[GRASS-SVN] r58373 - in grass/trunk/gui/wxpython: animation gui_core
svn_grass at osgeo.org
Tue Dec 3 07:23:16 PST 2013
Author: annakrat
Date: 2013-12-03 07:23:16 -0800 (Tue, 03 Dec 2013)
New Revision: 58373
grass/trunk/gui/wxpython/animation/dialogs.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/gui_core/simplelmgr.py
wxGUI/animation: fix (workaround) for mysterious gui segfault when modules dialogs were hidden and not destroyed in SimpleLayerManager
Modified: grass/trunk/gui/wxpython/animation/dialogs.py
--- grass/trunk/gui/wxpython/animation/dialogs.py 2013-12-03 15:08:28 UTC (rev 58372)
+++ grass/trunk/gui/wxpython/animation/dialogs.py 2013-12-03 15:23:16 UTC (rev 58373)
@@ -1130,20 +1130,12 @@
def _layerChangeProperties(self, layer):
"""!Opens new module dialog or recycles it."""
- if layer in self._dialogs:
- dlg = self._dialogs[layer]
- if dlg.IsShown():
- dlg.Raise()
- dlg.SetFocus()
- else:
- dlg.Show()
+ if not hasattr(layer, 'maps'):
+ GUI(parent=self, giface=None,
+ modal=self._modal).ParseCommand(cmd=layer.cmd,
+ completed=(self.GetOptData, layer, ''))
else:
- if not hasattr(layer, 'maps'):
- GUI(parent=self, giface=None,
- modal=self._modal).ParseCommand(cmd=layer.cmd,
- completed=(self.GetOptData, layer, ''))
- else:
- self.SetStdsProperties(layer)
+ self.SetStdsProperties(layer)
def Activate3D(self, activate=True):
"""!Activates/deactivates certain tool depending on 2D/3D view."""
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2013-12-03 15:08:28 UTC (rev 58372)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2013-12-03 15:23:16 UTC (rev 58373)
@@ -751,7 +751,7 @@
self.dialogClosing.emit()
if self.get_dcmd and \
self.parent and \
- self.parent.GetName() in ('LayerTree', 'SimpleLayerManager',
+ self.parent.GetName() in ('LayerTree',
'MapWindow'):
# display decorations and
# pressing OK or cancel after setting layer properties
Modified: grass/trunk/gui/wxpython/gui_core/simplelmgr.py
--- grass/trunk/gui/wxpython/gui_core/simplelmgr.py 2013-12-03 15:08:28 UTC (rev 58372)
+++ grass/trunk/gui/wxpython/gui_core/simplelmgr.py 2013-12-03 15:23:16 UTC (rev 58373)
@@ -56,8 +56,6 @@
self._style = lmgrStyle
self._layerList = layerList
self._checkList = wx.CheckListBox(self, style=wx.LB_EXTENDED)
- # dialog windows held separately
- self._dialogs = {}
if not toolbarCls:
toolbarCls = SimpleLmgrToolbar
self._toolbar = toolbarCls(self, lmgrStyle=self._style)
@@ -65,7 +63,9 @@
self._auimgr = wx.aui.AuiManager(self)
self._modal = modal
+ # d.* dialogs are recreated each time, attempt to hide it resulted
+ # in completely mysterious memory corruption and crash when opening
+ # any dialog with stock labels (wx.ID_OK and so on)
# needed in order not to change selection when moving layers
self._blockSelectionChanged = False
@@ -168,8 +168,6 @@
for layer in layers:
self.layerRemoved.emit(index=self._layerList.GetLayerIndex(layer), layer=layer)
self._layerList.RemoveLayer(layer)
- if layer in self._dialogs and self._dialogs[layer]:
- self._dialogs[layer].Destroy()
self._update()
self.anyChange.emit()
event.Skip()
@@ -216,17 +214,9 @@
- if dlg.IsShown():
- dlg.Raise()
- dlg.SetFocus()
- else:
- dlg.Show()
- else:
def OnLayerChangeOpacity(self, event):
"""!Opacity of a layer is changing."""
@@ -280,7 +270,6 @@
"""!Handler for module dialogs."""
if dcmd:
layer.cmd = dcmd
- self._dialogs[layer] = propwin
layer.selected = True
mapName, found = GetLayerNameFromCmd(dcmd)
if found:
@@ -307,7 +296,6 @@
layer = self._layerList.AddNewLayer(name=name, mapType='rast',
active=True,
cmd=cmd, hidden=hidden)
- self._dialogs[layer] = dialog
return layer
def AddRast3d(self, name, cmd, hidden, dialog):
@@ -315,7 +303,6 @@
layer = self._layerList.AddNewLayer(name=name, mapType='rast3d',
active=True,
return layer
def AddVector(self, name, cmd, hidden, dialog):
@@ -323,7 +310,6 @@
layer = self._layerList.AddNewLayer(name=name, mapType='vect',
active=True,
return layer
def GetLayerInfo(self, layer, key):
@@ -338,8 +324,6 @@
def Delete(self, layer):
"""!Just for compatibility, should be removed in the future"""
- if self._dialogs[layer]:
class SimpleLmgrToolbar(BaseToolbar):
