[GRASS-SVN] r58541 - grass/trunk/gui/wxpython/gmodeler
svn_grass at osgeo.org
Sat Dec 28 07:16:23 PST 2013
Author: martinl
Date: 2013-12-28 07:16:23 -0800 (Sat, 28 Dec 2013)
New Revision: 58541
grass/trunk/gui/wxpython/gmodeler/dialogs.py
grass/trunk/gui/wxpython/gmodeler/frame.py
grass/trunk/gui/wxpython/gmodeler/model.py
wxGUI/modeler: fix loop item definition
fix condition objects
Modified: grass/trunk/gui/wxpython/gmodeler/dialogs.py
--- grass/trunk/gui/wxpython/gmodeler/dialogs.py 2013-12-28 13:04:03 UTC (rev 58540)
+++ grass/trunk/gui/wxpython/gmodeler/dialogs.py 2013-12-28 15:16:23 UTC (rev 58541)
@@ -534,10 +534,9 @@
self.listBoxElse = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
label=" %s " % _("List of items in 'else' block"))
self.itemListElse = ItemCheckListCtrl(parent = self.panel,
- window = self,
- columns = [_("Name"),
+ columns = [_("Label"),
_("Command")],
- shape = shape)
+ shape = shape, frame = parent)
self.itemListElse.SetName('ElseBlockList')
self.itemListElse.Populate(self.parent.GetModel().GetItems())
@@ -787,6 +786,8 @@
self.disablePopup = disablePopup
ModelListCtrl.__init__(self, parent, columns, frame, **kwargs)
+ self.itemIdMap = list()
self.SetColumnWidth(1, 100)
self.SetColumnWidth(2, 65)
@@ -801,16 +802,17 @@
def Populate(self, data):
"""!Populate the list"""
self.itemDataMap = dict()
if self.shape:
+ items = self.frame.GetModel().GetItems(objType=ModelAction)
if isinstance(self.shape, ModelCondition):
- if self.GetText() == 'ElseBlockList':
- shapeItems = map(lambda x: x.GetId(), self.shape.GetItems()['else'])
+ if self.GetLabel() == 'ElseBlockList':
+ shapeItems = map(lambda x: x.GetId(), self.shape.GetItems(items)['else'])
else:
- shapeItems = map(lambda x: x.GetId(), self.shape.GetItems()['if'])
+ shapeItems = map(lambda x: x.GetId(), self.shape.GetItems(items)['if'])
else:
- self.shape.GetItems(self.frame.GetModel().GetItems(objType=ModelAction)))
+ shapeItems = map(lambda x: x.GetId(), self.shape.GetItems(items))
else:
shapeItems = list()
@@ -822,6 +824,8 @@
action == self.shape:
continue
+ self.itemIdMap.append(action.GetId())
if len(self.columns) == 2:
self.itemDataMap[i] = [action.GetLabel(),
action.GetLog()]
@@ -993,12 +997,13 @@
"""!Get list of selected actions"""
ids = { 'checked' : list(),
'unchecked' : list() }
# action ids start at 1
for i in range(self.GetItemCount()):
if self.IsChecked(i):
- ids['checked'].append(i+1)
+ ids['checked'].append(self.itemIdMap[i])
else:
- ids['unchecked'].append(i+1)
+ ids['unchecked'].append(self.itemIdMap[i])
return ids
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py 2013-12-28 13:04:03 UTC (rev 58540)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py 2013-12-28 15:16:23 UTC (rev 58541)
@@ -959,11 +959,12 @@
def DefineCondition(self, condition):
"""!Define if-else statement with given list of items"""
- parent = condition
- items = condition.GetItems()
+ items = condition.GetItems(self.model.GetItems(objType=ModelAction))
if not items['if'] and not items['else']:
return
+ parent = condition
# remove defined relations first
for rel in condition.GetRelations():
self.canvas.GetDiagram().RemoveShape(rel)
@@ -1136,11 +1137,12 @@
alist = list()
for aId in ids['unchecked']:
action = model.GetItem(aId, objType=ModelAction)
- action.UnSetBlock(shape)
+ if action:
+ action.UnSetBlock(shape)
for aId in ids['checked']:
- action.SetBlock(shape)
if action:
+ action.SetBlock(shape)
alist.append(aId)
shape.SetItems(alist)
self.frame.DefineLoop(shape)
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2013-12-28 13:04:03 UTC (rev 58540)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2013-12-28 15:16:23 UTC (rev 58541)
@@ -1407,17 +1407,7 @@
"""!Abstract class for loops and conditions"""
ModelObject.__init__(self, id, label)
self.parent = parent
- self.itemIds = list() # unordered
- def GetItems(self, items):
- """!Get sorted items by id"""
- result = list()
- for item in items:
- if item.GetId() in self.itemIds:
- result.append(item)
- return result
def SetId(self, id):
"""!Set loop id"""
self.id = id
@@ -1447,7 +1437,8 @@
def __init__(self, parent, x, y, id=-1, idx=-1, width = None, height = None, label = '', items = []):
"""!Defines a loop"""
ModelItem.__init__(self, parent, x, y, id, width, height, label, items)
+ self.itemIds = list() # unordered
if not width:
width = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'width'))
if not height:
@@ -1488,7 +1479,16 @@
def Update(self):
self._setBrush()
+ def GetItems(self, items):
+ """!Get sorted items by id"""
+ result = list()
+ for item in items:
+ if item.GetId() in self.itemIds:
+ result.append(item)
+ return result
def SetItems(self, items):
"""!Set items (id)"""
self.itemIds = items
@@ -1500,10 +1500,11 @@
ogl.RectangleShape.OnDraw(self, dc)
class ModelCondition(ModelItem, ogl.PolygonShape):
- def __init__(self, parent, x, y, id = -1, width = None, height = None, text = '',
+ def __init__(self, parent, x, y, id = -1, width = None, height = None, label = '',
items = { 'if' : [], 'else' : [] }):
"""!Defines a if-else condition"""
- ModelItem.__init__(self, parent, x, y, id, width, height, text, items)
+ ModelItem.__init__(self, parent, x, y, id, width, height, label, items)
+ self.itemIds = {'if' : [], 'else': []}
if not width:
self.width = UserSettings.Get(group='modeler', key='if-else', subkey=('size', 'width'))
@@ -1527,8 +1528,8 @@
self.SetX(x)
self.SetY(y)
self.SetPen(wx.BLACK_PEN)
- if text:
- self.AddText('(' + str(self.id) + ') ' + text)
+ if label:
+ self.AddText('(' + str(self.id) + ') ' + label)
else:
self.AddText('(' + str(self.id) + ')')
@@ -1544,6 +1545,17 @@
"""!Get object height"""
return self.height
+ result = {'if' : [], 'else': []}
+ if item.GetId() in self.itemIds['if']:
+ result['if'].append(item)
+ elif item.GetId() in self.itemIds['else']:
+ result['else'].append(item)
+ return result
def SetItems(self, items, branch = 'if'):
"""!Set items (id)
@@ -1551,7 +1563,7 @@
@param branch 'if' / 'else'
if branch in ['if', 'else']:
- self.items[branch] = items
+ self.itemIds[branch] = items
class ProcessModelFile:
"""!Process GRASS model file (gxm)"""
