[GRASS-SVN] r58414 - grass/trunk/vector/v.outlier
svn_grass at osgeo.org
Sun Dec 8 13:49:40 PST 2013
Author: mmetz
Date: 2013-12-08 13:49:40 -0800 (Sun, 08 Dec 2013)
New Revision: 58414
grass/trunk/vector/v.outlier/main.c
grass/trunk/vector/v.outlier/outlier.c
grass/trunk/vector/v.outlier/outlier.h
grass/trunk/vector/v.outlier/v.outlier.html
v.outlier: add option to filter out only positive or negative outliers
Modified: grass/trunk/vector/v.outlier/main.c
--- grass/trunk/vector/v.outlier/main.c 2013-12-08 21:25:51 UTC (rev 58413)
+++ grass/trunk/vector/v.outlier/main.c 2013-12-08 21:49:40 UTC (rev 58414)
@@ -42,6 +42,7 @@
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
int last_row, last_column, flag_auxiliar = FALSE;
+ int filter_mode;
int *lineVect;
double *TN, *Q, *parVect; /* Interpolating and least-square vectors */
@@ -50,7 +51,7 @@
/* Structs' declarations */
struct Map_info In, Out, Outlier, Qgis;
struct Option *in_opt, *out_opt, *outlier_opt, *qgis_opt, *stepE_opt,
- *stepN_opt, *lambda_f_opt, *Thres_O_opt;
+ *stepN_opt, *lambda_f_opt, *Thres_O_opt, *filter_opt;
struct Flag *spline_step_flag;
struct GModule *module;
@@ -125,6 +126,14 @@
Thres_O_opt->description = _("Threshold for the outliers");
Thres_O_opt->answer = "50";
+ filter_opt = G_define_option();
+ filter_opt->key = "filter";
+ filter_opt->type = TYPE_STRING;
+ filter_opt->required = NO;
+ filter_opt->description = _("Filtering option");
+ filter_opt->options = "both,positive,negative";
+ filter_opt->answer = "both";
/* Parsing */
G_gisinit(argv[0]);
@@ -142,6 +151,13 @@
lambda = atof(lambda_f_opt->answer);
Thres_Outlier = atof(Thres_O_opt->answer);
+ filter_mode = 0;
+ if (strcmp(filter_opt->answer, "positive") == 0)
+ filter_mode = 1;
+ else if (strcmp(filter_opt->answer, "negative") == 0)
+ filter_mode = -1;
+ P_set_outlier_fn(filter_mode);
/* Checking vector names */
@@ -402,11 +418,13 @@
if (qgis_opt->answer)
P_Outlier(&Out, &Outlier, &Qgis, elaboration_reg,
general_box, overlap_box, obsVect, parVect,
- mean, dims.overlap, lineVect, npoints, driver, table_name);
+ mean, dims.overlap, lineVect, npoints,
+ driver, table_name);
else
P_Outlier(&Out, &Outlier, NULL, elaboration_reg,
G_free_vector(parVect);
Modified: grass/trunk/vector/v.outlier/outlier.c
--- grass/trunk/vector/v.outlier/outlier.c 2013-12-08 21:25:51 UTC (rev 58413)
+++ grass/trunk/vector/v.outlier/outlier.c 2013-12-08 21:49:40 UTC (rev 58414)
@@ -4,6 +4,20 @@
#include <math.h>
#include "outlier.h"
+typedef int (*outlier_fn)(double);
+static outlier_fn is_outlier;
+void P_set_outlier_fn(int filter_mode)
+ if (filter_mode < 0)
+ is_outlier = P_is_outlier_n;
+ else if (filter_mode > 0)
+ is_outlier = P_is_outlier_p;
+ else
+ is_outlier = P_is_outlier;
extern double Thres_Outlier;
void P_Outlier(struct Map_info *Out, struct Map_info *Outlier,
@@ -20,6 +34,7 @@
struct line_pnts *point;
struct line_cats *categories;
point = Vect_new_line_struct();
categories = Vect_new_cats_struct();
@@ -46,7 +61,7 @@
residual = *point->z - interpolation;
- if (FALSE == P_is_outlier(residual)) {
+ if (FALSE == is_outlier(residual)) {
Vect_write_line(Out, GV_POINT, point, categories);
Vect_cat_set(categories, 1, (int)*point->z);
if (Qgis)
@@ -109,7 +124,7 @@
if (Qgis)
@@ -147,7 +162,7 @@
if (Qgis)
@@ -171,7 +186,7 @@
if (Qgis)
@@ -287,6 +302,22 @@
return TRUE;
+int P_is_outlier_p(double pippo)
+ if (pippo < Thres_Outlier)
+ return FALSE;
+ return TRUE;
+int P_is_outlier_n(double pippo)
+ if (pippo > Thres_Outlier)
+ return FALSE;
+ return TRUE;
/*! DEFINITION OF THE SUBZONES
5: inside Overlap region
Modified: grass/trunk/vector/v.outlier/outlier.h
--- grass/trunk/vector/v.outlier/outlier.h 2013-12-08 21:25:51 UTC (rev 58413)
+++ grass/trunk/vector/v.outlier/outlier.h 2013-12-08 21:49:40 UTC (rev 58414)
@@ -15,7 +15,7 @@
struct bound_box, /**/
double **, /**/
double *, /**/
- double, /**/ double, /**/ int *, /**/ int, /**/ dbDriver *, /**/ char *);
+ double, /**/ double, /**/ int *, /**/ int, /**/ dbDriver *, /**/ char *);
int Insert_Outlier(double, /**/ int, /**/ dbDriver *, /**/ char *);
@@ -23,4 +23,7 @@
int Select_Outlier(double *, /**/ int, /**/ dbDriver *, /**/ char *);
+void P_set_outlier_fn(int);
int P_is_outlier(double);
+int P_is_outlier_p(double);
+int P_is_outlier_n(double);
Modified: grass/trunk/vector/v.outlier/v.outlier.html
--- grass/trunk/vector/v.outlier/v.outlier.html 2013-12-08 21:25:51 UTC (rev 58413)
+++ grass/trunk/vector/v.outlier/v.outlier.html 2013-12-08 21:49:40 UTC (rev 58414)
@@ -8,6 +8,15 @@
reckoned from its surroundings by the interpolation, are considered as
an outlier, and hence are removed.
+<p>
+The <em>filter</em> option specifies if all outliers will be removed
+(default), or only positive or only negative outliers. Filtering out
+only positive outliers can be useful to filter out vegetation returns
+(e.g. from forest canopies) from LIDAR point clouds, in order to
+extract Digital Terrain Models. Filtering out only negative outliers
+can be useful to estimate vegetation height.
+<p>
There is a flag to create a vector that can be visualizated by
qgis. That means that topology is build and the z coordinate is
considered as a category.
