[GRASS-SVN] r58415 - in grass/trunk/gui/wxpython: core gui_core
svn_grass at osgeo.org
Sun Dec 8 13:51:51 PST 2013
Author: martinl
Date: 2013-12-08 13:51:51 -0800 (Sun, 08 Dec 2013)
New Revision: 58415
grass/trunk/gui/wxpython/core/gconsole.py
grass/trunk/gui/wxpython/gui_core/forms.py
wxGUI: re-render display when mask set
Modified: grass/trunk/gui/wxpython/core/gconsole.py
--- grass/trunk/gui/wxpython/core/gconsole.py 2013-12-08 21:49:40 UTC (rev 58414)
+++ grass/trunk/gui/wxpython/core/gconsole.py 2013-12-08 21:51:51 UTC (rev 58415)
@@ -345,6 +345,8 @@
# Signal when some map is created or updated by a module.
# attributes: name: map name, ltype: map type,
self.mapCreated = Signal('GConsole.mapCreated')
+ # emitted when map display should be re-render
+ self.updateMap = Signal('GConsole.updateMap')
# emitted when log message should be written
self.writeLog = Signal('GConsole.writeLog')
# emitted when command log message should be written
@@ -663,11 +665,13 @@
# TODO: do it better (?)
name in ('r.colors', 'r3.colors', 'v.colors')) and \
p.get('value', None):
- name = p.get('value')
- if '@' not in name:
- name = name + '@' + grass.gisenv()['MAPSET']
- self.mapCreated.emit(name=name, ltype=prompt)
+ lname = p.get('value')
+ if '@' not in lname:
+ lname += '@' + grass.gisenv()['MAPSET']
+ self.mapCreated.emit(name=lname, ltype=prompt)
+ if name == 'r.mask':
+ self.updateMap.emit()
event.Skip()
def OnProcessPendingOutputWindowEvents(self, event):
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2013-12-08 21:49:40 UTC (rev 58414)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2013-12-08 21:51:51 UTC (rev 58415)
@@ -460,6 +460,7 @@
self._gconsole = self.notebookpanel._gconsole
if self._gconsole:
self._gconsole.mapCreated.connect(self.OnMapCreated)
+ self._gconsole.updateMap.connect(lambda: self._giface.updateMap.emit())
self.goutput = self.notebookpanel.goutput
if self.goutput:
self.goutput.showNotification.connect(lambda message: self.SetStatusText(message))
@@ -795,6 +796,7 @@
wx.Panel.__init__(self, parent, id = id, *args, **kwargs)
# Determine tab layout
sections = []
