[GRASS-SVN] r58504 - grass/trunk/raster/r.topmodel
svn_grass at osgeo.org
Sun Dec 22 00:30:08 PST 2013
Author: hcho
Date: 2013-12-22 00:30:08 -0800 (Sun, 22 Dec 2013)
New Revision: 58504
grass/trunk/raster/r.topmodel/file_io.c
grass/trunk/raster/r.topmodel/global.h
grass/trunk/raster/r.topmodel/main.c
grass/trunk/raster/r.topmodel/r.topmodel.html
grass/trunk/raster/r.topmodel/topmodel.c
Added dt, ntimesteps, and nch in output.
Removed the obsflow parameter and let the user evaluate the model performance.
Modified: grass/trunk/raster/r.topmodel/file_io.c
--- grass/trunk/raster/r.topmodel/file_io.c 2013-12-21 19:06:51 UTC (rev 58503)
+++ grass/trunk/raster/r.topmodel/file_io.c 2013-12-22 08:30:08 UTC (rev 58504)
@@ -1,7 +1,6 @@
#include <stdlib.h>
#include <string.h>
#include <time.h>
-#include <grass/gis.h>
#include <grass/raster.h>
#include <grass/glocale.h>
#include "global.h"
@@ -16,8 +15,6 @@
if ((str = (char *)strchr(buffer, '#')))
*str = 0;
- return;
void read_input(void)
@@ -208,29 +205,10 @@
input.ntimesteps = i;
fclose(fp);
- /* Read obsflow file */
- if (file.obsflow) {
- if ((fp = fopen(file.obsflow, "r")) == NULL)
- G_fatal_error(_("Unable to open input file <%s>"), file.obsflow);
- misc.Qobs = (double *)G_malloc(input.ntimesteps * sizeof(double));
- for (i = 0; i < input.ntimesteps && !feof(fp);) {
- get_line(fp, buf);
- if (sscanf(buf, "%lf", &(misc.Qobs[i])) == 1)
- i++;
- input.ntimesteps = (i < input.ntimesteps ? i : input.ntimesteps);
- fclose(fp);
if (!(misc.timestep > 0 && misc.timestep < input.ntimesteps + 1))
misc.timestep = 0;
if (!(misc.topidxclass > 0 && misc.topidxclass < misc.ntopidxclasses + 1))
misc.topidxclass = 0;
- return;
void write_output(void)
@@ -255,113 +233,72 @@
ltime->tm_year, ltime->tm_mon, ltime->tm_mday,
ltime->tm_hour, ltime->tm_min, ltime->tm_sec);
fprintf(fp, "#\n");
- fprintf(fp, "# %-15s Model efficiency\n", "Em:");
- fprintf(fp, "# %-15s Peak observed Q\n"
- "# %77s\n", "Qobs_peak:", "[m^3/timestep]");
- fprintf(fp, "# %-15s Peak time for observed Q\n"
- "# %77s\n", "tobs_peak:", "[timestep]");
- fprintf(fp, "# %-15s Mean observed Q\n"
- "# %77s\n", "Qobs_mean:", "[m^3/timestep]");
- fprintf(fp, "# %-15s Peak simulated Q\n"
- "# %77s\n", "Qt_peak:", "[m^3/timestep]");
- fprintf(fp, "# %-15s Peak time for simulated Q\n"
- "# %77s\n", "tt_peak:", "[timestep]");
- fprintf(fp, "# %-15s Mean simulated Q\n"
- "# %77s\n", "Qt_mean:", "[m^3/timestep]");
- fprintf(fp, "# %-15s Number of time steps\n", "ntimesteps:");
- fprintf(fp, "# %-15s Number of non-NULL cells\n", "ncells:");
- fprintf(fp, "# %-15s Number of topographic index classes\n",
- "ntopidxclasses:");
- fprintf(fp, "# %-15s Number of delay time steps (delay time between "
- "rainfall and\n#\t\t\tflow response)\n", "ndelays:");
- fprintf(fp, "# %-15s Number of reach time steps "
- "(time of concentration)\n", "nreaches:");
- fprintf(fp, "# %-15s Areal average of ln(T0) = ln(Te)\n"
- "# %77s\n", "lnTe:", "[ln(m^2/timestep)]");
- fprintf(fp, "# %-15s Main channel routing velocity\n"
- "# %77s\n", "vch:", "[m/timestep]");
- fprintf(fp, "# %-15s Internal subcatchment routing velocity\n"
- "# %77s\n", "vr:", "[m/timestep]");
- fprintf(fp, "# %-15s Areal average of topographic index\n"
- "# %77s\n", "lambda:", "[ln(m^2)]");
- fprintf(fp, "# %-15s Subsurface flow per unit area at a soil surface\n"
- "# %77s\n", "qss:", "[m/timestep]");
- fprintf(fp, "# %-15s Initial subsurface flow per unit area\n"
- "# %77s\n", "qs0:", "[m/timestep]");
+ fprintf(fp, "# Qt_peak [m^3/timestep]: Total peak flow\n");
+ fprintf(fp, "# tt_peak [timestep]: Peak time for total flow\n");
+ fprintf(fp, "# Qt_mean [m^3/timestep]: Mean total flow\n");
+ fprintf(fp, "# lnTe [ln(m^2/timestep)]: Areal average of ln(T0)\n");
+ fprintf(fp, "# vch [m/timestep]: Main channel routing velocity\n");
+ fprintf(fp, "# vr [m/timestep]: Internal subcatchment routing velocity\n");
+ fprintf(fp, "# lambda [ln(m^2)]: Areal average of topographic index\n");
+ fprintf(fp, "# qss [m/timestep]: Subsurface flow per unit area at a soil surface\n");
+ fprintf(fp, "# qs0 [m/timestep]: Initial subsurface flow per unit area\n");
+ fprintf(fp, "# ncells: Number of non-NULL cells\n");
+ fprintf(fp, "# ntopidxclasses: Number of topographic index classes\n");
+ fprintf(fp, "# dt [h]: Time step\n");
+ fprintf(fp, "# ntimesteps: Number of time steps\n");
+ fprintf(fp, "# nch: Number of routing time steps\n");
+ fprintf(fp, "# nreaches: Number of reach time steps (time of concentration)\n");
+ fprintf(fp, "# ndelays: Delay time steps between rainfall and flow response\n");
fprintf(fp, "#\n");
- fprintf(fp, "# %-15s Routing time step\n"
- "# %77s\n", "tch:", "[timestep]");
- fprintf(fp, "# %-15s Difference in contribution area for each reach "
- "time step\n" "# %77s\n", "Ad:", "[m^2]");
- fprintf(fp, "# %-15s Total flow\n" "# %77s\n", "Qt:", "[m^3/timestep]");
- fprintf(fp, "# %-15s Total flow per unit area\n"
- "# %77s\n", "qt:", "[m/timestep]");
- fprintf(fp, "# %-15s Saturation overland flow per unit area\n"
- "# %77s\n", "qo:", "[m/timestep]");
- fprintf(fp, "# %-15s Subsurface flow per unit area\n"
- "# %77s\n", "qs:", "[m/timestep]");
- fprintf(fp, "# %-15s Vertical flux (or drainage flux)\n"
- "# %77s\n", "qv:", "[m/timestep]");
- fprintf(fp, "# %-15s Mean saturation deficit in the watershed\n"
- "# %77s\n", "S_mean:", "[m]");
+ fprintf(fp, "# tch [timestep]: Routing time\n");
+ fprintf(fp, "# Ad [m^2]: Difference in contribution area for reach time steps\n");
+ fprintf(fp, "# Qt [m^3/timestep]: Total flow\n");
+ fprintf(fp, "# qt [m/timestep]: Total flow per unit area\n");
+ fprintf(fp, "# qo [m/timestep]: Saturation overland flow per unit area\n");
+ fprintf(fp, "# qs [m/timestep]: Subsurface flow per unit area\n");
+ fprintf(fp, "# qv [m/timestep]: Vertical flux (or drainage flux)\n");
+ fprintf(fp, "# S_mean [m]: Mean saturation deficit in the watershed\n");
if (params.infex) {
- fprintf(fp, "# %-15s Infiltration rate\n"
- "# %30s\n", "f:", "[m/timestep]");
- fprintf(fp, "# %-15s Infiltration excess runoff\n"
- "# %77s\n", "fex:", "[m/timestep]");
+ fprintf(fp, "# f [m/timestep]: Infiltration rate\n");
+ fprintf(fp, "# fex [m/timestep]: Infiltration excess runoff\n");
if (misc.timestep || misc.topidxclass) {
fprintf(fp, "#\n");
- fprintf(fp, "# %-15s Root zone storage deficit\n"
- "# %77s\n", "Srz:", "[m]");
- fprintf(fp, "# %-15s Unsaturated (gravity drainage) zone "
- "storage\n" "# %77s\n", "Suz:", "[m]");
- fprintf(fp, "# %-15s Local saturated zone deficit due to "
- "gravity drainage\n" "# %77s\n", "S:", "[m]");
- fprintf(fp, "# %-15s Actual evapotranspiration\n"
- "# %77s\n", "Ea:", "[m/timestep]");
- fprintf(fp, "# %-15s Excess flow from a fully saturated "
- "area per unit area\n" "# %77s\n", "ex:", "[m/timestep]");
+ fprintf(fp, "# Srz [m]: Root zone storage deficit\n");
+ fprintf(fp, "# Suz [m]: Unsaturated (gravity drainage) zone storage\n");
+ fprintf(fp, "# S [m]: Local saturated zone deficit due to gravity drainage\n");
+ fprintf(fp, "# Ea [m/timestep]: Actual evapotranspiration\n");
+ fprintf(fp, "# ex [m/timestep]: Excess flow from a fully saturated area per unit area\n");
fprintf(fp, "\n");
- fprintf(fp, "%-16s ", "Em:");
- if (!Rast_is_d_null_value(&misc.Em))
- fprintf(fp, "%10.5lf\n", misc.Em);
- else
- fprintf(fp, "Not resolved due to constant observed Q\n");
- fprintf(fp, "%-16s %10.3le\n", "Qobs_peak:", misc.Qobs_peak);
- fprintf(fp, "%-16s %10d\n", "tobs_peak:", misc.tobs_peak);
- fprintf(fp, "%-16s %10.3le\n", "Qobs_mean:", misc.Qobs_mean);
- fprintf(fp, "%-16s %10.3le\n", "Qt_peak:", misc.Qt_peak);
- fprintf(fp, "%-16s %10d\n", "tt_peak:", misc.tt_peak);
- fprintf(fp, "%-16s %10.3le\n", "Qt_mean:", misc.Qt_mean);
- fprintf(fp, "%-16s %10d\n", "ntimesteps:", input.ntimesteps);
- fprintf(fp, "%-16s %10d\n", "ncells:", misc.ncells);
- fprintf(fp, "%-16s %10d\n", "ntopidxclasses:", misc.ntopidxclasses);
- fprintf(fp, "%-16s %10d\n", "ndelays:", misc.ndelays);
- fprintf(fp, "%-16s %10d\n", "nreaches:", misc.nreaches);
- fprintf(fp, "%-16s %10.3le\n", "lnTe:", misc.lnTe);
- fprintf(fp, "%-16s %10.3le\n", "vch:", misc.vch);
- fprintf(fp, "%-16s %10.3le\n", "vr:", misc.vr);
- fprintf(fp, "%-16s %10.3le\n", "lambda:", misc.lambda);
- fprintf(fp, "%-16s %10.3le\n", "qss:", misc.qss);
- fprintf(fp, "%-16s %10.3le\n", "qs0:", misc.qs0);
+ fprintf(fp, "Qt_peak: %10.3e\n", misc.Qt_peak);
+ fprintf(fp, "tt_peak: %10d\n", misc.tt_peak);
+ fprintf(fp, "Qt_mean: %10.3e\n", misc.Qt_mean);
+ fprintf(fp, "lnTe: %10.3e\n", misc.lnTe);
+ fprintf(fp, "vch: %10.3e\n", misc.vch);
+ fprintf(fp, "vr: %10.3e\n", misc.vr);
+ fprintf(fp, "lambda: %10.3e\n", misc.lambda);
+ fprintf(fp, "qss: %10.3e\n", misc.qss);
+ fprintf(fp, "qs0: %10.3e\n", misc.qs0);
+ fprintf(fp, "ncells: %10d\n", misc.ncells);
+ fprintf(fp, "ntopidxclasses: %10d\n", misc.ntopidxclasses);
+ fprintf(fp, "dt: %10.3e\n", input.dt);
+ fprintf(fp, "ntimesteps: %10d\n", input.ntimesteps);
+ fprintf(fp, "nch: %10d\n", params.nch);
+ fprintf(fp, "nreaches: %10d\n", misc.nreaches);
+ fprintf(fp, "ndelays: %10d\n", misc.ndelays);
fprintf(fp, "\n");
fprintf(fp, "%10s\n", "tch");
for (i = 0; i < params.nch; i++)
- fprintf(fp, "%10.3le\n", misc.tch[i]);
+ fprintf(fp, "%10.3e\n", misc.tch[i]);
fprintf(fp, "\n");
fprintf(fp, "%10s\n", "Ad");
for (i = 0; i < misc.nreaches; i++)
- fprintf(fp, "%10.3le\n", misc.Ad[i]);
+ fprintf(fp, "%10.3e\n", misc.Ad[i]);
fprintf(fp, "\n");
st = et = si = ei = 0;
@@ -385,20 +322,20 @@
- fprintf(fp, "%10s %10s %10s %10s %10s %10s %10s", "timestep", "Qt",
- "qt", "qo", "qs", "qv", "S_mean");
+ fprintf(fp, "%10s %10s %10s %10s %10s %10s %10s",
+ "timestep", "Qt", "qt", "qo", "qs", "qv", "S_mean");
if (params.infex)
fprintf(fp, " %10s %10s", "f", "fex");
fprintf(fp, "\n");
for (i = 0; i < input.ntimesteps; i++) {
- fprintf(fp, "%10d %10.3le %10.3le %10.3le %10.3le %10.3le "
- "%10.3le", i + 1, misc.Qt[i],
+ fprintf(fp, "%10d %10.3e %10.3e %10.3e %10.3e %10.3e %10.3e",
+ i + 1, misc.Qt[i],
misc.qt[i][misc.ntopidxclasses],
misc.qo[i][misc.ntopidxclasses], misc.qs[i],
misc.qv[i][misc.ntopidxclasses], misc.S_mean[i]);
if (params.infex)
- fprintf(fp, " %10.3le %10.3le", misc.f[i], misc.fex[i]);
+ fprintf(fp, " %10.3e %10.3e", misc.f[i], misc.fex[i]);
fprintf(fp, "\n");
@@ -432,9 +369,9 @@
fprintf(fp, "%10d ", i + 1);
- fprintf(fp, "%10.3le %10.3le %10.3le "
- "%10.3le %10.3le %10.3le "
- "%10.3le %10.3le %10.3le\n",
+ fprintf(fp, "%10.3e %10.3e %10.3e "
+ "%10.3e %10.3e %10.3e "
+ "%10.3e %10.3e %10.3e\n",
misc.qt[i][j], misc.qo[i][j],
misc.qs[i], misc.qv[i][j],
misc.Srz[i][j], misc.Suz[i][j],
@@ -443,6 +380,4 @@
fclose(fp);
- return;
Modified: grass/trunk/raster/r.topmodel/global.h
--- grass/trunk/raster/r.topmodel/global.h 2013-12-21 19:06:51 UTC (rev 58503)
+++ grass/trunk/raster/r.topmodel/global.h 2013-12-22 08:30:08 UTC (rev 58504)
@@ -80,7 +80,6 @@
char *topidxstats;
char *input;
char *output;
- char *obsflow;
/* Miscellaneous TOPMODEL variables */
@@ -90,8 +89,6 @@
int ncells;
/* Number of topographic index classes */
int ntopidxclasses;
- /* Model efficiency */
- double Em;
int ndelays;
int nreaches;
double lnTe;
@@ -100,9 +97,7 @@
double lambda;
double qss;
double qs0;
- double Qobs_peak;
double Qt_peak;
- double Qobs_mean;
double Qt_mean;
int tobs_peak;
int tt_peak;
@@ -111,7 +106,6 @@
/* misc.nreach's */
double *Ad;
/* input.ntimestep's */
- double *Qobs;
double *Qt;
double *qs; /* spatially constant? */
double *S_mean;
Modified: grass/trunk/raster/r.topmodel/main.c
--- grass/trunk/raster/r.topmodel/main.c 2013-12-21 19:06:51 UTC (rev 58503)
+++ grass/trunk/raster/r.topmodel/main.c 2013-12-22 08:30:08 UTC (rev 58504)
@@ -30,7 +30,6 @@
struct Option *topidxstats;
struct Option *input;
struct Option *output;
- struct Option *obsflow;
struct Option *timestep;
struct Option *topidxclass;
struct Option *topidx;
@@ -68,11 +67,6 @@
params.output = G_define_standard_option(G_OPT_F_OUTPUT);
params.output->description = _("Name for output file");
- params.obsflow = G_define_standard_option(G_OPT_F_INPUT);
- params.obsflow->key = "obsflow";
- params.obsflow->description = _("Name of observed flow file");
- params.obsflow->required = NO;
params.timestep = G_define_option();
params.timestep->key = "timestep";
params.timestep->label = _("Time step");
@@ -130,7 +124,6 @@
file.topidxstats = params.topidxstats->answer;
file.input = params.input->answer;
file.output = params.output->answer;
- file.obsflow = params.obsflow->answer;
if (!params.timestep->answer)
params.timestep->answer = "0";
Modified: grass/trunk/raster/r.topmodel/r.topmodel.html
--- grass/trunk/raster/r.topmodel/r.topmodel.html 2013-12-21 19:06:51 UTC (rev 58503)
+++ grass/trunk/raster/r.topmodel/r.topmodel.html 2013-12-22 08:30:08 UTC (rev 58504)
@@ -101,22 +101,6 @@
</pre></div>
</dd>
-<dt><b>obsflow</b></dt>
-<dd>
-Compare simulated flows with observed flows and calculate the model
-efficiency. This file contains observed flow data and the number of records
-should match the number of time steps (ntimesteps in the input file).
-<div class="code"><pre>
-# Qobs [m^3/dt]: Observed flow per time step
-2568918.24
-1668573.562
-1039800.24
-</pre></div>
-</dd>
<dt><b>timestep</b></dt>
<dd>
If a time step is specified, output will be generated for the specific time
Modified: grass/trunk/raster/r.topmodel/topmodel.c
--- grass/trunk/raster/r.topmodel/topmodel.c 2013-12-21 19:06:51 UTC (rev 58503)
+++ grass/trunk/raster/r.topmodel/topmodel.c 2013-12-22 08:30:08 UTC (rev 58504)
@@ -1,5 +1,4 @@
#include <math.h>
#include <grass/spawn.h>
#include "global.h"
@@ -24,16 +23,14 @@
double calculate_lambda(void)
int i;
- double retval;
+ double lambda;
- retval = 0.0;
+ lambda = 0.0;
for (i = 1; i < misc.ntopidxclasses; i++)
- retval += topidxstats.Aatb_r[i] *
+ lambda += topidxstats.Aatb_r[i] *
(topidxstats.atb[i] + topidxstats.atb[i - 1]) / 2.0;
- return retval;
+ return lambda;
void initialize(void)
@@ -41,7 +38,6 @@
int i, j, t;
double A1, A2;
misc.lambda = calculate_lambda();
misc.lnTe = params.lnTe + log(input.dt);
misc.vch = params.vch * input.dt;
@@ -117,9 +113,6 @@
A1 += misc.Ad[i];
misc.Qt[misc.ndelays + i] = misc.qs0 * (params.A - A1);
- return;
void calculate_flows(void)
@@ -129,7 +122,6 @@
double R;
double qo, qv;
misc.S = (double **)G_malloc(input.ntimesteps * sizeof(double *));
misc.Ea = (double **)G_malloc(input.ntimesteps * sizeof(double *));
misc.ex = (double **)G_malloc(input.ntimesteps * sizeof(double *));
@@ -261,45 +253,6 @@
- return;
-/* Objective function for hydrograph suggested by Servet and Dezetter(1991) */
-double calculate_efficiency(void)
- int i;
- double Em, numerator, denominator;
- misc.Qobs_mean = 0.0;
- numerator = 0.0;
- for (i = 0; i < input.ntimesteps; i++) {
- misc.Qobs_mean += misc.Qobs[i];
- numerator += pow(misc.Qobs[i] - misc.Qt[i], 2.0);
- misc.Qobs_mean /= input.ntimesteps;
- denominator = 0.0;
- denominator += pow(misc.Qobs[i] - misc.Qobs_mean, 2.0);
- if (denominator == 0.0) {
- G_warning("Em can not be resolved due to constant observed Q");
- Rast_set_d_null_value(&Em, 1);
- else {
- Em = 1.0 - numerator / denominator;
- return Em;
-void calculate_others(void)
- int i;
misc.Qt_mean = 0.0;
misc.Qt_mean += misc.Qt[i];
@@ -309,25 +262,10 @@
misc.Qt_mean /= input.ntimesteps;
- misc.Em = calculate_efficiency();
- if (!i || misc.Qobs_peak < misc.Qobs[i]) {
- misc.Qobs_peak = misc.Qobs[i];
- misc.tobs_peak = i + 1;
- return;
void run_topmodel(void)
initialize();
calculate_flows();
- calculate_others();
- return;
