo "You must be in GRASS GIS to run this program." 1>&2
- exit 1
+ exit 1
fi
# save command line
@@ -79,10 +79,17 @@
export LC_NUMERIC
### setup enviro vars ###
-eval `g.gisenv`
+LOCATION_NAME=`g.gisenv get=LOCATION_NAME`
+GISDBASE=`g.gisenv get=GISDBASE`
+# the following line simply complains if any of these vars are unset.
+# It could be removed, as `` will at least set to "", but is left
+# here for historical-instructive purposes
+: ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
# does map exist in CURRENT mapset?
eval `g.findfile element=vector file="$GIS_OPT_MAP" mapset="$MAPSET"`
MAP_MAPSET=`echo "$GIS_OPT_MAP" | grep '@' | cut -f2 -d'@'`
Modified: grass/branches/releasebranch_6_4/scripts/v.db.reconnect.all/v.db.reconnect.all
--- grass/branches/releasebranch_6_4/scripts/v.db.reconnect.all/v.db.reconnect.all 2013-09-01 06:33:55 UTC (rev 57572)
+++ grass/branches/releasebranch_6_4/scripts/v.db.reconnect.all/v.db.reconnect.all 2013-09-01 06:46:04 UTC (rev 57573)
@@ -47,14 +47,11 @@
exit 1
fi
-eval `g.gisenv`
if [ "$1" != "@ARGS_PARSED@" ] ; then
exec g.parser "$0" "$@"
fi
OLD_DATABASE="$GIS_OPT_OLD_DATABASE"
NEW_DATABASE="$GIS_OPT_NEW_DATABASE"
OLD_SCHEMA="$GIS_OPT_OLD_SCHEMA"
@@ -70,10 +67,13 @@
exit 1
fi
for VECT in `g.list type=vect mapset="$MAPSET" | sed 1,2d | grep -v '^-*$'`
do
- g.message message="Reconnecting vector '${VECT}@${MAPSET}'"
- for LINK in `v.db.connect -g fs="|" map=${VECT}@${MAPSET}` ; do
+ g.message message="Reconnecting vector <$VECT> in mapset <$MAPSET>"
+ for LINK in `v.db.connect -g fs="|" map="$VECT@$MAPSET"` ; do
eval `echo "$LINK" | sed 's$\([^\|]*\)|\([^\|]*\)|\([^\|]*\)|\([^\|]*\)|\([^\|]*\)$LAYER=\1 SCHEMA_TABLE=\2 KEY=\3 DATABASE=\4 DRIVER=\5$'`
SCHEMA=`echo "$SCHEMA_TABLE" | grep '\.' | sed 's/\([^.]*\)\..*/\1/'`
Modified: grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol
--- grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol 2013-09-01 06:33:55 UTC (rev 57572)
+++ grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol 2013-09-01 06:46:04 UTC (rev 57573)
@@ -80,8 +80,8 @@
-eval `g.gisenv`
if [ ! "$file" ] ; then
Modified: grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update
--- grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update 2013-09-01 06:33:55 UTC (rev 57572)
+++ grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update 2013-09-01 06:46:04 UTC (rev 57573)
@@ -77,25 +77,16 @@
fi
-PROG=`basename "$0"`
-#### check if we have awk
-if [ ! -x "`which awk`" ] ; then
- g.message -e "awk required, please install awk or gawk first"
- exit 1
-fi
# setting environment, so that awk works properly in all languages
unset LC_ALL
LC_NUMERIC=C
export LC_NUMERIC
-eval `g.gisenv`
-eval `g.findfile element=vector file=$GIS_OPT_MAP mapset=$MAPSET`
+eval `g.findfile element=vector file="$GIS_OPT_MAP" mapset="$MAPSET"`
g.message -e "Vector map '$GIS_OPT_MAP' not found in current mapset"
exit 1
