[GRASS-SVN] r58435 - in grass/trunk: include include/defs include/vect ps/ps.map
svn_grass at osgeo.org
Tue Dec 10 09:21:20 PST 2013
Author: wenzeslaus
Date: 2013-12-10 09:21:19 -0800 (Tue, 10 Dec 2013)
New Revision: 58435
grass/trunk/include/bitmap.h
grass/trunk/include/defs/dig_atts.h
grass/trunk/include/vect/dig_structs.h
grass/trunk/ps/ps.map/local_proto.h
diglib and ps.map: removing _STDIO_H preprocessor ifndefs and ifdef because they break compilation with clang (LLVM) on Mac OS X Mavericks?\226?\128?\142 where _STDIO_H define is not defined (we suppose to have stdio always so there is no point in checking it and this define is not a part of standard library interface)
Modified: grass/trunk/include/bitmap.h
--- grass/trunk/include/bitmap.h 2013-12-10 16:50:33 UTC (rev 58434)
+++ grass/trunk/include/bitmap.h 2013-12-10 17:21:19 UTC (rev 58435)
@@ -33,9 +33,7 @@
struct BMlink *next;
-#ifndef _STDIO_H
#include <stdio.h>
-#endif
#include <grass/defs/bitmap.h>
Modified: grass/trunk/include/defs/dig_atts.h
--- grass/trunk/include/defs/dig_atts.h 2013-12-10 16:50:33 UTC (rev 58434)
+++ grass/trunk/include/defs/dig_atts.h 2013-12-10 17:21:19 UTC (rev 58435)
@@ -1,6 +1,4 @@
-#ifndef _STDIO_H
#include <stdio.h>
-#endif
#define WRITE_ATT_FORMAT "%c %12.2lf %12.2lf %8d"
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h 2013-12-10 16:50:33 UTC (rev 58434)
+++ grass/trunk/include/vect/dig_structs.h 2013-12-10 17:21:19 UTC (rev 58435)
@@ -13,10 +13,7 @@
#ifndef DIG___STRUCTS___
#define DIG___STRUCTS___
-/* this file depends on <stdio.h> */
-#ifndef _STDIO_H
#include <stdio.h>
-#endif
#include <sys/types.h>
Modified: grass/trunk/ps/ps.map/local_proto.h
--- grass/trunk/ps/ps.map/local_proto.h 2013-12-10 16:50:33 UTC (rev 58434)
+++ grass/trunk/ps/ps.map/local_proto.h 2013-12-10 17:21:19 UTC (rev 58435)
@@ -42,9 +42,8 @@
/* do_labels.c */
int do_labels(int);
-#ifdef _STDIO_H
int do_label(FILE *, int);
-#endif
/* do_masking.c */
int do_masking(void);
@@ -271,9 +270,8 @@
int accept(void);
int reject(void);
-#ifdef _STDIO_H
int print_session(FILE *);
-#endif
/* show_scale.c */
int show_scale(void);
@@ -299,9 +297,8 @@
int eps_bbox(char *, double *, double *, double *, double *);
int eps_trans(double, double, double, double, double, double, double, double,
-#ifdef _STDIO_H
int eps_save(FILE *, char *, char *);
int eps_draw_saved(char *, double, double, double, double);
int eps_draw(FILE *, char *, double, double, double, double);
int pat_save(FILE *, char *, char *);
-#endif
