[GRASS-SVN] r58542 - grass-addons/grass7/raster/r.sun.hourly
svn_grass at osgeo.org
Sat Dec 28 08:33:58 PST 2013
Author: annakrat
Date: 2013-12-28 08:33:57 -0800 (Sat, 28 Dec 2013)
New Revision: 58542
grass-addons/grass7/raster/r.sun.hourly/r.sun.hourly.html
grass-addons/grass7/raster/r.sun.hourly/r.sun.hourly.py
r.sun.hourly: new flag b for binary output
Modified: grass-addons/grass7/raster/r.sun.hourly/r.sun.hourly.html
--- grass-addons/grass7/raster/r.sun.hourly/r.sun.hourly.html 2013-12-28 15:16:23 UTC (rev 58541)
+++ grass-addons/grass7/raster/r.sun.hourly/r.sun.hourly.html 2013-12-28 16:33:57 UTC (rev 58542)
@@ -5,15 +5,20 @@
(instant mode, see r.sun <a href="r.sun.html">manual page</a>).
<h3>Output parameters explanation</h3>
-Output is one or more series of raster maps.
-Series of maps are (if flag <i>t</i> is checked) registered
+<p>
+Output is one or more series of irradiance raster maps.
+If flag <b>b</b> is checked the output is a series of binary maps.
+Using this flag in combination with <n>beam_rad_basename</b>
+is a convenient way to determine if there is direct sunlight or not at a certain place and time.
+</p>
+<p>
+Series of maps are (if flag <b>t</b> is checked) registered
to space time raster dataset with absolute time and point time (not interval time).
-Option <i>year</i> has to be specified so that the raster maps can be registered
+Option <b>year</b> has to be specified so that the raster maps can be registered
to space time dataset or assigned a timestamp. The reason is that it is not possible
to assign time without date.
For GRASS 6, only timestamp is assigned.
+</p>
<h2>EXAMPLE</h2>
@@ -26,6 +31,9 @@
t.rast.list beam
</pre></div>
+<h2>NOTE</h2>
+Beam irradiance binary raster maps can be displayed as semitransparent over other map layers
+or module <a href="r.null.html"><em>r.null</em></a> can be used to set one of the values (either shade or sunlight) as NULL.
<h2>SEE ALSO</h2>
Modified: grass-addons/grass7/raster/r.sun.hourly/r.sun.hourly.py
--- grass-addons/grass7/raster/r.sun.hourly/r.sun.hourly.py 2013-12-28 15:16:23 UTC (rev 58541)
+++ grass-addons/grass7/raster/r.sun.hourly/r.sun.hourly.py 2013-12-28 16:33:57 UTC (rev 58542)
@@ -125,6 +125,10 @@
#% label: Register created series of output maps into temporal dataset
#%end
#%flag
+#% key: b
+#% description: Create binary rasters instead of irradiation rasters
+#%end
+#%flag
#% key: overwrite
#% description: Allow output files to overwrite existing files
#%end
@@ -162,7 +166,7 @@
# add latitude map
def run_r_sun(elevation, aspect, slope, day, time, beam_rad, diff_rad,
- refl_rad, glob_rad, incidout, suffix):
+ refl_rad, glob_rad, incidout, suffix, binary, binaryTmpName):
params = {}
if beam_rad:
params.update({'beam_rad': beam_rad + suffix})
@@ -187,14 +191,27 @@
day=day, time=time,
overwrite=core.overwrite(), quiet=True,
**params)
+ if binary:
+ for output in (beam_rad, diff_rad, refl_rad, glob_rad):
+ if not output:
+ continue
+ exp='{out} = if({inp} > 0, 1, 0)'.format(out=output + suffix + binaryTmpName,
+ inp=output + suffix)
+ grass.mapcalc(exp=exp, overwrite=core.overwrite())
+ grass.run_command('g.rename', rast=[output + suffix + binaryTmpName,
+ output + suffix],
+ overwrite=True)
-def set_color_table(rasters):
+def set_color_table(rasters, binary=False):
+ table = 'gyr'
+ if binary:
+ table='grey'
if is_grass_7():
- grass.run_command('r.colors', map=rasters, col='gyr', quiet=True)
+ grass.run_command('r.colors', map=rasters, col=table, quiet=True)
else:
for rast in rasters:
- grass.run_command('r.colors', map=rast, col='gyr', quiet=True)
+ grass.run_command('r.colors', map=rast, col=table, quiet=True)
def set_time_stamp(raster, time):
@@ -205,13 +222,23 @@
return '%05.2f' % time
-def check_time_map_names(basename, mapset, start_time, end_time, time_step):
+def check_time_map_names(basename, mapset, start_time, end_time, time_step,
+ binary, binaryTmpName):
if not basename:
return
for time in frange(start_time, end_time, time_step):
- map_ = '%s%s%s' % (basename, '_', format_time(time))
- if grass.find_file(map_, element='cell', mapset=mapset)['file']:
- grass.fatal(_("Raster map <%s> already exists. Change the base name or allow overwrite.") % map_)
+ maps = []
+ maps.append('{name}{delim}{time}'.format(name=basename,
+ delim='_',
+ time=format_time(time)))
+ if binary:
+ maps.append('{name}{delim}{time}{binary}'.format(name=basename,
+ delim='_',
+ time=format_time(time),
+ binary=binaryTmpName))
+ for map_ in maps:
+ if grass.find_file(map_, element='cell', mapset=mapset)['file']:
+ grass.fatal(_("Raster map <%s> already exists. Change the base name or allow overwrite.") % map_)
def frange(x, y, step):
@@ -255,6 +282,8 @@
nprocs = int(options['nprocs'])
day = int(options['day'])
temporal = flags['t']
+ binary = flags['b']
+ binaryTmpName = 'binary'
year = int(options['year'])
if not is_grass_7() and temporal:
@@ -269,13 +298,13 @@
# here we check all the days
if not grass.overwrite():
check_time_map_names(beam_rad_basename, grass.gisenv()['MAPSET'],
- start_time, end_time, time_step)
+ start_time, end_time, time_step, binary, binaryTmpName)
check_time_map_names(diff_rad_basename, grass.gisenv()['MAPSET'],
check_time_map_names(refl_rad_basename, grass.gisenv()['MAPSET'],
check_time_map_names(glob_rad_basename, grass.gisenv()['MAPSET'],
# check for slope/aspect
if not aspect_input or not slope_input:
@@ -315,7 +344,8 @@
refl_rad_basename,
glob_rad_basename,
incidout_basename,
- suffix)))
+ suffix,
+ binary, binaryTmpName)))
proc_list[proc_count].start()
proc_count += 1
@@ -401,16 +431,16 @@
if beam_rad_basename:
maps = [beam_rad_basename + suf for suf in suffixes_all]
- set_color_table(maps)
+ set_color_table(maps, binary)
if diff_rad_basename:
maps = [diff_rad_basename + suf for suf in suffixes_all]
if refl_rad_basename:
maps = [refl_rad_basename + suf for suf in suffixes_all]
if glob_rad_basename:
maps = [glob_rad_basename + suf for suf in suffixes_all]
if incidout_basename:
maps = [incidout_basename + suf for suf in suffixes_all]
