[GRASS-SVN] r58503 - in grass-addons/grass7/imagery: . i.feo_tio2
Sat Dec 21 11:06:51 PST 2013
Author: ychemin
Date: 2013-12-21 11:06:51 -0800 (Sat, 21 Dec 2013)
New Revision: 58503
Added:
   grass-addons/grass7/imagery/i.feo_tio2/
   grass-addons/grass7/imagery/i.feo_tio2/feo.c
   grass-addons/grass7/imagery/i.feo_tio2/i.feo_tio2.html
   grass-addons/grass7/imagery/i.feo_tio2/main.c
   grass-addons/grass7/imagery/i.feo_tio2/tio2.c
   grass-addons/grass7/imagery/Makefile
Added i.feo_tio2
Modified: grass-addons/grass7/imagery/Makefile
--- grass-addons/grass7/imagery/Makefile	2013-12-21 17:39:44 UTC (rev 58502)
+++ grass-addons/grass7/imagery/Makefile	2013-12-21 19:06:51 UTC (rev 58503)
@@ -9,6 +9,7 @@
 	i.evapo.potrad \
 	i.evapo.senay \
 	i.evapo.zk \
+	i.feo_tio2 \
 	i.gravity \
 	i.histo.match \
 	i.lmf \
Added: grass-addons/grass7/imagery/i.feo_tio2/feo.c
--- grass-addons/grass7/imagery/i.feo_tio2/feo.c	                        (rev 0)
+++ grass-addons/grass7/imagery/i.feo_tio2/feo.c	2013-12-21 19:06:51 UTC (rev 58503)
@@ -0,0 +1,9 @@
+#include<math.h>
+ * Wilcox, B.B., Lucey, P.G., Gillis, J.J., 2005. Mapping iron in the lunar mare: An improved approach. J. Geophys. Res. 110(E11):2156-2202.
+ * with theta = 1.3885 rad, the ‘average slope of the trends in the mare’ from Wilcox et al (2005).
+double feo(double r750, double r950, double theta)
+    return (-137.97 *( r750 * sin(theta) + (r950/r750) * cos(theta) ) + 57.46);
Added: grass-addons/grass7/imagery/i.feo_tio2/i.feo_tio2.html
--- grass-addons/grass7/imagery/i.feo_tio2/i.feo_tio2.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.feo_tio2/i.feo_tio2.html	2013-12-21 19:06:51 UTC (rev 58503)
@@ -0,0 +1,24 @@
+<h2>DESCRIPTION</h2>
+<em>i.feo_tio2</em> calculates the FeO or TiO2 contents.
+wt%TiO2 = 3.708 arctan ((R415/R750)-y0Ti)/(R750-s0Ti) (1)
+wt%FeO = -137.97 ( R750 sin(theta) + (R950/R750) cos(theta) ) + 57.46	(2)
+with theta = 1.3885 rad, the ‘average slope of the trends in the mare’ from Wilcox et al (2005).
+<h2>NOTES</h2>
+Initially created for Clementine data.
+<H2>REFERENCES</H2>
+(1) Lucey, P.G., Blewett, D.T., Jolliff, B.L., 2000. Lunar iron and titanium abundance algorithms based on final processing of Clementine ultraviolet-visible images. J. Geophys. Res. 105(E8): 20297-20305.
+(2) Wilcox, B.B., Lucey, P.G., Gillis, J.J., 2005. Mapping iron in the lunar mare: An improved approach. J. Geophys. Res. 110(E11):2156-2202.
+<h2>AUTHORS</h2>
+Yann Chemin (B.Sc. student), Birkbeck, University of London.
+<p><i>Last changed: $Date: 2013-12-24 22:24:20 +0100 (Tue, 24 Dec 2013) $</i>
Added: grass-addons/grass7/imagery/i.feo_tio2/main.c
--- grass-addons/grass7/imagery/i.feo_tio2/main.c	                        (rev 0)
+++ grass-addons/grass7/imagery/i.feo_tio2/main.c	2013-12-21 19:06:51 UTC (rev 58503)
@@ -0,0 +1,159 @@
+ * MODULE:       i.feo_tio2
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Calculate FeO or TiO2 content
+ *               from various UVVIS bands
+ * COPYRIGHT:    (C) 2014 by the GRASS Development Team
+ *               This program is free software under the GNU Lesser General Public
+ *   	    	 License. Read the file COPYING that comes with GRASS for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+#define MAXFILES 8
+double feo(double r750, double r950, double theta);
+double tio2(double r415, double r750, double y0Ti, double s0Ti);
+int main(int argc, char *argv[])
+    struct Cell_head cellhd;	/*region+header info */
+    int nrows, ncols;
+    int row, col;
+    struct GModule *module;
+    struct Option *in0, *in1, *output, *param0, *param1;
+    struct Flag *flag1, *flag2;
+    struct History history;	/*metadata */
+    struct Colors colors;	/*Color rules */
+    int infd0, infd1, outfd;
+    int i = 0;
+    DCELL *inrast0, *inrast1;
+    DCELL *outrast;
+    CELL val1, val2;
+    /*Default value of theta from Wilcox et al (2005)*/
+    double theta = 1.3885;
+    double param_0, param_1;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("imagery"));
+    G_add_keyword(_("Moon"));
+    G_add_keyword(_("FeO"));
+    G_add_keyword(_("TiO2"));
+    G_add_keyword(_("reflectance"));
+    module->description = _("Computes FeO (default) or TiO2 (-t) from various bands.");
+    /* Define the different options */
+    in0 = G_define_standard_option(G_OPT_R_INPUT);
+    in0->key = "band0";
+    in0->description = _("reflectance band at 750 nm");
+    in1 = G_define_standard_option(G_OPT_R_INPUT);
+    in1->key = "band1";
+    in1->description = _("reflectance band at 950 nm (FeO) or at 415 nm (TiO2)");
+    output = G_define_standard_option(G_OPT_R_OUTPUT);
+    param0 = G_define_option();
+    param0->key = "param0";
+    param0->type = TYPE_DOUBLE;
+    param0->required = NO;
+    param0->description = _("Value of theta (FeO) or y0Ti (TiO2)");
+    param0->guisection = _("Parameters");
+    param1 = G_define_option();
+    param1->key = "param1";
+    param1->type = TYPE_DOUBLE;
+    param1->required = NO;
+    param1->description = _("Value of s0Ti (TiO2)");
+    param1->guisection = _("Parameters");
+    /* Define the different flags */
+    flag1 = G_define_flag();
+    flag1->key = 't';
+    flag1->description = _("TiO2 (refl at 415, refl at 750 & y0Ti, s0Ti)");
+    if (G_parser(argc, argv)) exit(EXIT_FAILURE);
+    if(param0->answer) param_0 = atof(param0->answer);
+    else if (!flag1->answer) param_0 = theta;
+    else G_fatal_error(_("Please define param0 for -t flag"));
+    if(param1->answer) param_1 = atof(param1->answer);
+    else if (flag1->answer) G_fatal_error(_("Please define param1 for -t flag"));
+    /* Allocate input buffer */
+    infd0 = Rast_open_old(in0->answer, "");
+    Rast_get_cellhd(in0->answer, "", &cellhd);
+    inrast0 = Rast_allocate_d_buf();
+    infd1 = Rast_open_old(in1->answer, "");
+    Rast_get_cellhd(in1->answer, "", &cellhd);
+    inrast1 = Rast_allocate_d_buf();
+    /* Allocate output buffer, use input map data_type */
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    outrast = Rast_allocate_buf(DCELL_TYPE);
+    /* Create New raster files */
+    outfd = Rast_open_new(output->answer, 1);
+    /* Process pixels */
+    for (row = 0; row < nrows; row++) {
+	DCELL d0, d1;
+	G_percent(row, nrows, 2);
+        Rast_get_d_row(infd0, inrast0, row);
+        Rast_get_d_row(infd1, inrast1, row);
+	/*process the data */
+	for (col = 0; col < ncols; col++) {
+            d0 = (double)((DCELL *) inrast0)[col];
+            d1 = (double)((DCELL *) inrast1)[col];
+            if (Rast_is_d_null_value(&d0) ||
+                Rast_is_d_null_value(&d1)){
+                Rast_set_d_null_value(&outrast[col], 1);
+            } else {
+                if (flag2->answer){
+                    outrast[col] = tio2(d0, d1, param_0, param_1);
+	        } else {
+                    outrast[col] = feo(d0, d1, param_0);
+	Rast_put_d_row(outfd, outrast);
+    G_free(inrast0);
+    G_free(inrast1);
+    Rast_close(infd0);
+    Rast_close(infd1);
+    G_free(outrast);
+    Rast_close(outfd);
+    /* Color table from 0.0 to 1.0 */
+    Rast_init_colors(&colors);
+    val1 = 0;
+    val2 = 1;
+    Rast_add_c_color_rule(&val1, 0, 0, 0, &val2, 255, 255, 255, &colors);
+    /* Metadata */
+    Rast_short_history(output->answer, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(output->answer, &history);
+    exit(EXIT_SUCCESS);
Added: grass-addons/grass7/imagery/i.feo_tio2/tio2.c
--- grass-addons/grass7/imagery/i.feo_tio2/tio2.c	                        (rev 0)
+++ grass-addons/grass7/imagery/i.feo_tio2/tio2.c	2013-12-21 19:06:51 UTC (rev 58503)
@@ -0,0 +1,9 @@
+#include<math.h>
+ * Lucey, P.G., Blewett, D.T., Jolliff, B.L., 2000. Lunar iron and titanium abundance algorithms based on final processing of Clementine ultraviolet-visible images. J. Geophys. Res. 105(E8): 20297-20305.
+    return (3.708 * atan((r415/r750)-y0Ti)/(r750-s0Ti));
