[GRASS-SVN] r58434 - in grass/trunk/raster: r.terraflow r.viewshed
Tue Dec 10 08:50:33 PST 2013
Author: wenzeslaus
Date: 2013-12-10 08:50:33 -0800 (Tue, 10 Dec 2013)
New Revision: 58434
   grass/trunk/raster/r.terraflow/direction.cpp
   grass/trunk/raster/r.terraflow/nodata.cpp
   grass/trunk/raster/r.terraflow/nodata.h
   grass/trunk/raster/r.viewshed/rbbst.cpp
   grass/trunk/raster/r.viewshed/rbbst.h
   grass/trunk/raster/r.viewshed/statusstructure.cpp
   grass/trunk/raster/r.viewshed/statusstructure.h
r.terraflow and r.viewshed: using longer names instead of function overloading to fix compilation error with C++11 (reference to is_empty/is_void is ambiguous)
Modified: grass/trunk/raster/r.terraflow/direction.cpp
--- grass/trunk/raster/r.terraflow/direction.cpp	2013-12-10 15:39:03 UTC (rev 58433)
+++ grass/trunk/raster/r.terraflow/direction.cpp	2013-12-10 16:50:33 UTC (rev 58434)
@@ -53,11 +53,11 @@
   if(!is_nodata(elevwin.get())) {
     dir = 0;
-    if (elevwin.get(5) < elevwin.get() && !is_void(elevwin.get(5))) dir |= 1;
-    if (elevwin.get(3) < elevwin.get() && !is_void(elevwin.get(3))) dir |= 16;
+    if (elevwin.get(5) < elevwin.get() && !elevation_type_is_void(elevwin.get(5))) dir |= 1;
+    if (elevwin.get(3) < elevwin.get() && !elevation_type_is_void(elevwin.get(3))) dir |= 16;
     for(int i=0; i<3; i++) {
-      if(elevwin.get(i) < elevwin.get() && !is_void(elevwin.get(i))) dir |= 32<<i;
-      if(elevwin.get(i+6) < elevwin.get() && !is_void(elevwin.get(6+i))) dir |= 8>>i;
+      if(elevwin.get(i) < elevwin.get() && !elevation_type_is_void(elevwin.get(i))) dir |= 32<<i;
+      if(elevwin.get(i+6) < elevwin.get() && !elevation_type_is_void(elevwin.get(6+i))) dir |= 8>>i;
Modified: grass/trunk/raster/r.terraflow/nodata.cpp
--- grass/trunk/raster/r.terraflow/nodata.cpp	2013-12-10 15:39:03 UTC (rev 58433)
+++ grass/trunk/raster/r.terraflow/nodata.cpp	2013-12-10 16:50:33 UTC (rev 58434)
@@ -73,7 +73,7 @@
 int
-is_void(elevation_type el) {
+elevation_type_is_void(elevation_type el) {
   return (el == nodataType::ELEVATION_NODATA);
Modified: grass/trunk/raster/r.terraflow/nodata.h
--- grass/trunk/raster/r.terraflow/nodata.h	2013-12-10 15:39:03 UTC (rev 58433)
+++ grass/trunk/raster/r.terraflow/nodata.h	2013-12-10 16:50:33 UTC (rev 58434)
@@ -37,7 +37,7 @@
 int is_nodata(elevation_type el);
 int is_nodata(int x);
 int is_nodata(float x);
-int is_void(elevation_type el);
+int elevation_type_is_void(elevation_type el);
 class nodataType : public ijBaseType {
Modified: grass/trunk/raster/r.viewshed/rbbst.cpp
--- grass/trunk/raster/r.viewshed/rbbst.cpp	2013-12-10 15:39:03 UTC (rev 58433)
+++ grass/trunk/raster/r.viewshed/rbbst.cpp	2013-12-10 16:50:33 UTC (rev 58434)
@@ -104,7 +104,7 @@
 /*LT: not sure if this is correct */
-int is_empty(RBTree * t)
+int rbtree_is_empty(RBTree * t)
     assert(t);
     return (t->root == NIL);
Modified: grass/trunk/raster/r.viewshed/rbbst.h
--- grass/trunk/raster/r.viewshed/rbbst.h	2013-12-10 15:39:03 UTC (rev 58433)
+++ grass/trunk/raster/r.viewshed/rbbst.h	2013-12-10 16:50:33 UTC (rev 58434)
@@ -96,7 +96,7 @@
 double find_max_gradient_within_key(RBTree * rbt, double key, double angle, double gradient);
-int is_empty(RBTree * t);
+int rbtree_is_empty(RBTree * t);
Modified: grass/trunk/raster/r.viewshed/statusstructure.cpp
--- grass/trunk/raster/r.viewshed/statusstructure.cpp	2013-12-10 15:39:03 UTC (rev 58433)
+++ grass/trunk/raster/r.viewshed/statusstructure.cpp	2013-12-10 16:50:33 UTC (rev 58434)
@@ -292,7 +292,7 @@
     assert(sl);
     /*note: if there is nothing in the status struccture, it means this
        cell is VISIBLE */
-    if (is_empty(sl))
+    if (status_list_is_empty(sl))
 	return SMALLEST_GRADIENT;
     /*it is also possible that the status structure is not empty, but
        there are no events with key < dist ---in this case it returns
@@ -301,9 +301,9 @@
 /*returns true if it is empty */
-int is_empty(StatusList * sl)
+int status_list_is_empty(StatusList * sl)
     assert(sl);
-    return (is_empty(sl->rbt) ||
+    return (rbtree_is_empty(sl->rbt) ||
 	    sl->rbt->root->value.maxGradient == SMALLEST_GRADIENT);
Modified: grass/trunk/raster/r.viewshed/statusstructure.h
--- grass/trunk/raster/r.viewshed/statusstructure.h	2013-12-10 15:39:03 UTC (rev 58433)
+++ grass/trunk/raster/r.viewshed/statusstructure.h	2013-12-10 16:50:33 UTC (rev 58434)
@@ -89,7 +89,7 @@
 void delete_status_structure(StatusList * sl);
 /*returns true is it is empty */
-int is_empty(StatusList * sl);
+int status_list_is_empty(StatusList * sl);
 /*delete the statusNode with the given key */
